ich habe den popp Flow Stop 2 erfolgreich in Betrieb genommen:
https://popp.eu/de/produkte/flow-stop-2/ (https://popp.eu/de/produkte/flow-stop-2/)
Funktioniert soweit auch super, allerdings fehlt das Bild.
Hier mal das Listing von dem Gerät:
DEF e7c578f9 16
FUUID 62e3be83-f33f-b6d9-c458-35d4c6954c206de9
IODev ZWAVE
NAME HZ.ws
NR 644
STATE on
TYPE ZWave
ZWaveSubDevice no
cmdsPending 0
eventCount 2
homeId e7c578f9
isWakeUp
lastMsgSent 1662285170.46176
nodeIdHex 10
2022-09-03 19:03:59 IODev ZWAVE
2022-09-04 14:54:22 alive alive
2022-08-01 21:51:17 assocGroup_1 Max 5 Nodes ZWAVE
2022-08-01 21:51:17 assocGroups 1
2022-08-29 12:54:00 model Popp & Co 009501 Flow Stop
2022-08-29 12:54:00 modelConfig popp/009501.xml
2022-08-29 12:54:00 modelId 0154-0005-0003
2022-08-25 23:11:15 neighborList HZ.co PR.button HZ.kompressor HZ.wm2
2022-08-25 22:57:47 neighborUpdate done
2022-08-01 21:52:36 powerlvl current 0 remain 0
2022-08-31 18:21:29 reportedState on
2022-09-04 11:52:52 routeInfo timeToCb:0.08 repeaters:2 rssi0:-57 dBm rssi1:N/A rssi2:N/A ackCh:1 lastCh:1 scheme:LastWorkingRoute rep:SK.licht HZ.kompressor at 40kbps routeTries:1 lastFailed:
2022-09-04 11:52:50 state on
2022-08-31 18:21:29 swbStatus 255
2022-09-04 11:52:52 timeToAck 1.990
2022-09-04 11:52:52 transmit OK
2022-08-01 21:52:12 zwavePlusInfo version:01 role:AlwaysOnSlave node:Z-Wave+Node installerIcon:1500 userIcon:1500
alias WasserStop
classes ZWAVEPLUS_INFO VERSION MANUFACTURER_SPECIFIC DEVICE_RESET_LOCALLY POWERLEVEL ASSOCIATION ASSOCIATION_GRP_INFO SWITCH_BINARY SWITCH_ALL BASIC
devStateIcon on:aurora@green:off off:aurora@yellow:on .*:checkbox_checked@red
event-on-change-reading state,reportedState
icon aurora
neighborListPos 253,55
readingsWatcher 90000,,state
room Heizraum,Wassermelder
vclasses ASSOCIATION:2 ASSOCIATION_GRP_INFO:1 BASIC:1 DEVICE_RESET_LOCALLY:1 MANUFACTURER_SPECIFIC:2 POWERLEVEL:1 SWITCH_ALL:1 SWITCH_BINARY:1
verbose 2
VG Klaus
Die Bilder kommen von https://products.z-wavealliance.org.
Ich habe da dieses Geraet nicht aufgelistet gefunden.
Ok, was kann/muss ich tun dass das Device ind die https://products.z-wavealliance.org (https://products.z-wavealliance.org) aufgenommen wird ?
Hallo Klaus,
zur Not gibt es einen Workaround.
- Besorg dir ein Bild und kopiere es nach /opt/fhem/www/deviceimages/zwave.
- In /opt/fhem/FHEM/lib gibt es zwei Dateien zwave_....links.csv.gz
- Entpacke die zwave_pepperlinks.csv.gz. Da hat sich am längsten nichts getan.
- Füge in der entpackten zwave_pepperlinks.csv eine Zeile hinzu.
Das erste ist modelId des betreffenden Device
Das zweite ist eigentlich der link zum Download. Bleibt aber leer
Das dritte ist der Dateiname des Bildes - Die csv wieder einpacken. FHEM restart. Fertig
Ich habe auf die Art Bilder bei Geräten hinzugefügt die kein Reading modelId geliefert haben.
Detlef
ZitatOk, was kann/muss ich tun dass das Device ind die https://products.z-wavealliance.org aufgenommen wird ?
Ich nehme an, dass sowas vom Hersteller initiiert wird, und dachte, dass es Teil der Z-Wave Zertifizierung ist.
Zitat von: DetlefR am 05 September 2022, 11:39:07
Hallo Klaus,
Sorry Detlef,
bei mir funktioniert das nicht, ich vermute das hängt damit zusammen, dass das Device in der openzwave_deviceconfig.xml.gz definiert ist.
2022.09.05 20:28:00 3: ZWave got config for popp/009501.xml from ./FHEM/lib/openzwave_deviceconfig.xml.gzVG Klaus
Schade.
Vielleicht kommt ja irgendwann noch das offizielle Bild.
Hallo Experts,
leider hat der Flow Stop noch immer kein Bild.
Gibt es da nichts was ich machen kann ?
VG Klaus
ZitatGibt es da nichts was ich machen kann ?
Selbst Foto machen, es in /opt/fhem/www/deviceimages/zwave ablegen.
Die Datei /opt/fhem/FHEM/lib/zwave_pepperlinks.csv.gz erweitern mit <modelId>,,<BildName-OhnePfad>
Test: ein Refresh im Browser sollte reichen, wenn nicht, FHEM Neustarten.
Wenn alles klappt, Foto und modelId hier anhaengen, und wir bauen das ein.
Hat funktioniert..
Hinzugefügte Zeile in zwave_pepperlinks.csv.gz:
VG Klaus
Danke, habs eingecheckt, bzw. das Bild hochgeladen.
Nach dem heutigem update ist die Zeile:
in die zwave_pepperlinks.csv.gz aufgenommen. DANKE
Sollte nicht das Bild (Flow-Stop.jpg) auch nach /opt/fhem/www/deviceimages/zwave/* verteilt worden sein ?
VG Klaus
ZitatSollte nicht das Bild (Flow-Stop.jpg) auch nach /opt/fhem/www/deviceimages/zwave/* verteilt worden sein ?
Das ist nur ein "Cache" Verzeichnis, d.h. wird nur bei Bedarf gefuellt.
Das ZWave Modul laedt das Bild von fhem.de wenn das Geraet vorhanden ist, und die Detailseite zum ersten mal aufgerufen wird.
