Hallo Zusammen,
Ich habe seit dem heutigen Update problem mit OWAD. Das Modul kann nicht mehr geladen werden. Ist für mich im Moment nur ein kleines Problem, da darüber nur eine Messung der Spannungsversorgung erfolgt.
Ich hänge mal einen Auszug aus dem Log an.
./FHEM/21_OWAD.pm has too many errors.
Missing right curly or square bracket at ./FHEM/21_OWAD.pm line 1634, at end of line
Can't use global @_ in "my" at ./FHEM/21_OWAD.pm line 1359, near "= @_"
Unknown regexp modifier "/D" at ./FHEM/21_OWAD.pm line 1272, at end of line
Unknown regexp modifier "/A" at ./FHEM/21_OWAD.pm line 1272, at end of line
Unknown regexp modifier "/W" at ./FHEM/21_OWAD.pm line 1272, at end of line
Unknown regexp modifier "/O" at ./FHEM/21_OWAD.pm line 1272, at end of line
Unknown regexp modifier "/_" at ./FHEM/21_OWAD.pm line 1272, at end of line
Unknown regexp modifier "/1" at ./FHEM/21_OWAD.pm line 1272, at end of line
Unknown regexp modifier "/2" at ./FHEM/21_OWAD.pm line 1272, at end of line
2021.01.20 12:22:55 0: syntax error at ./FHEM/21_OWAD.pm line 1272, near "2021.01.17 05"
2021.01.20 12:22:55 1: reload: Error:Modul 21_OWAD deactivated:
2021.01.20 12:22:55 1: PERL WARNING: (Missing operator before at?)
2021.01.20 12:22:55 1: PERL WARNING: Bareword found where operator expected at ./FHEM/21_OWAD.pm line 1272, near ") at"
2021.01.20 12:22:55 1: PERL WARNING: Use of bare << to mean <<"" is deprecated at ./FHEM/21_OWAD.pm line 1272, <$fh> line 1493.
2021.01.20 12:22:55 1: PERL WARNING: (Missing operator before in?)
2021.01.20 12:22:55 1: PERL WARNING: Bareword found where operator expected at ./FHEM/21_OWAD.pm line 1272, near "@owg_resoln in"
2021.01.20 12:22:55 1: PERL WARNING: (Do you need to predeclare within?)
2021.01.20 12:22:55 1: PERL WARNING: Array found where operator expected at ./FHEM/21_OWAD.pm line 1272, near "within @owg_resoln"
2021.01.20 12:22:55 1: PERL WARNING: (Missing operator before 1?)
2021.01.20 12:22:55 1: PERL WARNING: Number found where operator expected at ./FHEM/21_OWAD.pm line 1272, near "05 1"
2021.01.20 12:22:55 1: PERL WARNING: (Missing operator before 05?)
2021.01.20 12:22:55 1: PERL WARNING: Number found where operator expected at ./FHEM/21_OWAD.pm line 1272, near "2021.01.17 05"
2021.01.20 12:22:55 1: OWID: Device OWX_01_D2039C190000 defined.
2021.01.20 12:22:55 1: OWID: Device OWX_01_44C09E190000 defined.
2021.01.20 12:22:55 1: OWID: Device OWX_01_6AC69E190000 defined.
2021.01.20 12:22:54 1: miniCUL_868: Can't connect to 192.168.10.30:23: Network is unreachable
2021.01.20 12:22:53 2: eventTypes: loaded 537 lines from ./log/eventTypes.txt
2021.01.20 12:22:53 1: Including fhem.cfg
2021.01.20 12:22:21 0: Server shutdown
Ich weiß im Moment keine Lösung, vielleicht kann mir jemand einen kleinen Schubs geben.
FHEM läuft auf einem Raspi unter Stretch
Hoffe das die Infos reichen.
Vielen Dank für die Hilfe
Gerd
Sorry, da habe ich kurz vor dem Commit irgendwie noch drei überflüssige Zeilen hineingeschrieben. Anbei die gefixte Version, wird umgehend ins Repository geschrieben.
pah
Danke für den fixen Fix,
und nochmals Danke für Deine Arbeit für FHEM
Grüße Gerd
PS.: Funktioniert nach Update wieder ausgezeichnet
