Ich habe mir 5 zusätzliche Homematic Thermostate gegönnt um meine Heizkörper zu erweitern/steuern wie ich es bereits in 3 Zimmern habe. Der erste Thermostat funktioniert einwandfrei, ist mit dem HK-Ventil gepaired und sieht so aus:
DEF 726575
FUUID 604f6c38-f33f-55a1-9d17-7c619f83ff86e104
IODev WZ_LGW
LASTInputDev WZ_LGW
MSGCNT 73
NAME Therm.EZ
NOTIFYDEV global
NR 326
NTFY_ORDER 50-Therm.EZ
STATE CMDs_done
TYPE CUL_HM
WZ_LGW_MSGCNT 73
WZ_LGW_RAWMSG 050000356A865A726575000000A0E125
WZ_LGW_RSSI -53
WZ_LGW_TIME 2021-03-16 17:07:02
channel_01 Therm.EZ_Weather
channel_02 Therm.EZ_Climate
channel_03 Therm.EZ_WindowRec
channel_06 Therm.EZ_remote
channel_07 Therm.EZ_SwitchTr
lastMsg No:6A - t:5A s:726575 d:000000 A0E125
protLastRcv 2021-03-16 17:07:02
protRcv 73 last_at:2021-03-16 17:07:02
protSnd 3 last_at:2021-03-16 15:45:26
protSndB 1 last_at:2021-03-16 15:45:26
protState CMDs_done
rssi_WZ_LGW cnt:2 min:-41 max:-41 avg:-41 lst:-41
rssi_at_WZ_LGW cnt:73 min:-70 max:-45 avg:-51.87 lst:-53
2021-03-16 15:55:18 Activity alive
2021-03-16 15:45:26 CommandAccepted yes
2021-03-15 15:32:30 D-firmware 1.4
2021-03-15 15:32:30 D-serialNr REQ0838603
2021-03-16 13:06:28 PairedTo 0x061157
2021-03-16 13:06:28 R-btnLock on
2021-03-16 13:06:28 R-burstRx on
2021-03-16 13:06:28 R-cyclicInfoMsg on
2021-03-16 13:06:28 R-cyclicInfoMsgDis 0
2021-03-16 13:06:28 R-globalBtnLock off
2021-03-16 13:06:28 R-localResDis off
2021-03-16 13:06:28 R-lowBatLimitRT 2.2 V
2021-03-16 13:06:28 R-modusBtnLock off
2021-03-16 13:06:28 R-pairCentral 0x061157
2021-03-16 16:59:54 battery ok
2021-03-16 16:59:54 batteryLevel 3.1
2021-03-16 13:45:10 cfgState ok
2021-03-16 15:45:27 commState CMDs_done
2021-03-16 16:59:54 desired-temp 20.0
2021-03-16 16:59:54 measured-temp 22.5
2021-03-16 15:45:27 state CMDs_done
2021-03-15 15:32:46 time-request -
2021-03-16 14:00:38 trigLast fhem:81
helper:
HM_CMDNR 106
cSnd 11061157726575860428,11061157726575860228
mId 00AD
peerFriend
peerOpt -:thermostat
regLst 0
rxType 6
supp_Pair_Rep 0
cmds:
TmplKey :no:1615905920.02312
TmplTs 1615905920.02312
cmdKey 0:1:0::Therm.EZ:00AD:00:
cmdLst:
assignHmKey noArg
clear [(readings|trigger|register|oldRegs|rssi|msgEvents|{msgErrors}|attack|all)]
deviceRename -newName-
fwUpdate -filename- [-bootTime-]
getConfig noArg
getDevInfo noArg
getRegRaw (List0|List1|List2|List3|List4|List5|List6|List7) [-peerChn-]
inhibit [(on|{off})]
raw -data- [...]
regBulk -list-.-peerChn- -addr1:data1- -addr2:data2-...
regSet [(prep|{exec})] -regName- -value- [-peerChn-]
reset noArg
sysTime noArg
tplDel -tplDel-
tplSet_0 -tplChan-
unpair noArg
lst:
condition slider,0,1,255
peer
peerOpt
tplChan
tplDel
tplPeer
rtrvLst:
cmdList [({short}|long)]
deviceInfo [({short}|long)]
list [({normal}|full)]
param -param-
reg -addr- -list- [-peerChn-]
regList noArg
regTable noArg
regVal -addr- -list- [-peerChn-]
saveConfig [-filename-]
tplInfo noArg
expert:
def 1
det 1
raw 0
tpl 0
io:
newChn +726575,00,00,00
nextSend 1615910822.53066
prefIO
rxt 0
vccu VCCU
p:
726575
00
00
00
mRssi:
mNo 6A
io:
WZ_LGW:
-47
-47
peerIDsH:
prt:
awake 0
bErr 0
sProc 0
q:
qReqConf
qReqStat
role:
dev 1
prs 1
rssi:
WZ_LGW:
avg -41
cnt 2
lst -41
max -41
min -41
at_WZ_LGW:
avg -51.8767123287671
cnt 73
lst -53
max -45
min -70
shRegW:
07 02
tmpl:
IODev WZ_LGW
IOgrp VCCU
actCycle 000:10
actStatus alive
autoReadReg 4_reqStatus
expert defReg,allReg
model HM-TC-IT-WM-W-EU
msgRepeat 1
sortby 12
subType thermostat
webCmd getConfig:clear msgEvents
Beim nächsten und übernächsten Thermostat habe ich ein Problem - beide stehen mit CMDs_pending. set <device> clear all zeigt zwar den Status "Info_cleared", aber beim nächsten Command bin ich wieder im CMDs_pending. Hier ein list:
CFGFN
DEF 726558
FUUID 6050cad2-f33f-55a1-dbd3-18e8929a4fa4b533
IODev WZ_LGW
LASTInputDev WZ_LGW
MSGCNT 49
NAME HM_726558
NOTIFYDEV global
NR 440
STATE CMDs_pending
TYPE CUL_HM
WZ_LGW_MSGCNT 49
WZ_LGW_RAWMSG 0500001511847072655800000000F023
WZ_LGW_RSSI -21
WZ_LGW_TIME 2021-03-16 17:12:38
channel_01 HM_726558_Weather
channel_02 HM_726558_Climate
channel_03 HM_726558_WindowRec
channel_06 HM_726558_remote
channel_07 HM_726558_SwitchTr
lastMsg No:11 - t:70 s:726558 d:000000 00F023
protCmdPend 14 CMDs pending
protCondBurst off
protLastRcv 2021-03-16 17:12:38
protRcv 6 last_at:2021-03-16 17:12:38
protSnd 1 last_at:2021-03-16 17:06:42
protSndB 1 last_at:2021-03-16 17:06:42
protState CMDs_pending
rssi_at_WZ_LGW cnt:6 min:-22 max:-21 avg:-21.16 lst:-21
2021-03-16 17:06:42 cfgState updating
2021-03-16 17:06:49 commState CMDs_pending
2021-03-16 17:06:49 state CMDs_pending
cmdStack:
++A00106115772655800040000000000
++A0010611577265580103
++A00106115772655801040000000001
++A0010611577265580203
++A00106115772655802040000000001
++A00106115772655800040000000007
++A00106115772655802040000000008
++A00106115772655802040000000009
++A0010611577265580303
++A00106115772655803040000000001
++A0010611577265580603
++A00106115772655806040000000001
++A0010611577265580703
++A00106115772655807040000000001
helper:
HM_CMDNR 17
PONtest 0
mId 00AD
peerFriend peerSensT
peerOpt p:thermostat
regLst 0,1
rxType 6
supp_Pair_Rep 0
cfgChk:
idPc01 fail
idRc01 .RegL_00.
cmds:
TmplKey :no:1615909344.66226
TmplTs 1615909344.66226
cmdKey 0:1:0::HM_726558:00AD:01:
cmdLst:
assignHmKey noArg
getConfig noArg
getDevInfo noArg
raw -data- [...]
reset noArg
sign [(on|{off})]
sysTime noArg
tplDel -tplDel-
tplSet_0 -tplChan-
unpair noArg
lst:
peer
peerOpt
tplChan
tplDel
tplPeer
rtrvLst:
param -param-
regList noArg
regTable noArg
tplInfo noArg
expert:
def 1
det 1
raw 0
tpl 0
io:
newChn +726558,00,00,00
nextSend 1615911158.7092
prefIO
rxt 0
vccu VCCU
p:
726558
00
00
00
mRssi:
mNo 11
io:
WZ_LGW:
-13
-13
peerIDsH:
prt:
awake 0
bErr 0
brstWu 0
sProc 2
q:
qReqConf
qReqStat
role:
dev 1
rssi:
at_WZ_LGW:
avg -21.1666666666667
cnt 6
lst -21
max -21
min -22
shRegW:
07 02
tmpl:
IODev WZ_LGW
IOgrp VCCU
actCycle 000:10
actStatus alive
firmware 1.4
msgRepeat 1
room CUL_HM
serialNr REQ0838632
subType thermostat
Irgendwelche Ideen ? Danke !
Meine VCCU (WZ_LGW) ist übrigens eine eQ3-HM-LGW
keine anzeichen eines pairings zu sehen.
also clear msgEvents und dann "drüberpairen", nichts löschen oder resetten.
liegen die beiden aufeinander?
Zitatrssi_at_WZ_LGW cnt:6 min:-22 max:-21 avg:-21.16 lst:-21
man sagt ja immer: zu nah ist auch nicht gut... ;)
Zitat von: Otto123 am 16 März 2021, 19:06:05
liegen die beiden aufeinander?man sagt ja immer: zu nah ist auch nicht gut... ;)
ca. 50cm auseinander (CUL unter dem Schreibtisch, der Thermostat auf dem Schreibtisch). Werd mal "auf Distanz gehen" und Frank's Vgw. befolgen.
Danke !! Kaum macht man's richtig funktioniert's auch schon !! :)
