ich weiß nun nicht mehr weiter.
Ich habe mir vor ein paar Wochen meinen Xiaomi Vaccuum Gen1 per Valetudo über mqtt in Fhem eingebunden. Läuft alles super !
Nun legt sich aber jede Nacht um exakt 3:18 Uhr ein neue mqtt2 device an:
CFGFN
CID mqttjs_2cd1ccce
DEF mqttjs_2cd1ccce
DEVICETOPIC MQTT2_mqttjs_2cd1ccce
FUUID 60161391-f33f-98db-1624-912bc4d397e49188
IODev MQTT2_FHEM_Server
NAME MQTT2_mqttjs_2cd1ccce
NR 13037
STATE ???
TYPE MQTT2_DEVICE
2021-01-31 03:18:58 config_command_topic Geraete/BOB/command
2021-01-31 03:18:58 config_device_identifiers_1 BOB
2021-01-31 03:18:58 config_device_manufacturer Roborock
2021-01-31 03:18:58 config_device_model rockrobo.vacuum.v1
2021-01-31 03:18:58 config_device_name BOB
2021-01-31 03:18:58 config_device_sw_version 0.10.1
2021-01-31 03:18:58 config_fan_speed_list_1 whisper
2021-01-31 03:18:58 config_fan_speed_list_2 min
2021-01-31 03:18:58 config_fan_speed_list_3 medium
2021-01-31 03:18:58 config_fan_speed_list_4 high
2021-01-31 03:18:58 config_fan_speed_list_5 max
2021-01-31 03:18:58 config_json_attributes_topic Geraete/BOB/attributes
2021-01-31 03:18:58 config_name BOB
2021-01-31 03:18:58 config_schema state
2021-01-31 03:18:58 config_send_command_topic Geraete/BOB/custom_command
2021-01-31 03:18:58 config_set_fan_speed_topic Geraete/BOB/set_fan_speed
2021-01-31 03:18:58 config_state_topic Geraete/BOB/state
2021-01-31 03:18:58 config_supported_features_1 start
2021-01-31 03:18:58 config_supported_features_10 send_command
2021-01-31 03:18:58 config_supported_features_2 pause
2021-01-31 03:18:58 config_supported_features_3 stop
2021-01-31 03:18:58 config_supported_features_4 return_home
2021-01-31 03:18:58 config_supported_features_5 battery
2021-01-31 03:18:58 config_supported_features_6 status
2021-01-31 03:18:58 config_supported_features_7 locate
2021-01-31 03:18:58 config_supported_features_8 clean_spot
2021-01-31 03:18:58 config_supported_features_9 fan_speed
2021-01-31 03:18:58 config_unique_id BOB
2021-01-31 03:18:57 subscriptions Geraete/BOB/command Geraete/BOB/custom_command Geraete/BOB/set_fan_speed
readingList mqttjs_2cd1ccce:homeassistant/vacuum/Geraete_BOB/config:.* { json2nameValue($EVENT, 'config_', $JSONMAP) }
room MQTT2_DEVICE
Der Name hat immer das Muster mqttjs_2XXXXXXX
Das unter readingList genannte Topic homeassistant/vacuum/Geraete_BOB/ ist nicht das Topic das in meinem Aktiven Sauger eingetragen ist.
Es werden auch Nachrichten über diese Topic geschickt. Hat jemand einen Tipp wie ich den Ursprung dieser Messages finden und ausschalten kann ?
Kann es sein das es vom Raspberry kommt, da ich dort mal versucht hatte den Valetudo Mapper zu installieren? Das hatte ich dann irgendwann aufgegeben und nun brauche ich die Funktion auch nicht mehr. Ich hab aber keine Ahnung wo das vielleicht im Hintergrund noch aktiv ist und vielleicht der Ursprung der Nachrichen ist. Das lief irgendwie über NPM...
Jemand ne Idee wie ich das angehen kann ?
also ich weiß warum es passiert aber erstmal nicht wie Du die eigentliche Ursache bekämpfst.
Dein MQTT Prozess kommt mit einer zufälligen Client ID. Offenbar hast Du nachts Inettrennung und dann baut der MQTT mit einer neuen CID die Verbindung wieder auf. Dann wird eine neues Device angelegt.
Wie sieht denn dein eigentliches Roborock MQTT Device aus? Wahrscheinlich reicht es wenn du dort die CID löschst.
Also das es mit der Internet Trennung zusammenhängt hatte ich auch schon gedacht, aber meine Trennung passiert nicht zu diesem Zeitpunkt, sagt die Fritzbox.
Hier der List von meinem aktiven Robo:
CID BOB
DEF BOB
DEVICETOPIC BOB
FUUID 5ff03838-f33f-98db-80ea-7eae7a284b5eae5b
LASTInputDev MQTT2_FHEM_Server
MQTT2_FHEM_Server_MSGCNT 4
MQTT2_FHEM_Server_TIME 2021-01-31 03:19:13
MSGCNT 4
NAME BOB
NR 719
STATE docked
TYPE MQTT2_DEVICE
2021-01-02 11:58:21 attrTemplateVersion 20200522 or prior
2021-01-31 03:19:08 battery_level 100
2021-01-31 03:19:13 bin_in_time 1404
2021-01-31 03:19:13 cleanArea 12182.3
2021-01-31 03:19:13 cleanCount 310
2021-01-31 03:19:13 cleanTime 202.1
2021-01-31 03:19:13 currentCleanArea 0.9
2021-01-31 03:19:13 currentCleanTime 0.0
2021-01-02 12:31:14 destinations
2021-01-27 13:19:56 error Cliff sensors alarm, carry the robot to different place
2021-01-27 13:19:56 errorCode 3
2021-01-03 10:47:41 fan_power set min
2021-01-31 03:19:08 fan_speed medium
2021-01-31 03:19:13 filter 98.1
2021-01-03 10:51:08 get_destinations set
2021-01-31 03:19:13 last_bin_full -1
2021-01-31 03:19:13 last_bin_out 1610302989407
2021-01-31 03:19:13 last_loaded_map_date 1611768774525
2021-01-31 03:19:13 last_loaded_map_name Standard
2021-01-31 03:19:13 last_run_stats_area 0.9
2021-01-31 03:19:13 last_run_stats_duration 0
2021-01-31 03:19:13 last_run_stats_endTime 1611767867000
2021-01-31 03:19:13 last_run_stats_errorCode 0
2021-01-31 03:19:13 last_run_stats_errorDescription No error
2021-01-31 03:19:13 last_run_stats_finishedFlag false
2021-01-31 03:19:13 last_run_stats_startTime 1611767823000
2021-01-31 03:19:13 mainBrush 97.8
2021-01-14 19:54:44 map_data ERROR: Unknown format
2021-01-02 13:06:16 play_sound set /opt/rockrobo/resources/sounds/custom/R2D2-yeah.wav
2021-01-31 03:19:13 sensor 28.3
2021-01-31 03:19:13 sideBrush 198.3
2021-01-30 10:50:17 sound set opt/rockrobo/resources/sounds/custom/R2D2-yeah.wav
2021-01-31 03:19:13 state docked
2021-01-31 03:19:13 valetudo_state_id 8
2021-01-31 03:19:13 valetudo_state_name Charging
2021-01-27 18:17:03 zone set Alles
comment For original code for "attrTmqtt2_roborock_valetudo2svg()" see <a href="https://forum.fhem.de/index.php/topic,104687.msg986304.html#msg986304">this forum thread</a>. To display generated map seperately, define a weblink device: <br>define valetudo_map weblink htmlCode <img src="fhem/images/BOB_map.svg">
devStateIcon { '<img src="fhem/images/mqttjs_fa51d44e_map.png" style="max-width:256;;max-height:256;;">' }
event-on-change-reading state
icon vacuum_top
model roborock
readingList Geraete/BOB/config:.* { json2nameValue($EVENT) }
Geraete/BOB/state:.* { json2nameValue($EVENT) }
Geraete/BOB/attributes:.* { json2nameValue($EVENT) }
Geraete/BOB/map_data:.* {attrTmqtt2_roborock_Geraete2svg("map_data",$EVENT,"www/images/BOB_map.svg")}
Geraete/BOB/destinations.* { json2nameValue($EVENT) }
room 2.1_Geräte
setList start:noArg Geraete/BOB/command start
charge:noArg Geraete/BOB/command return_to_base
stop:noArg Geraete/BOB/command stop
spot:noArg Geraete/BOB/command clean_spot
pause:noArg Geraete/BOB/command pause
locate:noArg Geraete/BOB/command locate
fan_power:min,medium,high,max,mop Geraete/BOB/set_fan_speed $EVTPART1
zone Geraete/BOB/custom_command {"command":"zoned_cleanup","zone_ids":["$EVTPART1"]}
goto Geraete/BOB/custom_command {"command":"go_to","spot_id":"$EVTPART1"}
load_map Geraete/BOB/custom_command {"command":"load_map","name":"$EVTPART1"}
store_map Geraete/BOB/custom_command {"command":"store_map","name":"$EVTPART1"}
sound Geraete/BOB/custom_command {"command":"play_sound","file":"$EVTPART1"}
get_destinations:noArg Geraete/BOB/custom_command get_destinations
setStateList charge locate pause stop start
Naja die readingslist kommt da nicht vor und sieht anders aus:
Schnelle Abhilfe: lass das eine Gerät so und lösch dort die CID:
attr MQTT2_mqttjs_2cd1ccce readingList homeassistant/vacuum/Geraete_BOB/config:.* { json2nameValue($EVENT, 'config_', $JSONMAP) }
Dein MQTT2_FHEM_Server steht auf autocreate complex? Wenn ja solltest Du besser auf simple stellen, es sei denn Du brauchst es bewusst.
Vielleicht ist 3:18 Schichtwechsel? Ich weiß es nicht :)
Stichwort noch: ignoreRegexp.
Den ...config-Zweig benötigt man für FHEM nicht.
Alternativ entfernt man ClientID aus dem readingsList, und benennt das Geraet um oder man ignoriert es.
