habe nun seit ein paar Tagen ZWAVE am Start, bin auch ganz zufrieden. Allerdings stören/wundern mich beim Startup zwei Meldungen:
2021.01.15 09:02:17 1: ZWAVE: SOF missing (got 00 instead of 01)
2021.01.15 09:03:01 2: ZWDongle_ProcessSendStack: no ACK, resending message 0107000301020100f9
2021.01.15 09:02:17 3: Opening ZWAVE device /dev/serial/by-id/usb-0658_0200-if00
2021.01.15 09:02:17 3: Setting ZWAVE serial parameters to 115200,8,N,1
2021.01.15 09:02:18 3: ZWAVE device opened
2021.01.15 09:02:56 0: Featurelevel: 6
2021.01.15 09:02:56 0: Server started with 596 defined entities (fhem.pl:23471/2021-01-04 perl:5.014002 os:linux user:fhem pid:2220)
Ich verwende den AEONTEC USB Stick GEN5+ (also den Neuen mit dem + am Ende), hier mal ein List:
internals:
CallbackNr 0
Clients :ZWave:
DEF /dev/serial/by-id/usb-0658_0200-if00@115200
DeviceName /dev/serial/by-id/usb-0658_0200-if00@115200
FD 98
FUUID 5ffc2fd4-f33f-b6d9-a373-9c04d0ecebe4a58c
MaxSendRetries 3
NAME ZWAVE
NR 638
PARTIAL
ReadTime 1610697782.77434
STATE Initialized
SendRetries 0
SendTime 1610697781.92836
TYPE ZWDongle
WaitForAck 0
homeId e7c578f9
nodeIdHex 01
nrNAck 0
MatchList:
1:ZWave .*
2021-01-12 06:47:22 backgroundRSSI ch1:-82 dBm ch2:-86 dBm
2021-01-15 09:02:18 caps Vers:1 Rev:2 ManufID:0086 ProductType:0001 ProductID:005a SERIAL_API_GET_INIT_DATA SERIAL_API_APPL_NODE_INFORMATION APPLICATION_COMMAND_HANDLER ZW_GET_CONTROLLER_CAPABILITIES SERIAL_API_SET_TIMEOUTS SERIAL_API_GET_CAPABILITIES SERIAL_API_SOFT_RESET UNKNOWN_09 UNKNOWN_0a SERIAL_API_SETUP ZW_SET_R_F_RECEIVE_MODE ZW_SET_SLEEP_MODE ZW_SEND_NODE_INFORMATION ZW_SEND_DATA ZW_SEND_DATA_MULTI ZW_GET_VERSION ZW_SEND_DATA_ABORT ZW_R_F_POWER_LEVEL_SET ZW_GET_RANDOM MEMORY_GET_ID MEMORY_GET_BYTE MEMORY_PUT_BYTE MEMORY_GET_BUFFER MEMORY_PUT_BUFFER FLASH_AUTO_PROG_SET ZW_NVR_GET_VALUE NVM_GET_ID NVM_EXT_READ_LONG_BUFFER NVM_EXT_WRITE_LONG_BUFFER NVM_EXT_READ_LONG_BYTE NVM_EXT_WRITE_LONG_BYTE UNKNOWN_2e UNKNOWN_2f ZW_CLEAR_TX_TIMERS ZW_GET_TX_TIMERS CLEAR_NETWORK_STATS GET_NETWORK_STATS GET_BACKGROUND_RSSI UNKNOWN_3c REMOVE_NODEID_FROM_NETWORK ZW_GET_NODE_PROTOCOL_INFO ZW_SET_DEFAULT ZW_REPLICATION_COMMAND_COMPLETE ZW_REPLICATION_SEND_DATA ZW_ASSIGN_RETURN_ROUTE ZW_DELETE_RETURN_ROUTE ZW_REQUEST_NODE_NEIGHBOR_UPDATE ZW_APPLICATION_UPDATE ZW_ADD_NODE_TO_NETWORK ZW_REMOVE_NODE_FROM_NETWORK ZW_CREATE_NEW_PRIMARY ZW_CONTROLLER_CHANGE ZW_ASSIGN_PRIORITY_RETURN_ROUTE ZW_SET_LEARN_MODE ZW_ASSIGN_SUC_RETURN_ROUTE ZW_REQUEST_NETWORK_UPDATE ZW_SET_SUC_NODE_ID ZW_DELETE_SUC_RETURN_ROUTE ZW_GET_SUC_NODE_ID ZW_SEND_SUC_ID ZW_ASSIGN_PRIORITY_SUC_RETURN_ROUTE ZW_EXPLORE_REQUEST_INCLUSION ZW_EXPLORE_REQUEST_EXCLUSION ZW_REQUEST_NODE_INFO ZW_REMOVE_FAILED_NODE_ID ZW_IS_FAILED_NODE ZW_REPLACE_FAILED_NODE UNKNOWN_66 UNKNOWN_67 ZW_FIRMWARE_UPDATE_NVM GET_ROUTING_TABLE_LINE LOCK_ROUTE_RESPONSE ZW_GET_PRIORITY_ROUTE ZW_SET_PRIORITY_ROUTE UNKNOWN_98 APPLICATION_SLAVE_COMMAND_HANDLER ZW_SET_WUT_TIMEOUT ZW_WATCHDOG_ENABLE ZW_WATCHDOG_DISABLE ZW_WATCHDOG_CHECK ZW_SET_EXT_INT_LEVEL ZW_RF_POWERLEVEL_GET ZW_TYPE_LIBRARY ZW_SEND_TEST_FRAME ZW_GET_PROTOCOL_STATUS ZW_SET_PROMISCUOUS_MODE PROMISCUOUS_COMMAND_HANDLER WATCHDOG_START WATCHDOG_STOP ZW_SET_ROUTING_MAX UNKNOWN_ee UNKNOWN_ef
2021-01-15 09:02:18 ctrlCaps PRIMARY
2021-01-15 09:02:18 homeId HomeId:e7c578f9 CtrlNodeIdHex:01
2021-01-14 17:25:07 isFailedNode_3 no
2021-01-14 22:21:49 nodeList ZWAVE SZ.co
2021-01-15 09:02:18 random c4977ba77f5b465adaec81b06924e5c96ef645d0c56cd1074e3124bfcb71f18e
2021-01-15 09:02:18 state Initialized
2021-01-11 22:45:34 statistics Transmitted:231 BackOffs:0 ReceivedNoErrors:212
ChecksumErrors:5 CRC16Errors:4 ForeignHomeId:0
2021-01-15 09:02:18 sucNodeId no
2021-01-12 06:46:58 version Z-Wave 6.07 STATIC_CONTROLLER
SendStack:
devStateIcon Initialized:cul_868@green .*:cul_868@red
homeId e7c578f9
icon cul_868
room FHEM
Funktional ist alles ..
Nachtrag:
Die SOF Meldung kommt nur, wenn ich einen reboot des Raspberry 2 durchführe, bei FHEM Restart sind alles sauber aus...
VG Klaus
Beide Meldungen sind ein Hinweis auf USB-Kommunikationsprobleme, oder auf einen kaputten/ueberlasteten Firmware.
Dass die Firmware ueberlastet wird, kann auch an dem FHEM-Modul liegen, der zu viel dem Dongle zumutet, obwohl wir Geduld lange geuebt haben.
Wenn es nur um die beiden Meldungen beim Start geht, dann wuerde ich das ignorieren.
