Hallo , ich habe mehrere WTH-2 mit der Automatik ;
get d_ccu createDev ;
angelegt
list S_Bad
Save config
HMCCUCHN
HMCCURPCPROC
Heizung
Homematic
MQTT2_DEVICE
Unsorted
icoEverything Everything
Logfile
Commandref
Remote doc
Edit files
Select style
Event monitor
   DEF        000A97098ED065:1
   FUUID      638e377d-f33f-e8dd-a230-41e2f738a5c285a9
   IODev      d_ccu
   NAME       S_Bad
   NR         49
   STATE      19.1
   TYPE       HMCCUCHN
   ccuaddr    000A97098ED065:1
   ccudevstate active
   ccuif      HmIP-RF
   ccuname    S_Bad:1
   ccutype    HmIP-WTH-2
   eventCount 10
   readonly   no
     2022-12-07 12:39:22   ACTIVE_PROFILE  1
     2022-12-07 12:39:22   ACTUAL_TEMPERATURE 20.1
     2022-12-07 12:39:22   ACTUAL_TEMPERATURE_STATUS 0
     2022-12-07 12:39:22   BOOST_MODE      0
     2022-12-07 12:39:22   BOOST_TIME      0
     2022-12-07 12:39:22   FROST_PROTECTION 0
     2022-12-07 12:39:22   HEATING_COOLING 0
     2022-12-07 12:39:22   HUMIDITY        50
     2022-12-07 12:39:22   HUMIDITY_STATUS 0
     2022-12-06 11:04:39   IODev           d_ccu
     2022-12-07 12:39:22   PARTY_MODE      0
     2022-12-07 08:46:07   PARTY_SET_POINT_TEMPERATURE 0.0
     2022-12-07 08:46:07   PARTY_TIME_END
     2022-12-07 08:46:07   PARTY_TIME_START
     2022-12-07 12:39:22   QUICK_VETO_TIME 0
     2022-12-07 12:39:22   SET_POINT_MODE  1
     2022-12-07 12:39:22   SET_POINT_TEMPERATURE 23.0
     2022-12-07 12:39:22   SWITCH_POINT_OCCURED 0
     2022-12-07 12:39:22   WINDOW_STATE    0
     2022-12-07 12:39:21   activity        alive
     2022-12-07 12:39:21   battery         ok
     2022-12-06 10:49:36   control         23.0
     2022-12-06 10:49:36   desired-temp    23.0
     2022-12-07 12:39:22   devstate        ok
     2022-12-07 12:39:22   hmstate         19.1
     2022-12-06 10:49:36   humidity        51
     2022-12-06 10:49:36   measured-temp   19.1
     2022-12-07 12:39:21   rssidevice      -63
     2022-12-07 08:46:07   rssipeer        -69
     2022-12-06 10:49:36   state           19.1
     2022-12-07 12:39:21   voltage         2.4
   hmccu:
     channels   1
     detect     0
     devspec    000A97098ED065:1
     nodefaults 1
     setDefaults 0
     cmdlist:
     control:
     dp:
       0.CONFIG_PENDING:
         VALUES:
           NVAL       0
           ONVAL      0
           OSVAL      0
           OVAL       0
           SVAL       0
           VAL        0
       0.DUTY_CYCLE:
         VALUES:
           NVAL       0
           ONVAL      0
           OSVAL      0
           OVAL       0
           SVAL       0
           VAL        0
       0.INSTALL_TEST:
         VALUES:
           NVAL       true
           ONVAL      true
           OSVAL      true
           OVAL       true
           SVAL       true
           VAL        true
       0.LOW_BAT:
         VALUES:
           NVAL       0
           ONVAL      0
           OSVAL      ok
           OVAL       0
           SVAL       ok
           VAL        0
       0.OPERATING_VOLTAGE:
         VALUES:
           NVAL       2.4
           ONVAL      2.4
           OSVAL      2.4
           OVAL       2.4
           SVAL       2.4
           VAL        2.4
       0.OPERATING_VOLTAGE_STATUS:
         VALUES:
           NVAL       0
           ONVAL      0
           OSVAL      0
           OVAL       0
           SVAL       0
           VAL        0
       0.RSSI_DEVICE:
         VALUES:
           NVAL       -63
           ONVAL      -65
           OSVAL      -65
           OVAL       -65
           SVAL       -63
           VAL        -63
       0.RSSI_PEER:
         VALUES:
           NVAL       -69
           ONVAL      -69
           OSVAL      -69
           OVAL       187
           SVAL       -69
           VAL        187
       0.UNREACH:
         VALUES:
           NVAL       0
           ONVAL      0
           OSVAL      alive
           OVAL       0
           SVAL       alive
           VAL        0
       0.UPDATE_PENDING:
         VALUES:
           NVAL       false
           ONVAL      false
           OSVAL      false
           OVAL       false
           SVAL       false
           VAL        false
       1.ACTIVE_PROFILE:
         VALUES:
           NVAL       1
           ONVAL      1
           OSVAL      1
           OVAL       1
           SVAL       1
           VAL        1
       1.ACTUAL_TEMPERATURE:
         VALUES:
           NVAL       20.1
           ONVAL      19.9
           OSVAL      19.9
           OVAL       19.9
           SVAL       20.1
           VAL        20.1
       1.ACTUAL_TEMPERATURE_STATUS:
         VALUES:
           NVAL       0
           ONVAL      0
           OSVAL      0
           OVAL       0
           SVAL       0
           VAL        0
       1.BOOST_MODE:
         VALUES:
           NVAL       0
           ONVAL      0
           OSVAL      0
           OVAL       0
           SVAL       0
           VAL        0
       1.BOOST_TIME:
         VALUES:
           NVAL       0
           ONVAL      0
           OSVAL      0
           OVAL       0
           SVAL       0
           VAL        0
       1.FROST_PROTECTION:
         VALUES:
           NVAL       0
           ONVAL      0
           OSVAL      0
           OVAL       0
           SVAL       0
           VAL        0
       1.HEATING_COOLING:
         VALUES:
           NVAL       0
           ONVAL      0
           OSVAL      0
           OVAL       0
           SVAL       0
           VAL        0
       1.HUMIDITY:
         VALUES:
           NVAL       50
           ONVAL      50
           OSVAL      50
           OVAL       50
           SVAL       50
           VAL        50
       1.HUMIDITY_STATUS:
         VALUES:
           NVAL       0
           ONVAL      0
           OSVAL      0
           OVAL       0
           SVAL       0
           VAL        0
       1.PARTY_MODE:
         VALUES:
           NVAL       0
           ONVAL      0
           OSVAL      0
           OVAL       0
           SVAL       0
           VAL        0
       1.PARTY_SET_POINT_TEMPERATURE:
         VALUES:
           NVAL       0.000000
           ONVAL      0.000000
           OSVAL      0.0
           OVAL       0.000000
           SVAL       0.0
           VAL        0.000000
       1.PARTY_TIME_END:
         VALUES:
           NVAL
           ONVAL
           OSVAL
           OVAL
           SVAL
           VAL
       1.PARTY_TIME_START:
         VALUES:
           NVAL
           ONVAL
           OSVAL
           OVAL
           SVAL
           VAL
       1.QUICK_VETO_TIME:
         VALUES:
           NVAL       0
           ONVAL      0
           OSVAL      0
           OVAL       0
           SVAL       0
           VAL        0
       1.SET_POINT_MODE:
         VALUES:
           NVAL       1
           ONVAL      1
           OSVAL      1
           OVAL       1
           SVAL       1
           VAL        1
       1.SET_POINT_TEMPERATURE:
         VALUES:
           NVAL       23.0
           ONVAL      23.0
           OSVAL      23.0
           OVAL       23.0
           SVAL       23.0
           VAL        23.0
       1.SWITCH_POINT_OCCURED:
         VALUES:
           NVAL       0
           ONVAL      0
           OSVAL      0
           OVAL       0
           SVAL       0
           VAL        0
       1.WINDOW_STATE:
         VALUES:
           NVAL       0
           ONVAL      0
           OSVAL      0
           OVAL       0
           SVAL       0
           VAL        0
     roleCmds:
       get:
       set:
     state:
   cmdIcon    auto:sani_heating_automatic manu:sani_heating_manual boost:sani_heating_boost on:general_an off:general_aus
   room       HMCCUCHN,Heizung
   substexcl  desired-temp
   webCmd     desired-temp:auto:manu:boost:on:off
   widgetOverride desired-temp:slider,4.5,0.5,30.5,1
wie man sieht wird dabei webCMD und WidgetOverride angelegt
direkt nach dem anlegen funktioniert es, nach einiger Zeit kommt jedoch bei bedienung des Sliders die Fehlermeldung :
Unknown argument desired-temp choose one of clear defaults:reset,update,old,forceReset
readingFilter:multiple-strict,ACTIVE_PROFILE,ACTUAL_TEMPERATURE,ACTUAL_TEMPERATURE_STATUS,
BOOST_MODE,BOOST_TIME,FROST_PROTECTION,HEATING_COOLING,HUMIDITY,HUMIDITY_STATUS,PARTY_MODE,
PARTY_SET_POINT_TEMPERATURE,PARTY_TIME_END,PARTY_TIME_START,QUICK_VETO_TIME,SET_POINT_MODE,
SET_POINT_TEMPERATURE,SWITCH_POINT_OCCURED,WINDOW_STATE config datapoint
mit dem eintrag im Logfile:
2022.12.07 12:02:07 2: HMCCU [d_ccu] Can't get device description for 000615699CED0A  HMCCU_DetectDevice:8126 HMCCU_SetDefaultSCDatapoints:8240 HMCCU_GetSCDatapoints:4748 HMCCU_UpdateParamsetReadings:4959 HMCCU_UpdateMultipleDevices:878 HMCCURPCPROC_Read:3976 CallFn:784
2022.12.07 12:02:08 2: HMCCU [d_ccu] Can't get device description for 000615699CED0A  HMCCU_DetectDevice:8126 HMCCU_SetDefaultSCDatapoints:8240 HMCCU_GetSCDatapoints:4748 HMCCU_UpdateParamsetReadings:4959 HMCCU_UpdateMultipleDevices:878 HMCCURPCPROC_Read:3976 CallFn:784
2022.12.07 12:02:12 2: HMCCU [d_ccu] Can't get device description for 000615699CED0A  HMCCU_DetectDevice:8126 HMCCU_SetDefaultSCDatapoints:8240 HMCCU_GetSCDatapoints:4748 HMCCU_UpdateParamsetReadings:4959 HMCCU_UpdateMultipleDevices:878 HMCCURPCPROC_Read:3976 CallFn:784
nun habe ich mich an lesen und suchen gegeben, auch habe ich versucht zap eine PM zu senden, leider alles ohne ein Ergebnis , was dies löst.
auch eine Änderung der Werte
webCmd             desired-temp
widgetOverride    desired-temp:uzsuDropDown,5,18,18.5,19,19.5,20,20.5,21,21.5,22,22.5,23
hilft nicht
kann mir dazu einer etwas sagen?
Besten DAnk
				ZitatCan't get device description for 000615699CED0A
das ist dein problematischer FAL24, hat also primär nichts mit dem WTH-2 zu tun.
vermutlich hast du sie gepeert und das setzen der desired-temp erzeugt eine änderung im FAL24.
konzentriere dich auf den FAL24.
				Der FAL ist gar nicht mehr im System! und ok aber worauf sollte ich mich dort Konzentrieren, bitte?
Ich habe Ihnraus genommen weil ich das auch dachte. Nur es liegt nicht an Ihm!
Type list <name> for detailed info.
Global:
  global               (no definition)
MQTT2_SERVER:
  m2server             (Initialized)
  m2server_192.168.178.119_60016 (Connected)
  m2server_192.168.178.122_54889 (Connected)
FHEMWEB:
  WEB                  (Initialized)
  WEB_192.168.178.136_59680 (Connected)
  WEB_192.168.178.136_61546 (Connected)
  WEB_192.168.178.136_61557 (Connected)
MQTT2_DEVICE:
  MQTT2_Hausverteiler_oben_12 (???)
  MQTT2_Hausverteiler_unten_10_10 (???)
HMCCU:
  d_ccu                (running/OK)
HMCCUCHN:
  S_AWohnZ             (23.3)
  S_Bad                (19.1)
  S_PC                 (18.5)
  S_SchlafZ            (17.6)
HMCCURPCPROC:
  d_rpc178003BidCos_RF (running/OK)
  d_rpc178003HmIP_RF   (running/OK)
  d_rpc178003VirtualDevices (running/OK)
FileLog:
  FileLog_MQTT2_Hausverteiler_oben_12 (active)
  FileLog_MQTT2_Hausverteiler_unten_10_10 (active)
  FileLog_S_Bad        (active)
  Logfile              (active)
DOIF:
  Nachricht_Ausfall    (cmd_2)
SVG:
  SVG_FileLog_S_Bad_1  (initialized)
autocreate:
  autocreate           (active)
readingsWatcher:
  myreadingsWatcher    (ok)
telnet:
  telnetForBlockingFn_1670413968.94859 (Initialized)
attr global userattr cmdIcon devStateIcon:textField-long devStateStyle icon readingsWatcher sortby webCmd webCmdLabel:textField-long widgetOverride
attr global altitude 47
attr global autoload_undefined_devices 1
attr global autosave 0
attr global backup_before_update 1
attr global logfile ./log/fhem-%Y-%m.log
attr global modpath .
attr global nrarchive 7
attr global sendStatistics onUpdate
attr global statefile ./log/fhem.save
attr global verbose 3
define WEB FHEMWEB 8083 global
setuuid WEB 63721405-f33f-e8dd-18df-98cd77497037aa63
attr WEB JavaScripts codemirror/fhem_codemirror.js
attr WEB detailLinks 6
attr WEB editConfig 1
# Fake FileLog entry, to access the fhem log from FHEMWEB
define Logfile FileLog ./log/fhem-%Y-%m.log Logfile
setuuid Logfile 63721405-f33f-e8dd-b3eb-9e2ffff0b824dbbe
define autocreate autocreate
setuuid autocreate 63721405-f33f-e8dd-e3fe-d7cd02f667bd5dc3
attr autocreate filelog ./log/%NAME-%Y-%m.log
# Disable this to avoid looking for new USB devices on startup
define m2server MQTT2_SERVER 1883 global
setuuid m2server 63888cd8-f33f-e8dd-97d7-8289592d949b5955
attr m2server autocreate complex
attr m2server room MQTT2_DEVICE
define myreadingsWatcher readingsWatcher global
setuuid myreadingsWatcher 638dd137-f33f-e8dd-c36f-458ca1c51e5d0b72
attr myreadingsWatcher interval 10
attr myreadingsWatcher readingActivity none
define Nachricht_Ausfall DOIF ([myreadingsWatcher:dead] > 0) ()
setuuid Nachricht_Ausfall 638dd4b6-f33f-e8dd-afb0-ad1cc9fb54c5fd42
attr Nachricht_Ausfall do always
define d_ccu HMCCU 192.168.178.3 ccudelay=180
setuuid d_ccu 638e351a-f33f-e8dd-b597-a57d5b76103f2e06
attr d_ccu ccudef-substitute AES_KEY!(0|false):off,(1|true):on;;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;;UNREACH!(0|false):alive,(1|true):dead;;MOTION!(0|false):noMotion,(1|true):motion;;DIRECTION!0:stop,1:up,2:down,3:undefined;;WORKING!0:false,1:true;;INHIBIT!(0|false):unlocked,(1|true):locked
attr d_ccu ccuflags procrpc
attr d_ccu ccuget Value
attr d_ccu cmdIcon on:general_an off:general_aus
attr d_ccu room Homematic
attr d_ccu rpcinterfaces BidCos-RF,CUxD,HmIP-RF,VirtualDevices
attr d_ccu rpcserver on
attr d_ccu stateFormat rpcstate/state
define d_rpc178003BidCos_RF HMCCURPCPROC http://192.168.178.3 BidCos-RF
setuuid d_rpc178003BidCos_RF 638e351a-f33f-e8dd-6b43-272c993eb745754e
attr d_rpc178003BidCos_RF alias CCU 178003 RPC BidCos-RF
attr d_rpc178003BidCos_RF eventMap /rpcserver on:on/rpcserver off:off/
attr d_rpc178003BidCos_RF room HMCCURPCPROC,Homematic
attr d_rpc178003BidCos_RF stateFormat rpcstate/state
attr d_rpc178003BidCos_RF verbose 2
define d_rpc178003VirtualDevices HMCCURPCPROC http://192.168.178.3 VirtualDevices
setuuid d_rpc178003VirtualDevices 638e351b-f33f-e8dd-c447-e97c934f9d86f9a6
attr d_rpc178003VirtualDevices alias CCU 178003 RPC VirtualDevices
attr d_rpc178003VirtualDevices eventMap /rpcserver on:on/rpcserver off:off/
attr d_rpc178003VirtualDevices room HMCCURPCPROC,Homematic
attr d_rpc178003VirtualDevices stateFormat rpcstate/state
attr d_rpc178003VirtualDevices verbose 2
define d_rpc178003HmIP_RF HMCCURPCPROC http://192.168.178.3 HmIP-RF
setuuid d_rpc178003HmIP_RF 638e351b-f33f-e8dd-b7db-f8d37225d25ff6ef
attr d_rpc178003HmIP_RF alias CCU 178003 RPC HmIP-RF
attr d_rpc178003HmIP_RF eventMap /rpcserver on:on/rpcserver off:off/
attr d_rpc178003HmIP_RF room HMCCURPCPROC,Homematic
attr d_rpc178003HmIP_RF stateFormat rpcstate/state
attr d_rpc178003HmIP_RF verbose 2
define S_AWohnZ HMCCUCHN 000A97098ED86C:1
setuuid S_AWohnZ 638e3722-f33f-e8dd-a30a-764ec75d72ae60fc
attr S_AWohnZ cmdIcon auto:sani_heating_automatic manu:sani_heating_manual boost:sani_heating_boost on:general_an off:general_aus
attr S_AWohnZ room Heizung,HMCCUCHN,Homematic
attr S_AWohnZ webCmd desired-temp
attr S_AWohnZ widgetOverride desired-temp:uzsuDropDown,5,18,18.5,19,19.5,20,20.5,21,21.5,22,22.5,23
define S_Bad HMCCUCHN 000A97098ED065:1
setuuid S_Bad 638e377d-f33f-e8dd-a230-41e2f738a5c285a9
attr S_Bad cmdIcon auto:sani_heating_automatic manu:sani_heating_manual boost:sani_heating_boost on:general_an off:general_aus
attr S_Bad room HMCCUCHN,Heizung
attr S_Bad substexcl desired-temp
attr S_Bad webCmd desired-temp:auto:manu:boost:on:off
attr S_Bad widgetOverride desired-temp:slider,4.5,0.5,30.5,1
define S_SchlafZ HMCCUCHN 000A97098EDA27:1
setuuid S_SchlafZ 638e5250-f33f-e8dd-6a84-50b47830acccf745
attr S_SchlafZ cmdIcon auto:sani_heating_automatic manu:sani_heating_manual boost:sani_heating_boost on:general_an off:general_aus
attr S_SchlafZ room HMCCUCHN,Heizung
attr S_SchlafZ substexcl desired-temp
attr S_SchlafZ webCmd desired-temp:auto:manu:boost:on:off
attr S_SchlafZ widgetOverride desired-temp:slider,4.5,0.5,30.5,1
define S_PC HMCCUCHN 000A97098ED06C:1
setuuid S_PC 638e5269-f33f-e8dd-ee2a-f52b89b7b825ce78
attr S_PC cmdIcon auto:sani_heating_automatic manu:sani_heating_manual boost:sani_heating_boost on:general_an off:general_aus
attr S_PC room HMCCUCHN,Heizung
attr S_PC substexcl desired-temp
attr S_PC webCmd desired-temp:auto:manu:boost:on:off
attr S_PC widgetOverride desired-temp:slider,4.5,0.5,30.5,1
define SVG_FileLog_S_Bad_1 SVG FileLog_S_Bad:SVG_FileLog_S_Bad_1:CURRENT
setuuid SVG_FileLog_S_Bad_1 638f07f6-f33f-e8dd-0b23-4ba79329b830eb76
define MQTT2_Hausverteiler_unten_10_10 MQTT2_DEVICE Hausverteiler_unten_10_10
setuuid MQTT2_Hausverteiler_unten_10_10 638f0c2a-f33f-e8dd-c0ba-6a7beae13ea8b357
attr MQTT2_Hausverteiler_unten_10_10 readingList Hausverteiler_unten_10_10:Hausverteiler_unten_10/Heiz_Unten2/T02:.* T02\
Hausverteiler_unten_10_10:Hausverteiler_unten_10/Heiz_Unten/T01:.* T01\
Hausverteiler_unten_10_10:Hausverteiler_unten_10/status/LWT:.* LWT\
Hausverteiler_unten_10_10:Hausverteiler_unten_10/EE2_SysInf/freeRAM:.* freeRAM\
Hausverteiler_unten_10_10:Hausverteiler_unten_10/EE2_SysInf/freeStack:.* freeStack\
Hausverteiler_unten_10_10:Hausverteiler_unten_10/EE2_SysInf/SysLoad:.* SysLoad\
Hausverteiler_unten_10_10:Hausverteiler_unten_10/EE2_SysInf/WifiRSSI:.* WifiRSSI
attr MQTT2_Hausverteiler_unten_10_10 room MQTT2_DEVICE
define FileLog_MQTT2_Hausverteiler_unten_10_10 FileLog ./log/MQTT2_Hausverteiler_unten_10_10-%Y-%m.log MQTT2_Hausverteiler_unten_10_10
setuuid FileLog_MQTT2_Hausverteiler_unten_10_10 638f0c2a-f33f-e8dd-cff7-a3ae14fd8a2fdb70
attr FileLog_MQTT2_Hausverteiler_unten_10_10 logtype text
attr FileLog_MQTT2_Hausverteiler_unten_10_10 room MQTT2_DEVICE
define MQTT2_Hausverteiler_oben_12 MQTT2_DEVICE Hausverteiler_oben_12
setuuid MQTT2_Hausverteiler_oben_12 638f0d8d-f33f-e8dd-4bf1-4c94ee492102c125
attr MQTT2_Hausverteiler_oben_12 readingList Hausverteiler_oben_12:Hausverteiler_oben/Vorlauf_1/t_1_1:.* t_1_1\
Hausverteiler_oben_12:Hausverteiler_oben/Vorlauf_2/t_1_2:.* t_1_2\
Hausverteiler_oben_12:Hausverteiler_oben/status/LWT:.* LWT
attr MQTT2_Hausverteiler_oben_12 room MQTT2_DEVICE
define FileLog_MQTT2_Hausverteiler_oben_12 FileLog ./log/MQTT2_Hausverteiler_oben_12-%Y-%m.log MQTT2_Hausverteiler_oben_12
setuuid FileLog_MQTT2_Hausverteiler_oben_12 638f0d8d-f33f-e8dd-c8aa-5422e720160d5156
attr FileLog_MQTT2_Hausverteiler_oben_12 logtype text
attr FileLog_MQTT2_Hausverteiler_oben_12 room MQTT2_DEVICE
define FileLog_S_Bad FileLog ./log/S_Bad-%Y-%m.log S_Bad
setuuid FileLog_S_Bad 638f12cd-f33f-e8dd-6f64-3ac0d50bd7b54525
attr FileLog_S_Bad logtype text
attr FileLog_S_Bad room HMCCUCHN,Heizung
das ist ein WTH-2 define S_PC HMCCUCHN 000A97098ED06C:1
neuester Fehler: 2022.12.07 14:28:47 2: HMCCU [d_ccu] Error during HTTP request: http://192.168.178.3:8181/tclrega.exe: Select timeout/error:
2022.12.07 14:28:47 1: HMCCUCHN [S_PC] HMCCUCHN: S_PC Execution of CCU script or command failed
				ZitatDer FAL ist gar nicht mehr im System!
aber in der ccu, oder?
oder direkte verknüpfungen, die im wth existieren.
				gerne alles was mich in diesen Punkzen weiter bringt.
Global:
MQTT2_SERVER:
  m2server_192.168.178.119_52947 (Connected)
  m2server_192.168.178.122_60873 (Connected)
FHEMWEB:
  WEB                  (Initialized)
  WEB_192.168.178.136_61905 (Connected)
  WEB_192.168.178.136_62845 (Connected)
MQTT2_DEVICE:
HMCCU:
  d_ccu                (running/OK)
HMCCUCHN:
  S_AWohnZ             (23.4)
  S_Bad                (21.2)
  S_PC                 (19.4)
  S_SchlafZ            (19.7)
HMCCURPCPROC:
FileLog:
  Logfile              (active)
DOIF:
SVG:
autocreate:
  autocreate           (active)
readingsWatcher:
welche Verknüpfungen meinst Du?
auch die die auf dem HomeMatic Raspberry pi sind, der stellt ja eigentlich ein ccu2 dar.
Wenn ich es richtig verstehe macht der FAL die vielen probleme, ich hab es aber bisher nicht verstanden wie ich Ihn nutzen kann oder ob er nicht nutzbar ist oder es einfach an mir liegt.
Ich bitte hier wirklich um Hilfe , Beispiele. Oder ein ToDo am besten.
Ich möchte eben das die Stellmotoren auch ansprechbar sind. am besten alles über fhem aber wenn es nicht geht dann wenigstens das ich die Temp sehe und am wth-2 einstellen kann , die Auswirkungen ohne das ich die in fhem sehe aber vollzogen werden, damit es in dem Raum eben auch warm wird.
Besten Dank
das mag ja sein, sollte ich also den FAL ganz aus dem System nehmen? gibt es einen Ersatz dafür? Ich jedenfalls bekomme das mit dem FAL-24 nicht hin und die Info Konzentriere Dich auf ist nicht zielführend!
In der Hoffnung eine aussagekräftige und weiterführende Antwort zu erhalten.
