FHEM - Hausautomations-Systeme => Homematic => Thema gestartet von: Fredi69 am 10 Dezember 2020, 13:09:08
Titel: Problem mit DBLog
Beitrag von: Fredi69 am 10 Dezember 2020, 13:09:08
Kann mir jemand erklären warum ValvePosition im Log ankommt, desired-temp aber nicht
DEF        4ED3CB04
   FUUID      5c4570df-f33f-0af0-15ac-86a708cb2e6ed14b
   NAME       DG.Kz.HZ.Thermostat_Clima
   NOTIFYDEV  global
   NR         362
   NTFY_ORDER 50-DG.Kz.HZ.Thermostat_Clima
   STATE      T: 13.7 desired: 14.0 valve: 100
   TYPE       CUL_HM
   chanNo     04
   device     DG.Kz.HZ.Thermostat
   Helper:
     DBLOG:
       ValvePosition:
         MyDBlog:
           TIME       1607601781.00845
           VALUE      100
     2020-12-10 13:00:31   CommandAccepted yes
     2019-12-09 11:05:02   R-boostPeriod   5 min
     2019-12-09 11:05:02   R-boostPos      80 %
     2019-12-09 11:05:02   R-btnNoBckLight off
     2019-12-09 11:05:02   R-dayTemp       21 C
     2019-12-09 11:05:02   R-daylightSaveTime on
     2019-12-09 11:05:02   R-decalcTime    11:00
     2019-12-09 11:05:02   R-decalcWeekday Sat
     2019-12-09 11:05:02   R-modePrioManu  all
     2019-12-09 11:05:02   R-modePrioParty all
     2019-12-09 11:05:02   R-nightTemp     17 C
     2019-12-09 11:05:02   R-noMinMax4Manu off
     2019-12-09 11:05:02   R-regAdaptive   on
     2019-12-09 11:05:02   R-reguExtI      18
     2019-12-09 11:05:02   R-reguExtP      33
     2019-12-09 11:05:02   R-reguExtPstart 45
     2019-12-09 11:05:02   R-reguIntI      16
     2019-12-09 11:05:02   R-reguIntP      31
     2020-11-25 09:31:30   R-reguIntPstart 33
     2019-12-09 11:05:02   R-showInfo      time
     2019-12-09 11:05:02   R-showWeekday   off
     2019-04-23 21:45:32   R-sign          off
     2019-12-09 11:05:02   R-tempMax       30.5 C
     2019-12-09 11:05:02   R-tempMin       4.5 C
     2019-12-09 11:05:02   R-tempOffset    0.0K
     2019-12-09 11:05:02   R-valveErrPos   15 %
     2019-12-09 11:05:02   R-valveMaxPos   100 %
     2019-12-09 11:05:02   R-valveOffsetRt 0 %
     2019-12-09 11:05:02   R-winOpnBoost   off
     2019-12-09 11:05:02   R-winOpnDetFall 1.4 K
     2019-12-09 11:05:02   R-winOpnMode    off
     2019-12-09 11:05:02   R-winOpnPeriod  15 min
     2019-12-09 11:05:02   R-winOpnTempI   12 C
     2020-12-10 11:32:09   R_0_tempListSat  24:00 13.0
     2020-12-10 11:32:09   R_1_tempListSun  24:00 13.0
     2020-12-10 11:32:09   R_2_tempListMon  24:00 13.0
     2020-12-10 11:32:09   R_3_tempListTue  24:00 13.0
     2020-12-10 11:32:09   R_4_tempListWed  24:00 13.0
     2020-12-10 11:32:09   R_5_tempListThu  24:00 13.0
     2020-12-10 11:32:09   R_6_tempListFri  24:00 13.0
     2020-12-10 11:32:09   R_tempList_State verified
     2020-12-10 13:05:17   ValvePosition   100
     2020-12-10 13:05:17   boostTime       -
     2020-12-10 11:32:12   cfgState        ok
     2020-12-10 13:05:17   controlMode     manual
     2020-12-10 13:05:17   desired-temp    14.0
     2020-12-10 13:05:17   measured-temp   13.7
     2020-12-10 13:05:17   partyEnd        -
     2020-12-10 13:05:17   partyStart      -
     2020-12-10 13:05:17   partyTemp       -
     2020-12-10 13:00:31   recentStateType ack
     2020-12-10 13:05:17   state           T: 13.7 desired: 14.0 valve: 100
     2020-08-26 08:59:00   trigLast        fhem:81
   helper:
     peerFriend peerRTteam2
     peerIDsRaw ,00000000
     peerOpt    p:thermostat
     regLst     1,7
     cmds:
       TmplKey    :no:1607584481.1265
       TmplTs     1607584481.1265
       cmdKey     1:0:0::DG.Kz.HZ.Thermostat:0095:04:
       cmdLst:
         burstXmit  noArg
         clear      [(readings|trigger|register|oldRegs|rssi|msgEvents|{msgErrors}|attack|all)]
         controlManu (on|off|5.0..30.0;0.5)
         controlMode (auto|manual|boost|day|night)
         controlParty -temp- -startDate- -startTime- -endDate- -endTime-
         desired-temp (on|off|5.0..30.0;0.5)
         getConfig  noArg
         getRegRaw  (List0|List1|List2|List3|List4|List5|List6) [-peerChn-]
         inhibit    [(on|{off})]
         peerBulk   -peer1,peer2,...- [({set}|unset)]
         peerSmart  -peerOpt-
         regBulk    -list-.-peerChn- -addr1:data1- -addr2:data2-...
         regSet     [(prep|{exec})] -regName- -value- [-peerChn-]
         sign       [(on|{off})]
         sysTime    noArg
         tempListFri [(prep|{exec})] -HH:MM- -temp- [...]
         tempListMon [(prep|{exec})] -HH:MM- -temp- [...]
         tempListSat [(prep|{exec})] -HH:MM- -temp- [...]
         tempListSun [(prep|{exec})] -HH:MM- -temp- [...]
         tempListThu [(prep|{exec})] -HH:MM- -temp- [...]
         tempListTmpl [({verify}|restore)] [[-file-:]-templateName-]
         tempListTue [(prep|{exec})] -HH:MM- -temp- [...]
         tempListWed [(prep|{exec})] -HH:MM- -temp- [...]
         tempTmplSet -tempTmpl-
         tplDel     -tplDel-
         tplSet_0   -tplChan-
       lst:
         condition  slider,0,1,255
         peer
         peerOpt    DG.Bad.HZ.Thermostat_ClimaTeam,DG.Ga.HZ.Thermostat_ClimaTeam,DG.Sz.HZ.Thermostat_ClimaTeam
         tplChan
         tplDel
         tplPeer
       rtrvLst:
         cmdList    [({short}|long)]
         deviceInfo [({short}|long)]
         param      -param-
         reg        -addr- -list- [-peerChn-]
         regList    noArg
         regTable   noArg
         regVal     -addr- -list- [-peerChn-]
         saveConfig [-filename-]
         tplInfo    noArg
     expert:
       def        1
       det        1
       raw        0
       tpl        0
     regCollect:
     role:
       chn        1
     shRegR:
       07         00
     shadowReg:
     tmpl:
   DbLogExclude .*
   DbLogInclude ValvePosition,desired-temp
   event-min-interval 900
   event-on-change-reading ValvePosition:1,desired-temp:0.5
   model      HM-CC-RT-DN
   peerIDs    00000000,
Titel: Antw:Problem mit DBLog
Beitrag von: Otto123 am 10 Dezember 2020, 13:48:34
lass doch mal die Schwelle weg
Wozu ist die hier überhaupt sinnvoll? ist der minimal Schritt nicht sowieso 1 bzw. 0.5?
Beitrag von: Fredi69 am 10 Dezember 2020, 15:00:17
Hatte ich auch schon versucht, leider kein Unterschied
Beitrag von: Frank_Huber am 10 Dezember 2020, 15:29:40
poste mal bitte noch ein list deines dblog Gerätes.
Beitrag von: Fredi69 am 10 Dezember 2020, 21:14:10
Danke, das war der entscheidende Hinweis.
Ich habe ja nur bestimmte Werte im define des DBLog.
