CHN 00241BE989xxxx:0 HmIP-MOD-HO 00241BE989xxxx:0
DPT {b} HmIP-RF.00241BE989xxxx:0.CONFIG_PENDING = false [RE]
DPT {b} HmIP-RF.00241BE989xxxx:0.DUTY_CYCLE = false [RE]
DPT {b} HmIP-RF.00241BE989xxxx:0.INSTALL_TEST = true [RW]
DPT {f} HmIP-RF.00241BE989xxxx:0.OPERATING_VOLTAGE = 0.000000 [RE]
DPT {i} HmIP-RF.00241BE989xxxx:0.OPERATING_VOLTAGE_STATUS = 0 [RE]
DPT {n} HmIP-RF.00241BE989xxxx:0.RSSI_DEVICE = 158 [RE]
DPT {n} HmIP-RF.00241BE989xxxx:0.RSSI_PEER = 158 [RE]
DPT {b} HmIP-RF.00241BE989xxxx:0.UNREACH = true [RE]
DPT {b} HmIP-RF.00241BE989xxxx:0.UPDATE_PENDING = false [RE]
CHN 00241BE989xxxx:1 HmIP-MOD-HO 00241BE989xxxx:1
DPT {i} HmIP-RF.00241BE989xxxx:1.DOOR_COMMAND = [W]
DPT {i} HmIP-RF.00241BE989xxxx:1.DOOR_STATE = 2 [RE]
DPT {i} HmIP-RF.00241BE989xxxx:1.ERROR_CODE = 0 [RE]
DPT {i} HmIP-RF.00241BE989xxxx:1.PROCESS = 0 [RE]
DPT {i} HmIP-RF.00241BE989xxxx:1.SECTION = 3 [RE]
DPT {i} HmIP-RF.00241BE989xxxx:1.SECTION_STATUS = 0 [RE]
CHN 00241BE989xxxx:2 HmIP-MOD-HO 00241BE989xxxx:2
DPT {i} HmIP-RF.00241BE989xxxx:2.PROCESS = 0 [RE]
DPT {i} HmIP-RF.00241BE989xxxx:2.SECTION = 3 [RE]
DPT {i} HmIP-RF.00241BE989xxxx:2.SECTION_STATUS = 0 [RE]
DPT {b} HmIP-RF.00241BE989xxxx:2.STATE = true [RWE]set HM_HmIP_MOD_HO_00241BE989xxxx datapoint 1.DOOR_COMMAND 1set HM_HmIP_MOD_HO_00241BE989xxxx datapoint 1.DOOR_COMMAND 2set HM_HmIP_MOD_HO_00241BE989xxxx datapoint 1.DOOR_COMMAND 3set HM_HmIP_MOD_HO_00241BE989xxxx datapoint 1.DOOR_COMMAND 4| ID | Parameter | Logical | Physical | Access | Default | Possible Values | |
| 66.3.1.1.1 | CONFIG_PENDING | BOOLEAN | integer | read/event | false | Min: false | Max: true |
| 66.3.1.1.2 | DUTY_CYCLE | BOOLEAN | integer | read/event | false | Min: false | Max: true |
| 66.3.1.1.3 | OPERATING_VOLTAGE | FLOAT | integer | read/event | 0.0 | Min: 0.0 | Max: 25.2 |
| 66.3.1.1.4 | OPERATING_VOLTAGE_STATUS | ENUM | integer | read/event | NORMAL | NORMAL / UNKNOWN / OVERFLOW | |
| 66.3.1.1.5 | RSSI_DEVICE | INTEGER | integer | read/event | 0 | Min: -128 | Max: 127 |
| 66.3.1.1.6 | RSSI_PEER | INTEGER | integer | read/event | 0 | Min: -128 | Max: 127 |
| 66.3.1.1.7 | UNREACH | BOOLEAN | integer | read/event | false | Min: false | Max: true |
| 66.3.1.2.1 | ARR_TIMEOUT | INTEGER | integer | read/write | 10 | Min: 0 | Max: 255 |
| 66.3.1.2.2 | CYCLIC_INFO_MSG | INTEGER | integer | read/write | 1 | Min: 0 | Max: 255 |
| 66.3.1.2.3 | CYCLIC_INFO_MSG_DIS | INTEGER | integer | read/write | 1 | Min: 0 | Max: 255 |
| 66.3.1.2.4 | CYCLIC_INFO_MSG_DIS_UNCHANGED | INTEGER | integer | read/write | 20 | Min: 0 | Max: 255 |
| 66.3.1.2.5 | CYCLIC_INFO_MSG_OVERDUE_THRESHOLD | INTEGER | integer | read/write | 2 | Min: 0 | Max: 2147483647 |
| 66.3.1.2.6 | DISABLE_MSG_TO_AC | BOOLEAN | integer | read/event | false | Min: false | Max: true |
| 66.3.1.2.7 | DUTYCYCLE_LIMIT | INTEGER | integer | read/write | 180 | Min: 0 | Max: 255 |
| 66.3.1.2.8 | ENABLE_ROUTING | BOOLEAN | integer | read/event | true | Min: false | Max: true |
| 66.3.1.2.9 | LOCAL_RESET_DISABLED | BOOLEAN | integer | read/event | false | Min: false | Max: true |
| 66.3.2.1.1 | DOOR_COMMAND | ENUM | integer | write | NOP | NOP / OPEN / STOP / CLOSE / PARTIAL_OPEN | |
| 66.3.2.1.2 | DOOR_STATE | ENUM | integer | read/event | CLOSED | CLOSED / OPEN / VENTILATION_POSITION / POSITION_UNKNOWN | |
| 66.3.2.1.3 | ERROR_CODE | INTEGER | integer | read/event | 0 | Min: 0 | Max: 255 |
| 66.3.2.1.4 | PROCESS | ENUM | integer | read/event | STABLE | STABLE / NOT_STABLE | |
| 66.3.2.1.5 | SECTION | INTEGER | integer | read/event | 0 | Min: 0 | Max: 15 |
| 66.3.2.1.6 | SECTION_STATUS | ENUM | integer | read/event | NORMAL | NORMAL / UNKNOWN | |
| 66.3.2.2.1 | EVENT_DELAY_UNIT | ENUM | integer | read/write | S | 100MS / S / M / H | |
| 66.3.2.2.2 | EVENT_DELAY_VALUE | INTEGER | integer | read/write | 1 | Min: 0 | Max: 63 |
| 66.3.2.2.3 | EVENT_RANDOMTIME_UNIT | ENUM | integer | read/write | S | 100MS / S / M / H | |
| 66.3.2.2.4 | EVENT_RANDOMTIME_VALUE | INTEGER | integer | read/write | 1 | Min: 0 | Max: 63 |
| 66.3.3.1.1 | PROCESS | ENUM | integer | read/event | STABLE | STABLE / NOT_STABLE | |
| 66.3.3.1.2 | SECTION | INTEGER | integer | read/event | 0 | Min: 0 | Max: 15 |
| 66.3.3.1.3 | SECTION_STATUS | ENUM | integer | read/event | NORMAL | NORMAL / UNKNOWN | |
| 66.3.3.1.4 | STATE | BOOLEAN | integer | read/write/event | false | Min: false | Max: true |
| 66.3.3.2.1 | EVENT_DELAY_UNIT | ENUM | integer | read/write | S | 100MS / S / M / H | |
| 66.3.3.2.2 | EVENT_DELAY_VALUE | INTEGER | integer | read/write | 1 | Min: 0 | Max: 63 |
| 66.3.3.2.3 | EVENT_RANDOMTIME_UNIT | ENUM | integer | read/write | S | 100MS / S / M / H | |
| 66.3.3.2.4 | EVENT_RANDOMTIME_VALUE | INTEGER | integer | read/write | 1 | Min: 0 | Max: 63 |
defmod HM_HmIP_MOD_HO_00241BE989xxxx HMCCUDEV 00241BE989xxxx
attr HM_HmIP_MOD_HO_00241BE989xxxx IODev d_ccu
attr HM_HmIP_MOD_HO_00241BE989xxxx alias Garagentor2
attr HM_HmIP_MOD_HO_00241BE989xxxx cmdIcon open:fts_garage_door_up stop:fts_garage_door_manual close:fts_garage_door_down vent:fts_garage_door_60
attr HM_HmIP_MOD_HO_00241BE989xxxx devStateIcon closed:fts_garage_door_100 open:fts_garage vent_pos:fts_garage_door_60 unknown:fts_garage_door_40
attr HM_HmIP_MOD_HO_00241BE989xxxx eventMap /datapoint 1.DOOR_COMMAND 1:open/datapoint 1.DOOR_COMMAND 2:stop/datapoint 1.DOOR_COMMAND 3:close/datapoint 1.DOOR_COMMAND 4:vent/
attr HM_HmIP_MOD_HO_00241BE989xxxx room Garage
attr HM_HmIP_MOD_HO_00241BE989xxxx statedatapoint 1.DOOR_STATE
attr HM_HmIP_MOD_HO_00241BE989xxxx substitute DOOR_STATE!0:closed,1:open,2:vent_pos,3:unknown
attr HM_HmIP_MOD_HO_00241BE989xxxx webCmd open:stop:close:vent
attr HM_HmIP_MOD_HO_00241BE989xxxx devStateIcon closed:fts_garage_door_100@green open:fts_garage@green vent_pos:fts_garage_door_60@blue unknown:fts_garage_door_20@red
attr HM_HmIP_MOD_HO_00241BE989xxxx widgetOverride control:uzsuToggle,off,ondefmod HM_HmIP_MOD_HO_00241BE989xxxx_2 HMCCUCHN 00241BE989xxxx:2
attr HM_HmIP_MOD_HO_00241BE989xxxx_2 IODev d_ccu
attr HM_HmIP_MOD_HO_00241BE989xxxx_2 alias Garagentor2_Beleuchtung
attr HM_HmIP_MOD_HO_00241BE989xxxx_2 room Garage
attr HM_HmIP_MOD_HO_00241BE989xxxx_2 statedatapoint 2.STATE
attr HM_HmIP_MOD_HO_00241BE989xxxx_2 statevals on:true,off:false
attr HM_HmIP_MOD_HO_00241BE989xxxx_2 substitute 2.STATE!(1|true):on,(0|false):off
attr HM_HmIP_MOD_HO_00241BE989xxxx_2 webCmd control
attr HM_HmIP_MOD_HO_00241BE989xxxx_2 widgetOverride control:uzsuToggle,off,ondefmod di_GaragentoreZu DOIF ([{sunset(600)}]) ## Sonnenuntergang +00:10:00 / 600s\
(IF ([HM_HmIP_MOD_HO_00241BE989xxxx:1.DOOR_STATE] ne "0") ## Wenn Garagentor2 nicht ZU\
(set HM_HmIP_MOD_HO_00241BE989xxxx datapoint 1.DOOR_COMMAND 3)) ## Dann Garagentor2 ZU\
(IF ([HM_HmIP_MOD_HO_00241BE989xxxx:1.DOOR_STATE] ne "0") ## Wenn Garagentor3 nicht ZU\
(set HM_HmIP_MOD_HO_00241BE989xxxx datapoint 1.DOOR_COMMAND 3)) ## Dann Garagentor3 ZU\
attr di_GaragentoreZu do always
attr di_GaragentoreZu room Garage
attr di_GaragentoreZu stateFormat last execution: {(ReadingsTimestamp('di_GaragentoreZu','cmd_event','0'))}</br>\
next execution: {(ReadingsVal('di_GaragentoreZu','timer_01_c01','0'))}
define HmIP_MOD_HO_00241blub HMCCUDEV 00241blub
setuuid HmIP_MOD_HO_00241blub 6165ec00-f33f-d9f2-65c3-tja
attr HmIP_MOD_HO_00241blub IODev d_ccu
attr HmIP_MOD_HO_00241blub alias Hoftor
attr HmIP_MOD_HO_00241blub cmdIcon open:fts_garage_door_up stop:fts_garage_door_manual close:fts_garage_door_down vent:fts_garage_door_60
attr HmIP_MOD_HO_00241blub eventMap /datapoint 1.DOOR_COMMAND 1:open/datapoint 1.DOOR_COMMAND 2:stop/datapoint 1.DOOR_COMMAND 3:close/datapoint 1.DOOR_COMMAND 4:vent/
attr HmIP_MOD_HO_00241blub room Außen
attr HmIP_MOD_HO_00241blub statedatapoint 1.DOOR_STATE
attr HmIP_MOD_HO_00241blub substitute DOOR_STATE!0:closed,1:open,2:vent_pos,3:unknown
attr HmIP_MOD_HO_00241blub webCmd open:stop:close:vent
