Lösung:
homebridgeMapping Brightness=brightness::brightness,maxValue=100,max=100,factor=0.39371,delay=true
wird auch per Fhem update verteilt.
Hallo ich habe ein Problem beim dimmen mit Alexa und einem Zigbee2Mqtt Device
Dimmen von 1-99 Prozent Funktioniert super, aber bei 100% setzt der mir beim Reading ein set mit dazu...
Wo liegt der Fehler?
2022-12-01 15:34:42 brightness 252.44798041615667
2022-12-01 15:29:27 brightness set 254.99796001631987
CID zigbee_0x842e14fffe413dbb
DEF zigbee_0x842e14fffe413dbb
FUUID 61d48d2e-f33f-19ae-b726-4a4b2704697ed9af
IODev m2s
LASTInputDev m2s
MSGCNT 62
NAME MQTT2_zigbee_Stehlampe
NR 289
STATE on
TYPE MQTT2_DEVICE
eventCount 80
m2s_CONN m2s_10.1.1.4_33768
m2s_MSGCNT 62
m2s_TIME 2022-12-01 15:29:25
JSONMAP:
color_temp ct
color_temp_startup ct_startup
2022-11-13 00:02:07 IODev m2s
2022-01-04 19:08:47 associatedWith MQTT2_zigbee_bridge
2022-12-01 15:26:56 attrTemplateVersion 20220909
2022-11-30 08:19:09 linkquality 255
2022-01-09 22:17:31 power_on_behavior on
2022-12-01 15:28:36 state on
2022-10-16 18:00:49 update_available true
2022-01-04 19:47:37 update_progress 100
2022-01-04 19:47:37 update_remaining 6
2022-10-16 18:00:49 update_state available
hmccu:
alexaName Stehlampe
devStateIcon {zigbee2mqtt_devStateIcon255($name)}
devicetopic zigbee2mqtt/0x842e14fffe413dbb
event-on-change-reading .*
homebridgeMapping Brightness=brightness::brightness,maxValue=100,factor=0.39216,delay=true
icon light_control
jsonMap color_temp:ct color_temp_startup:ct_startup
model zigbee2mqtt_light_dimmer
readingList $DEVICETOPIC:.* { my $ret=json2nameValue($EVENT); $ret->{state}=lc($ret->{state}) if defined $ret->{state}; return $ret }
room MQTT2_DEVICE->Licht
setList on:noArg $DEVICETOPIC/set {"state":"ON"}
off:noArg $DEVICETOPIC/set {"state":"OFF"}
brightness:colorpicker,BRI,0,5,255 $DEVICETOPIC/set {"state":"on","$EVTPART0":"$EVTPART1"}
setStateList on off
timestamp-on-change-reading .*
webCmd toggle:on:off:brightness
Das "set" (im betreffenden Reading) kommt m.E. immer zunächst mal, wenn man (mit gesetzter setStateList) ein MQTT2_DEVICE von FHEM aus schaltet.
Es wird dann auf Bestätigung seitens der "Gegenstelle" (hier: zigbee2mqtt-Dienst) gewartet. Die scheint bei 100% auszubleiben.
hm ok..
habe jetzt folgendes erstmal geändert:
homebridgeMapping Brightness=brightness::brightness,maxValue=99,factor=0.39216,delay=true
so kann ich "Alexa Stehlampe 100% sagen", wird aber intern auf 99 gesetzt......
Der Grund für das Verhalten bei 100 % steht im Reading Log der Bridge:
{"message":"Publish 'set' 'brightness' to '0x00158d0003609724' failed: 'Error: Brightness value of message: '{\"state\":\"on\",\"brightness\":\"254.99796001631987\"}' invalid, must be a number >= 0 and =< 254'","meta":{"friendly_name":"0x00158d0003609724"},"type":"zigbee_publish_error"}
ok Zigbee2mqtt kann nur bis 254
Hmmm, dazu fällt mir auf die Schnelle auch nichts "einfaches" ein.
Grübel. Vielleicht braucht es doch ein 2. "light_255"-Sprachsteuerungstemplate (also ein "light_254")? Aber wie soll das dann ausssehen? Mit den 99? Hat das irgendwo Nebenwirkungen?
EDIT: Oder eher den factor ändern (auf 0.3937)?
0.39371
Und die Rückmeldungen vlt. runden ?
"state": "on",
"brightness": "254.99796001631987"
die 99% bei Alexa haben bis jetzt keine Nebenwirkung. Wenn ich Alexa 100% sage sehe ich kurz danach in der Alexa app wie es auf 99% springt.
Mit dem Faktor kann ich mal testen.
Hmm, also anderer Faktor ließe sich ja einrichten, aber zum einen ist das irritierend, dass man zwar nur 254 reinkloppen darf, aber (fast) 255 zurückkommt?!?
Zum anderen mag ich die Rundung nicht, das müßte man sonst in die ganzen Templates einbauen, und das nur wegen dieses kleinen Schönheitsfehlerchens...
Das mit den "Nebenwirkungen" betrifft uU. andere Sprachsteuerungen. factor dürfte unkritischer sein, ist aber nur ein Bauchgefühl.
Also für mich reicht es mit dem Faktor, ich kann es auch nur bei meinen Geräten ändern.
Na ja, wenn wir wissen, dass es ein generelles Problem ist, können wir es auch generell lösen (bzw. es zumindest versuchen).
Wäre nett, wenn ihr die fixes austesten könntet ;) .
Gerne, morgen Mittag wenn ich wach bin, habe Nachtschicht.
Wird per update verteilt?
Ja. Ab 8.
Zitat... aber zum einen ist das irritierend, dass man zwar nur 254 reinkloppen darf, aber (fast) 255 zurückkommt?!?
Das war ein Kopierfehler, hatte das gestern nur so nebenbei bei einer kurzen Pause am Tablet nachvollzogen.
Heute kränkle ich sowieso und es hat mich nicht losgelassen bis ich den korrekten Umrechnungsfaktor rausgefunden habe ::), der ist:
0.3937007874015742515:25:12.449
SENT
zigbee2mqtt/0x00158d0003278378/set
{"state":"on","brightness":"100"}
15:25:12.532
mqttjs_91f275c4
zigbee2mqtt/bridge/logging
{"level":"debug","message":"Received MQTT message on 'zigbee2mqtt/0x00158d0003278378/set' with data '{\"state\":\"on\",\"brightness\":\"100\"}'"}
15:25:12.550
mqttjs_91f275c4
{"level":"debug","message":"Publishing 'set' 'brightness' to '0x00158d0003278378'"}
15:25:12.561
mqttjs_91f275c4
{"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/0x00158d0003278378', payload '{\"brightness\":100,\"color_mode\":\"color_temp\",\"color_temp\":320,\"linkquality\":143,\"state\":\"ON\"}'"}
15:25:12.572
mqttjs_91f275c4
{"brightness":100,"color_mode":"color_temp","color_temp":320,"linkquality":143,"state":"ON"}
15:25:17.885
SENT
{"state":"on","brightness":"75"}
15:25:17.967
mqttjs_91f275c4
{"level":"debug","message":"Received MQTT message on 'zigbee2mqtt/0x00158d0003278378/set' with data '{\"state\":\"on\",\"brightness\":\"75\"}'"}
15:25:17.977
mqttjs_91f275c4
15:25:18.000
mqttjs_91f275c4
{"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/0x00158d0003278378', payload '{\"brightness\":75,\"color_mode\":\"color_temp\",\"color_temp\":320,\"linkquality\":143,\"state\":\"ON\"}'"}
15:25:18.010
mqttjs_91f275c4
{"brightness":75,"color_mode":"color_temp","color_temp":320,"linkquality":143,"state":"ON"}
15:25:23.440
SENT
{"state":"on","brightness":"49"}
15:25:23.522
mqttjs_91f275c4
{"level":"debug","message":"Received MQTT message on 'zigbee2mqtt/0x00158d0003278378/set' with data '{\"state\":\"on\",\"brightness\":\"49\"}'"}
15:25:23.532
mqttjs_91f275c4
15:25:23.552
mqttjs_91f275c4
{"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/0x00158d0003278378', payload '{\"brightness\":49,\"color_mode\":\"color_temp\",\"color_temp\":320,\"linkquality\":143,\"state\":\"ON\"}'"}
15:25:23.562
mqttjs_91f275c4
{"brightness":49,"color_mode":"color_temp","color_temp":320,"linkquality":143,"state":"ON"}
Zitat von: TomLee am 02 Dezember 2022, 15:26:25der ist:
0.39370078740157425
...auf sowas ähnliches war ich auch gekommen, daher die Kurzform ohne den Kleinschmodder hinter den zwei Nullen...
Bedeutet: "Bitte übernehmen" (weil die damit ermittelten Zahlenwerte super-integer sind) oder "ich melde mich nochmal, wenn ich das im fitten Zustand getestet habe"?
(Ich kann das nicht aus eigener Anschauung beurteilen und werde aus dem Log auch nicht so schlau wie es vermutlich gedacht ist).
Bedeutet, bitte genauso jetzt übernehmen, das gestern mit einer Stelle mehr, war einfach nur ein Schnellschuss, weil ich eh am schreiben war, du aber schneller warst und das mit factor schon angesprochen hattest.
Der Auszug aus dem letzten Beitrag ist der MQTT-Verkehr am MQTT2-Server, bei dem drei Sprachbefehle abgesetzt wurden.
Es kommt also genau das zurüxk was auch gesendet wurde.
Wenn jetzt noch fragen sind hab ich erstmal keine Zeit, weil eh heut schon alles liegengeblieben ist wegen der Kacke und ich trotz kränkeln noch was arbeiten will.
Hallo, ich habe wieder einen Fehler im system, jetzt bekomme ich einen brightness wert von:
set 254.00000000000034
obwohl der factor=0.39370078740157425 ist..
Bitte mal mit den ersten 4 stellen testen.
mit folgendem Faktor geht es:
0.39370078740159
damit bekomme ich
brightness = 253.9999999999902
Interessant wär den MQTT Verkehr zu sehen mit factor=0.39370078740157425.
Ich vermute von Alexa kommt 100 zurück und in z2m wird bei dem dimmer wieder anders gerechnet wie mit den Leuchten mit denen ich getestet hatte.
Alexa log erst 50% dann 100%
[8.12.2022, 19:00:51] >>>> [ssh] {"directive":{"header":{"messageId":"78201bf7-a64e-4a46-971d-c8c5e8e795c1","namespace":"Alexa.BrightnessController","name":"SetBrightness","payloadVersion":"3","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"39F6EFCC-F7ADEA4A9C957841"},"endpointId":"638a23df-f33f-19ae-5f8a-24d32dfafe6ee68b","cookie":{"device":"MQTT2_zigbee_Stehlampe","fuuid":"638a23df-f33f-19ae-5f8a-24d32dfafe6ee68b"}},"payload":{"brightness":50}}}
[8.12.2022, 19:00:51] [FHEM] caching: Brightness: NaN (as number; from 'set 254.00000000000034')
[8.12.2022, 19:00:51] [FHEM] MQTT2_zigbee_Stehlampe: executing set cmd for Brightness with value 50
[8.12.2022, 19:00:51] [FHEM] executing: http://127.0.0.1:8083/fhem?cmd=set%20MQTT2_zigbee_Stehlampe%20brightness%20127.00000000000017&XHR=1
[8.12.2022, 19:00:51] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.BrightnessController","name":"brightness","value":50,"timeOfSample":"2022-12-08T18:00:51.254Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"9379a7ca-605b-4f91-ba3e-0a76bb810ebf","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"39F6EFCC-F7ADEA4A9C957841"},"endpointId":"638a23df-f33f-19ae-5f8a-24d32dfafe6ee68b"},"payload":{}}}
2022-12-08 19:00:51 caching: MQTT2_zigbee_Stehlampe-brightness: set 127.00000000000017
[8.12.2022, 19:00:51] [FHEM] caching: Brightness: NaN (as number; from 'set 127.00000000000017')
2022-12-08 19:00:51 caching: MQTT2_zigbee_Stehlampe-brightness: 127.00000000000017
[8.12.2022, 19:00:51] [FHEM] caching: Brightness: 50 (as number; from '127.00000000000017')
[8.12.2022, 19:00:55] >>>> [ssh] {"directive":{"header":{"messageId":"91ba84fd-1b17-4207-91e2-20bcb527a51d","namespace":"Alexa.BrightnessController","name":"SetBrightness","payloadVersion":"3","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"39F6EFCC-F7ADEA4A9C957841"},"endpointId":"638a23df-f33f-19ae-5f8a-24d32dfafe6ee68b","cookie":{"device":"MQTT2_zigbee_Stehlampe","fuuid":"638a23df-f33f-19ae-5f8a-24d32dfafe6ee68b"}},"payload":{"brightness":100}}}
[8.12.2022, 19:00:55] [FHEM] caching: Brightness: 50 (as number; from '127.00000000000017')
[8.12.2022, 19:00:55] [FHEM] MQTT2_zigbee_Stehlampe: executing set cmd for Brightness with value 100
[8.12.2022, 19:00:55] [FHEM] executing: http://127.0.0.1:8083/fhem?cmd=set%20MQTT2_zigbee_Stehlampe%20brightness%20254.00000000000034&XHR=1
[8.12.2022, 19:00:55] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.BrightnessController","name":"brightness","value":100,"timeOfSample":"2022-12-08T18:00:55.722Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"b41ec524-c066-4078-9b79-0f88c109e4be","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"39F6EFCC-F7ADEA4A9C957841"},"endpointId":"638a23df-f33f-19ae-5f8a-24d32dfafe6ee68b"},"payload":{}}}
2022-12-08 19:00:55 caching: MQTT2_zigbee_Stehlampe-brightness: set 254.00000000000034
[8.12.2022, 19:00:55] [FHEM] caching: Brightness: NaN (as number; from 'set 254.00000000000034')
MQTT 50% und 100%
19:03:46.961
SENT
zigbee2mqtt/0x842e14fffe413dbb/set
{"state":"on","brightness":"127.00000000000017"}
19:03:47.083
zigbee2mqtt
{"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/0x842e14fffe413dbb', payload '{\"brightness\":127.00000000000017,\"linkquality\":160,\"power_on_behavior\":\"on\",\"state\":\"ON\",\"update\":{\"state\":\"idle\"},\"update_available\":false}'"}
19:03:47.087
zigbee2mqtt
{"brightness":127.00000000000017,"linkquality":160,"power_on_behavior":"on","state":"ON","update":{"state":"idle"},"update_available":false}
19:03:51.713
SENT
{"state":"on","brightness":"254.00000000000034"}
19:03:51.719
zigbee2mqtt
{"level":"error","message":"Publish 'set' 'brightness' to '0x842e14fffe413dbb' failed: 'Error: Brightness value of message: '{\"state\":\"on\",\"brightness\":\"254.00000000000034\"}' invalid, must be a number >= 0 and =< 254'"}
19:03:51.723
zigbee2mqtt
{"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{\"message\":\"Publish 'set' 'brightness' to '0x842e14fffe413dbb' failed: 'Error: Brightness value of message: '{\\\"state\\\":\\\"on\\\",\\\"brightness\\\":\\\"254.00000000000034\\\"}' invalid, must be a number >= 0 and =< 254'\",\"meta\":{\"friendly_name\":\"0x842e14fffe413dbb\"},\"type\":\"zigbee_publish_error\"}'"}
19:03:51.727
zigbee2mqtt
{"message":"Publish 'set' 'brightness' to '0x842e14fffe413dbb' failed: 'Error: Brightness value of message: '{\"state\":\"on\",\"brightness\":\"254.00000000000034\"}' invalid, must be a number >= 0 and =< 254'","meta":{"friendly_name":"0x842e14fffe413dbb"},"type":"zigbee_publish_error"}
Hmm, keine Ahnung, bei mir siehts im Alexa_log gut aus.
Meine alexa-fhem Version ist die 0.5.61.
[8.12.2022, 19:32:49] >>>> [srv] {"directive":{"header":{"messageId":"0e69814c-fdbe-465c-bd6f-c365216d759a","namespace":"Alexa.BrightnessController","name":"SetBrightness","payloadVersion":"3","correlationToken":"bla"},"endpoint":{"scope":{"type":"BearerToken","token":"bla"},"endpointId":"5fcd1b4c-f33f-78f5-517f-83893558e44c8d56","cookie":{"device":"MQTT2_zigbee_gu10_6","fuuid":"5fcd1b4c-f33f-78f5-517f-83893558e44c8d56"}},"payload":{"brightness":50}}}
[8.12.2022, 19:32:49] accepted new token
[8.12.2022, 19:32:49] [FHEM] MQTT2_zigbee_gu10_6: executing set cmd for Brightness with value 50
[8.12.2022, 19:32:49] [FHEM] executing: http://192.168.188.26:8083/fhem?cmd=set%20MQTT2_zigbee_gu10_6%20brightness%2050&fwcsrf=bla&XHR=1
[8.12.2022, 19:32:49] <<<< [srv] {"context":{"properties":[{"namespace":"Alexa.BrightnessController","name":"brightness","value":50,"timeOfSample":"2022-12-08T18:32:49.580Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"e7031e31-4203-450c-ac0e-2f6cf4562f34","correlationToken":"bla"},"endpoint":{"scope":{"type":"BearerToken","token":"bla"},"endpointId":"5fcd1b4c-f33f-78f5-517f-83893558e44c8d56"},"payload":{}}}
[8.12.2022, 19:32:56] >>>> [srv] {"directive":{"header":{"messageId":"d3e81897-c3e4-421c-8343-81b34931f1d4","namespace":"Alexa.BrightnessController","name":"SetBrightness","payloadVersion":"3","correlationToken":"bla"},"endpoint":{"scope":{"type":"BearerToken","token":"bla"},"endpointId":"5fcd1b4c-f33f-78f5-517f-83893558e44c8d56","cookie":{"device":"MQTT2_zigbee_gu10_6","fuuid":"5fcd1b4c-f33f-78f5-517f-83893558e44c8d56"}},"payload":{"brightness":100}}}
[8.12.2022, 19:32:56] accepted new token
[8.12.2022, 19:32:56] [FHEM] MQTT2_zigbee_gu10_6: executing set cmd for Brightness with value 100
[8.12.2022, 19:32:56] [FHEM] executing: http://192.168.188.26:8083/fhem?cmd=set%20MQTT2_zigbee_gu10_6%20brightness%20100&fwcsrf=bla&XHR=1
[8.12.2022, 19:32:56] <<<< [srv] {"context":{"properties":[{"namespace":"Alexa.BrightnessController","name":"brightness","value":100,"timeOfSample":"2022-12-08T18:32:56.503Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"ac8ddf5c-f16d-4c23-b115-9ff271154173","correlationToken":"bla"},"endpoint":{"scope":{"type":"BearerToken","token":"bla"},"endpointId":"5fcd1b4c-f33f-78f5-517f-83893558e44c8d56"},"payload":{}}}
19:32:49.628
SENT
{"state":"on","brightness":"50"}
19:32:49.783
mqttjs_91f275c4
{"level":"debug","message":"Received MQTT message on 'zigbee2mqtt/0x00158d0003278378/set' with data '{\"state\":\"on\",\"brightness\":\"50\"}'"}
19:32:49.793
mqttjs_91f275c4
19:32:49.813
mqttjs_91f275c4
{"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/0x00158d0003278378', payload '{\"brightness\":50,\"color_mode\":\"color_temp\",\"color_temp\":320,\"linkquality\":143,\"state\":\"ON\"}'"}
19:32:49.823
mqttjs_91f275c4
{"brightness":50,"color_mode":"color_temp","color_temp":320,"linkquality":143,"state":"ON"}
19:32:56.544
SENT
19:32:56.696
mqttjs_91f275c4
19:32:56.706
mqttjs_91f275c4
19:32:56.718
mqttjs_91f275c4
19:32:56.729
mqttjs_91f275c4
define MQTT2_zigbee_gu10_6 MQTT2_DEVICE zigbee_0x00158d0003278378
attr MQTT2_zigbee_gu10_6 userattr lightSceneParamsToSave lightSceneRestoreOnlyIfChanged:1,0 structexclude wzdl wzdl_map
attr MQTT2_zigbee_gu10_6 IODev MQTT2_Server
attr MQTT2_zigbee_gu10_6 alexaName decke6
attr MQTT2_zigbee_gu10_6 devStateIcon {zigbee2mqtt_devStateIcon255($name)}
attr MQTT2_zigbee_gu10_6 devicetopic zigbee2mqtt/0x00158d0003278378
attr MQTT2_zigbee_gu10_6 genericDeviceType light
attr MQTT2_zigbee_gu10_6 group Wohnzimmer
attr MQTT2_zigbee_gu10_6 homebridgeMapping Brightness=brightness::brightness,maxValue=100,0.393700787401574250 ,delay=true
attr MQTT2_zigbee_gu10_6 icon light_control
attr MQTT2_zigbee_gu10_6 imageLink /fhem/deviceimages/mqtt2/404006-404008-404004.jpg
attr MQTT2_zigbee_gu10_6 jsonMap color_temp:ct color_temp_startup:ct_startup
attr MQTT2_zigbee_gu10_6 model zigbee2mqtt_light_cct
attr MQTT2_zigbee_gu10_6 readingList $DEVICETOPIC:.* { json2nameValue($EVENT,'',$JSONMAP) }
attr MQTT2_zigbee_gu10_6 room MQTT2_DEVICE,Privat->OG->Wohnzimmer
attr MQTT2_zigbee_gu10_6 setList on:noArg $DEVICETOPIC/set {"brightness": 120 , "state":"ON", "color_temp": 320}\
off:noArg $DEVICETOPIC/set {"state":"OFF"}\
brightness:colorpicker,BRI,0,5,255 $DEVICETOPIC/set {"state":"on","$EVTPART0":"$EVTPART1"}\
ct:colorpicker,CT,154,2,500 $DEVICETOPIC/set {"color_temp":"$EVTPART1"}\
ct_startup:coolest,cool,neutral,warmest,previous $DEVICETOPIC/set {"color_temp_startup":"$EVTPART1"}
attr MQTT2_zigbee_gu10_6 setStateList on off
attr MQTT2_zigbee_gu10_6 verbose 2
attr MQTT2_zigbee_gu10_6 webCmd toggle:on:off:brightness:ct
attr MQTT2_zigbee_gu10_6 webCmdLabel Helligkeit\
# CID zigbee_0x00158d0003278378
# DEF zigbee_0x00158d0003278378
# FUUID 5fcd1b4c-f33f-78f5-517f-83893558e44c8d56
# IODev MQTT2_Server
# LASTInputDev MQTT2_Server
# MQTT2_Server_CONN MQTT2_Server_127.0.0.1_44538
# MQTT2_Server_MSGCNT 170
# MQTT2_Server_TIME 2022-12-08 19:32:56
# MSGCNT 170
# NAME MQTT2_zigbee_gu10_6
# NR 280
# STATE ON
# TYPE MQTT2_DEVICE
# eventCount 340
# .DT:
# DEVICETOPIC zigbee2mqtt/0x00158d0003278378
# .attraggr:
# .attrminint:
# JSONMAP:
# color_temp ct
# color_temp_startup ct_startup
# READINGS:
# 2022-12-02 15:19:30 IODev MQTT2_Server
# 2022-12-08 19:32:56 brightness 100
# 2022-12-08 19:32:56 color_mode color_temp
# 2022-12-08 19:32:56 ct 320
# 2022-12-08 19:32:56 linkquality 143
# 2022-12-08 19:32:56 state ON
setstate MQTT2_zigbee_gu10_6 ON
setstate MQTT2_zigbee_gu10_6 2022-12-02 15:19:30 IODev MQTT2_Server
setstate MQTT2_zigbee_gu10_6 2022-12-08 19:32:56 brightness 100
setstate MQTT2_zigbee_gu10_6 2022-12-08 19:32:56 color_mode color_temp
setstate MQTT2_zigbee_gu10_6 2022-12-08 19:32:56 ct 320
setstate MQTT2_zigbee_gu10_6 2022-12-08 19:32:56 linkquality 143
setstate MQTT2_zigbee_gu10_6 2022-12-08 19:32:56 state ON
ich habe die Alexa Version 0.5.64
Ich mach später oder morgen mal ein update, um auszuschliessen das es an der Version liegt.
bei dir rechnet der ja nix um.. mqtt sendet bei dir brightness 50 und 100
Habe noch was gefunden:
damit bekomme ich nur glatte werte
100% = brightness 254
50% = brightness 127
Tatsache, ich hab tatsächlich das homebridgemapping falsch, da fehlt das factor und die ganze Zeit einen Denkfehler, sry an beide, schäm.
Zitatdamit bekomme ich nur glatte werte
Ich halt zwar besser den Mund, aber ja ich auch.
Nein alles gut ;)
Ihr habt mich etwas verloren. Soll ich denn jetzt den factor auf 0.39371 anpassen oder nicht?
(Bin bekennender Blinder, was das mit alexa&Co. angeht; RHASSPY tickt anders).
Bitte die gesamte homebridgeMapping auf:
das max=100 ist dazu gekommen und funktioniert bei mir, sogar mit gerundeten zahlen.
:) Danke, update kommt dann demnächst bei Gelegenheit.
