Ich hoffe, ich bin im richtiuen Forum. Falls nicht, bitte ich um einen Hinweis, werde dann verschieben.
Ich habe ein H801 Tasmota geflshed.
Funktioniert auch gut. Angeschlossen ists nur ein weisser LED-Stripe.
Ich kann also nur die Helligkeit ändern, was auch ok wäre.
Aber: Wenn ich das mache (Helligkeit von 50 auf 70), bekomme ich folgende Meldungen:
2021.10.23 19:34:43 1: stacktrace:
2021.10.23 19:34:43 1: main::__ANON__ called by FHEM/Color.pm (508)
2021.10.23 19:34:43 1: Color::devStateIcon called by (eval 114275) (1)
2021.10.23 19:34:43 1: (eval) called by ./FHEM/01_FHEMWEB.pm (2976)
2021.10.23 19:34:43 1: main::FW_dev2image called by ./FHEM/01_FHEMWEB.pm (3301)
2021.10.23 19:34:43 1: main::FW_devState called by ./FHEM/01_FHEMWEB.pm (3163)
2021.10.23 19:34:43 1: main::FW_Notify called by fhem.pl (3895)
2021.10.23 19:34:43 1: main::CallFn called by fhem.pl (3812)
2021.10.23 19:34:43 1: main::DoTrigger called by fhem.pl (4910)
2021.10.23 19:34:43 1: main::readingsEndUpdate called by fhem.pl (5093)
2021.10.23 19:34:43 1: main::readingsSingleUpdate called by ./FHEM/10_MQTT2_DEVICE.pm (424)
2021.10.23 19:34:43 1: main::MQTT2_DEVICE_Set called by fhem.pl (3890)
2021.10.23 19:34:43 1: main::CallFn called by fhem.pl (1939)
2021.10.23 19:34:43 1: main::DoSet called by fhem.pl (1971)
2021.10.23 19:34:43 1: main::CommandSet called by fhem.pl (1265)
2021.10.23 19:34:43 1: main::AnalyzeCommand called by fhem.pl (1116)
2021.10.23 19:34:43 1: main::AnalyzeCommandChain called by ./FHEM/01_FHEMWEB.pm (2779)
2021.10.23 19:34:43 1: main::FW_fC called by ./FHEM/01_FHEMWEB.pm (963)
2021.10.23 19:34:43 1: main::FW_answerCall called by ./FHEM/01_FHEMWEB.pm (598)
2021.10.23 19:34:43 1: main::FW_Read called by fhem.pl (3895)
2021.10.23 19:34:43 1: main::CallFn called by fhem.pl (773)
2021.10.23 19:34:43 1: PERL WARNING: Argument "set" isn't numeric in numeric lt (<) at FHEM/Color.pm line 508.
2021.10.23 19:34:43 1: Color::devStateIcon called by (eval 114276) (1)
List:
nternals:
CID DVES_E0D793
DEF DVES_E0D793
DEVICETOPIC MQTT2_DVES_E0D793
FUUID 5e997488-f33f-8098-eb00-ea794e6da3311ee6
IODev MQTT2_Server
LASTInputDev MQTT2_Server
MQTT2_Server_MSGCNT 39
MQTT2_Server_TIME 2021-10-23 19:40:11
MSGCNT 39
NAME MQTT2_DVES_E0D793
NR 370
STATE set_on
TYPE MQTT2_DEVICE
JSONMAP:
Channel_1 0
Channel_2 0
Channel_3 0
Channel_4 white
Dimmer pct
HSBColor 0
POWER1 0
2020-04-17 14:06:37 BASE 18
2021-10-23 19:40:11 CT 153
2021-10-23 19:40:11 Channel_5 0
2021-10-23 19:40:11 Color 000000B300
2020-04-17 14:06:37 FLAG 15
2021-10-23 19:40:11 Fade OFF
2021-10-23 18:22:24 FallbackTopic cmnd/DVES_E0D793_fb/
2020-04-17 14:06:37 GPIO_1 255
2020-04-17 14:06:37 GPIO_10 255
2020-04-17 14:06:37 GPIO_11 255
2020-04-17 14:06:37 GPIO_12 255
2020-04-17 14:06:37 GPIO_13 255
2020-04-17 14:06:37 GPIO_2 255
2020-04-17 14:06:37 GPIO_3 255
2020-04-17 14:06:37 GPIO_4 255
2020-04-17 14:06:37 GPIO_5 255
2020-04-17 14:06:37 GPIO_6 255
2020-04-17 14:06:37 GPIO_7 255
2020-04-17 14:06:37 GPIO_8 255
2020-04-17 14:06:37 GPIO_9 255
2021-10-23 18:22:24 GroupTopic cmnd/tasmotas/
2021-10-23 19:40:11 Heap 28
2021-10-23 18:22:24 Hostname tasmota_E0D793-6035
2021-10-23 09:10:55 IODev MQTT2_Server
2021-10-23 18:22:24 IPAddress 192.168.178.52
2021-10-23 18:43:13 LWT Online
2021-10-23 19:40:11 LedTable ON
2021-10-23 19:40:11 LoadAvg 38
2021-10-23 18:22:24 Module H801
2021-10-23 19:40:11 MqttCount 2
2020-04-17 14:06:37 NAME Generic
2020-05-01 11:04:55 OtaUrl http://thehackbox.org/tasmota/release/tasmota.bin
2021-10-23 19:40:11 POWER ON
2021-10-23 18:22:24 RestartReason External System
2020-05-01 10:56:26 RestartReason_CallChain_1 40248981
2020-05-01 10:56:26 RestartReason_CallChain_10 4027df68
2020-05-01 10:56:26 RestartReason_CallChain_11 4022539d
2020-05-01 10:56:26 RestartReason_CallChain_12 4027df68
2020-05-01 10:56:26 RestartReason_CallChain_13 40202cd6
2020-05-01 10:56:26 RestartReason_CallChain_14 4027de48
2020-05-01 10:56:26 RestartReason_CallChain_15 4021fc4d
2020-05-01 10:56:26 RestartReason_CallChain_16 40248a38
2020-05-01 10:56:26 RestartReason_CallChain_17 40216b64
2020-05-01 10:56:26 RestartReason_CallChain_18 40000020
2020-05-01 10:56:26 RestartReason_CallChain_19 40103434
2020-05-01 10:56:26 RestartReason_CallChain_2 40286cb7
2020-05-01 10:56:26 RestartReason_CallChain_20 40248a48
2020-05-01 10:56:26 RestartReason_CallChain_21 40217875
2020-05-01 10:56:26 RestartReason_CallChain_22 40000000
2020-05-01 10:56:26 RestartReason_CallChain_23 40220db0
2020-05-01 10:56:26 RestartReason_CallChain_24 40101830
2020-05-01 10:56:26 RestartReason_CallChain_25 40101acf
2020-05-01 10:56:26 RestartReason_CallChain_26 4025351c
2020-05-01 10:56:26 RestartReason_CallChain_27 4024ebda
2020-05-01 10:56:26 RestartReason_CallChain_28 40234a3e
2020-05-01 10:56:26 RestartReason_CallChain_29 40234a96
2020-05-01 10:56:26 RestartReason_CallChain_3 4022913b
2020-05-01 10:56:26 RestartReason_CallChain_30 4023b888
2020-05-01 10:56:26 RestartReason_CallChain_31 4023b9d7
2020-05-01 10:56:26 RestartReason_CallChain_4 402293ad
2020-05-01 10:56:26 RestartReason_CallChain_5 4020da3d
2020-05-01 10:56:26 RestartReason_CallChain_6 4021a4f7
2020-05-01 10:56:26 RestartReason_CallChain_7 40224dd2
2020-05-01 10:56:26 RestartReason_CallChain_8 4027df7d
2020-05-01 10:56:26 RestartReason_CallChain_9 4027de50
2020-05-01 10:56:26 RestartReason_DEPC 00000000
2020-05-01 10:56:26 RestartReason_EPC_1 4000dce5
2020-05-01 10:56:26 RestartReason_EPC_2 00000000
2020-05-01 10:56:26 RestartReason_EPC_3 40100450
2020-05-01 10:56:26 RestartReason_EXCVADDR 00000000
2020-05-01 10:56:26 RestartReason_Exception 0
2020-05-01 10:56:26 RestartReason_Reason Exception
2020-04-17 13:54:45 SaveData on
2021-10-23 19:40:11 Scheme 0
2020-04-17 13:54:44 SetOption26 on
2021-10-23 19:40:11 Sleep 10
2021-10-23 19:40:11 SleepMode Dynamic
2021-10-23 19:40:11 Speed 20
2020-04-17 13:54:44 StateText1 off
2020-04-17 13:54:44 StateText2 on
2020-04-17 13:54:44 StateText3 toggle
2020-04-17 13:54:44 StateText4 hold
2021-10-23 19:40:11 Time 2021-10-23T18:40:10
2020-05-01 11:04:55 Upgrade Version 8.2.0 from http://thehackbox.org/tasmota/release/tasmota.bin
2021-10-23 19:40:11 Uptime 0T01:17:54
2021-10-23 19:40:11 UptimeSec 4674
2021-10-23 18:22:24 Version 8.2.0(tasmota)
2020-05-01 10:58:36 Wakeup Done
2021-10-23 18:22:24 WebServerMode Admin
2021-10-23 19:40:11 White 70
2021-10-23 19:40:11 Wifi_AP 1
2021-10-23 19:40:11 Wifi_BSSId 24:65:11:CB:BC:0F
2021-10-23 19:40:11 Wifi_Channel 13
2021-10-23 19:40:11 Wifi_Downtime 0T00:00:06
2021-10-23 19:40:11 Wifi_LinkCount 1
2021-10-23 19:40:11 Wifi_RSSI 100
2021-10-23 19:40:11 Wifi_SSId HachMichHart
2021-10-23 19:40:11 Wifi_Signal -32
2020-05-01 10:54:02 dimup set
2020-07-10 15:37:02 mode set
2021-10-23 19:40:11 pct 70
2020-05-01 11:12:37 saturation 0
2020-07-10 16:21:58 state set_on
2021-10-17 19:56:14 subscriptions cmnd/DVES_E0D793_fb/# cmnd/tasmota_E0D793/# cmnd/tasmotas/#
2021-10-23 19:40:11 white 70
IODev MQTT2_Server
autocreate 0
comment NOTE: For on-for-timer SetExtensions are used. You may add on-for-timer option running on the device. The following is limited to 1h max duration, but will not affect future simple "on" commands:<br>on-for-timer {my $duration = $EVTPART1*10; 'cmnd/cmnd/tasmota_E0D793/Backlog POWER1 1; delay '.$duration.'; POWER1 0'}<br>See the "Praxisbeispiele" in the wiki for "pulseTime1" alternative option and it's restrictions.
devStateIcon {Color::devStateIcon($name,"rgb","Color","pct","POWER")}
genericDeviceType light
icon light_control
jsonMap POWER1:0 Dimmer:pct Channel_4:white Channel_1:0 Channel_2:0 Channel_3:0 HSBColor:0
model tasmota_rgbw_led
readingList tele/tasmota_E0D793/LWT:.* LWT
tele/tasmota_E0D793/STATE:.* { json2nameValue($EVENT,'',$JSONMAP) }
tele/tasmota_E0D793/SENSOR:.* { json2nameValue($EVENT,'',$JSONMAP) }
tele/tasmota_E0D793/INFO.:.* { json2nameValue($EVENT,'',$JSONMAP) }
tele/tasmota_E0D793/UPTIME:.* { json2nameValue($EVENT,'',$JSONMAP) }
stat/tasmota_E0D793/RESULT:.* { json2nameValue($EVENT,'',$JSONMAP) }
stat/tasmota_E0D793/RESULT:.* { $EVENT =~ m,HSBColor...(\d+)\,(\d+)\,(\d+), ? $2 eq ReadingsVal($NAME,"saturation","unknown") ? undef :{"saturation"=>$2} : undef }
stat/tasmota_E0D793/POWER1:.* state
room MQTT2_DEVICE,Wohnung->Wohnzimmer
setList off:noArg cmnd/tasmota_E0D793/POWER1 0
on:noArg cmnd/tasmota_E0D793/POWER1 1
toggle:noArg cmnd/tasmota_E0D793/POWER1 2
Color:colorpicker,RGB cmnd/tasmota_E0D793/COLOR
pct:colorpicker,BRI,0,5,100 cmnd/tasmota_E0D793/DIMMER
dimup:noArg { my $num=int((ReadingsNum($NAME,'pct',0)+4)/10)*10+10; return qq {cmnd/tasmota_E0D793/Dimmer $num}; }
dimdown:noArg { my $num=int((ReadingsNum($NAME,'pct',0)+7)/10)*10-10; return qq {cmnd/tasmota_E0D793/Dimmer $num}; }
white:colorpicker,BRI,0,5,100 { "cmnd/tasmota_E0D793/COLOR ". sprintf("000000%02X",$EVTPART1*2.55) }
saturation:colorpicker,BRI,0,1,100 cmnd/tasmota_E0D793/HSBCOLOR2
Speed:colorpicker,BRI,0,1,20 cmnd/tasmota_E0D793/SPEED
Fade:uzsuSelect,ON,OFF cmnd/tasmota_E0D793/FADE $EVTPART1
mode:selectnumbers,0,1,4,0,lin cmnd/tasmota_E0D793/SCHEME
setStateList on off toggle
webCmd pct
webCmdLabel Helligkeit
RAW:
defmod MQTT2_DVES_E0D793 MQTT2_DEVICE DVES_E0D793
attr MQTT2_DVES_E0D793 IODev MQTT2_Server
attr MQTT2_DVES_E0D793 autocreate 0
attr MQTT2_DVES_E0D793 comment NOTE: For on-for-timer SetExtensions are used. You may add on-for-timer option running on the device. The following is limited to 1h max duration, but will not affect future simple "on" commands:<br>on-for-timer {my $duration = $EVTPART1*10;; 'cmnd/cmnd/tasmota_E0D793/Backlog POWER1 1;; delay '.$duration.';; POWER1 0'}<br>See the "Praxisbeispiele" in the wiki for "pulseTime1" alternative option and it's restrictions.
attr MQTT2_DVES_E0D793 devStateIcon {Color::devStateIcon($name,"rgb","Color","pct","POWER")}
attr MQTT2_DVES_E0D793 genericDeviceType light
attr MQTT2_DVES_E0D793 icon light_control
attr MQTT2_DVES_E0D793 jsonMap POWER1:0 Dimmer:pct Channel_4:white Channel_1:0 Channel_2:0 Channel_3:0 HSBColor:0
attr MQTT2_DVES_E0D793 model tasmota_rgbw_led
attr MQTT2_DVES_E0D793 readingList tele/tasmota_E0D793/LWT:.* LWT\
tele/tasmota_E0D793/STATE:.* { json2nameValue($EVENT,'',$JSONMAP) }\
tele/tasmota_E0D793/SENSOR:.* { json2nameValue($EVENT,'',$JSONMAP) }\
tele/tasmota_E0D793/INFO.:.* { json2nameValue($EVENT,'',$JSONMAP) }\
tele/tasmota_E0D793/UPTIME:.* { json2nameValue($EVENT,'',$JSONMAP) }\
stat/tasmota_E0D793/RESULT:.* { json2nameValue($EVENT,'',$JSONMAP) }\
stat/tasmota_E0D793/RESULT:.* { $EVENT =~ m,HSBColor...(\d+)\,(\d+)\,(\d+), ? $2 eq ReadingsVal($NAME,"saturation","unknown") ? undef :{"saturation"=>$2} : undef }\
attr MQTT2_DVES_E0D793 room MQTT2_DEVICE,Wohnung->Wohnzimmer
attr MQTT2_DVES_E0D793 setList off:noArg cmnd/tasmota_E0D793/POWER1 0\
on:noArg cmnd/tasmota_E0D793/POWER1 1\
toggle:noArg cmnd/tasmota_E0D793/POWER1 2\
Color:colorpicker,RGB cmnd/tasmota_E0D793/COLOR\
pct:colorpicker,BRI,0,5,100 cmnd/tasmota_E0D793/DIMMER\
dimup:noArg { my $num=int((ReadingsNum($NAME,'pct',0)+4)/10)*10+10;; return qq {cmnd/tasmota_E0D793/Dimmer $num};; }\
dimdown:noArg { my $num=int((ReadingsNum($NAME,'pct',0)+7)/10)*10-10;; return qq {cmnd/tasmota_E0D793/Dimmer $num};; }\
white:colorpicker,BRI,0,5,100 { "cmnd/tasmota_E0D793/COLOR ". sprintf("000000%02X",$EVTPART1*2.55) }\
saturation:colorpicker,BRI,0,1,100 cmnd/tasmota_E0D793/HSBCOLOR2\
Speed:colorpicker,BRI,0,1,20 cmnd/tasmota_E0D793/SPEED\
Fade:uzsuSelect,ON,OFF cmnd/tasmota_E0D793/FADE $EVTPART1\
attr MQTT2_DVES_E0D793 setStateList on off toggle
attr MQTT2_DVES_E0D793 webCmd pct
attr MQTT2_DVES_E0D793 webCmdLabel Helligkeit
setstate MQTT2_DVES_E0D793 set_on
setstate MQTT2_DVES_E0D793 2020-04-17 14:06:37 BASE 18
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 CT 153
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 Channel_5 0
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 Color 000000B300
setstate MQTT2_DVES_E0D793 2020-04-17 14:06:37 FLAG 15
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 Fade OFF
setstate MQTT2_DVES_E0D793 2021-10-23 18:22:24 FallbackTopic cmnd/DVES_E0D793_fb/
setstate MQTT2_DVES_E0D793 2020-04-17 14:06:37 GPIO_1 255
setstate MQTT2_DVES_E0D793 2020-04-17 14:06:37 GPIO_10 255
setstate MQTT2_DVES_E0D793 2020-04-17 14:06:37 GPIO_11 255
setstate MQTT2_DVES_E0D793 2020-04-17 14:06:37 GPIO_12 255
setstate MQTT2_DVES_E0D793 2020-04-17 14:06:37 GPIO_13 255
setstate MQTT2_DVES_E0D793 2020-04-17 14:06:37 GPIO_2 255
setstate MQTT2_DVES_E0D793 2020-04-17 14:06:37 GPIO_3 255
setstate MQTT2_DVES_E0D793 2020-04-17 14:06:37 GPIO_4 255
setstate MQTT2_DVES_E0D793 2020-04-17 14:06:37 GPIO_5 255
setstate MQTT2_DVES_E0D793 2020-04-17 14:06:37 GPIO_6 255
setstate MQTT2_DVES_E0D793 2020-04-17 14:06:37 GPIO_7 255
setstate MQTT2_DVES_E0D793 2020-04-17 14:06:37 GPIO_8 255
setstate MQTT2_DVES_E0D793 2020-04-17 14:06:37 GPIO_9 255
setstate MQTT2_DVES_E0D793 2021-10-23 18:22:24 GroupTopic cmnd/tasmotas/
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 Heap 28
setstate MQTT2_DVES_E0D793 2021-10-23 18:22:24 Hostname tasmota_E0D793-6035
setstate MQTT2_DVES_E0D793 2021-10-23 09:10:55 IODev MQTT2_Server
setstate MQTT2_DVES_E0D793 2021-10-23 18:22:24 IPAddress 192.168.178.52
setstate MQTT2_DVES_E0D793 2021-10-23 18:43:13 LWT Online
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 LedTable ON
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 LoadAvg 38
setstate MQTT2_DVES_E0D793 2021-10-23 18:22:24 Module H801
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 MqttCount 2
setstate MQTT2_DVES_E0D793 2020-04-17 14:06:37 NAME Generic
setstate MQTT2_DVES_E0D793 2020-05-01 11:04:55 OtaUrl http://thehackbox.org/tasmota/release/tasmota.bin
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 POWER ON
setstate MQTT2_DVES_E0D793 2021-10-23 18:22:24 RestartReason External System
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_1 40248981
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_10 4027df68
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_11 4022539d
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_12 4027df68
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_13 40202cd6
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_14 4027de48
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_15 4021fc4d
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_16 40248a38
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_17 40216b64
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_18 40000020
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_19 40103434
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_2 40286cb7
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_20 40248a48
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_21 40217875
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_22 40000000
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_23 40220db0
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_24 40101830
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_25 40101acf
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_26 4025351c
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_27 4024ebda
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_28 40234a3e
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_29 40234a96
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_3 4022913b
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_30 4023b888
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_31 4023b9d7
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_4 402293ad
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_5 4020da3d
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_6 4021a4f7
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_7 40224dd2
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_8 4027df7d
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_CallChain_9 4027de50
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_DEPC 00000000
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_EPC_1 4000dce5
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_EPC_2 00000000
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_EPC_3 40100450
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_EXCVADDR 00000000
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_Exception 0
setstate MQTT2_DVES_E0D793 2020-05-01 10:56:26 RestartReason_Reason Exception
setstate MQTT2_DVES_E0D793 2020-04-17 13:54:45 SaveData on
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 Scheme 0
setstate MQTT2_DVES_E0D793 2020-04-17 13:54:44 SetOption26 on
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 Sleep 10
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 SleepMode Dynamic
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 Speed 20
setstate MQTT2_DVES_E0D793 2020-04-17 13:54:44 StateText1 off
setstate MQTT2_DVES_E0D793 2020-04-17 13:54:44 StateText2 on
setstate MQTT2_DVES_E0D793 2020-04-17 13:54:44 StateText3 toggle
setstate MQTT2_DVES_E0D793 2020-04-17 13:54:44 StateText4 hold
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 Time 2021-10-23T18:40:10
setstate MQTT2_DVES_E0D793 2020-05-01 11:04:55 Upgrade Version 8.2.0 from http://thehackbox.org/tasmota/release/tasmota.bin
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 Uptime 0T01:17:54
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 UptimeSec 4674
setstate MQTT2_DVES_E0D793 2021-10-23 18:22:24 Version 8.2.0(tasmota)
setstate MQTT2_DVES_E0D793 2020-05-01 10:58:36 Wakeup Done
setstate MQTT2_DVES_E0D793 2021-10-23 18:22:24 WebServerMode Admin
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 White 70
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 Wifi_AP 1
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 Wifi_BSSId 24:65:11:CB:BC:0F
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 Wifi_Channel 13
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 Wifi_Downtime 0T00:00:06
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 Wifi_LinkCount 1
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 Wifi_RSSI 100
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 Wifi_SSId HachMichHart
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 Wifi_Signal -32
setstate MQTT2_DVES_E0D793 2020-05-01 10:54:02 dimup set
setstate MQTT2_DVES_E0D793 2020-07-10 15:37:02 mode set
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 pct 70
setstate MQTT2_DVES_E0D793 2020-05-01 11:12:37 saturation 0
setstate MQTT2_DVES_E0D793 2020-07-10 16:21:58 state set_on
setstate MQTT2_DVES_E0D793 2021-10-17 19:56:14 subscriptions cmnd/DVES_E0D793_fb/# cmnd/tasmota_E0D793/# cmnd/tasmotas/#
setstate MQTT2_DVES_E0D793 2021-10-23 19:40:11 white 70
Was muss ich denn unternehmen, um das zu beseitigen?
Was liefert "version Color.pm"?
File Rev Last Change
Color.pm 20813 2019-12-22 18:42:10Z justme1968
HMinfoTools.js 1009 2020-09-03 16:00:00Z frank
doif.js 24438 2021-05-14 18:08:18Z Ellert
f18.js 24575 2021-06-03 09:52:42Z rudolfkoenig
fhemweb.js 25022 2021-09-27 07:11:18Z rudolfkoenig
fhemweb_readingsGroup.js 15189 2017-10-03 17:53:27Z justme1968
OK, glaube das Problem gefunden zu haben, komisch, dass das noch keiner gemeldet hat...
Kannst du die Color.pm bitte mal versuchsweise tauschen?
Die Version scheint prima zu laufen. Der Fehler kommt nicht mehr.
Danke für die Hilfe.
Warum das bisher keiner gemeldet hat liegt daran, dass ich ein besonderer Pechvogel bin. LOL
...eher, weil du halt hin und wieder ins Log schaust...
Danke für's Testen, ich werd's weitergeben.
Stimmt nicht ganz, hatte den gleichen Fehler und war auf der Suche wo ich ihn einkippen kann :)
Mit deiner angepassten Version ist bei mir ebenfalls der Fehler behoben, besten Dank.
Gruß Reinhard
