Hallo FHEM Z-Wave Maintainer,
könntet ihr bitte die Konfiguration des Aeotec Nano Shutter (ZW141) mit in FHEM aufnehmen. Anbei die Infos zu dem Device.
Model ID (bei mir): 0x0371 0x0003 0x008d
Links:
- OpenZwave Device config ZW141 https://github.com/OpenZWave/open-zwave/blob/master/config/aeotec/zw141.xml (https://github.com/OpenZWave/open-zwave/blob/master/config/aeotec/zw141.xml)
- Aeotec Spec https://aeotec.freshdesk.com/support/solutions/articles/6000198818-nano-shutter-technical-specifications- (https://aeotec.freshdesk.com/support/solutions/articles/6000198818-nano-shutter-technical-specifications-)
- Aeotec Docu https://aeotec.freshdesk.com/support/solutions/articles/6000198854-nano-shutter-user-guide- (https://aeotec.freshdesk.com/support/solutions/articles/6000198854-nano-shutter-user-guide-)
Das Listing meines ZW141 FHEM Devices:
   CFGFN
   DEF        c341a14b 13
   FUUID      622b423f-f33f-8275-28ac-fa4850e466603973
   IODev      ZWDongle
   LASTInputDev ZWDongle
   MSGCNT     23
   NAME       AeotecNanoShutterZW141
   NR         767
   STATE      dim 48
   TYPE       ZWave
   ZWDongle_MSGCNT 23
   ZWDongle_RAWMSG 0004000d199881e74cda89bd6c2b9a5ac547d74c24f6207a2bdf63083af8cf00
   ZWDongle_TIME 2022-03-11 13:40:27
   ZWaveSubDevice no
   cmdsPending 0
   homeId     XXXXX
   isWakeUp
   lastMsgSent 1647002427.20939
   nodeIdHex  0d
   secTime    1647002427.20922
     2022-03-11 13:36:15   IODev           ZWDongle
     2022-03-11 13:36:16   SECURITY        ENABLED
     2022-03-11 13:36:16   model           0x0371 0x0003 0x008d
     2022-03-11 13:36:16   modelId         0371-0003-008d
     2022-03-11 13:40:27   reportedState   dim 48
     2022-03-11 13:40:27   routeInfo       timeToCb:0.02 repeaters:0 rssi0:-49 dBm ackCh:0 lastCh:0 scheme:LastWorkingRoute rep:at 100kbps routeTries:1 lastFailed:
     2022-03-11 13:40:27   state           dim 48
     2022-03-11 13:40:27   swmStatus       48 target 48 duration 0 seconds
     2022-03-11 13:40:27   timeToAck       0.032
     2022-03-11 13:40:27   transmit        OK
     2022-03-11 13:36:19   zwavePlusInfo    version:01 role:AlwaysOnSlave node:Z-Wave+Node installerIcon:1a00 userIcon:1a00
   secMsg:
   secNonce:
   classes    ZWAVEPLUS_INFO ASSOCIATION ASSOCIATION_GRP_INFO TRANSPORT_SERVICE CONFIGURATION SCENE_ACTUATOR_CONF SCENE_ACTIVATION SWITCH_MULTILEVEL VERSION MANUFACTURER_SPECIFIC DEVICE_RESET_LOCALLY POWERLEVEL SECURITY SECURITY_S2 SUPERVISION FIRMWARE_UPDATE_MD CENTRAL_SCENE
   room       ZWave
   secure_classes ASSOCIATION ASSOCIATION_GRP_INFO CONFIGURATION SCENE_ACTUATOR_CONF SCENE_ACTIVATION SWITCH_MULTILEVEL POWERLEVEL FIRMWARE_UPDATE_MD VERSION DEVICE_RESET_LOCALLY CENTRAL_SCENE
   vclasses   ASSOCIATION:2 ASSOCIATION_GRP_INFO:1 CENTRAL_SCENE:3 CONFIGURATION:1 DEVICE_RESET_LOCALLY:1 FIRMWARE_UPDATE_MD:4 MANUFACTURER_SPECIFIC:2 POWERLEVEL:1 SCENE_ACTIVATION:1 SCENE_ACTUATOR_CONF:1 SECURITY:1 SECURITY_S2:1 SUPERVISION:1 SWITCH_MULTILEVEL:4 TRANSPORT_SERVICE:2 VERSION:2 ZWAVEPLUS_INFO:2
				Habe das Gerät aufgenommen und die Änderung ungetestet eingecheckt. Ab sofort Download per svn.fhem.de und ab morgen ca. 8 Uhr Verteilung per Befehl "update". Zur Aktivierung bitte nach dem update und shutdown restart beim entsprechenden Device einmalig "get <device> model".
Gruß, Christian
				Vielen Dank!
