kann mir mal einer sagen was mir dieser Fehler sagen will:
ERROR:Malformed prototype for main::KNX_TypAendern: $device, $dpt, $gr, $anz at ./FHEM/99_myUtils_Allgemein.pm line 38.
Ich komme nicht weiter. Hier mein Code:
# $Id: myUtilsTemplate.pm 21509 2020-03-25 11:20:51Z rudolfkoenig $
# Save this file as 99_myUtils.pm, and create your own functions in the new
# file. They are then available in every Perl expression.
package main;
use strict;
use warnings;
sub
myUtils_Allgemein_Initialize($$)
my ($hash) = @_;
# Enter you functions below _this_ line.
sub test()
sub KNX_rename ()
my @devices = devspec2array("NAME=KNX.*");
my $anz = 0;
my ($ugr, $gr);
foreach my $device (@devices)
#1/1/ - Schalten
if (substr($device,4,4) eq "0101")
KNX_TypAendern($device, "1.001", "1/2/", $anz);
#1/2/ - Dimmen
elsif (substr($device,4,4) eq "0102")
KNX_TypAendern($device, "3.007", "1/2/", $anz);
#1/3/ - Wert (Dimmen)
elsif (substr($device,4,4) eq "0103")
KNX_TypAendern($device, "5.001", "1/3/", $anz);
#1/4/ - RMs
elsif (substr($device,4,4) eq "0104")
KNX_TypAendern($device, "1.001", "1/4/", $anz);
#1/5/ - RMw
elsif (substr($device,4,4) eq "0105")
KNX_TypAendern($device, "5.001", "1/5/", $anz);
#2/0/ - Temperaturmesswert
elsif (substr($device,4,4) eq "0200")
KNX_TypAendern($device, "9.001", "2/0/", $anz);
#2/2/ - Betriebsartvorwahl
elsif (substr($device,4,4) eq "0202")
KNX_TypAendern($device, "20.102", "2/2/", $anz);
#2/3/ - Betriebsart Direkt
elsif (substr($device,4,4) eq "0203")
KNX_TypAendern($device, "1.001", "2/3/", $anz);
#3/1/ - Auf / Ab
elsif (substr($device,4,4) eq "0301")
KNX_TypAendern($device, "1.008", "3/1/", $anz);
#3/3/ - Absolute Position (inkl Lamellenposition)
elsif (substr($device,4,4) eq "0303")
KNX_TypAendern($device, "5.001", "3/3/", $anz);
#3/6/ - Diagnosetext
elsif (substr($device,4,4) eq "0306")
KNX_TypAendern($device, "16.000", "3/6/", $anz);
#4/0/ - Fensterkontakt auf/zu
elsif (substr($device,4,4) eq "0400")
KNX_TypAendern($device, "1.001", "4/0/", $anz);
elsif (substr($device,4,4) eq "0401")
KNX_TypAendern($device, "1.001", "4/1/", $anz);
elsif (substr($device,4,4) eq "0402")
KNX_TypAendern($device, "1.001", "4/2/", $anz);
sub KNX_TypAendern ($device, $dpt, $gr, $anz)
my ($device, $dpt, $gr, $anz) = @_;
my $ugr;
$anz++;
$ugr = substr($device,8);
if(substr($ugr,0,1) eq "0") {$ugr =~ s/0//;}
$gr = $gr.$ugr;
fhem("defmod ".$device." KNX ".$gr.":dpt".$dpt);
1;
Line 38 ist übrigens: KNX_TypAendern($device, "1.001", "1/2/", $anz);
Du kannst in den Prototypen keine Variablen Namen angeben:
https://docstore.mik.ua/orelly/perl/prog3/ch06_04.htm
Am besten lässt Du die auch gleich weg und verlierst dich nicht in dem Glauben, sie würden dir wirklich helfen.
Es gibt nur wenige Fälle in denen in Perl Prototypen verwendet werden sollten.
Pack die Validierung der übergebenen Variablen besser in die sub.
Gruß Sidey
Ich habe nichtmal ahnung was Prototypen sind. Ich kann null mit dem Fehler anfange. Sorry. Wo habe ich den Prototypen genutzt?
Edit:
Was ich will ist folgendes. Die Sub KNX_TypAendern wird immer wieder gebraucht und muss aus der Haupt Sub ja die Daten bekommen, welche sich teilweise ändern. Wo liegt nun der Fehler in der Übergabe bzw. wo nutze ich dies Prototypen?
sub KNX_TypAendern ($$$$)
oder gleich ganz weg lassen
sub KNX_TypAendern {
Edit:
Ich komme gleich nochmal neu :D
Habe es jetzt wie folgt geändert:
package main;
use strict;
use warnings;
sub
my ($hash) = @_;
sub test()
sub KNX_rename ()
my $anz = 0;
my ($ugr, $gr);
#1/1/ - Schalten
#1/2/ - Dimmen
#1/4/ - RMs
#1/5/ - RMw
#3/1/ - Auf / Ab
my $ugr;
$anz++;
$gr = $gr.$ugr;
1;
Der neue Fehler lautet:
oo many arguments for main::KNX_TypAendern at ./FHEM/99_myUtils_Allgemein.pm line 38, near "$anz)"
Ich bin doch net doof und habe das schon ein paar Mal gemacht. Irgendwas muss ich doch übersehen, was ich sonst anders mache. Komisch
Ich habe mal die Rheinfolge der Subs geändert, das scheint geholfen zu haben. Warum auch immer. Hoffen wir, dass es dabei bleibt. Danke für die Hilfe
package main;
use strict;
use warnings;
sub
myUtils_TestFn_Initialize($$)
my ($hash) = @_;
sub test()
my $ugr;
$anz++;
$gr = $gr.$ugr;
sub KNX_rename ()
my $anz = 0;
my ($ugr, $gr);
#1/1/ - Schalten
KNX_TypAendern($device, $anz);
#1/2/ - Dimmen
#1/4/ - RMs
#1/5/ - RMw
#3/1/ - Auf / Ab
1;
Es liegt in der Tat an der Reihnfolge
Ich meine mich auch zu erinnern, dass subs vorhanden sein müssen bevor sie aufgerufen werden ;)
Das Sollte sich aber eigentlich erledigt haben wenn man Prototypen nicht verwendet. Und ich habe das gerade getestet. Bei mir geht es
package main;
use strict;
use warnings;
sub
myUtils_TestFn_Initialize {
my ($hash) = @_;
sub test {
sub KNX_rename {
my $anz = 0;
my ($ugr, $gr);
#1/1/ - Schalten
#1/2/ - Dimmen
#1/4/ - RMs
#1/5/ - RMw
#3/1/ - Auf / Ab
my $ugr;
$anz++;
$gr = $gr.$ugr;
1;
Hex, Hex.... :D Keine Ahnung woran es lag. Vielleicht weil die sub neu eingelesen wurde und alles neu angelegt?
Prototypen sind subs in denen angegeben wird, wie viele Variablen und von welchem Typ sie erwartet werden:
sub KNX_TypAendern ($$$$)Genau genommen die ($$$$) Angabe beschreibt den Prototypen.
Lässt Du es weg, wird kein Prototyp erzeugt gegen den der Compiler den Aufruf validiert.
Empfehlung: Prototypen in Perl meiden, solange es nicht zwingend Gründe gibt sie zu verwenden.
Du rufst da vierzehn mal substr($device,4,4) auf - das könntest du auch auf einen Aufruf + eine Variable eindampfen.
Vorallem ist das ja eine exklusive Bedingung, d.h. der Rückgabewerk von substr erfüllt genau nur eine deiner Bedingungen - du prüfst aber jede Bedingung bei jedem Durchlauf durch, auch wenn z.B. die erste Bedingung wahr ist.
$anz ist in KNX_rename auch immer 0.
oh haben wir hier ein neues Spiel ala "wir stellen Amenophis86 99myUtils heute mal auf den Kopf " ?
Wenn ja hätte ich auch noch einen der mich inwischen oft anspringt : der unötige Wechsel FHEM->Perl->FHEM usw.
Bsp : fhem("defmod -> CommandDefMod :)
Ich dachte heute wäre MyUtils-Dienstag?!
Wenn man an Prototypen was ändert, hilft in aller Regel ein FHEM Neustart mehr als das bloße Neuladen der Moduldatei nach dem Edit. Das führt immer mal zu solchen Effekten wie hier im Thread aufgetreten.
(man könnte das jetzt tiefergehend erklären, aber dazu habe ich jetzt keine Lust. Einfach merken: Neustart nach Änderung von Prototypen, auch wenn man sie löscht.)
Jetzt geht es los, ich habe für mich mal schnell ein Programm geschrieben um nicht alles per Hand ändern zu müssen bei über 200 Gruppenadresse und nicht mein bestes geben, ich bitte dies zu entschuldigten :D Aber danke für eure Vorschläge, welche ich übernehmen werde, wenn ich die Sub feste einplane und schön machen werde ;)
Das habe ich gemerkt und mir gedacht aber top, dass du es nochmals bestätigst. Dann lag ich nicht so falsch mit meiner Vermutung :)
Ach und die Var $anz hatte ich am Anfang genutzt und ist dann durch Copy und Paste einfach drinnen geblieben. Hast recht, dass die nix bringt aktuell :)
sub KNX_rename {
my $anz = 0;
my ($ugr, $gr);
foreach my $device (@devices) {
given (substr($device,4,4)) {
when ('0101') { KNX_TypAendern($device, $anz); next; };
when ('0102') { KNX_TypAendern($device, "1.001", "1/2/", $anz); next; };
# usw...
default {}
Du hast zwar prinzipiell recht, aber wenn jemand mit fhem() arbeitet, finde ich das völlig ok und vor allem für viele Anwender einfacher zu verstehen.
Und wenn Du schon mit Command<...> um die Ecke kommst: man könnte ja auch gleich AnalyzeCommandChain() verwenden ;)
Zitat von: betateilchen am 10 November 2020, 19:54:55
sub KNX_rename {
my $anz = 0;
my ($ugr, $gr);
when ('0101') { KNX_TypAendern($device, $anz); return; };
when ('0102') { KNX_TypAendern($device, "1.001", "1/2/", $anz); return; };
# usw...
default {}
s/return/next/;
Zitat von: Christoph Morrison am 10 November 2020, 20:04:11
s/return/next/;
Danke für den Hinweis, das war ein copy&paste Fehler meinerseits.
ah given when heißt das bei Perl. Habe nach Switch und Case gesucht aber gelesen, dass man Probleme bekommen könnte. Wieder was gelernt. Da bin ich ja froh, dass MyUtils Dienstag ist und ihr meine hässlichen Code so schön gemacht habt :)
