Zeitweilig geht alles gut, dann geht mal wieder alles durcheinander ....
- energy Reading spinnt
- water Reading ist Unsinn
- UNKNOWN ..... sollte sicher auch nicht dauernd auftreten
- SEND_DATA failed:00
Letzteres ist das Ergebnis von 'get model', was zwar in einem Timeout endet, aber trotzdem ausgefuehrt worden ist.
DEF cfba8db6 86
FUUID 5d0de130-f33f-775d-949d-842882b4873256fc
IODev ZWAVE2
LASTInputDev ZWAVE2
MSGCNT 1513
NAME ZWHeizungWerkstatt
NR 182
STATE off
TYPE ZWave
ZWAVE2_MSGCNT 1513
ZWAVE2_RAWMSG 000410560a3202a14a0000012d0000
ZWAVE2_TIME 2021-12-19 18:29:02
ZWaveSubDevice no
cmdsPending 0
endpointChildren ZWave_Node_86.3,ZWave_Node_86.4
homeId cfba8db6
isWakeUp
lastMsgSent 1639934422.41757
nodeIdHex 56
2021-12-19 14:19:12 IODev ZWAVE2
2021-12-19 18:20:22 SEND_DATA failed:00
2021-12-19 17:53:55 UNKNOWN_0 0 UNKNOWN previous: 2.56 delta_time: 301 s
2021-12-18 15:55:47 UNKNOWN_17 241.34 UNKNOWN previous: 240.11 delta_time: 33 s
2021-12-19 12:19:22 UNPARSED METER 0a3200a3425dfe00035e2a
2021-12-19 18:13:10 associatedWith ZWave_Node_86.3,ZWave_Node_86.4
2021-12-19 18:20:19 configButtonOnOff Enable
2021-12-19 18:20:23 configConfigureMaximumAlarmCurrent 13
2021-12-19 18:29:02 current 0 A previous: 0 delta_time: 301 s
2021-12-19 18:28:55 energy -21474781.44 kWh previous: 21474891.52 delta_time: 301 s
2021-12-19 18:20:00 model Neo CoolCam Power plug 12A
2021-12-19 18:20:00 modelConfig shenzen_neo/nas-wr01ze.xml
2021-12-19 18:20:00 modelId 0258-0200-1027
2021-12-19 18:28:57 power 0 W previous: 0 delta_time: 301 s
2021-12-19 14:23:52 reportedState off
2021-12-19 14:23:52 state off
2021-12-19 18:20:24 timeToAck 2.003
2021-12-19 18:20:24 transmit OK
2021-12-19 18:29:00 voltage 244.96 V previous: 244.21 delta_time: 301 s
2021-12-19 08:34:42 water 3089367.11 m3
IODev ZWAVE2
classes ZWAVEPLUS_INFO SECURITY SECURITY_S2 TRANSPORT_SERVICE POWERLEVEL VERSION ASSOCIATION MULTI_CHANNEL_ASSOCIATION ASSOCIATION_GRP_INFO MANUFACTURER_SPECIFIC DEVICE_RESET_LOCALLY SWITCH_BINARY SWITCH_ALL METER ALARM CONFIGURATION SUPERVISION
devStateIcon .*off:black_Steckdose.off .*on:black_Steckdose.on
event-on-change-reading power,energy
icon ge_wht_steckdose
room Garage,ZWave
vclasses ALARM:8 ASSOCIATION:2 ASSOCIATION_GRP_INFO:1 CONFIGURATION:1 DEVICE_RESET_LOCALLY:1 MANUFACTURER_SPECIFIC:2 METER:4 MULTI_CHANNEL_ASSOCIATION:3 POWERLEVEL:1 SECURITY:1 SECURITY_S2:1 SUPERVISION:1 SWITCH_ALL:1 SWITCH_BINARY:1 TRANSPORT_SERVICE:2 VERSION:3 ZWAVEPLUS_INFO:2
Mal nachgeforscht : Das Teil kann eigentlich nur 'on/off' und power-Report ordentlich, der Rest funktioniert ab und an.
