FHEM - Hausautomations-Systeme => Homematic => Thema gestartet von: Homalix99 am 16 Mai 2022, 15:18:55
Titel: .AttrList der Internals bei allen CUL_HM Objekten mit Schrotteinträgen gefüllt.
Beitrag von: Homalix99 am 16 Mai 2022, 15:18:55
seit Kurzem ist mir aufgefallen, dass alle Homematic-Geräte in Fhem in den .AttrList (Internals) beliebige Schrotteinträge beinhalten.
   .AttrList  .devInfo .mId .stc IODev IOgrp actCycle actStatus aesCommReq:1,0 aesKey:5,4,3,2,1,0 autoReadReg:0_off,1_restart,2_pon-restart,3_onChange,4_reqStatus,5_readMissing,8_stateOnly burstAccess:0_off,1_auto commStInCh:on,off do_not_notify:1,0 dummy:1,0 event-aggregator event-min-interval event-on-change-reading event-on-update-reading expert:multiple,defReg,allReg,rawReg,templ,none firmware hmKey hmKey2 hmKey3 hmProtocolEvents:0_off,1_dump,2_dumpFull,3_dumpTrigger ignore:1,0 levelMap levelRange model modelForce:ACTIONDETECTOR,ACTIONDETECTOR,ASH550,ASH550I,CCU-FHEM,CMM,DORMA_ATENT,DORMA_BRC-H,DORMA_RC-H,HM-CC-RT-DN,HM-CC-RT-DN-BOM,HM-CC-SCD,HM-CC-TC,HM-CC-VD,HM-DIS-EP-WM55,HM-DIS-TD-T,HM-DIS-WM55,HM-DW-WM,HM-ES-PMSW1-DR,HM-ES-PMSW1-PL,HM-ES-PMSW1-PL-DN-R1,HM-ES-PMSW1-PL-DN-R2,HM-ES-PMSW1-PL-DN-R3,HM-ES-PMSW1-PL-DN-R4,HM-ES-PMSW1-PL-DN-R5,HM-ES-PMSW1-SM,HM-ES-TX-WM,HM-HM-LC-DW-WM,HM-LC-AO-SM,HM-LC-BL1-FM,HM-LC-BL1-FM-2,HM-LC-BL1-PB-FM,HM-LC-BL1-SM,HM-LC-BL1-SM-2,HM-LC-BL1PBU-FM,HM-LC-DDC1-PCB,HM-LC-DIM1L-CV,HM-LC-DIM1L-CV-2,HM-LC-DIM1L-CV-644,HM-LC-DIM1L-PL,HM-LC-DIM1L-PL-2,HM-LC-DIM1L-PL-3,HM-LC-DIM1L-PL-644,HM-LC-DIM1PWM-CV,HM-LC-DIM1PWM-CV-2,HM-LC-DIM1T-CV,HM-LC-DIM1T-CV-2,HM-LC-DIM1T-CV-644,HM-LC-DIM1T-DR,HM-LC-DIM1T-FM,HM-LC-DIM1T-FM-2,HM-LC-DIM1T-FM-644,HM-LC-DIM1T-FM-LF,HM-LC-DIM1T-PL,HM-LC-DIM1T-PL-2,HM-LC-DIM1T-PL-3,HM-LC-DIM1T-PL-644,HM-LC-DIM1TPBU-FM,HM-LC-DIM1TPBU-FM-2,HM-LC-DIM2L-CV,HM-LC-DIM2L-SM,HM-LC-DIM2L-SM-2,HM-LC-DIM2L-SM-644,HM-LC-DIM2T-SM,HM-LC-DIM2T-SM,HM-LC-DIM2T-SM-2,HM-LC-JA1PBU-FM,HM-LC-RGBW-WM,HM-LC-SW1-BA-PCB,HM-LC-SW1-DR,HM-LC-SW1-FM,HM-LC-SW1-FM-2,HM-LC-SW1-PB-FM,HM-LC-SW1-PCB,HM-LC-SW1-PL,HM-LC-SW1-PL-3,HM-LC-SW1-PL-CT-R1,HM-LC-SW1-PL-CT-R2,HM-LC-SW1-PL-CT-R3,HM-LC-SW1-PL-CT-R4,HM-LC-SW1-PL-CT-R5,HM-LC-SW1-PL-DN-R1,HM-LC-SW1-PL-DN-R2,HM-LC-SW1-PL-DN-R3,HM-LC-SW1-PL-DN-R4,HM-LC-SW1-PL-DN-R5,HM-LC-SW1-PL-OM54,HM-LC-SW1-PL2,HM-LC-SW1-SM,HM-LC-SW1-SM-2,HM-LC-SW1-SM-ATMEGA168,HM-LC-SW1PBU-FM,HM-LC-SW2-DR,HM-LC-SW2-DR-2,HM-LC-SW2-FM,HM-LC-SW2-FM-2,HM-LC-SW2-PB-FM,HM-LC-SW2-SM,HM-LC-SW2PBU-FM,HM-LC-SW4-BA-PCB,HM-LC-SW4-DR,HM-LC-SW4-DR-2,HM-LC-SW4-PCB,HM-LC-SW4-PCB-2,HM-LC-SW4-SM,HM-LC-SW4-SM-2,HM-LC-SW4-SM-ATMEGA168,HM-LC-SW4-WM,HM-LC-SW4-WM-2,HM-MOD-EM-8,HM-MOD-EM-8BIT,HM-MOD-RE-8,HM-OU-CF-PL,HM-OU-CFM-PL,HM-OU-CFM-TW,HM-OU-CM-PCB,HM-OU-LED16,HM-PB-2-FM,HM-PB-2-WM,HM-PB-2-WM55,HM-PB-2-WM55-2,HM-PB-4-WM,HM-PB-4DIS-WM,HM-PB-4DIS-WM-2,HM-PB-6-WM55,HM-PBI-4-FM,HM-RC-12,HM-RC-12-B,HM-RC-12-SW,HM-RC-19,HM-RC-19-B,HM-RC-19-SW,HM-RC-2-PBU-FM,HM-RC-2-PBU-FM-2,HM-RC-4,HM-RC-4-2,HM-RC-4-3,HM-RC-4-3-D,HM-RC-4-B,HM-RC-8,HM-RC-DIS-H-X-EU,HM-RC-KEY3,HM-RC-KEY3-B,HM-RC-KEY4-2,HM-RC-KEY4-3,HM-RC-P1,HM-RC-SEC3,HM-RC-SEC3-B,HM-RC-SEC4-2,HM-RC-SEC4-3,HM-SCI-3-FM,HM-SEC-CEN,HM-SEC-KEY,HM-SEC-KEY-O,HM-SEC-KEY-S,HM-SEC-MDIR,HM-SEC-MDIR-2,HM-SEC-MDIR-3,HM-SEC-RHS,HM-SEC-RHS-2,HM-SEC-SC,HM-SEC-SC-2,HM-SEC-SCO,HM-SEC-SD,HM-SEC-SD-2,HM-SEC-SFA-SM,HM-SEC-SIR-WM,HM-SEC-TIS,HM-SEC-WDS,HM-SEC-WDS-2,HM-SEC-WIN,HM-SEN-DB-PCB,HM-SEN-EP,HM-SEN-LI-O,HM-SEN-MDIR-O,HM-SEN-MDIR-O-2,HM-SEN-MDIR-O-3,HM-SEN-MDIR-SM,HM-SEN-MDIR-WM55,HM-SEN-RD-O,HM-SEN-WA-OD,HM-SWI-3-FM,HM-SYS-SRP-PL,HM-TC-IT-WM-W-EU,HM-WDC7000,HM-WDS10-TH-O,HM-WDS100-C6-O,HM-WDS100-C6-O-2,HM-WDS20-TH-O,HM-WDS30-OT2-SM,HM-WDS30-OT2-SM-2,HM-WDS30-T-O,HM-WDS40-TH-I,HM-WDS40-TH-I-2,HM-WS550,HM-WS550LCB,HM-WS550LCW,HM-WS550TECH,IS-WDS-TH-OD-S-R3,KFM-DISPLAY,KFM-SENSOR,KS550,KS550LC,KS550TECH,KS888,OLIGO-SMART-IQ-HM,PS-SWITCH,PS-TH-SENS,ROTO_ZEL-STG-RM-DWT-10,ROTO_ZEL-STG-RM-FDK,ROTO_ZEL-STG-RM-FEP-230V,ROTO_ZEL-STG-RM-FFK,ROTO_ZEL-STG-RM-FSA,ROTO_ZEL-STG-RM-FSS-UP3,ROTO_ZEL-STG-RM-FST-UP4,ROTO_ZEL-STG-RM-FWT,ROTO_ZEL-STG-RM-FZS,ROTO_ZEL-STG-RM-FZS-2,ROTO_ZEL-STG-RM-HS-4,ROTO_ZEL-STG-RM-WT-2,S550IA,SCHUECO_263-130,SCHUECO_263-131,SCHUECO_263-132,SCHUECO_263-133,SCHUECO_263-134,SCHUECO_263-135,SCHUECO_263-144,SCHUECO_263-145,SCHUECO_263-146,SCHUECO_263-147,SCHUECO_263-155,SCHUECO_263-157,SCHUECO_263-158,SCHUECO_263-160,SCHUECO_263-162,SCHUECO_263-167,SCHUECO_263-XXX,SENSOTIMER-ST-6,VIRTUAL,WDF-SOLAR,WS888 msgRepeat oldreadings param peerIDs readOnly:0,1 readingOnDead:multiple,noChange,state,periodValues,periodString,channels rssiLog:1,0 serialNr showtime:1,0 stateFormat:textField-long subType:AlarmControl,KFM100,THSensor,blindActuator,blindActuatorSol,dimmer,display,keyMatic,motionAndBtn,motionDetector,no,outputUnit,powerMeter,powerSensor,pushButton,remote,repeater,rgb,senBright,sensRain,sensor,singleButton,siren,smokeDetector,swi,switch,thermostat,threeStateSensor,timer,tipTronic,virtual,winMatic timestamp-on-change-reading
   CFGFN      ./FHEM/00_config_HM_LAN.conf
   DEF        687F37
   FUUID      5df22240-f33f-5615-62ca-e4a195caafa441b3
   HMLAN1_MSGCNT 969
   HMLAN1_RAWMSG E687F37,0000,8444285F,FF,FFB1,E4A610687F3726EB1306010000
   HMLAN1_RSSI -79
   HMLAN1_TIME 2022-05-16 15:04:59
   HMLAN2_MSGCNT 868
   HMLAN2_RAWMSG 0501004BE4A610687F3726EB1306010000
   HMLAN2_RSSI -75
   HMLAN2_TIME 2022-05-16 15:04:59
   HMUSB1_MSGCNT 970
   HMUSB1_RAWMSG 0500003CE4A610687F3726EB1306010000
   HMUSB1_RSSI -60
   HMUSB1_TIME 2022-05-16 15:04:59
   IODev      HMLAN2
   LASTInputDev HMLAN1
   MSGCNT     2807
   NAME       FTS_1.OG_Bad
   NR         180
   NTFY_ORDER 48-FTS_1.OG_Bad
   STATE      closed
   TYPE       CUL_HM
   chanNo     01
   disableNotifyFn 1
   lastMsg    No:E4 - t:10 s:687F37 d:26EB13 06010000
   peerList   WT_1.OG_Bad_WindowRec
   protLastRcv 2022-05-16 15:04:59
   protRcv    970 last_at:2022-05-16 15:04:59
   protRcvB   127 last_at:2022-05-16 14:46:19
   protSnd    843 last_at:2022-05-16 15:04:59
   protState  CMDs_done
   rssi_at_HMLAN1 cnt:969 min:-99 max:-71 avg:-78.84 lst:-79
   rssi_at_HMLAN2 cnt:868 min:-85 max:-55 avg:-69.38 lst:-75
   rssi_at_HMUSB1 cnt:970 min:-73 max:-50 avg:-60.73 lst:-60
   .attraggr:
   .attreocr:
     state
   .attrminint:
     2021-12-11 18:37:45   .D-devInfo      810101
     2021-12-11 18:37:45   .D-stc          80
     2021-12-11 18:37:46   .RegL_00.       00:00 02:01 09:01 0A:26 0B:EB 0C:13 10:01 14:06
     2021-12-11 18:37:47   .RegL_01.       00:00 08:00 20:9C 21:00 30:06
     2021-12-11 18:37:48   .RegL_04.WT_1.OG_Bad_WindowRec 00:00 01:01
     2022-04-21 23:36:51   .associatedWith FTS_1.OG_Bad,FTS_1.OG_Bad,WT_1.OG_Bad_WindowRec
     2021-12-11 18:37:47   .peerListRDate  2021-12-11 18:37:47
     2022-05-16 15:04:59   .protLastRcv    20220516150459
     2022-04-21 23:46:49   Activity        alive
     2021-12-11 18:37:46   CommandAccepted yes
     2021-12-11 18:37:45   D-firmware      1.0
     2021-12-11 18:37:45   D-serialNr      PEQ0568528
     2022-05-16 15:04:59   IODev           HMLAN2
     2022-05-16 14:46:19   Last_State      closed
     2021-12-11 18:37:47   PairedTo        0x26EB13
     2021-12-11 18:37:48   R-WT_1.OG_Bad_WindowRec-expectAES off
     2021-12-11 18:37:48   R-WT_1.OG_Bad_WindowRec-peerNeedsBurst on
     2021-12-11 18:36:17   R-cyclicInfoMsg on
     2021-12-11 18:37:47   R-eventDlyTime  0 s
     2021-12-11 18:37:47   R-msgScPosA     open
     2021-12-11 18:37:47   R-msgScPosB     closed
     2021-12-11 18:36:17   R-pairCentral   0x26EB13
     2021-12-11 18:36:17   R-sabotageMsg   on
     2021-12-11 18:37:47   R-sign          off
     2021-12-11 18:36:17   R-transmDevTryMax 6
     2021-12-11 18:37:47   R-transmitTryMax 6
     2022-05-16 15:04:44   Signal_repetitions 0
     2022-05-16 09:57:44   Timer           -1
     2022-05-16 15:04:59   alive           yes
     2022-05-16 15:04:59   battery         ok
     2021-12-11 19:07:18   cfgState        PeerVerf
     2022-05-16 15:04:59   commState       CMDs_done
     2022-05-16 15:04:59   contact         closed (to HMVCCU)
     2022-04-21 23:36:51   peerList        WT_1.OG_Bad_WindowRec
     2022-05-16 15:04:59   recentStateType info
     2022-05-16 15:04:59   sabotageError   off
     2022-05-16 15:04:59   state           closed
     2022-05-16 14:46:20   trigger_cnt     54
   helper:
     HM_CMDNR   228
     lastMsgTm  1652706299.3799
     mId        00C7
     peerFriend peerAct,peerVirt
     peerIDsState complete
     peerOpt    4:threeStateSensor
     regLst     0,1,4p
     rxType     28
     supp_Pair_Rep 0
     ack:
     cmds:
       TmplKey    WT_1.OG_Bad_WindowRec:no:1650577011.3397
       TmplTs     1650577011.3397
       cmdKey     1:1:0::FTS_1.OG_Bad:00C7:01:WT_1.OG_Bad_WindowRec
       cmdLst:
         assignHmKey noArg
         clear      [({msgErrors}|msgEvents|rssi|attack|trigger|register|oldRegs|readings|all)]
         deviceRename -newName-
         fwUpdate   -filename- [-bootTime-]
         getConfig  noArg
         getDevInfo noArg
         getRegRaw  (List0|List1|List2|List3|List4|List5|List6|List7) [-peerChn-]
         peerBulk   -peer1,peer2,...- [({set}|unset)]
         peerChan   -btnNumber- -actChn- [({single})] [({set}|unset)] [actor|remote|both]
         peerSmart  -peerOpt-
         raw        -data- [...]
         regBulk    -list-.-peerChn- -addr1:data1- [-addr2:data2-]...
         regSet     [(prep|{exec})] -regName- -value- [-peerChn-]
         reset      noArg
         sign       [(on|{off})]
         tplDel     -tplDel-
         tplSet_0   -tplChan-
         tplSet_WT_1.OG_Bad_WindowRec -tplPeer-
         trgEventL  -peer- -condition-
         trgEventS  -peer- -condition-
         trgPressL  [(-peer-|{all})]
         trgPressS  [(-peer-|{all})]
         unpair     noArg
       lst:
         condition  closed,open,tilted
         peer       WT_1.OG_Bad_WindowRec
         peerOpt    remove_WT_1.OG_Bad_WindowRec,1K_Aktor,4K_Switch_K1,4K_Switch_K2,4K_Switch_K3,4K_Switch_K4,FSA_Energiemesser_Sw,FSA_Fhem_Speaker,FSA_WaMa_Sw,GTor_Antrieb,HMVCCU_Btn4,HM_686E79_WindowRec,HM_686E79_remote,HT_1.OG_Bad_WindowRec,HT_1.OG_Bad_remote,HT_Arbeitszimmer_WindowRec,HT_Arbeitszimmer_remote,HT_Kueche_WindowRec,HT_Kueche_remote,RolloAktor_AZ_l,RolloAktor_Kueche,RolloAktor_WZ_Fenster,RolloAktor_WZ_Terrassentuer,WT_1.OG_Bad_remote,WT_Arbeitszimmer_WindowRec,WT_Arbeitszimmer_remote
         tplChan
         tplDel
         tplPeer
       rtrvLst:
         cmdList    [({short}|long)]
         deviceInfo [({short}|long)]
         list       [({normal}|full)]
         param      -param-
         reg        -addr- -list- [-peerChn-]
         regList    noArg
         regTable   noArg
         regVal     -addr- -list- [-peerChn-]
         saveConfig [-filename-]
         tplInfo    noArg
     expert:
       def        1
       det        1
       raw        0
       tpl        0
     io:
       flgs       0
       newChn     +687F37,00,03,00
       nextSend   1652706299.47628
       rxt        2
       vccu       HMVCCU
       p:
         687F37
         00
         03
         00
       prefIO:
         HMLAN2
     mRssi:
       mNo        E4
       io:
         HMLAN1:
           -79
           -79
         HMLAN2:
           -73
           -73
         HMUSB1:
           -60
           -60
     peerIDsH:
       00000000   broadcast
       686DD103   WT_1.OG_Bad_WindowRec
     prt:
       bErr       0
       sProc      0
       sleeping   1
       rspWait:
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
     rpt:
       IO         HMUSB1
       flg        A
       ts         1652706299.3799
       ack:
         HASH(0xaaab199efb50)
         E4800226EB13687F3700
     rssi:
       at_HMLAN1:
         avg        -78.8410732714138
         cnt        969
         lst        -79
         max        -71
         min        -99
       at_HMLAN2:
         avg        -69.3847926267281
         cnt        868
         lst        -75
         max        -55
         min        -85
       at_HMUSB1:
         avg        -60.7319587628866
         cnt        970
         lst        -60
         max        -50
         min        -73
     tmpl:
   .mId       00C7
   AA_Examine on
   AA_Level   high
   Batt_Changedate 2020-12-01
   DbLogExclude .*
   IOgrp      HMVCCU:HMLAN2
   Init_Timer 15
   Signal_Rep_Count 3
   Signal_Rep_Time 5
   Temp_control 1
   Voicetext  Badfenster im ersten Stock offen
   actCycle   028:00
   actStatus  alive
   autoReadReg 4_reqStatus
   comment    Fensterkontakt ist mit WT gepeert
   devStateIcon open:fts_window_1w_open@red closed:fts_window_1w@green deact:fts_window_1w@lightgrey
   enable     1
   event-on-change-reading state
   expert     defReg,allReg
   firmware   1.0
   group      FTS
   icon       fts_window_1w@black
   model      HM-SEC-SCO
   peerIDs    00000000,686DD103
   room       1.OG_Nord,CUL
   serialNr   PEQ0568528
   subType    threeStateSensor
   userattr   AA_Examine AA_Level Init_Timer Signal_Rep_Count Signal_Rep_Time Temp_control
Frage mich, woher das kommen könnte und habe im Forum dazu noch nichts gefunden.
Modulversion: 10_CUL_HM.pm          25298 2021-12-05 08:23:08Z martinp876
Vielen Dank im voraus für Hinweise.
Alex
Titel: Antw:.AttrList der Internals bei allen CUL_HM Objekten mit Schrotteinträgen gefüllt.
Beitrag von: frank am 16 Mai 2022, 15:25:12
ich sehe kein schrott.
Beitrag von: TomLee am 16 Mai 2022, 15:32:28
Zitat von: Homalix99 am 16 Mai 2022, 15:18:55
seit Kurzem ...
Frage mich, woher das kommen könnte ...
Vor Kurzem showInternalValues in global aktiviert ?
Titel: Gelöst: AttrList der Internals bei allen CUL_HM Obj. mit Schrott gefüllt.
Beitrag von: Homalix99 am 16 Mai 2022, 16:33:32
Danke für den Hinweis,
kann mich zwar nicht mehr erinnern, ob und zu welchem Zweck ich das gesetzt haben sollte. Vielleicht kam es mit Umstellung auf Docker, keine Ahnung.
Alex
