Hallo zusammen.
Nach heutigem Update wird das LOG vollgeschrieben. Habe mal stacktrace aktiviert.
Hoffe es hilft weiter.
2021.10.10 17:50:50 1: stacktrace:
2021.10.10 17:50:50 1: main::__ANON__ called by fhem.pl (4987)
2021.10.10 17:50:50 1: main::readingsBulkUpdate called by ./FHEM/10_MQTT2_DEVICE.pm (190)
2021.10.10 17:50:50 1: main::MQTT2_DEVICE_Parse called by fhem.pl (4091)
2021.10.10 17:50:50 1: main::Dispatch called by ./FHEM/00_MQTT2_SERVER.pm (507)
2021.10.10 17:50:50 1: main::MQTT2_SERVER_doPublish called by ./FHEM/00_MQTT2_SERVER.pm (389)
2021.10.10 17:50:50 1: main::MQTT2_SERVER_Read called by ./FHEM/00_MQTT2_SERVER.pm (459)
2021.10.10 17:50:50 1: main::__ANON__ called by fhem.pl (3427)
2021.10.10 17:50:50 1: main::HandleTimeout called by fhem.pl (695)
2021.10.10 17:50:56 1: PERL WARNING: Argument ".*" isn't numeric in numeric lt (<) at fhem.pl line 4989.
2021.10.10 17:50:56 1: stacktrace:
2021.10.10 17:50:56 1: main::__ANON__ called by fhem.pl (4987)
2021.10.10 17:50:56 1: main::readingsBulkUpdate called by ./FHEM/10_MQTT2_DEVICE.pm (190)
2021.10.10 17:50:56 1: main::MQTT2_DEVICE_Parse called by fhem.pl (4091)
2021.10.10 17:50:56 1: main::Dispatch called by ./FHEM/00_MQTT2_SERVER.pm (507)
2021.10.10 17:50:56 1: main::MQTT2_SERVER_doPublish called by ./FHEM/00_MQTT2_SERVER.pm (389)
2021.10.10 17:50:56 1: main::MQTT2_SERVER_Read called by fhem.pl (3895)
2021.10.10 17:50:56 1: main::CallFn called by fhem.pl (773)
2021.10.10 17:50:58 3: mapleCUL433: Unknown CUL_REDIRECT device detected, define one to get detailed information.
2021.10.10 17:51:00 1: PERL WARNING: Argument ".*" isn't numeric in numeric lt (<) at fhem.pl line 4989.
2021.10.10 17:51:00 1: stacktrace:
2021.10.10 17:51:00 1: main::__ANON__ called by fhem.pl (4987)
2021.10.10 17:51:00 1: main::readingsBulkUpdate called by ./FHEM/10_MQTT2_DEVICE.pm (190)
2021.10.10 17:51:00 1: main::MQTT2_DEVICE_Parse called by fhem.pl (4091)
2021.10.10 17:51:00 1: main::Dispatch called by ./FHEM/00_MQTT2_SERVER.pm (507)
2021.10.10 17:51:00 1: main::MQTT2_SERVER_doPublish called by ./FHEM/00_MQTT2_SERVER.pm (389)
2021.10.10 17:51:00 1: main::MQTT2_SERVER_Read called by ./FHEM/00_MQTT2_SERVER.pm (459)
2021.10.10 17:51:00 1: main::__ANON__ called by fhem.pl (3427)
2021.10.10 17:51:00 1: main::HandleTimeout called by fhem.pl (695)
2021.10.10 17:51:00 1: main::MQTT2_SERVER_Read called by fhem.pl (3895)
2021.10.10 17:51:00 1: main::CallFn called by fhem.pl (773)
Jemand schon eine Idee ??
Sascha
Ich vermute, dass bei einem MQTT2_DEVICE event-on-change-reading mit threshold gesetzt ist, und dabei threshold als .* definiert wurde.
Korrekt waere irgendwas numerisches, womit "kleiner als" klarkommt.
Duerfte nichts mit dem update zu tun haben.
Zitatevent-on-change-reading
The attribute takes a comma-separated list of readings. You may use regular expressions in that list. If set, only changes of the listed readings create events. In other words, if a reading listed here is updated with the new value identical to the old value, no event is created. If an optional [:threshold] is given after a reading name events are only generated if the change is >= threshold.
