FHEM => Anfängerfragen => Thema gestartet von: Kellerkind86 am 13 Februar 2021, 21:33:11
Titel: [gelöst] Unifi Client (Smartphone) bleibt disconnected
Beitrag von: Kellerkind86 am 13 Februar 2021, 21:33:11
Nabend zusammen,
Habe zwei Unifi clients angelegt..
eins von meiner Frau....funktioniert...steht als connected.
und meins..steht leider auf disconnected,
Jemand ne Idee wieso ?
Hier mal ein list
   CFGFN
   CODE       Mi9T-TiggersPhone
   DEF        Mi9T-TiggersPhone
   FUUID      60283409-f33f-153e-dac2-a1bdf878594a17b4
   IODev      Unifi_Controller
   LASTInputDev Unifi_Controller
   MODEL      XiaomiCo
   MSGCNT     27
   NAME       Marcells_Phone
   NOTIFYDEV  global
   NR         446
   STATE      disconnected
   TYPE       UnifiClient
   Unifi_Controller_MSGCNT 27
   Unifi_Controller_TIME 2021-02-13 21:31:20
   VERSION    0.0.3 BETA
     2021-02-13 21:31:20   _f_assoc_time   43d 20h 20m 15s
     2021-02-13 21:31:20   _f_dhcpend_time 0d 0h 2m 20s
     2021-02-13 21:31:20   _f_diff_tx_bytes 1927
     2021-02-13 21:31:20   _f_essid        UNDEFINED
     2021-02-13 21:31:20   _f_first_seen   2021-02-05 14:11:29
     2021-02-13 21:31:20   _f_last_seen    2021-02-13 20:27:25
     2021-02-13 21:31:20   _f_last_seen_by_uap 2021-02-13 21:31:02
     2021-02-13 21:31:20   _f_last_seen_duration 0d 1h 3m 55s
     2021-02-13 21:31:20   _f_latest_assoc_time 2021-02-13 21:20:15
     2021-02-13 21:31:20   _f_uptime       0d 0h 10m 47s
     2021-02-13 21:31:20   _f_uptime_by_uap 0d 0h 10m 47s
     2021-02-13 21:31:20   _f_usergroup_name Default
     2021-02-13 21:31:20   _id             601d44015b475b025636d529
     2021-02-13 21:31:20   _is_guest_by_uap 0
     2021-02-13 21:31:20   _last_seen_by_uap 1613248262
     2021-02-13 21:31:20   _uptime_by_uap  647
     2021-02-13 21:31:20   accesspoint     unknown
     2021-02-13 21:31:20   anomalies       0
     2021-02-13 21:31:20   ap_mac          f4:92:bf:10:91:24
     2021-02-13 21:31:20   assoc_time      1613247615
     2021-02-13 21:31:20   authorized      1
     2021-02-13 21:31:20   blocked         1
     2021-02-13 21:31:20   bssid           f6:92:bf:12:91:24
     2021-02-13 21:31:20   bytes-r         2
     2021-02-13 21:31:20   ccq             333
     2021-02-13 21:31:20   channel         149
     2021-02-13 21:31:20   dev_id_override 2913
     2021-02-13 21:31:20   dhcpend_time    140
     2021-02-13 21:31:20   essid           LauMarSteMat-5G
     2021-02-13 21:31:20   fhem_clientName Mi9T-TiggersPhone
     2021-02-13 21:31:20   fhem_state      disconnected
     2021-02-13 21:31:20   fhem_usedOnlineTime 1 Minuten
     2021-02-13 21:31:20   fingerprint_override 1
     2021-02-13 21:31:20   first_seen      1612530689
     2021-02-13 21:31:20   hostname        Mi9T-TiggersPhone
     2021-02-13 21:31:20   idletime        6
     2021-02-13 21:31:20   ip              192.168.178.101
     2021-02-13 21:31:20   is_11r          0
     2021-02-13 21:31:20   is_guest        0
     2021-02-13 21:31:20   is_wired        0
     2021-02-13 21:31:20   last_seen       1613244445
     2021-02-13 21:31:20   latest_assoc_time 1613247615
     2021-02-13 21:31:20   mac             20:f4:78:43:86:18
     2021-02-13 21:31:20   noise           -100
     2021-02-13 21:31:20   oui             XiaomiCo
     2021-02-13 21:31:20   powersave_enabled 1
     2021-02-13 21:31:20   qos_policy_applied 1
     2021-02-13 21:31:20   radio           na
     2021-02-13 21:31:20   radio_name      wifi1
     2021-02-13 21:31:20   radio_proto     ac
     2021-02-13 21:31:20   rssi            48
     2021-02-13 21:31:20   rx_bytes        218681
     2021-02-13 21:31:20   rx_bytes-r      2
     2021-02-13 21:31:20   rx_packets      581
     2021-02-13 21:31:20   rx_rate         6000
     2021-02-13 21:31:20   satisfaction    100
     2021-02-13 21:31:20   signal          -48
     2021-02-13 21:31:20   site_id         6013386d5b475b0383241c4d
     2021-02-13 21:31:20   tx_bytes        230160
     2021-02-13 21:31:20   tx_bytes-r      0
     2021-02-13 21:31:20   tx_packets      565
     2021-02-13 21:31:20   tx_power        40
     2021-02-13 21:31:20   tx_rate         433300
     2021-02-13 21:31:20   tx_retries      0
     2021-02-13 21:31:20   uptime          647
     2021-02-13 21:31:20   user_id         601c47515b475b025636c0f4
     2021-02-13 21:31:20   vlan            0
     2021-02-13 21:31:20   wifi_tx_attempts 636
   timeControl:
     clientblocked 0
     maxOnlineMinutesPerDay 2000
     thresholdBytesPerMinute 75000
     usedOnlineTime 64
   unifiClient:
     _f_essid   UNDEFINED
     accesspoint unknown
     oui        XiaomiCo
   event-on-change-reading .*
gruß Marcell
Titel: Antw:[gelöst] Unifi Client (Smartphone) bleibt disconnected
Beitrag von: Kellerkind86 am 14 Februar 2021, 00:14:23
Naja.. Nach nem neustart lief es dann..  ???
