es macht mal wieder ein HM-TC-IT-WM-W-EU Problemchen.
Und zeigt der auf dem Display eine andere Temperatur an, als im Reading measured-temp.
Ich habe da zwar mal was mit tempOffset rumgespielt, kann das ggf. das Problem sein?
Anbei mal list vom Device und vom Climate Channel.
.AttrList .devInfo .mId .stc IODev IOgrp actCycle actStatus aesCommReq:1,0 aesKey:5,4,3,2,1,0 autoReadReg:0_off,1_restart,2_pon-restart,3_onChange,4_reqStatus,5_readMissing,8_stateOnly burstAccess:0_off,1_auto commStInCh:on,off do_not_notify:1,0 dummy:1,0 event-aggregator event-min-interval event-on-change-reading event-on-update-reading expert:multiple,defReg,allReg,rawReg,templ,none firmware hmKey hmKey2 hmKey3 hmProtocolEvents:0_off,1_dump,2_dumpFull,3_dumpTrigger ignore:1,0 model modelForce:ACTIONDETECTOR,ACTIONDETECTOR,ASH550,ASH550I,CCU-FHEM,CMM,DORMA_ATENT,DORMA_BRC-H,DORMA_RC-H,HM-CC-RT-DN,HM-CC-RT-DN-BOM,HM-CC-SCD,HM-CC-TC,HM-CC-VD,HM-DIS-EP-WM55,HM-DIS-TD-T,HM-DIS-WM55,HM-DW-WM,HM-ES-PMSW1-DR,HM-ES-PMSW1-PL,HM-ES-PMSW1-PL-DN-R1,HM-ES-PMSW1-PL-DN-R2,HM-ES-PMSW1-PL-DN-R3,HM-ES-PMSW1-PL-DN-R4,HM-ES-PMSW1-PL-DN-R5,HM-ES-PMSW1-SM,HM-ES-TX-WM,HM-HM-LC-DW-WM,HM-LC-AO-SM,HM-LC-BL1-FM,HM-LC-BL1-FM-2,HM-LC-BL1-PB-FM,HM-LC-BL1-SM,HM-LC-BL1-SM-2,HM-LC-BL1PBU-FM,HM-LC-DDC1-PCB,HM-LC-DIM1L-CV,HM-LC-DIM1L-CV-2,HM-LC-DIM1L-CV-644,HM-LC-DIM1L-PL,HM-LC-DIM1L-PL-2,HM-LC-DIM1L-PL-3,HM-LC-DIM1L-PL-644,HM-LC-DIM1PWM-CV,HM-LC-DIM1PWM-CV-2,HM-LC-DIM1T-CV,HM-LC-DIM1T-CV-2,HM-LC-DIM1T-CV-644,HM-LC-DIM1T-DR,HM-LC-DIM1T-FM,HM-LC-DIM1T-FM-2,HM-LC-DIM1T-FM-644,HM-LC-DIM1T-FM-LF,HM-LC-DIM1T-PL,HM-LC-DIM1T-PL-2,HM-LC-DIM1T-PL-3,HM-LC-DIM1T-PL-644,HM-LC-DIM1TPBU-FM,HM-LC-DIM1TPBU-FM-2,HM-LC-DIM2L-CV,HM-LC-DIM2L-SM,HM-LC-DIM2L-SM-2,HM-LC-DIM2L-SM-644,HM-LC-DIM2T-SM,HM-LC-DIM2T-SM,HM-LC-DIM2T-SM-2,HM-LC-JA1PBU-FM,HM-LC-RGBW-WM,HM-LC-SW1-BA-PCB,HM-LC-SW1-DR,HM-LC-SW1-FM,HM-LC-SW1-FM-2,HM-LC-SW1-PB-FM,HM-LC-SW1-PCB,HM-LC-SW1-PL,HM-LC-SW1-PL-3,HM-LC-SW1-PL-CT-R1,HM-LC-SW1-PL-CT-R2,HM-LC-SW1-PL-CT-R3,HM-LC-SW1-PL-CT-R4,HM-LC-SW1-PL-CT-R5,HM-LC-SW1-PL-DN-R1,HM-LC-SW1-PL-DN-R2,HM-LC-SW1-PL-DN-R3,HM-LC-SW1-PL-DN-R4,HM-LC-SW1-PL-DN-R5,HM-LC-SW1-PL-OM54,HM-LC-SW1-PL2,HM-LC-SW1-SM,HM-LC-SW1-SM-2,HM-LC-SW1-SM-ATMEGA168,HM-LC-SW1PBU-FM,HM-LC-SW2-DR,HM-LC-SW2-DR-2,HM-LC-SW2-FM,HM-LC-SW2-FM-2,HM-LC-SW2-PB-FM,HM-LC-SW2-SM,HM-LC-SW2PBU-FM,HM-LC-SW4-BA-PCB,HM-LC-SW4-DR,HM-LC-SW4-DR-2,HM-LC-SW4-PCB,HM-LC-SW4-PCB-2,HM-LC-SW4-SM,HM-LC-SW4-SM-2,HM-LC-SW4-SM-ATMEGA168,HM-LC-SW4-WM,HM-LC-SW4-WM-2,HM-MOD-EM-8,HM-MOD-EM-8BIT,HM-MOD-RE-8,HM-OU-CF-PL,HM-OU-CFM-PL,HM-OU-CFM-TW,HM-OU-CM-PCB,HM-OU-LED16,HM-PB-2-FM,HM-PB-2-WM,HM-PB-2-WM55,HM-PB-2-WM55-2,HM-PB-4-WM,HM-PB-4DIS-WM,HM-PB-4DIS-WM-2,HM-PB-6-WM55,HM-PBI-4-FM,HM-RC-12,HM-RC-12-B,HM-RC-12-SW,HM-RC-19,HM-RC-19-B,HM-RC-19-SW,HM-RC-2-PBU-FM,HM-RC-2-PBU-FM-2,HM-RC-4,HM-RC-4-2,HM-RC-4-3,HM-RC-4-3-D,HM-RC-4-B,HM-RC-8,HM-RC-DIS-H-X-EU,HM-RC-KEY3,HM-RC-KEY3-B,HM-RC-KEY4-2,HM-RC-KEY4-3,HM-RC-P1,HM-RC-SEC3,HM-RC-SEC3-B,HM-RC-SEC4-2,HM-RC-SEC4-3,HM-SCI-3-FM,HM-SEC-CEN,HM-SEC-KEY,HM-SEC-KEY-O,HM-SEC-KEY-S,HM-SEC-MDIR,HM-SEC-MDIR-2,HM-SEC-MDIR-3,HM-SEC-RHS,HM-SEC-RHS-2,HM-SEC-SC,HM-SEC-SC-2,HM-SEC-SCO,HM-SEC-SD,HM-SEC-SD-2,HM-SEC-SFA-SM,HM-SEC-SIR-WM,HM-SEC-TIS,HM-SEC-WDS,HM-SEC-WDS-2,HM-SEC-WIN,HM-SEN-DB-PCB,HM-SEN-EP,HM-SEN-LI-O,HM-SEN-MDIR-O,HM-SEN-MDIR-O-2,HM-SEN-MDIR-O-3,HM-SEN-MDIR-SM,HM-SEN-MDIR-WM55,HM-SEN-RD-O,HM-SEN-WA-OD,HM-SWI-3-FM,HM-SYS-SRP-PL,HM-TC-IT-WM-W-EU,HM-WDC7000,HM-WDS10-TH-O,HM-WDS100-C6-O,HM-WDS100-C6-O-2,HM-WDS20-TH-O,HM-WDS30-OT2-SM,HM-WDS30-OT2-SM-2,HM-WDS30-T-O,HM-WDS40-TH-I,HM-WDS40-TH-I-2,HM-WS550,HM-WS550LCB,HM-WS550LCW,HM-WS550TECH,IS-WDS-TH-OD-S-R3,KFM-DISPLAY,KFM-SENSOR,KS550,KS550LC,KS550TECH,KS888,OLIGO-SMART-IQ-HM,PS-SWITCH,PS-TH-SENS,ROTO_ZEL-STG-RM-DWT-10,ROTO_ZEL-STG-RM-FDK,ROTO_ZEL-STG-RM-FEP-230V,ROTO_ZEL-STG-RM-FFK,ROTO_ZEL-STG-RM-FSA,ROTO_ZEL-STG-RM-FSS-UP3,ROTO_ZEL-STG-RM-FST-UP4,ROTO_ZEL-STG-RM-FWT,ROTO_ZEL-STG-RM-FZS,ROTO_ZEL-STG-RM-FZS-2,ROTO_ZEL-STG-RM-HS-4,ROTO_ZEL-STG-RM-WT-2,S550IA,SCHUECO_263-130,SCHUECO_263-131,SCHUECO_263-132,SCHUECO_263-133,SCHUECO_263-134,SCHUECO_263-135,SCHUECO_263-144,SCHUECO_263-145,SCHUECO_263-146,SCHUECO_263-147,SCHUECO_263-155,SCHUECO_263-157,SCHUECO_263-158,SCHUECO_263-160,SCHUECO_263-162,SCHUECO_263-167,SCHUECO_263-XXX,SENSOTIMER-ST-6,VIRTUAL,WDF-SOLAR,WS888 msgRepeat oldreadings param readOnly:0,1 readingOnDead:multiple,noChange,state,periodValues,periodString,channels rssiLog:1,0 serialNr showtime:1,0 stateFormat:textField-long subType:AlarmControl,KFM100,THSensor,blindActuator,blindActuatorSol,dimmer,display,keyMatic,motionAndBtn,motionDetector,no,outputUnit,powerMeter,powerSensor,pushButton,remote,repeater,rgb,senBright,sensRain,sensor,singleButton,siren,smokeDetector,swi,switch,thermostat,threeStateSensor,timer,tipTronic,virtual,winMatic timestamp-on-change-reading
.lastTimemeasured-temp 1667830516.53428
.triggerUsed 1
DEF 303ABC
FUUID 63307ceb-f33f-7b3d-db6f-76840c875e8f7615
IODev myHMLGW_Schlafzimmer
LASTInputDev myHMLGW_Schlafzimmer
MSGCNT 50553
NAME HM_303ABC
NR 269
NTFY_ORDER 48-HM_303ABC
STATE CMDs_done
TYPE CUL_HM
channel_01 HM_303ABC_Weather
channel_02 HM_303ABC_Climate
channel_03 HM_303ABC_WindowRec
channel_06 HM_303ABC_remote
channel_07 HM_303ABC_SwitchTr
disableNotifyFn 1
eventCount 1506
lastMsg No:47 - t:70 s:303ABC d:000000 00BD3E
myHMLGW_MSGCNT 25268
myHMLGW_RAWMSG 0500003E478470303ABC00000000BD3E
myHMLGW_RSSI -62
myHMLGW_Schlafzimmer_MSGCNT 25285
myHMLGW_Schlafzimmer_RAWMSG 05000042478470303ABC00000000BD3E
myHMLGW_Schlafzimmer_RSSI -66
myHMLGW_Schlafzimmer_TIME 2022-11-07 15:41:03
myHMLGW_TIME 2022-11-07 15:41:03
protCmdDel 3
protLastRcv 2022-11-07 15:41:03
protNack 3 last_at:2022-10-22 17:39:51
protRcv 25314 last_at:2022-11-07 15:41:03
protSnd 292 last_at:2022-11-07 12:52:26
protSndB 30 last_at:2022-11-07 12:52:25
protState CMDs_done
rssi_at_myHMLGW cnt:25268 min:-92 max:-33 avg:-66.64 lst:-62
rssi_at_myHMLGW_Schlafzimmer cnt:25285 min:-93 max:-55 avg:-64.13 lst:-66
rssi_myHMLGW_Schlafzimmer cnt:30 min:-62 max:-52 avg:-56.7 lst:-58
.attraggr:
.attrminint:
measured-temp:60
CL:
Authenticated 0
BUF
FD 22
FW_ID 252523
LASTACCESS 1667832147.37085
NAME WEB_192.168.178.40_53284
NR 252524
PEER 192.168.178.40
PORT 53284
SNAME WEB
SSL
STATE Connected
TEMPORARY 1
TYPE FHEMWEB
canAsyncOutput 1
encoding UTF-8
.attraggr:
.attrminint:
2022-11-07 15:42:22 state Connected
2022-10-22 09:24:59 .D-devInfo 03FFFF
2022-10-22 09:24:59 .D-stc 58
2022-09-27 17:33:28 .R-btnLock off
2022-09-27 17:33:28 .R-burstRx on
2022-09-27 17:33:28 .R-cyclicInfoMsg on
2022-09-27 17:33:28 .R-cyclicInfoMsgDis 0
2022-09-27 17:33:28 .R-globalBtnLock off
2022-09-27 17:33:28 .R-localResDis off
2022-09-27 17:33:28 .R-lowBatLimitRT 2.2 V
2022-09-27 17:33:28 .R-modusBtnLock off
2022-10-22 19:19:24 .R-pairCentral 0x9A234E
2022-10-22 10:48:32 .associatedWith HM_303ABC,HM_303ABC_Climate,HM_303ABC_SwitchTr,HM_303ABC_Weather,HM_303ABC_WindowRec,HM_303ABC_remote,HM_303ABC
2022-11-07 15:41:03 .protLastRcv 20221107154103
2022-11-07 12:52:26 CommandAccepted yes
2022-10-22 09:24:59 D-firmware 1.3
2022-10-22 09:24:59 D-serialNr LEQ1215838
2022-11-07 12:52:25 IODev myHMLGW_Schlafzimmer
2022-11-07 12:52:01 PairedTo 0x9A234E
2022-11-07 12:52:01 RegL_00. 00:00 01:01 02:01 09:01 0A:9A 0B:23 0C:4E 0F:00 11:00 12:16 16:00 18:00 19:00 1A:00
2022-11-07 15:15:16 battery ok
2022-11-07 15:15:16 batteryLevel 2.9
2022-11-07 12:53:15 cfgState ok
2022-11-07 12:52:26 commState CMDs_done
2022-11-07 15:15:16 desired-temp 18.0
2022-11-07 15:15:16 measured-temp 18.9
2022-10-22 09:23:47 powerOn 2022-10-22 09:23:47
2022-10-22 09:23:47 recentStateType info
2022-11-07 12:52:26 state CMDs_done
2022-10-22 09:25:15 time-request -
RegL_07.:
VAL
helper:
HM_CMDNR 71
PONtest 1
cSnd 119A234E303ABC860424,119A234E303ABC860224
cfgChkResult No regs found for:HM_303ABC-ret--ret-
cfgStateUpdt 0
lastMsgTm 1667832063.54521
mId 00AD
peerFriend -
peerOpt -:thermostat
regLst 0
rxType 6
supp_Pair_Rep 0
ack:
cmds:
TmplKey :no:1666428512.84309
TmplTs 1666428512.84309
cmdKey 0:1:0::HM_303ABC:00AD:00:
cmdLst:
assignHmKey noArg
clear [({msgErrors}|msgEvents|rssi|attack|trigger|register|oldRegs|readings|all)]
deviceRename -newName-
fwUpdate -filename- [-bootTime-]
getConfig noArg
getDevInfo noArg
getRegRaw (List0|List1|List2|List3|List4|List5|List6|List7) [-peerChn-]
inhibit [(on|{off})]
raw -data- [...]
regBulk -list-.-peerChn- -addr1:data1- [-addr2:data2-]...
regSet [(prep|{exec})] -regName- -value- [-peerChn-]
reset noArg
sysTime noArg
tplDel -tplDel-
tplSet_0 -tplChan-
unpair noArg
lst:
condition slider,0,1,255
peer
peerOpt
tplChan
tplDel
tplPeer
rtrvLst:
cmdList [({short}|long)]
deviceInfo [({short}|long)]
list [({normal}|full)]
param -param-
reg -addr- -list- [-peerChn-]
regList noArg
regTable noArg
regVal -addr- -list- [-peerChn-]
saveConfig [-filename-]
tplInfo noArg
expert:
def 0
det 0
raw 1
tpl 0
io:
flgs 0
newChn +303ABC,00,00,00
nextSend 1667832063.63968
rxt 0
vccu myVCCU
p:
303ABC
00
00
00
prefIO:
mRssi:
mNo 47
io:
myHMLGW:
-62
-62
myHMLGW_Schlafzimmer:
-62
-62
peerIDsH:
prt:
awake 0
bErr 0
sProc 0
tryMsg:
q:
qReqConf
qReqStat
regCollect:
role:
dev 1
prs 1
rssi:
at_myHMLGW:
avg -66.6427892987179
cnt 25268
lst -62
max -33
min -92
at_myHMLGW_Schlafzimmer:
avg -64.1393316195379
cnt 25285
lst -66
max -55
min -93
avg -56.7
cnt 30
lst -58
max -52
min -62
shRegW:
07 02
shadowReg:
tmpl:
nb:
cnt 1
.mId 00AD
IOgrp myVCCU:myHMLGW_Schlafzimmer
alias Wohnzimmer
autoReadReg 4_reqStatus
event-min-interval measured-temp:60
expert rawReg
firmware 1.3
model HM-TC-IT-WM-W-EU
msgRepeat 1
room Temperatur
serialNr LEQ1215838
subType thermostat
webCmd getConfig:clear msgEvents
.AttrList aesCommReq:1,0 do_not_notify:1,0 event-aggregator event-min-interval event-on-change-reading event-on-update-reading expert:multiple,defReg,allReg,rawReg,templ,none levelMap levelRange model oldreadings param peerIDs readOnly:0,1 showtime:1,0 stateFormat:textField-long tempListTmpl timestamp-on-change-reading
.lastTimemeasured-temp 1667832043.54624
.triggerUsed 1
DEF 303ABC02
FUUID 63307ceb-f33f-7b3d-99a5-ace9d1096ecdebf2
NAME HM_303ABC_Climate
NR 271
NTFY_ORDER 48-HM_303ABC_Climate
STATE T: 18.9 desired: 18.0
TYPE CUL_HM
chanNo 02
device HM_303ABC
disableNotifyFn 1
eventCount 10624
.attraggr:
.attrminint:
measured-temp:300
CL:
Authenticated 0
BUF
FD 23
FW_ID 252502
LASTACCESS 1667832057.18528
NAME WEB_192.168.178.40_53242
NR 252503
PEER 192.168.178.40
PORT 53242
SNAME WEB
SSL
STATE Connected
TEMPORARY 1
TYPE FHEMWEB
canAsyncOutput 1
encoding UTF-8
.attraggr:
.attrminint:
2022-11-07 15:40:50 state Connected
2022-09-27 17:33:33 .R-boostPeriod 5 min
2022-09-27 17:33:33 .R-dayTemp 21 C
2022-09-27 17:33:33 .R-daylightSaveTime on
2022-09-27 17:33:33 .R-heatCool heating
2022-09-27 17:33:33 .R-modePrioManu all
2022-09-27 17:33:33 .R-modePrioParty all
2022-09-27 17:33:33 .R-nightTemp 17 C
2022-09-27 17:33:33 .R-noMinMax4Manu off
2022-11-07 12:51:28 .R-sendWeatherData on
2022-11-07 12:51:28 .R-showHumidity temp
2022-09-27 17:33:33 .R-showInfo time
2022-11-07 12:51:28 .R-showSetTemp actTemp
2022-09-27 17:33:33 .R-showWeekday off
2022-09-27 17:33:29 .R-sign off
2022-09-27 17:33:33 .R-tempMax 30.5 C
2022-09-27 17:33:33 .R-tempMin 4.5 C
2022-11-07 12:51:28 .R-tempOffset 0.0K
2022-09-27 17:33:33 .R-weekPrgSel prog1
2022-09-27 17:33:33 .R-winOpnBoost off
2022-11-07 12:52:02 .associatedWith HM_303ABC,HM_303ABC_Climate,HM_303ABC_SwitchTr,HM_303ABC_Weather,HM_303ABC_WindowRec,HM_303ABC_remote,HM_303ABC
2022-11-07 12:52:02 .peerListRDate 2022-11-07 12:52:02
2022-11-07 12:52:06 R_P1_0_tempListSat 06:00 17.0 22:00 21.0 24:00 17.0
2022-11-07 12:52:06 R_P1_1_tempListSun 06:00 17.0 22:00 21.0 24:00 17.0
2022-11-07 12:52:06 R_P1_2_tempListMon 06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0
2022-11-07 12:52:06 R_P1_3_tempListTue 06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0
2022-11-07 12:52:06 R_P1_4_tempListWed 06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0
2022-11-07 12:52:06 R_P1_5_tempListThu 06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0
2022-11-07 12:52:06 R_P1_6_tempListFri 06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0
2022-11-07 12:52:06 R_P1_tempList_State verified
2022-11-07 12:52:10 R_P2_0_tempListSat 24:00 17.0
2022-11-07 12:52:10 R_P2_1_tempListSun 24:00 17.0
2022-11-07 12:52:10 R_P2_2_tempListMon 24:00 17.0
2022-11-07 12:52:10 R_P2_3_tempListTue 24:00 17.0
2022-11-07 12:52:10 R_P2_4_tempListWed 24:00 17.0
2022-11-07 12:52:10 R_P2_5_tempListThu 24:00 17.0
2022-11-07 12:52:10 R_P2_6_tempListFri 24:00 17.0
2022-11-07 12:52:10 R_P2_tempList_State verified
2022-11-07 12:52:13 R_P3_0_tempListSat 24:00 17.0
2022-11-07 12:52:13 R_P3_1_tempListSun 24:00 17.0
2022-11-07 12:52:13 R_P3_2_tempListMon 24:00 17.0
2022-11-07 12:52:13 R_P3_3_tempListTue 24:00 17.0
2022-11-07 12:52:13 R_P3_4_tempListWed 24:00 17.0
2022-11-07 12:52:13 R_P3_5_tempListThu 24:00 17.0
2022-11-07 12:52:13 R_P3_6_tempListFri 24:00 17.0
2022-11-07 12:52:13 R_P3_tempList_State verified
2022-11-07 12:52:02 RegL_01. 00:00 08:00
2022-11-07 12:52:06 RegL_07. 00:00 01:2A 02:22 03:09 04:3D 05:00 06:00 07:00 08:00 09:87 0A:30 0B:00 0C:00 0D:00 0E:01 0F:04 10:00 11:00 12:09 13:00 14:44 15:48 16:55 17:08 18:45 19:20 1A:45 1B:20 1C:45 1D:20 1E:45 1F:20 20:45 21:20 22:45 23:20 24:45 25:20 26:45 27:20 28:45 29:20 2A:45 2B:20 2C:45 2D:20 2E:44 2F:48 30:55 31:08 32:45 33:20 34:45 35:20 36:45 37:20 38:45 39:20 3A:45 3B:20 3C:45 3D:20 3E:45 3F:20 40:45 41:20 42:45 43:20 44:45 45:20 46:45 47:20 48:44 49:48 4A:54 4B:6C 4C:44 4D:CC 4E:55 4F:08 50:45 51:20 52:45 53:20 54:45 55:20 56:45 57:20 58:45 59:20 5A:45 5B:20 5C:45 5D:20 5E:45 5F:20 60:45 61:20 62:44 63:48 64:54 65:6C 66:44 67:CC 68:55 69:08 6A:45 6B:20 6C:45 6D:20 6E:45 6F:20 70:45 71:20 72:45 73:20 74:45 75:20 76:45 77:20 78:45 79:20 7A:45 7B:20 7C:44 7D:48 7E:54 7F:6C 80:44 81:CC 82:55 83:08 84:45 85:20 86:45 87:20 88:45 89:20 8A:45 8B:20 8C:45 8D:20 8E:45 8F:20 90:45 91:20 92:45 93:20 94:45 95:20 96:44 97:48 98:54 99:6C 9A:44 9B:CC 9C:55 9D:08 9E:45 9F:20 A0:45 A1:20 A2:45 A3:20 A4:45 A5:20 A6:45 A7:20 A8:45 A9:20 AA:45 AB:20 AC:45 AD:20 AE:45 AF:20 B0:44 B1:48 B2:54 B3:6C B4:44 B5:CC B6:55 B7:08 B8:45 B9:20 BA:45 BB:20 BC:45 BD:20 BE:45 BF:20 C0:45 C1:20 C2:45 C3:20 C4:45 C5:20 C6:45 C7:20 C8:45 C9:20 CA:00 CB:00 CC:00 CD:00 CE:00 CF:00
2022-11-07 12:52:10 RegL_08. 00:00 01:00 02:00 03:00 04:00 05:00 06:00 07:00 08:00 09:00 0A:00 0B:00 0C:00 0D:00 0E:00 0F:00 10:00 11:00 12:00 13:00 14:45 15:20 16:45 17:20 18:45 19:20 1A:45 1B:20 1C:45 1D:20 1E:45 1F:20 20:45 21:20 22:45 23:20 24:45 25:20 26:45 27:20 28:45 29:20 2A:45 2B:20 2C:45 2D:20 2E:45 2F:20 30:45 31:20 32:45 33:20 34:45 35:20 36:45 37:20 38:45 39:20 3A:45 3B:20 3C:45 3D:20 3E:45 3F:20 40:45 41:20 42:45 43:20 44:45 45:20 46:45 47:20 48:45 49:20 4A:45 4B:20 4C:45 4D:20 4E:45 4F:20 50:45 51:20 52:45 53:20 54:45 55:20 56:45 57:20 58:45 59:20 5A:45 5B:20 5C:45 5D:20 5E:45 5F:20 60:45 61:20 62:45 63:20 64:45 65:20 66:45 67:20 68:45 69:20 6A:45 6B:20 6C:45 6D:20 6E:45 6F:20 70:45 71:20 72:45 73:20 74:45 75:20 76:45 77:20 78:45 79:20 7A:45 7B:20 7C:45 7D:20 7E:45 7F:20 80:45 81:20 82:45 83:20 84:45 85:20 86:45 87:20 88:45 89:20 8A:45 8B:20 8C:45 8D:20 8E:45 8F:20 90:45 91:20 92:45 93:20 94:45 95:20 96:45 97:20 98:45 99:20 9A:45 9B:20 9C:45 9D:20 9E:45 9F:20 A0:45 A1:20 A2:45 A3:20 A4:45 A5:20 A6:45 A7:20 A8:45 A9:20 AA:45 AB:20 AC:45 AD:20 AE:45 AF:20 B0:45 B1:20 B2:45 B3:20 B4:45 B5:20 B6:45 B7:20 B8:45 B9:20 BA:45 BB:20 BC:45 BD:20 BE:45 BF:20 C0:45 C1:20 C2:45 C3:20 C4:45 C5:20 C6:45 C7:20 C8:45 C9:20 CA:00 CB:00 CC:00 CD:00 CE:00 CF:00
2022-11-07 12:52:13 RegL_09. 00:00 01:00 02:00 03:00 04:00 05:00 06:00 07:00 08:00 09:00 0A:00 0B:00 0C:00 0D:00 0E:00 0F:00 10:00 11:00 12:00 13:00 14:45 15:20 16:45 17:20 18:45 19:20 1A:45 1B:20 1C:45 1D:20 1E:45 1F:20 20:45 21:20 22:45 23:20 24:45 25:20 26:45 27:20 28:45 29:20 2A:45 2B:20 2C:45 2D:20 2E:45 2F:20 30:45 31:20 32:45 33:20 34:45 35:20 36:45 37:20 38:45 39:20 3A:45 3B:20 3C:45 3D:20 3E:45 3F:20 40:45 41:20 42:45 43:20 44:45 45:20 46:45 47:20 48:45 49:20 4A:45 4B:20 4C:45 4D:20 4E:45 4F:20 50:45 51:20 52:45 53:20 54:45 55:20 56:45 57:20 58:45 59:20 5A:45 5B:20 5C:45 5D:20 5E:45 5F:20 60:45 61:20 62:45 63:20 64:45 65:20 66:45 67:20 68:45 69:20 6A:45 6B:20 6C:45 6D:20 6E:45 6F:20 70:45 71:20 72:45 73:20 74:45 75:20 76:45 77:20 78:45 79:20 7A:45 7B:20 7C:45 7D:20 7E:45 7F:20 80:45 81:20 82:45 83:20 84:45 85:20 86:45 87:20 88:45 89:20 8A:45 8B:20 8C:45 8D:20 8E:45 8F:20 90:45 91:20 92:45 93:20 94:45 95:20 96:45 97:20 98:45 99:20 9A:45 9B:20 9C:45 9D:20 9E:45 9F:20 A0:45 A1:20 A2:45 A3:20 A4:45 A5:20 A6:45 A7:20 A8:45 A9:20 AA:45 AB:20 AC:45 AD:20 AE:45 AF:20 B0:45 B1:20 B2:45 B3:20 B4:45 B5:20 B6:45 B7:20 B8:45 B9:20 BA:45 BB:20 BC:45 BD:20 BE:45 BF:20 C0:45 C1:20 C2:45 C3:20 C4:45 C5:20 C6:45 C7:20 C8:45 C9:20 CA:00 CB:00 CC:00 CD:00 CE:00 CF:00
2022-11-07 15:15:16 boostTime -
2022-11-07 12:53:15 cfgState TempChk
2022-11-07 15:15:16 commReporting off
2022-11-07 15:15:16 controlMode manual
2022-11-07 15:40:43 desired-temp 18.0
2022-11-07 15:40:43 humidity 62
2022-11-07 15:40:43 measured-temp 18.9
2022-11-07 12:52:26 recentStateType ack
2022-11-07 15:40:43 state T: 18.9 desired: 18.0
2022-10-09 20:17:01 trigLast fhem:80
2022-11-07 15:15:16 winOpenReporting off
helper:
cfgChkResult No regs found for:-ret--ret-HM_303ABC_Climate type:thermostat - -ret-list:peer register :value-ret- 1: sign :off-ret- 7: boostPeriod :5 min-ret- 7: dayTemp :21 C-ret- 7: daylightSaveTime :on-ret- 7: heatCool :heating-ret- 7: modePrioManu :all-ret- 7: modePrioParty :all-ret- 7: nightTemp :17 C-ret- 7: noMinMax4Manu :off-ret- 7: sendWeatherData :set_on-ret- 7: showHumidity :set_temp-ret- 7: showInfo :time-ret- 7: showSetTemp :set_actTemp-ret- 7: showWeekday :off-ret- 7: tempMax :30.5 C-ret- 7: tempMin :4.5 C-ret- 7: tempOffset :set_-1.0K-ret- 7: weekPrgSel :prog1-ret- 7: winOpnBoost :off-ret-Temp set P2_: 0_Sat 24:00 17.0 C-ret-Temp set P2_: 1_Sun 24:00 17.0 C-ret-Temp set P2_: 2_Mon 24:00 17.0 C-ret-Temp set P2_: 3_Tue 24:00 17.0 C-ret-Temp set P2_: 4_Wed 24:00 17.0 C-ret-Temp set P2_: 5_Thu 24:00 17.0 C-ret-Temp set P2_: 6_Fri 24:00 17.0 C-ret-Temp set P3_: 0_Sat 24:00 17.0 C-ret-Temp set P3_: 1_Sun 24:00 17.0 C-ret-Temp set P3_: 2_Mon 24:00 17.0 C-ret-Temp set P3_: 3_Tue 24:00 17.0 C-ret-Temp set P3_: 4_Wed 24:00 17.0 C-ret-Temp set P3_: 5_Thu 24:00 17.0 C-ret-Temp set P3_: 6_Fri 24:00 17.0 C-ret- -ret- -ret-
peerFriend peerRtTc
peerIDsRaw ,00000000
peerIDsState complete
peerOpt p:thermostat
regLst 1,7,8,9
cfgChk:
idTp00 file: ./tempList.cfg error:Can't open ./tempList.cfg: No such file or directory
cmds:
TmplKey :no:1666428512.8437
TmplTs 1666428512.8437
cmdKey 1:0:0::HM_303ABC:00AD:02:
cmdLst:
controlManu (on|off|5.0..30.0;0.5)
controlMode (auto|manual|boost|day|night)
controlParty -temp- -startDate- -startTime- -endDate- -endTime-
desired-temp (on|off|5.0..30.0;0.5)
getConfig noArg
peerBulk -peer1,peer2,...- [({set}|unset)]
peerChan -btnNumber- -actChn- [({single})] [({set}|unset)] [(actor|remote|{both})]
sign [(on|{off})]
tempListFri [(prep|{exec})] [({p1}|p2|p3)] -HH:MM- -temp- [...]
tempListMon [(prep|{exec})] [({p1}|p2|p3)] -HH:MM- -temp- [...]
tempListSat [(prep|{exec})] [({p1}|p2|p3)] -HH:MM- -temp- [...]
tempListSun [(prep|{exec})] [({p1}|p2|p3)] -HH:MM- -temp- [...]
tempListThu [(prep|{exec})] [({p1}|p2|p3)] -HH:MM- -temp- [...]
tempListTmpl [({verify}|restore)] [[-file-:]-templateName-]
tempListTue [(prep|{exec})] [({p1}|p2|p3)] -HH:MM- -temp- [...]
tempListWed [(prep|{exec})] [({p1}|p2|p3)] -HH:MM- -temp- [...]
tempTmplSet -tempTmpl-
tplDel -tplDel-
tplSet_0 -tplChan-
lst:
peer
peerOpt
tplChan
tplDel
tplPeer
rtrvLst:
param -param-
regList noArg
regTable noArg
tplInfo noArg
expert:
def 0
det 0
raw 1
tpl 0
peerIDsH:
00000000 broadcast
regCollect:
role:
chn 1
shRegR:
07 00
shadowReg:
tmpl:
nb:
cnt 1
alias Wohnzimmer_Climate
event-min-interval measured-temp:300
peerIDs 00000000
room Temperatur
da kann man doch einstellen ob er die gemessene Temp oder die eingestellte Temp anzeigt.
Gruß Rolf
Danke für die Idee.
Aber es ist halt weder die aktuelle (measured-temp 18.9) noch die eingestellte (desired-temp 18.0) Temperatur.
Register => https://wiki.fhem.de/wiki/HM-TC-IT-WM-W-EU#Anzeige (https://wiki.fhem.de/wiki/HM-TC-IT-WM-W-EU#Anzeige) entsprechend gesetzt?
Sorry, verstehe ich jetzt nicht.
Ist doch das gleiche wie rvideobear es meinte oder?
Es ist ja weder die aktuelle Temperatur (da im Reading measured-temp 18.9 steht) und auch nicht die Soll-Temperatur (da im Reading desired-Temp 18.0) steht.
Oder bin ich komplett auf dem falschen Weg?
Neee, stimmt. Zumal der TC auch die aktuelle Temperatur (measured-temp imho) anzeigen soll:
Aber keine Ahnung woher die Diskrepanz zwischen Display-Anzeige und measured-temp kommen kann dann. Zeigt der TC ggf einen Messwert eines anderen Geräts an? :o
Hat dazu keiner eine Idee?
Das Dingen schmeisse ich glaube ich in die Tonne.
Werksreset hat auch nichts gebracht.
Momentan steht auf dem Display 24.3° unter measured-temp allerdings 19.2°
welche temp ist richtig?
vielleicht ein problem durch das update.
nach fw update mache ich grundsätzlich werkreset.
Also Deine Idee war gar nicht soooo verkehrt. Problem ist gelöst, aber eigentlich darf ich gar nicht sagen, was es war. ???
Denn ich habe ja 4 Thermostate auf einmal implementiert. Irgendwer hat mir wohl einen Streich gespielt und 2 vertauscht, so dass im Wohnzimmer das vom WC hing und umgekehrt. Klar, dass da die Angaben unterschiedlich sind.
Und im WC habe ich selten drauf geschaut.
Naja, nun ist es ja gelöst.
Wobei mit dem FW Update habe ich mir den einen wohl zerschossen.
Zeigt mein Reset ein "FUP" an und ist in FHEM auch nicht mehr richtig anzusprechen.
Gibt es da eine Möglichkeit, den wieder ins Leben zu rufen?
mit Geduld und etwas Glück:
https://forum.fhem.de/index.php/topic,98902.msg922639.html#msg922639
Jetzt suche und google ich schon 15 Minuten nach der 1.3 FW.
Da hast du doch bestimmt auch einen Link unter der Maus. 8)
lag bei mir noch lokal - anhängend.
