im Log habe ich derzeit folgendes Pearl Warning, welches, wenn ich es richtig interpretiere von einem Fritz Device kommt:
2021.03.29 13:41:47 1: PERL WARNING: Argument "100 %" isn't numeric in numeric lt (<) at (eval 27456660) line 1.
2021.03.29 13:41:47 1: stacktrace:
2021.03.29 13:41:47 1: main::__ANON__ called by (eval 27456660) (1)
2021.03.29 13:41:47 1: (eval) called by ./FHEM/33_readingsGroup.pm (357)
2021.03.29 13:41:47 1: main::lookup2 called by ./FHEM/33_readingsGroup.pm (1445)
2021.03.29 13:41:47 1: main::readingsGroup_Notify called by fhem.pl (3847)
2021.03.29 13:41:47 1: main::CallFn called by fhem.pl (3764)
2021.03.29 13:41:47 1: main::DoTrigger called by fhem.pl (4144)
2021.03.29 13:41:47 1: main::Dispatch called by ./FHEM/00_FBAHAHTTP.pm (165)
2021.03.29 13:41:47 1: main::__ANON__ called by FHEM/HttpUtils.pm (639)
2021.03.29 13:41:47 1: main::__ANON__ called by fhem.pl (770)
Ich vermute, dass es um das Thermostat geht, wo solch ein Wert bei Battery vorkommt.
Hier das List:
DEF FritzDECT:0xxxxxxx actuator,tempSensor
FUUID 605122c9-f33f-45fc-706e-a498e1dd8a7f6037
FritzDECT_MSGCNT 2497
FritzDECT_TIME 2021-03-29 13:51:47
IODev FritzDECT
LASTInputDev FritzDECT
MSGCNT 2497
NAME Bastelraum_Heizung
NR 496
STATE desired-temp: 17.0 C
TYPE FBDECT
id 0xxxxxx
props actuator,tempSensor
webCmd desired-temp
.attraggr:
.attrminint:
power:120
2021-03-29 13:51:47 AIN 0xxxxxxx
2021-03-29 13:51:47 FBNAME FRITZ!DECT 301 #1
2021-03-29 13:51:47 FBPROP actuator,tempSensor
2021-03-29 13:51:47 FBTYPE FRITZ!DECT 301
2021-03-29 13:51:47 ID 16
2021-03-29 13:51:47 battery 100 %
2021-03-29 13:51:47 batteryPercent 100
2021-03-29 13:51:47 batteryState ok
2021-03-29 13:51:47 batterylow 0
2021-03-29 13:51:47 boostactive no
2021-03-29 13:51:47 boostactiveendtime N/A
2021-03-29 13:51:47 day-temp 21.0 C
2021-03-29 13:51:47 desired-temp 17.0 C
2021-03-29 13:51:47 devicelock no
2021-03-29 13:51:47 errorcode noError (0)
2021-03-29 13:51:47 fwversion 04.94
2021-03-29 13:51:47 holidayactive no
2021-03-29 13:51:47 locked no
2021-03-29 13:51:47 nextPeriodStart 1970-01-01 01:00:00
2021-03-29 13:51:47 nextPeriodTemp 21.0 C
2021-03-29 13:51:47 night-temp 16.0 C
2021-03-29 13:51:47 present yes
2021-03-29 13:51:47 state desired-temp: 17.0 C
2021-03-29 13:51:47 summeractive no
2021-03-29 13:51:47 tempadjust 0.0 C
2021-03-29 13:51:47 temperature 17.5 C (measured)
2021-03-29 13:51:47 windowopenactiv no
2021-03-29 13:51:47 windowopenactiveendtime N/A
IODev FritzDECT
event-min-interval power:120
room Bastelraum,Fritz
Ist das % Zeichen einfach falsch beim Battery Reading und müsste ins Reading Battery Percentage?
Wie lässt sich der Fehler beheben?
Udomatic
Das duerfte ein readingsGroup-Konfigurations-Problem sein.
Ich gehe davon aus, dass man da spezifizieren kann, dass die Zahl extrahiert werden soll, analog zu der ReadingsNum FHEM-Hilfsfunktion.
Ich habe leider nicht verstanden ob und wie ich das lösen kann oder muss das vom Modul Entwickler umgesetzt werden?
Ich gehe davon aus, dass das ein Konfigurationparameter ist.
Gib doch mal bitte ein "list" von der readingsGroup - da wird vermutlich irgendwo das "battery" Reading (das mit dem % im Wert) als Zahl behandelt.
Also wenn ich eine ReadingsGroup auf battery erstelle ist das besagte Device
Bastelraum_Heizung das einzige, was ein %-Zeichen im String hat. Das muss wohl raus?!
Zitat von: Udomatic am 29 März 2021, 18:16:15
Also wenn ich eine ReadingsGroup auf battery erstelle ist das besagte Device Bastelraum_Heizung das einzige, was ein %-Zeichen im String hat. Das muss wohl raus?!
Mach doch bitte ein list vom readingsGroup-Device, keinen Screenshot.
Habe bisher nicht mit readingsGroup gearbeitet. Was muss ich genau tun bzw. Abfragen damit die gewünschte Liste raus kommt?
Wenn ich eine readingsGroup auf das Reading Battery erstelle kommt eine riesen Liste dabei raus. Ist das mit readings-Group vom Device gemeint?
Was wird bei:
list TYPE=readingsGroup
angezeigt.
Eines von den angezeigten Devices müsste es sein, bzw. davon eben das list...
Gruß, Joachim
Zitat von: MadMax-FHEM am 29 März 2021, 23:11:07
Was wird bei:
angezeigt.
Gruß, Joachim
Hallo Joachim,
das ergibt folgende Übersicht.
Ich nehme an dann vom batteries Device ein List? Kann ich dir das per PN senden?
Ich möchte ehrlich gesagt nicht die ganze Liste der batteries readingsGroup hier öffentlich machen, weil ich wirklich viele Devices habe!
Danke für die Unterstützung!
Bitte keine Screen Shots!
Was steht denn "Geheimes" in der readingsGroup?
Doch maximal wie sie definiert ist und wie die Geräte/Devices heißen, deren Readungs (battery) du anzeigen willst!?
Ich kann mit dem list nichts anfangen...
Ich hab nur bzgl. "welches list" und "wie kommt man da dran" geholfen...
Gruß, Joachim
Mach doch mal ein "list batteries" - das Ergebnis kannst du dir in Ruhe erstmal selbst anschauen und immer noch entscheiden, ob es irgendwelche Geheimnisse enthält, die du nicht mit uns teilen möchtest.
Wenn du dann herausfindet, dass du es posten kannst, dann bitte als Text in Code Tags.
Gruß, Joachim
Hier das List batteries
Edit 03.04.2021 --> List gelöscht, da keine Aussagekraft
Hat zwar jetzt nichts mit deinem Problem zu tun...
...aber, dass du einige Devices (vermutlich: Homematic Wandthermostat und Homematic Heizkörperthermostat) mehrfach in der readingsGroup aufgeführt hast weißt du?
"Quote gelöscht"
Wo machst du aus "ok" eine 1?
Warum hast du die Attribute nicht mit gepostet (da passiert das verm.)!?
Weil ich nehme an genau da passiert der "Fehler"... ;)
Ist das nicht etwas (sehr) unübersichtlich?
Ups, da hab ich mich wohl vertan ;)
Aber ich nutze zwar readingsGroup, hab mir aber noch kein list davon (zu "debug-Zwecken" ausgeben lassen ;) )...
EDIT: aber trotzdem: warum hast du keine Attribute gepostet? Oder nutzt du tatsächlich keine?
Ich nutze für meine Batterieübersicht ja das hier: https://forum.fhem.de/index.php/topic,82637.msg747514.html#msg747514
(da lässt sich das mit % und nicht % sehr einfach lösen ;) Ist aber nat. etwas "aufwändiger" als "nur" eine readingsGroup ;) )
Wobei ich ja auch mit deiner Meinung (von ganz zu beginn) "mitgehe", dass ein % bei dem Reading battery eigentlich nichts zu suchen hat!?
EDIT: wenn das vom "Original-Device" stammt und auch von dem darunter liegenden Modul so gemacht wird/wurde... Und jetzt bin ich besser wieder ruhig 8)
Gruß, Joachim
Wobei ich ja auch mit deiner Meinung (von ganz zu beginn) "mitgehe", dass ein % bei dem Reading battery eigentlich nichts zu suchen hat!?EDIT: wenn das vom "Original-Device" stammt und auch von dem darunter liegenden Modul so gemacht wird/wurde... Und jetzt bin ich besser wieder ruhig 8)
Gruß, Joachim
Mehr spuckt das list batteries eben nicht aus. Deshalb war auch meine Frage, was die lange Liste jetzt nutzt?
Und ja, das list im ertsten Post ist natürlich vom betroffene Device.
EDIT: aber nicht mal ein "Raum-Attribut? Wozu ist die readingsGroup dann nutze, wenn du nicht mal weißt, dass du sie hast ;) (sonst hätte ich ja nicht "erklären müssen" wie du sie "finden kannst" ;) Und sie auch nicht "leicht" aufmachen kannst? Aber: das sei dir überlassen)
Ich habe mich ja schon geoutet als "nicht readingsGroup-Debugger" ;)
Angefragt wurde das list ja hier: https://forum.fhem.de/index.php/topic,119982.msg1144284.html#msg1144284
Mal abwarten...
Gruß, Joachim
Die lange Liste sollte ausschließen, dass da irgendwelche Attribute der readingsGroup (valueFormat, ...) etwas spezielles im Bezug auf das reading machen. Du benutzt aber wohl offensichtlich eine einfache readingsGroup, die Deine gesamte FHEM Konfiguration auf readings, die im Namen "battery" enthalten. Daher die sehr lange Liste.
Das FBDECT Modul scheint wirklich in das reading battery das Prozentzeichen reinzuschreiben - und da readingsGroup wohl von numerischen Werten ausgeht, führt das zu der beobachteten Warnung.
Da nicht davon auszugehen ist, dass die Darstellung im FBDECT Modul geändert wird, könntest Du versuchen, mit Hilfe des readingsGroup Attributs valueFormat eine andere Darstellung bewirken - ich bezweifle allerdings, dass eine Warnung in einer so generellen readingsGroup diesen Aufwand rechtfertigt.
Es scheint nicht nur so, es ist auch so, Zeile 414 (https://svn.fhem.de/trac/browser/trunk/fhem/FHEM/10_FBDECT.pm#L414):
battery => 'sprintf("battery:%s %%", $val)',
Ich kenn den Stand der Diskussion über die kanonischen Batterie-Readings nicht, aber vielleicht stupst du mal Rudi an.
ich behaupte mal die meldung kommt nicht von der geposteten readingsGroup.
zeig mal die ausgabe von list TYPE=readingsGroup DEF
Ich verweise dann gerne einmal auf:
https://wiki.fhem.de/wiki/DevelopmentGuidelines#Einheitendarstellung
https://forum.fhem.de/index.php?topic=21247.0
https://forum.fhem.de/index.php?topic=68431.0
https://forum.fhem.de/index.php?topic=70634.0
https://forum.fhem.de/index.php?topic=44946.0
mal sehen für Diskussion ihr Euch entscheidet.
Grüße Jörg
Die Formulierung im Wiki ist nicht ganz richtig, insb. das Wort "nur" ist falsch. Der Wertebereich von batteryPercent, batteryState und batteryVoltage ist standardisiert. battery wurde haeufig von den Modulen vor der Standardisierung verwendet, und wir wollten die alten Benutzer nicht aergern, insofern bleibt es unveraendert.
Das FBDECT Modul generiert neben dem "alten" battery Reading die damals vereinbarten batteryPercent und batteryState.
Vielen Dank für die bisherigen Kommentare und Inputs. Was bedeutet das jetzt für die Lösung des Problems?
ZitatWas bedeutet das jetzt für die Lösung des Problems?
- "offiziell" ist battery das falsche Reading, man sollte stattdessen einen der vereinbarten verwenden (siehe Wiki-Link)
- ich habe nach der oben gezeigten Definition ein readingsGroup angelegt, und hatte kein Problem mit "battery 100 %".
- laut Stacktrace wurde das Problem bei der Evaluierung eines valueFormat readingsGroup Attributes ausgeloest, leider wurde dieses Attribut uns in der Listing verschwiegen. Ich rate: im Attribut wird "$VAL < " verwendet, statt "$NUM < ".
Die Ursache ist also weder das FBDECT, noch das readingsGroup Modul, sondern ein vom Benutzer definiertes Attribut.
Vielen Dank für die Unterstützung. Habe es verstanden. Es gab noch eine zweite Batteries readingsGroup. Habe diese gelöscht und seitdem ist der Fehler wohl Geschichte
