hallo martin,
die nutzung von "none" erzeugt fehler in hminfo configcheck:
configCheck done:
IOgrp: prefered IO undefined
DimUP01: ->none
SwitchUP02: ->none
.triggerUsed 1
DEF 1F64D8
FUUID 5c4ce2ea-f33f-09c4-5ec8-5dcb4e1b70f7b4d5
IODev hmlan1
LASTInputDev hmlan1
MSGCNT 4
NAME DimUP01
NOTIFYDEV global
NR 359
NTFY_ORDER 50-DimUP01
STATE off
TYPE CUL_HM
chanNo 01
cul868_MSGCNT 2
cul868_RAWMSG A0EDC80021F64D81ACE1F0101000039::-56.5:cul868
cul868_RSSI -56.5
cul868_TIME 2021-04-15 09:57:50
hmlan1_MSGCNT 2
hmlan1_RAWMSG RD4894994,0001,AD68705B,FF,FFC8,DC80021F64D81ACE1F0101000039
hmlan1_RSSI -56
hmlan1_TIME 2021-04-15 09:57:50
lastMsg No:DC - t:02 s:1F64D8 d:1ACE1F 0101000039
peerList SwitchPBU01_Btn_01,self01
protLastRcv 2021-04-15 09:57:50
protRcv 2 last_at:2021-04-15 09:57:50
protSnd 2 last_at:2021-04-15 09:57:50
protState CMDs_done
rssi_at_cul868 cnt:2 min:-56.5 max:-56.5 avg:-56.5 lst:-56.5
rssi_at_hmlan1 cnt:2 min:-57 max:-56 avg:-56.5 lst:-56
rssi_hmlan1 cnt:2 min:-57 max:-57 avg:-57 lst:-57
.attraggr:
.attreocr:
.attreour:
trigLast
.attrminint:
.attrtocr:
CL:
Authenticated 0
BUF
FD 87
FW_ID 2079
LASTACCESS 1618478338
NAME WEB_192.168.1.31_50166
NR 2117
PEER 192.168.1.31
PORT 50166
SNAME WEB
SSL
STATE Connected
TEMPORARY 1
TYPE FHEMWEB
canAsyncOutput 1
.attraggr:
.attrminint:
2021-04-15 11:18:52 state Connected
2021-04-15 09:57:33 .associatedWith DimUP01,DimUP01,SwitchPBU01_Btn_01
2021-04-08 19:40:33 .peerListRDate 2021-04-08 19:40:33
2021-04-15 09:57:50 .protLastRcv 20210415095750
2021-03-23 13:08:49 Activity alive
2021-03-23 13:04:55 CommandAccepted yes
from archivexx D-firmware 2.1
from archivexx D-serialNr KEQ0001853
2021-03-23 13:04:39 PairedTo 0x1ACE1F
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgActionTypeDim toggleDim
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgCtDlyOff geLo
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgCtDlyOn geLo
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgCtOff geLo
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgCtOn geLo
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgCtRampOff geLo
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgCtRampOn geLo
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgCtValHi 100
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgCtValLo 50
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgDimJtDlyOff rampOff
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgDimJtDlyOn rampOn
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgDimJtOff dlyOn
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgDimJtOn dlyOff
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgDimJtRampOff off
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgDimJtRampOn on
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgDimMaxLvl 100 %
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgDimMinLvl 0 %
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgDimStep 10 %
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgMultiExec on
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgOffDly 0 s
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgOffDlyBlink on
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgOffDlyNewTime 0.4 s
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgOffDlyOldTime 0.4 s
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgOffDlyStep 5 %
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgOffLevel 0 %
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgOffTime unused
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgOffTimeMode absolut
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgOnDly 0 s
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgOnDlyMode setToOff
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgOnLevel 100 %
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgOnLvlPrio high
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgOnMinLevel 10 %
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgOnTime unused
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgOnTimeMode absolut
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgRampOffTime 0.5 s
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgRampOnTime 0.5 s
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-lgRampSstep 10 %
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shActionTypeDim jmpToTarget
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shCtDlyOff geLo
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shCtDlyOn geLo
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shCtOff geLo
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shCtOn geLo
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shCtRampOff geLo
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shCtRampOn geLo
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shCtValHi 100
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shCtValLo 50
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shDimJtDlyOff rampOff
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shDimJtDlyOn rampOn
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shDimJtOff dlyOn
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shDimJtOn dlyOff
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shDimJtRampOff off
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shDimJtRampOn on
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shDimMaxLvl 100 %
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shDimMinLvl 0 %
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shDimStep 5 %
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shMultiExec off
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shOffDly 0 s
2021-04-08 19:40:35 R-SwitchPBU01_Btn_01-shOffDlyBlink off
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shOffDlyNewTime 0.4 s
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shOffDlyOldTime 0.4 s
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shOffDlyStep 5 %
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shOffLevel 0 %
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shOffTime unused
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shOffTimeMode absolut
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shOnDly 0 s
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shOnDlyMode setToOff
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shOnLevel 80 %
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shOnLvlPrio high
2021-04-08 19:40:35 R-SwitchPBU01_Btn_01-shOnMinLevel 0 %
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shOnTime unused
2021-04-08 19:02:54 R-SwitchPBU01_Btn_01-shOnTimeMode absolut
2021-04-08 19:40:35 R-SwitchPBU01_Btn_01-shRampOffTime 1 s
2021-04-08 19:40:35 R-SwitchPBU01_Btn_01-shRampOnTime 1 s
2021-04-08 19:40:35 R-SwitchPBU01_Btn_01-shRampSstep 0 %
2021-04-08 19:40:32 R-confBtnTime 10 min
2021-04-08 19:02:54 R-fuseDelay 1 s
2021-04-08 19:02:54 R-intKeyVisib visib
2021-04-08 19:02:54 R-ovrTempLvl 80 C
2021-04-08 19:02:54 R-pairCentral 0x1ACE1F
2021-04-08 19:02:54 R-powerUpAction off
2021-04-08 19:02:54 R-redLvl 40 %
2021-04-08 19:02:54 R-redTempLvl 75 C
2021-04-08 19:02:54 R-self01-lgActionTypeDim jmpToTarget
2021-04-08 19:02:54 R-self01-lgCtDlyOff geLo
2021-04-08 19:02:54 R-self01-lgCtDlyOn geLo
2021-04-08 19:02:54 R-self01-lgCtOff geLo
2021-04-08 19:02:54 R-self01-lgCtOn geLo
2021-04-08 19:02:54 R-self01-lgCtRampOff geLo
2021-04-08 19:02:54 R-self01-lgCtRampOn geLo
2021-04-08 19:02:54 R-self01-lgCtValHi 100
2021-04-08 19:02:54 R-self01-lgCtValLo 50
2021-04-08 19:40:36 R-self01-lgDimJtDlyOff rampOff
2021-04-08 19:40:36 R-self01-lgDimJtDlyOn rampOff
2021-04-08 19:40:36 R-self01-lgDimJtOff rampOff
2021-04-08 19:40:36 R-self01-lgDimJtOn rampOff
2021-04-08 19:40:36 R-self01-lgDimJtRampOff off
2021-04-08 19:40:36 R-self01-lgDimJtRampOn dlyOff
2021-04-08 19:02:54 R-self01-lgDimMaxLvl 100 %
2021-04-08 19:02:54 R-self01-lgDimMinLvl 0 %
2021-04-08 19:02:54 R-self01-lgDimStep 5 %
2021-04-08 19:40:36 R-self01-lgMultiExec off
2021-04-08 19:02:54 R-self01-lgOffDly 0 s
2021-04-08 19:40:36 R-self01-lgOffDlyBlink off
2021-04-08 19:02:54 R-self01-lgOffDlyNewTime 0.4 s
2021-04-08 19:02:54 R-self01-lgOffDlyOldTime 0.4 s
2021-04-08 19:02:54 R-self01-lgOffDlyStep 5 %
2021-04-08 19:02:54 R-self01-lgOffLevel 0 %
2021-04-08 19:02:54 R-self01-lgOffTime unused
2021-04-08 19:02:54 R-self01-lgOffTimeMode absolut
2021-04-08 19:02:54 R-self01-lgOnDly 0 s
2021-04-08 19:02:54 R-self01-lgOnDlyMode setToOff
2021-04-08 19:40:36 R-self01-lgOnLevel 100 %
2021-04-08 19:02:54 R-self01-lgOnLvlPrio high
2021-04-08 19:40:36 R-self01-lgOnMinLevel 0 %
2021-04-08 19:02:54 R-self01-lgOnTime unused
2021-04-08 19:02:54 R-self01-lgOnTimeMode absolut
2021-04-08 19:02:54 R-self01-lgRampOffTime 0.5 s
2021-04-08 19:02:54 R-self01-lgRampOnTime 0.5 s
2021-04-08 19:40:36 R-self01-lgRampSstep 0 %
2021-04-08 19:02:54 R-self01-shActionTypeDim jmpToTarget
2021-04-08 19:02:54 R-self01-shCtDlyOff geLo
2021-04-08 19:02:54 R-self01-shCtDlyOn geLo
2021-04-08 19:02:54 R-self01-shCtOff geLo
2021-04-08 19:02:54 R-self01-shCtOn geLo
2021-04-08 19:02:54 R-self01-shCtRampOff geLo
2021-04-08 19:02:54 R-self01-shCtRampOn geLo
2021-04-08 19:02:54 R-self01-shCtValHi 100
2021-04-08 19:02:54 R-self01-shCtValLo 50
2021-04-08 19:02:54 R-self01-shDimJtDlyOff rampOn
2021-04-08 19:02:54 R-self01-shDimJtDlyOn rampOn
2021-04-08 19:40:36 R-self01-shDimJtOff rampOn
2021-04-08 19:02:54 R-self01-shDimJtOn rampOn
2021-04-08 19:40:36 R-self01-shDimJtRampOff dlyOn
2021-04-08 19:02:54 R-self01-shDimJtRampOn on
2021-04-08 19:02:54 R-self01-shDimMaxLvl 100 %
2021-04-08 19:02:54 R-self01-shDimMinLvl 0 %
2021-04-08 19:02:54 R-self01-shDimStep 5 %
2021-04-08 19:02:54 R-self01-shMultiExec off
2021-04-08 19:02:54 R-self01-shOffDly 0 s
2021-04-08 19:40:36 R-self01-shOffDlyBlink off
2021-04-08 19:02:54 R-self01-shOffDlyNewTime 0.4 s
2021-04-08 19:02:54 R-self01-shOffDlyOldTime 0.4 s
2021-04-08 19:02:54 R-self01-shOffDlyStep 5 %
2021-04-08 19:02:54 R-self01-shOffLevel 0 %
2021-04-08 19:02:54 R-self01-shOffTime unused
2021-04-08 19:02:54 R-self01-shOffTimeMode absolut
2021-04-08 19:02:54 R-self01-shOnDly 0 s
2021-04-08 19:02:54 R-self01-shOnDlyMode setToOff
2021-04-08 19:40:36 R-self01-shOnLevel 50 %
2021-04-08 19:02:54 R-self01-shOnLvlPrio high
2021-04-08 19:40:36 R-self01-shOnMinLevel 0 %
2021-04-08 19:02:54 R-self01-shOnTime unused
2021-04-08 19:02:54 R-self01-shOnTimeMode absolut
2021-04-08 19:02:54 R-self01-shRampOffTime 0.5 s
2021-04-08 19:02:54 R-self01-shRampOnTime 0.5 s
2021-04-08 19:40:36 R-self01-shRampSstep 0 %
2021-04-08 19:02:54 R-statusInfoMinDly 2 s
2021-04-08 19:40:33 R-statusInfoRandom 0 s
2021-04-08 19:02:54 R-transmitTryMax 6
2021-04-08 19:40:32 RegL_00. 00:00 02:81 0A:1A 0B:CE 0C:1F 15:0A 16:00
2021-04-08 19:40:32 RegL_01. 00:00 30:06 32:50 33:64 34:4B 35:50 56:00 57:04
2021-04-08 19:40:34 RegL_03.SwitchPBU01_Btn_01 00:00 01:00 02:00 03:00 04:32 05:64 06:00 07:FF 08:00 09:FF 0A:01 0B:14 0C:52 0D:63 0E:00 0F:00 10:00 11:A0 12:00 13:0A 14:0A 15:00 16:C8 17:0A 18:0A 19:04 1A:04 81:00 82:00 83:00 84:32 85:64 86:00 87:FF 88:00 89:FF 8A:26 8B:14 8C:52 8D:63 8E:20 8F:00 90:14 91:C8 92:14 93:05 94:05 95:00 96:C8 97:14 98:0A 99:04 9A:04
2021-04-08 19:40:36 RegL_03.self01 00:00 01:00 02:00 03:00 04:32 05:64 06:00 07:FF 08:00 09:FF 0A:01 0B:22 0C:22 0D:13 0E:00 0F:00 10:00 11:64 12:00 13:05 14:05 15:00 16:C8 17:0A 18:0A 19:04 1A:04 81:00 82:00 83:00 84:32 85:64 86:00 87:FF 88:00 89:FF 8A:01 8B:55 8C:55 8D:64 8E:00 8F:00 90:00 91:C8 92:00 93:05 94:05 95:00 96:C8 97:0A 98:0A 99:04 9A:04
2021-04-08 19:41:54 cfgState IOGrpPref
2021-04-15 09:57:50 commState CMDs_done
2021-04-08 13:28:50 deviceMsg off (to ccu)
2021-04-08 13:28:50 dim stop:off
2021-04-15 06:11:32 inhibit set_on
2021-04-08 13:28:50 level 0
2021-03-23 13:04:26 overheat off
2021-03-23 13:04:26 overload off
2021-04-08 13:28:50 pct 0
2021-04-15 09:57:33 peerList SwitchPBU01_Btn_01,self01
2021-04-13 08:46:37 recentStateType ack
2021-03-23 13:04:26 reduced off
2021-04-15 09:57:49 state off
2021-03-23 13:04:26 timedOn off
- tmpl_SwitchPBU01_Btn_01:short toggleMaxMin_dimmer:maxLevel:80 minLevel:0 rampTime:1,
- tmpl_self01:long switchToOffLevel_dimmer:offLevel:0 rampTime:0.5,
- tmpl_self01:short switchToOnLevel_dimmer:onLevel:50 rampTime:0.5,
2021-04-15 09:57:50 trigLast fhem:02
2021-03-25 05:22:37 trig_SwitchPBU01_Btn_01 Short_147
helper:
HM_CMDNR 220
cSnd 111ACE1F1F64D80101,111ACE1F1F64D80201000000
dlvlCmd ++A0111ACE1F1F64D80201000000
mId 0057
peerFriend peerSens,peerVirt
peerIDsState complete
peerOpt 3:dimmer
regLst 0,1,3p
rxType 1
supp_Pair_Rep 0
tmplChg 0
cfgChk:
idPc04 ->none
cmds:
TmplKey SwitchPBU01_Btn_01,self01:1618473461.31187:1618473462.76474
TmplTs 1618473462.76474
cmdKey 1:1:0::DimUP01:0057:01:SwitchPBU01_Btn_01,self01
cmdLst:
assignHmKey noArg
clear [(readings|trigger|register|oldRegs|rssi|msgEvents|{msgErrors}|attack|all)]
deviceRename -newName-
down 'change:'[(0..100;1|{10})] [(-ontime-|{0})] [(-ramptime-|{2.4})] 'ontime: 0 = forever'
eventL -peer- -cond-
eventS -peer- -cond-
fwUpdate -filename- [-bootTime-]
getConfig noArg
getDevInfo noArg
getRegRaw (List0|List1|List2|List3|List4|List5|List6|List7) [-peerChn-]
getVersion noArg
inhibit [(on|{off})]
off noArg
old noArg
on noArg
on-for-timer -ontime- [(-ramptime-|{})]
on-till -time- [(-ramptime-|{})]
pair noArg
pct (-value-|old) [(-ontime-|{0})] [(-ramptime-|{2.4})] 'ontime: 0 = forever'
peerBulk -peer1,peer2,...- [({set}|unset)]
peerIODev [IO] -btn- [({set}|unset)] 'not for future use'
peerSmart -peerOpt-
press [(long|{short})] [(-peer-|{self01})] [(-repCount-|{0})] [(-repDelay-|{0.25})]
pressL [(-peer-|{self01})]
pressS [(-peer-|{self01})]
raw -data- [...]
regBulk -list-.-peerChn- -addr1:data1- -addr2:data2-...
regSet [(prep|{exec})] -regName- -value- [-peerChn-]
reset noArg
sign [(on|{off})]
statusRequest noArg
stop noArg
toggle noArg
tplDel -tplDel-
tplPara000_SwitchPBU01_Btn_01_short_toggleMaxMin_dimmer_maxLevel -value-
tplPara001_SwitchPBU01_Btn_01_short_toggleMaxMin_dimmer_minLevel -value-
tplPara002_SwitchPBU01_Btn_01_short_toggleMaxMin_dimmer_rampTime -value-
tplPara010_self01_long_switchToOffLevel_dimmer_offLevel -value-
tplPara011_self01_long_switchToOffLevel_dimmer_rampTime -value-
tplPara020_self01_short_switchToOnLevel_dimmer_onLevel -value-
tplPara021_self01_short_switchToOnLevel_dimmer_rampTime -value-
tplSet_0 -tplChan-
tplSet_SwitchPBU01_Btn_01 -tplPeer-
tplSet_self01 -tplPeer-
unpair noArg
up 'change:'[(0..100;1|{10})] [(-ontime-|{0})] [(-ramptime-|{2.4})] 'ontime: 0 = forever'
lst:
condition slider,0,1,255
peer SwitchPBU01_Btn_01,self01
peerOpt Fenster.Bad,SDTeam_Btn1,SwitchES01_SenF,SwitchES01_SenI,SwitchES01_SenPwr,SwitchES01_SenU,SwitchPBU01_Btn_01,SwitchPBU01_Btn_02,Tuer.SZ,Tuer.WZ.Terrasse,VentilControler.AZ.Nord_Btn1,VentilControler.AZ.West_Btn1,VentilControler.Bad_Btn1,VentilControler.Kueche_Btn1,VentilControler.SZ_Btn1,VentilControler.WZ_Btn1,ccu_Btn1,ccu_Btn2,ccu_Btn3,ccu_Btn4,ccu_Btn5,rssi_hmuart_Btn1,virtAktorAlarmOff_Btn1
tplChan ES_00,tplCheck
tplDel self01:short>switchToOnLevel_dimmer,SwitchPBU01_Btn_01:short>toggleMaxMin_dimmer,self01:long>switchToOffLevel_dimmer
tplPeer DimOff_long,DimOff_short,DimOn_long,DimOn_short,SwCondAbove_long,SwCondAbove_short,SwCondBelow_long,SwCondBelow_short,SwOnCond_long,SwOnCond_short,dimUpToMaxLevel_dimmer_onlyLong,motionOnDim_long,motionOnDim_short,switchToOffLevel_dimmer_long,switchToOffLevel_dimmer_short,switchToOnLevel_dimmer_long,switchToOnLevel_dimmer_short,toggleMaxMin_dimmer_long,toggleMaxMin_dimmer_short
rtrvLst:
cmdList [({short}|long)]
deviceInfo [({short}|long)]
list [({normal}|full)]
param -param-
reg -addr- -list- [-peerChn-]
regList noArg
regTable noArg
regVal -addr- -list- [-peerChn-]
saveConfig [-filename-]
tplInfo noArg
dir:
cur stop
expert:
def 1
det 1
raw 1
tpl 1
io:
flgs 0
newChn +1F64D8,00,00,00
nextSend 1618473470.62483
rxt 0
vccu ccu
p:
1F64D8
00
00
00
prefIO:
hmlan1
none
mRssi:
mNo DC
io:
cul868:
-56.5
-56.5
hmlan1:
-50
-50
hmuart1:
hmusb1:
peerIDsH:
00000000 broadcast
1F64D801 self01
266EA501 SwitchPBU01_Btn_01
prt:
bErr 0
sProc 0
q:
qReqConf
qReqStat
role:
chn 1
dev 1
prs 1
rssi:
at_cul868:
avg -56.5
cnt 2
lst -56.5
max -56.5
min -56.5
at_hmlan1:
avg -56.5
cnt 2
lst -56
max -56
min -57
hmlan1:
avg -57
cnt 2
lst -57
max -57
min -57
shadowReg:
tmpl:
SwitchPBU01_Btn_01:short>toggleMaxMin_dimmer 80 0 1
self01:long>switchToOffLevel_dimmer 0 0.5
self01:short>switchToOnLevel_dimmer 50 0.5
.mId 0059
IODev hmlan1
IOgrp ccu:hmlan1,none
actCycle 024:00
actStatus alive
alias Fluter_Terrasse
autoReadReg 5_readMissing
event-on-change-reading .*
event-on-update-reading trigLast
expert defReg,allReg,rawReg,templ
firmware 2.1
group Beleuchtung
model HM-LC-DIM1T-FM
peerIDs 00000000,1F64D801,266EA501
room 02_handy,70_Garten_Licht
serialNr KEQ0001853
subType dimmer
timestamp-on-change-reading .*
webCmd :
edit:
mit dieser änderung von zeile 764 in HMinfo_paramCheck bekomme ich keine fehlermeldungen mehr:
push @perfIoUndef,"$eName:\t ->$_" foreach ( grep {!$defs{$_} && $_ ne "none"} @pIOa);
