Revision 23752: 98_serviced: add additional argument and attribute to declare the ssh ...
98_serviced: add additional argument and attribute to declare the ssh port if not the default is used, fix retrieve status on define
Source: Revision 23752: 98_serviced: add additional argument and attribute to declare the ssh ... (http://svn.fhem.de/trac/changeset/23752/trunk)
