Revision 26607: 10_MQTT2_DEVICE.pm: transition parameter in zigbee2mqtt_RGB2JSON ...
10_MQTT2_DEVICE.pm: transition parameter in zigbee2mqtt_RGB2JSON (Forum: #129932)
Source: Revision 26607: 10_MQTT2_DEVICE.pm: transition parameter in zigbee2mqtt_RGB2JSON ... (http://svn.fhem.de/trac/changeset/26607/trunk)
