FHEM - Hausautomations-Systeme => Homematic => Thema gestartet von: Rampler am 12 Oktober 2021, 20:22:18
Titel: [Gelöst]Nach Update Meldungen
Beitrag von: Rampler am 12 Oktober 2021, 20:22:18
habe mich heute getraut mal wieder einen Update zu machen..
Jetzt bekomme ich nach FHEM Restart diese Meldungen:
2021.10.12 19:58:38 3: HMUART3 device opened
2021.10.12 19:58:46 3: ZWave got config for fibaro/fgcd001.xml from ./FHEM/lib/openzwave_deviceconfig.xml.gz
2021.10.12 19:58:47 2: AttrTemplates: got 229 entries
2021.10.12 19:59:10 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1307) line 1, <GEN157> line 203.
2021.10.12 19:59:10 3: eval: $fld[5]=~"GA.keymatic"&&$fld[3]=~"open"?1:0
2021.10.12 19:59:10 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1308) line 1, <GEN157> line 205.
2021.10.12 19:59:10 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1309) line 1, <GEN157> line 208.
2021.10.12 19:59:37 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1326) line 1, <GEN167> line 202.
2021.10.12 19:59:37 3: eval: $fld[5]=~"GA.keymatic"&&$fld[3]=~"open"?1:0
2021.10.12 19:59:37 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1327) line 1, <GEN167> line 204.
2021.10.12 19:59:37 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1328) line 1, <GEN167> line 207.
2021.10.12 20:00:04 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1375) line 1, <GEN178> line 202.
2021.10.12 20:00:04 3: eval: $fld[5]=~"GA.keymatic"&&$fld[3]=~"open"?1:0
2021.10.12 20:00:04 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1376) line 1, <GEN178> line 204.
2021.10.12 20:00:04 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1377) line 1, <GEN178> line 207.
2021.10.12 20:01:17 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1536) line 1, <GEN191> line 202.
2021.10.12 20:01:17 3: eval: $fld[5]=~"GA.keymatic"&&$fld[3]=~"open"?1:0
2021.10.12 20:01:17 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1537) line 1, <GEN191> line 204.
2021.10.12 20:01:17 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1538) line 1, <GEN191> line 207.
2021.10.12 20:01:58 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1555) line 1, <GEN201> line 202.
2021.10.12 20:01:58 3: eval: $fld[5]=~"GA.keymatic"&&$fld[3]=~"open"?1:0
2021.10.12 20:01:58 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1556) line 1, <GEN201> line 204.
2021.10.12 20:01:58 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1557) line 1, <GEN201> line 207.
2021.10.12 20:02:32 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1560) line 1, <GEN209> line 202.
2021.10.12 20:02:32 3: eval: $fld[5]=~"GA.keymatic"&&$fld[3]=~"open"?1:0
2021.10.12 20:02:32 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1561) line 1, <GEN209> line 204.
2021.10.12 20:02:32 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1562) line 1, <GEN209> line 207.
2021.10.12 20:02:59 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1562) line 1, <GEN218> line 202.
2021.10.12 20:02:59 3: eval: $fld[5]=~"GA.keymatic"&&$fld[3]=~"open"?1:0
2021.10.12 20:02:59 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1563) line 1, <GEN218> line 204.
2021.10.12 20:02:59 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1564) line 1, <GEN218> line 207.
2021.10.12 20:04:05 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1588) line 1, <GEN229> line 202.
2021.10.12 20:04:05 3: eval: $fld[5]=~"GA.keymatic"&&$fld[3]=~"open"?1:0
2021.10.12 20:04:05 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1589) line 1, <GEN229> line 204.
2021.10.12 20:04:05 1: PERL WARNING: Use of uninitialized value $fld[5] in pattern match (m//) at (eval 1590) line 1, <GEN229> line 207.
Nach cirka 5 Minuten ist Ruhe..
Hat jemand einen Tipp ?
Vg Klaus
Titel: Antw:[Gelöst]Nach Update Meldungen
Beitrag von: Rampler am 12 Oktober 2021, 21:26:44
Sorry, ich habe heute auch eine Batterie gewechselt, und was soll ich sagen, dadurch ist ein SVG plot ins schleudern gekommen ..
Jedenfalls nach löschen des Log files ist alles wieder gut
