FHEM => Automatisierung => DOIF => Thema gestartet von: bommel-bs am 27 März 2023, 12:41:45
Titel: [gelöst] DOIF wird nicht ausgeführt.
Beitrag von: bommel-bs am 27 März 2023, 12:41:45
HAllo,
ich habe folgendes DOIF:
define di_SchlafZimmer_Rollo DOIF ([{sunset("NAUTIC","0","16:00","22:30")}])\
    (set SchlafZimmer_Rolladen_Links pct 0;;\
     sleep 5;;\
     set SchlafZimmer_Rolladen_Tuer pct 0;;\
     sleep 5;;\
     set SchlafZimmer_Rolladen_Rechts pct 0;;)
attr di_SchlafZimmer_Rollo room 99_System
#   CFGFN
#   DEF        ([{sunset("NAUTIC","0","16:00","22:30")}])
#    (set SchlafZimmer_Rolladen_Links pct 0;
#     sleep 5;
#     set SchlafZimmer_Rolladen_Tuer pct 0;
#     sleep 5;
#     set SchlafZimmer_Rolladen_Rechts pct 0;)
#   FUUID      6419ead9-f33f-78f8-f787-cc3b1a2dcfc0b6f3
#   MODEL      FHEM
#   NAME       di_SchlafZimmer_Rollo
#   NOTIFYDEV  global
#   NR         5128
#   NTFY_ORDER 50-di_SchlafZimmer_Rollo
#   STATE      cmd_1
#   TYPE       DOIF
#   VERSION    27262 2023-02-21 19:36:39
#   eventCount 8
#   READINGS:
#     2023-03-21 19:52:23   cmd             1
#     2023-03-21 19:52:23   cmd_event       timer_1
#     2023-03-21 19:52:23   cmd_nr          1
#     2023-03-25 21:10:46   mode            enabled
#     2023-03-21 19:52:23   state           cmd_1
#     2023-03-26 21:01:50   timer_01_c01    27.03.2023 21:03:45
#   Regex:
#     accu:
#     bar:
#     barAvg:
#     collect:
#   attr:
#     cmdState:
#     waitdel:
#   condition:
#     0          ::DOIF_time_once($hash,0,$wday)
#   days:
#   do:
#     0:
#       0          set SchlafZimmer_Rolladen_Links pct 0;      sleep 5;      set SchlafZimmer_Rolladen_Tuer pct 0;      sleep 5;      set SchlafZimmer_Rolladen_Rechts pct 0;
#     1:
#   helper:
#     NOTIFYDEV  global
#     event      timer_1
#     globalinit 1
#     last_timer 1
#     sleeptimer -1
#     timerdev
#     timerevent timer_1
#     triggerDev
#     timerevents:
#       timer_1
#     timereventsState:
#       timer_1
#     triggerEvents:
#       timer_1
#     triggerEventsState:
#       timer_1
#   hmccu:
#   interval:
#   intervalfunc:
#   localtime:
#     0          1679943825
#   realtime:
#     0          21:03:45
#   time:
#     0          {sunset("NAUTIC","0","16:00","22:30")}
#   timeCond:
#     0          0
#   timer:
#     0          0
#   timers:
#     0           0
#   triggertime:
#     1679943825:
#       localtime  1679943825
#       hash:
#   uiState:
#   uiTable:
setstate di_SchlafZimmer_Rollo cmd_1
setstate di_SchlafZimmer_Rollo 2023-03-21 19:52:23 cmd 1
setstate di_SchlafZimmer_Rollo 2023-03-21 19:52:23 cmd_event timer_1
setstate di_SchlafZimmer_Rollo 2023-03-21 19:52:23 cmd_nr 1
setstate di_SchlafZimmer_Rollo 2023-03-25 21:10:46 mode enabled
setstate di_SchlafZimmer_Rollo 2023-03-21 19:52:23 state cmd_1
setstate di_SchlafZimmer_Rollo 2023-03-26 21:01:50 timer_01_c01 27.03.2023 21:03:45
Leider wird bei dem DOIF nur die Zeit für cmd 1 jeden Tag neu gesetzt aber nicht ausgeführt.
Wo ist mein Gedankenfehler?
Stefan
Titel: Aw: DOIF wird nciht ausgeführt.
Beitrag von: Damian am 27 März 2023, 14:04:16
Du musst das do always-Attribut setzen, damit es jeden Tag ausgeführt wird. Statt sleep solltest du das Attribut wait verwenden.
Beitrag von: bommel-bs am 27 März 2023, 14:35:56
Hallo Damian,
danke. Mal sehen, ob die Rolladen heute Abend schließen. Wie oft wird das DOIF ohne always ausgeführt?
Stefan
Beitrag von: Damian am 27 März 2023, 15:41:00
Stefan
Immer (always) wenn der Timer zuschlägt. Umgekehrt gesagt, wird ohne do always nur einmal ausgeführt, bis ein anderer Zweig ausgeführt wurde - also wenn sich der Zustand des Moduls geändert hat. So etwas steht in der Einleitung zum DOIF: https://fhem.de/commandref_DE.html#DOIF
Beitrag von: bommel-bs am 28 März 2023, 20:05:20
Hallo Damian,
Zitat von: Damian am 27 März 2023, 14:04:16Du musst das do always-Attribut setzen, damit es jeden Tag ausgeführt wird. Statt sleep solltest du das Attribut wait verwenden.
das war es.
Stefan
