Nach dem Update heute startet FHEM nicht mehr.
2022.11.17 12:04:03 1: Including fhem.cfg
2022.11.17 12:04:04 3: WEB: port 8083 opened
2022.11.17 12:04:04 2: eventTypes: loaded 3719 lines from ./log/eventTypes.txt
2022.11.17 12:04:04 1: PERL WARNING: main::km200_GetDynService() called too early to check prototype at ./FHEM/73_km200.pm line 2572, <$fh> line 76.
2022.11.17 12:04:04 1: stacktrace:
2022.11.17 12:04:04 1: main::__ANON__ called by ./FHEM/73_km200.pm (2572)
2022.11.17 12:04:04 1: (eval) called by fhem.pl (2757)
2022.11.17 12:04:04 1: (eval) called by fhem.pl (2756)
2022.11.17 12:04:04 1: main::CommandReload called by fhem.pl (2061)
2022.11.17 12:04:04 1: main::LoadModule called by fhem.pl (2126)
2022.11.17 12:04:04 1: main::CommandDefine called by fhem.pl (1274)
2022.11.17 12:04:04 1: main::AnalyzeCommand called by fhem.pl (1125)
2022.11.17 12:04:04 1: main::AnalyzeCommandChain called by fhem.pl (1413)
2022.11.17 12:04:04 1: main::CommandInclude called by fhem.pl (626)
2022.11.17 12:04:16 1: PERL WARNING: Use of uninitialized value $_ in string eq at ./FHEM/73_km200.pm line 482, <$fh> line 78.
2022.11.17 12:04:16 1: stacktrace:
2022.11.17 12:04:16 1: main::__ANON__ called by ./FHEM/73_km200.pm (482)
2022.11.17 12:04:16 1: main::km200_Attr called by fhem.pl (3972)
2022.11.17 12:04:16 1: main::CallFn called by fhem.pl (3194)
2022.11.17 12:04:16 1: main::CommandAttr called by fhem.pl (1274)
2022.11.17 12:04:16 1: main::AnalyzeCommand called by fhem.pl (1125)
2022.11.17 12:04:16 1: main::AnalyzeCommandChain called by fhem.pl (1413)
2022.11.17 12:04:16 1: main::CommandInclude called by fhem.pl (626)
Can't call method "first_index" without a package or object reference at ./FHEM/73_km200.pm line 482, <$fh> line 78.
ich habe die alte Version wieder eingespielt. Damit läuft FHEM wieder.
Vielleich kann ja jemand den Fehler finden.
Lösche mal dein "DoNotPol" Attribut und versuche es nochmal mit der neuen Version.
Ich kann den Fehler bei mir nicht nachvollziehen.
Und dann bitte auch mal ein list mit in das Forum legen.
Sailor
Beim zweiten Versuch hat es geklappt mit gelöschtem DoNotPol.
Es kommt beim Starten nur noch diese Meldung
2022.11.17 14:14:14 1: PERL WARNING: main::km200_GetDynService() called too early to check prototype at ./FHEM/73_km200.pm line 2572, <$fh> line 76.
2022.11.17 14:14:14 1: stacktrace:
2022.11.17 14:14:14 1: main::__ANON__ called by ./FHEM/73_km200.pm (2572)
2022.11.17 14:14:14 1: (eval) called by fhem.pl (2757)
2022.11.17 14:14:14 1: (eval) called by fhem.pl (2756)
2022.11.17 14:14:14 1: main::CommandReload called by fhem.pl (2061)
2022.11.17 14:14:14 1: main::LoadModule called by fhem.pl (2126)
2022.11.17 14:14:14 1: main::CommandDefine called by fhem.pl (1274)
2022.11.17 14:14:14 1: main::AnalyzeCommand called by fhem.pl (1125)
2022.11.17 14:14:14 1: main::AnalyzeCommandChain called by fhem.pl (1413)
2022.11.17 14:14:14 1: main::CommandInclude called by fhem.pl (626)
Ansonsten scheint es zu Laufen :)
Danke für den Hinweis.
die PERL WARNING: main::km200_GetDynService() called too early to check prototype at ./FHEM/73_km200.pm line 2572, <$fh> line 76. habe ich schon gelöst.
Das Andere schau ich mir mal an...
Sailor
DoNotPol kann bei mir nicht mehr gesetzt werden.
FHEM stürzt ab mit folgender Meldung
Ich habe das gleiche Problem.
ergerd
Könnt ihr den "elsif"-Zweig ab Zeile 448 mal testweise durch das hier ersetzen:
elsif($a[2] eq 'DoNotPoll') {
#my @KM200_DONOTPOLL = ();
my @temp = @a;
### Stop the current timer
RemoveInternalTimer($hash);
Log3 $name, 4, $name. " : km200 - InternalTimer has been removed.";
### Delete the first 3 items of the array
splice @temp, 0, 3;
### Insert empty field as minimum entry
push @temp, "";
### Transform string entries seperated by blank into array
my @KM200_DONOTPOLL = split m/\s+/, $temp[0];
@KM200_DONOTPOLL //=();
### Remove trailing slash of each item if available
### For each item found in this empty parent directory
for my $item (@KM200_DONOTPOLL) {
### Delete trailing slash
$item =~ s/\/$//;
### Save list of services not to be polled into hash
@{$hash->{Secret}{KM200DONOTPOLL}} = @KM200_DONOTPOLL;
### Get original list of root services back
@{$hash->{Secret}{KM200ALLSERVICES}} = @{$hash->{Secret}{KM200ALLSERVICESBACKUP}};
### For every blacklisted service
for my $SearchWord(@KM200_DONOTPOLL) {
last if @{$hash->{Secret}{KM200ALLSERVICES}}|| ref @{$hash->{Secret}{KM200ALLSERVICES}} ne 'ARRAY';
### Filter all blocked root services out of services to be polled
my $FoundPosition = first_index{ $_ eq $SearchWord }@{$hash->{Secret}{KM200ALLSERVICES}};
if ($FoundPosition >= 0) {
splice(@{$hash->{Secret}{KM200ALLSERVICES}}, $FoundPosition, 1);
### Message for debugging purposes
Log3 $name, 5, $name. "km200 module is only polling the following services! \n @{$hash->{Secret}{KM200ALLSERVICES}}";
Log3 $name, 5, $name. "km200 module is NOT polling the following services! \n @{$hash->{Secret}{KM200DONOTPOLL}}";
Log3 $name, 4, $name. " : km200 - The following services will not be polled: ". $a[3];
### Interrupting all currently running Polling
@{$hash->{Secret}{KM200DYNSERVICES}} = "";
$hash->{temp}{ServiceCounterDyn} = 0;
### Delete all Readings
fhem( "deletereading $name .*" );
### Re-start the sounding of values from KM200 but wait the period of $hash->{POLLINGTIMEOUT} + 10s
InternalTimer(gettimeofday()+$hash->{POLLINGTIMEOUT}+10, "km200_GetInitService", $hash, 1);
Log3 $name, 4, $name. " : km200 - Sounding of services re-started after change of DoNotPoll attribute";
Hi BetaUser
Danke für den Versuch. Da ich den Fehler nicht nachstellen kann, bin ich für jede Hilfe dankbar.
Um zusaetzlich die lästige Warnung im Log weg zu bekommen, fügt doch Testweise mal
sub km200_GetDynService($);in Zeile 57 ein.
Sailor
Wir sollten uns mal über Perl unterhalten... Diese forward-Declarations sind echt nicht der aktuelle Stand der Dinge.
Würde mal alternativ zu der forward declaration vorschlagen, Zeile 2572 (bzw. 2574 nach Einfügen meines Code-Vorschlags) so zu fassen:
$init_done ? km200_GetDynService($hash) : InternalTimer(gettimeofday()+30, \&km200_GetDynService, $hash, 1);
465 @KM200_DONOTPOLL //=();
485 my $FoundPosition = first_index{ $_ eq $SearchWord }@{$hash->{Secret}{KM200ALLSERVICES}};
Da bekomme ich an der Stelle folgende Fehlermeldung:
Can't modify private array in defined or assignment (//=) at .//FHEM/73_km200.pm line 465, near ");"
Type of arg 1 to List::MoreUtils::XS::firstidx must be block or sub {} (not reference constructor) at .//FHEM/73_km200.pm line 485, near "};"
Sailor
Habe die forward-Deklaration auskommentiert und deine Code-Zeile wie von dir vorgeschlagen eingefügt.
Resultat bei Neustart:
2022.11.18 12:07:57.671 1: PERL WARNING: main::km200_GetDynService() called too early to check prototype at .//FHEM/73_km200.pm line 2574, <$fh> line 262.
Sailor
Hmm, hätte ich wohl testen sollen...
Versuche es mal mit (nur) dem in der Zeile vorher:
my @KM200_DONOTPOLL = split m/\s+/, $temp[0] // ();Das lädt zumindest ordnungsgemäß.
(Das Problem, das gelöst werden muss: uU. ist das Array nach dem split nicht defined, und daraus resultieren dann die weiteren Fehlermeldungen. Also muss mindestens ein leeres Array her....)
Sailor
Kannst du mal stacktrace einschalten? Die Meldung zur verursachenden Zeile ist nämlich jetzt eine (deutlich) andere als vorher.
(Hier dürfte das Problem sein, dass bereits aus define heraus Code ausgeführt wird. Man sollte m.E. eine Art "firstinit"-Routine haben, die timerbasiert aufgerufen wird, wenn $init_done noch nicht wahr ist).
Hi Beta-User
Das hat schon mal gefunzt. Sowohl beim "reload 73_km200" als auch bei "shutdown restart"
Danke.... Schaun mer mal wie sich das über Nacht verhält.
Anbei der stacktrace
2022.11.18 13:02:11.804 1: PERL WARNING: main::km200_GetDynService() called too early to check prototype at .//FHEM/73_km200.pm line 2574, <$fh> line 262.
2022.11.18 13:02:11.804 1: stacktrace:
2022.11.18 13:02:11.805 1: main::__ANON__ called by .//FHEM/73_km200.pm (2574)
2022.11.18 13:02:11.805 1: (eval) called by fhem.pl (2757)
2022.11.18 13:02:11.805 1: (eval) called by fhem.pl (2756)
2022.11.18 13:02:11.806 1: main::CommandReload called by fhem.pl (2061)
2022.11.18 13:02:11.806 1: main::LoadModule called by fhem.pl (2126)
2022.11.18 13:02:11.806 1: main::CommandDefine called by fhem.pl (1274)
2022.11.18 13:02:11.806 1: main::AnalyzeCommand called by fhem.pl (1125)
2022.11.18 13:02:11.807 1: main::AnalyzeCommandChain called by fhem.pl (1413)
2022.11.18 13:02:11.807 1: main::CommandInclude called by fhem.pl (1274)
2022.11.18 13:02:11.807 1: main::AnalyzeCommand called by fhem.pl (1125)
2022.11.18 13:02:11.808 1: main::CommandInclude called by fhem.pl (626)
Sailor
Hmm, dann würde ich mal annehmen, dass das eine Folge aus Zeile 299 ist.
Sieht für mich nach einem Webfehler aus, irgendwelche Funktionen zur define-Time aufzurufen, die "hart" irgendwelche Reaktionen von einer Gegenstelle erwarten. Dto. übrigens auch für (indirekte) trigger-Kommandos wie readingsSingleUpdate() (#284). Dadurch werden uU. plötzlich alle möglichen Eventhandler wach und reagieren ihrerseits, obwohl die FHEM-Initialisierung noch nicht durch ist. Dann hat man Reihenfolgediskussionen zur Frage, wo was in der cfg steht (so man eine als File hat (!)), etc. pp..
Sollte man bereinigen!
Just my2ct.
OK, fürs Erste lass ich also die eine forward-Declaration mal drin.
Zumindest unterdrückt sie damit die Warning.
Dann lasse ich mir mal einfallen, wie ich die ganze #283 bis #325 in eine Subfunktion packe, die erst nach $init_done=true ausgeloest wird.
Sailor
Warum ein Plaster kleben, wenn du gleich operieren willst? Besser eine sichtbare Wunde lassen, dann vergißt du es auch nicht...
Schau dir mal den Code von TvHeadend (reloaded) (https://forum.fhem.de/index.php/topic,123117.msg1227814.html#msg1227814) an. Ist zwar gepackagt, aber der Gedanke ist relativ einfach. Am Ende von "DefFn()" steht:
return $init_done ? firstInit($hash) : InternalTimer(gettimeofday()+10, \&firstInit, $hash );Mit sowas wird man dann auch das Problem los, dass die credentials unbedingt in das DEF reingeknödelt sein müssen...
Hallo Beta-User
Habe den Code mal eingebaut.
Scheint soweit zu funktionieren.
Ich verstehe allerdings nicht ganz das "?" - Wenn die globale Variable $init_done = true, dann rufe firstInit auf ansonsten rufe firstInit erst nach in 10 s auf.
Was passiert wenn in 10s immer noch nicht $init_done = true?
Sailor
ZitatWas passiert wenn in 10s immer noch nicht $init_done = true?
Die InternalTimer Eintraege werden erst abgearbeitet, wenn $init_done = 1 ist.
Daher reicht auch InternalTimer(0, \&firstInit, $hash).
Ergänzend sicherheitshalber vielleicht noch eine Anmerkung zur Benennung: Das sollte in einem nicht "verpackten" Modul dann modulspezifisch benannt werden - und wenn wir schon beim Thema namespace sind: Da gibt es ganz zu Beginn ein paar Konstanten-Deklarationen, die mir im main-namespace eigentlich zu generisch wären...
Moin zusammen
Selbstverständlich habe ich das von Anfang an "km200_FirstInit($)" genannt. ;)
Du meinst die Definition im km200 - Modul
use constant false => 0;
use constant true => 1;
würde das für ganz fhem gleich mit definieren?
Sailor
Alles, was du an der Stelle reincodest, findet im lexical scope von main statt. Obwohl ich diese Art der Deklaration bisher nirgends gesehen habe, gehe ich davon aus, dass das ggf. auch Auswirkungen auf andere Module und/oder fhem.pl haben _kann_.
Solcher Art "Ungenauigkeiten" ist der Hauptgrund, warum ich zwischenzeitlich alles in's package-Format ziehe: Man ist einfach auch davor gefeit, dass einem irgend einer unbedacht was ändert, ohne dass man es merkt, und man kann selbst generische Namen nutzen ;) . Der Rahmen von dem hier verlinkten TvHeadend kann für alle möglichen anderen Module einfach so übernommen werden...
Da wir grade bei unschönen Dingen sind: Dein Modul ist das (von der Byte-Zahl her) größte im gesamten FHEM-Verzeichnis. Das liegt vorrangig daran, dass vor kurzem die gesamten Fehlercodes in der DE-Übersetzung ins Modul übernommen wurden. Vielleicht magst du überlegen, ob es nicht sinnvoll wäre, das in eine gesonderte Datei auszulagern? Dann kann das auch jemand nach englisch, ... übersetzen und ggf. relativ einfach dann für sich einbinden.
Wie immer: Just my2ct beim schnellen Drüberfliegen.
