FHEM => Anfängerfragen => Thema gestartet von: bullydog1984de am 19 Februar 2013, 19:40:15
Titel: Fehlermeldung im Logfile
Beitrag von: bullydog1984de am 19 Februar 2013, 19:40:15
ich hab seit einem der letzten Updates folgende Fehlermeldung im Logfile:
Zitat2013.02.19 19:21:56 2: CUL_0: unknown message ? (? (? (? (? (? ( F i AT010200A6F10E is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:21:56 2: CUL_0: unknown message ? (? (? (? (? (? ( F i A GT01020069B60E is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:22:37 2: CUL_0: unknown message ? (? (? (? (? (? ( C F iT252B00A6540D is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:22:38 2: CUL_0: unknown message ? (? (? (? (? (? ( T252B0069B60D is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:22:43 2: CUL_0: unknown message ? (? (? (? (? (? (A G M RT495E00A6320A is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:22:43 2: CUL_0: unknown message ? (? (? (? (? (? (T495E0069360B is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:23:52 2: CUL_0: unknown message ? (? (? (? (? (? ( G M RT010200A6F10E is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:23:52 2: CUL_0: unknown message ? (? (? (? (? (? ( F i AtA00695B4B80E is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:23:53 2: CUL_0: unknown message ? (? (? (? (? (? ( F i AT01020069B60E is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:24:34 2: CUL_0: unknown message ? (? (? (? (? (? ( F i AT252B00A6540D is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:24:34 2: CUL_0: unknown message ? (? (? (? (? (? ( F i A GT252B0069B60E is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:24:39 2: CUL_0: unknown message ? (? (? (? (? (? ( C F T495E00A6320B is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:24:40 2: CUL_0: unknown message ? (? (? (? (? (? (F i A G M R T495E0069360B is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:25:48 2: CUL_0: unknown message ? (? (? (? (? (? (of BT010200A6F10E is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:25:48 2: CUL_0: unknown message ? (? (? (? (? (? ( i tAA9678876A0E is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:25:49 2: CUL_0: unknown message ? (? (? (? (? (? (i A GT01020069B60D is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:26:30 2: CUL_0: unknown message ? (? (? (? (? (? (F i A T252B00A6540D is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:26:31 2: CUL_0: unknown message ? (? (? (? (? (? (?T252B0069B60E is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:26:37 2: CUL_0: unknown message ? (? (? (? (? (? (A G M RT495E00A6320B is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:26:38 2: CUL_0: unknown message ? (? (? (? (? (? (C F iT495E0069360B is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:27:44 2: CUL_0: unknown message ? (? (? (? (? (? (F i A T010200A6F10F is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:27:44 2: CUL_0: unknown message ? (? (? (? (? (? ( F i A G M R T T01020069B60F is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:28:27 2: CUL_0: unknown message ? (? (? (? (? (? (ne T252B00A6540E is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:28:27 2: CUL_0: unknown message ? (? (? (? (? (? (i A G M T252B0069B60F is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:28:35 2: CUL_0: unknown message ? (? (? (? (? (? ( C F T495E00A6320C is unknown) Use one of B C F i A G M R T V W X e f m l t u x
2013.02.19 19:28:36 2: CUL_0: unknown message ? (? (? (? (? (? (F i A G M R T VT495E0069360C is unknown) Use one of B C F i A G M R T V W X e f m l t u x
Zusätzlich wird die aktuelle Temperatur meiner FHT ger#te nicht mehr mitgelesen!!
Zitat2013-02-19_19:34:16 sz_Heizung actuator: 33%
2013-02-19_19:34:17 sz_Heizung actuator: unknown_69: 71%
2013-02-19_19:36:12 sz_Heizung actuator: 33%
2013-02-19_19:36:14 sz_Heizung actuator: unknown_69: 71%
Nach einem shutdown restart funktioniert erstmal alles wieder.
Würde mich freuen wenn mir jemand helfen kann.
Bullydog1984de
Titel: Aw: Fehlermeldung im Logfile
Beitrag von: bullydog1984de am 19 Februar 2013, 20:11:59
ok habe die obrige Fehlermeldung mit einem updat force wegbekommen. Die Temp. der FHT´s wird jedoch immer noch nicht aufgenommen
