ich versuche gerade einen eBUS v5 Adapter von John30 mit einer Ochsner GMLW 14 zum laufen zu bringen. Leider funktioniert wohl die automatische Auswahl der Konfiguration nicht.
Zur Konfiguration:
System = Raspberry Pi 4 Bullseye (aktuelle Updates)
Wärmepumpe = Ochsner GMLW 14 mit Steuerung OTE Plus (ebus v5.02/3.03)
Ebus-Adapter = v5 von John30 mit Ethernet Modul W5500 (aktuelle Firmware)
Ebusd = v23.1
/etc/default/ebusd config = EBUSD_OPTS="--scanconfig -d ens:192.168.1.150:9999 --httpport=8889  --htmlpath=/va$"
easi>
Chip ID: dc54756226c0, ESP32-C3, rev 4
Hostname: ebus-6226c0
Flash: 4194304
Version: v5.2-dev-350-g56123c52aa-dirty
Reset reason: 5
eBUS r/w: 1737/0
Host r/w: 4/2146
Up time: 40
Free heap: 112488
ebusd connected: yes (inactive)
eBUS signal: acquired
ebusctl find
broadcast datetime = 16.199;09:16:39;26.05.2023
broadcast error = SE60  E OK
broadcast id = no data stored
broadcast signoflife = no data stored
memory eeprom = no data stored
memory ram = no data stored
scan.06  = TEM;20851;0050;0000
scan.08  = TEM;WE_1 ;3632;3030
scan.15  = TEM;22420;0502;0102
scan.18  = TEM;WE_2 ;3632;3030
ebusctl info
version: ebusd 23.1.23.1
update check: OK, device firmware 1[8419] available
device: 192.168.1.150:9999, enhanced, firmware 1.1[3501].1[3501]
signal: acquired
symbol rate: 39
max symbol rate: 108
reconnects: 0
masters: 5
conditional: 0
poll: 0
update: 4
address 01: master #6
address 03: master #11
address 06: slave #6, scanned "MF=TEM;ID=20851;SW=0050;HW=0000"
address 08: slave #11, scanned "MF=TEM;ID=WE_1 ;SW=3632;HW=3030"
address 10: master #2
address 13: master #12
address 15: slave #2, scanned "MF=TEM;ID=22420;SW=0502;HW=0102"
address 18: slave #12, scanned "MF=TEM;ID=WE_2 ;SW=3632;HW=3030"
address 31: master #8, ebusd
address 36: slave #8, ebusd
/var/log/ebusd.log
2023-05-26 08:09:16.478 [main notice] ebusd 23.1.23.1 started with auto scan on enhanced device 192.168.1.150:9999
2023-05-26 08:09:17.290 [bus notice] device status: resetting
2023-05-26 08:09:17.290 [bus notice] bus started with own address 31/36
2023-05-26 08:09:17.302 [bus notice] signal acquired
2023-05-26 08:09:17.342 [bus notice] new master 01, master count 2
2023-05-26 08:09:17.402 [bus notice] new master 10, master count 3
2023-05-26 08:09:17.402 [update notice] received unknown MS cmd: 011506210400840040 / 0a04800d02e8030000c101
2023-05-26 08:09:17.731 [bus notice] device status: reset, supports info
2023-05-26 08:09:17.835 [bus notice] device status: extra info: firmware 1.1[3501].1[3501], jumpers 0x0f
2023-05-26 08:09:18.562 [update notice] received unknown MS cmd: 011506210400e00040 / 0a60800d02e80300008601
2023-05-26 08:09:19.622 [update notice] received unknown MS cmd: 011506210402b50040 / 0a35810000ff0000000000
2023-05-26 08:09:19.853 [bus notice] new master 03, master count 4
2023-05-26 08:09:19.862 [update notice] received unknown MM cmd: 031005030a010000004720ff3f0000
2023-05-26 08:09:20.431 [update notice] received unknown MM cmd: 1003050a00
2023-05-26 08:09:20.731 [update notice] received unknown MS cmd: 011506210402c60040 / 0a46410428ffff00000fb0
2023-05-26 08:09:21.072 [bus notice] new master 13, master count 5
2023-05-26 08:09:21.072 [update notice] received unknown MM cmd: 1013050a00
2023-05-26 08:09:21.662 [update notice] received update-read broadcast datetime QQ=10: 14.301;08:21:10;26.05.2023
2023-05-26 08:09:21.771 [update notice] received unknown MS cmd: 011506210402c80040 / 0a4841042a9f050000f501
2023-05-26 08:09:22.331 [update notice] received unknown MM cmd: 131005030a011a00004effff3f4300
2023-05-26 08:09:22.922 [update notice] received unknown MS cmd: 011506210400800040 / 0a00800d02f4010cfe8f00
2023-05-26 08:09:24.031 [update notice] received unknown MS cmd: 011506210400840040 / 0a04800d02e8030000c101
2023-05-26 08:09:25.142 [update notice] received unknown MS cmd: 011506210400e00040 / 0a60800d02e80300008601
2023-05-26 08:09:26.392 [update notice] received unknown MS cmd: 011506210402b50040 / 0a35810000ff0000000000
2023-05-26 08:09:27.362 [update notice] received unknown MS cmd: 011506210402c60040 / 0a46410428ffff00000fb0
2023-05-26 08:09:27.592 [bus notice] scan 06: ;TEM;20851;0050;0000
2023-05-26 08:09:27.592 [update notice] store 06 ident: done
2023-05-26 08:09:27.592 [update notice] sent scan-read scan.06  QQ=31: TEM;20851;0050;0000
2023-05-26 08:09:27.784 [main error] unable to load scan config 06: list files in tem ERR: element not found
2023-05-26 08:09:27.784 [main error] scan config 06: ERR: element not found
2023-05-26 08:09:27.873 [update notice] received unknown MM cmd: 031005030a010000004720ff3f0000
2023-05-26 08:09:28.512 [update notice] received unknown MS cmd: 011506210402c80040 / 0a4841042a9f050000f501
2023-05-26 08:09:28.892 [update notice] received unknown MM cmd: 131005030a011a00004effff3f4300
2023-05-26 08:09:29.622 [update notice] received unknown MS cmd: 011506210400800040 / 0a00800d02f4010cfe8f00
2023-05-26 08:09:29.992 [bus notice] scan 08: ;TEM;WE_1 ;3632;3030
2023-05-26 08:09:29.992 [update notice] store 08 ident: done
2023-05-26 08:09:29.992 [update notice] sent scan-read scan.08  QQ=31: TEM;WE_1 ;3632;3030
2023-05-26 08:09:30.192 [update notice] received unknown MM cmd: 100305010a00002f0e000000000000
2023-05-26 08:09:30.200 [main error] unable to load scan config 08: list files in tem ERR: element not found
2023-05-26 08:09:30.200 [main error] scan config 08: ERR: element not found
2023-05-26 08:09:30.731 [update notice] received unknown MS cmd: 011506210400840040 / 0a04800d02e8030000c101
2023-05-26 08:09:30.922 [update notice] received unknown MM cmd: 101305010a00000a0e000000000100
2023-05-26 08:09:31.522 [update notice] received unknown BC cmd: 10fe0801080027008000009a1d
2023-05-26 08:09:31.823 [update notice] received unknown MS cmd: 011506210400e00040 / 0a60800d02e80300008601
2023-05-26 08:09:32.431 [bus notice] scan 15: ;TEM;22420;0502;0102
2023-05-26 08:09:32.431 [update notice] store 15 ident: done
2023-05-26 08:09:32.431 [update notice] sent scan-read scan.15  QQ=31: TEM;22420;0502;0102
2023-05-26 08:09:32.618 [main error] unable to load scan config 15: list files in tem ERR: element not found
2023-05-26 08:09:32.618 [main error] scan config 15: ERR: element not found
2023-05-26 08:09:32.932 [update notice] received unknown MS cmd: 011506210402b50040 / 0a35810000ff0000000000
2023-05-26 08:09:33.995 [update notice] received unknown MS cmd: 011506210402c60040 / 0a46410428ffff00000fb0
2023-05-26 08:09:34.852 [bus notice] scan 18: ;TEM;WE_2 ;3632;3030
2023-05-26 08:09:34.852 [update notice] store 18 ident: done
2023-05-26 08:09:34.852 [update notice] sent scan-read scan.18  QQ=31: TEM;WE_2 ;3632;3030
2023-05-26 08:09:35.039 [main error] unable to load scan config 18: list files in tem ERR: element not found
2023-05-26 08:09:35.039 [main error] scan config 18: ERR: element not found
2023-05-26 08:09:35.122 [update notice] received unknown MS cmd: 011506210402c80040 / 0a4841042a9f050000f501
2023-05-26 08:09:35.872 [update notice] received unknown MM cmd: 031005030a010000004720ff3f0000
2023-05-26 08:09:36.372 [update notice] received unknown MS cmd: 011506210400800040 / 0a00800d02f4010cfe8f00
2023-05-26 08:09:36.892 [update notice] received unknown MM cmd: 131005030a011a00004effff3f4300
2023-05-26 08:09:37.342 [update notice] received unknown MS cmd: 011506210400840040 / 0a04800d02e8030000c101
2023-05-26 08:09:38.502 [update notice] received unknown MS cmd: 011506210400e00040 / 0a60800d02e80300008601
2023-05-26 08:09:39.607 [update notice] received unknown MS cmd: 011506210402b50040 / 0a35810000ff0000000000
2023-05-26 08:09:40.782 [update notice] received unknown BC cmd: 10fe0802080000002f00000310
2023-05-26 08:09:40.892 [update notice] received unknown MS cmd: 011506210402c60040 / 0a46410428ffff00000fb0
2023-05-26 08:09:41.807 [update notice] received unknown MS cmd: 011506210402c80040 / 0a4841042a9f050000f501
2023-05-26 08:09:42.922 [update notice] received unknown MS cmd: 011506210400800040 / 0a00800d02f4010cfe8f00
2023-05-26 08:09:43.903 [update notice] received unknown MM cmd: 031005030a010000004720ff3f0000
2023-05-26 08:09:44.009 [update notice] received unknown MS cmd: 011506210400840040 / 0a04800d02e8030000c101
2023-05-26 08:09:44.892 [update notice] received unknown MM cmd: 131005030a011a00004effff3f4300
2023-05-26 08:09:45.107 [update notice] received unknown MS cmd: 011506210400e00040 / 0a60800d02e80300008601
2023-05-26 08:09:46.354 [update notice] received unknown MS cmd: 011506210402b50040 / 0a35810000ff0000000000
2023-05-26 08:09:47.323 [update notice] received unknown MS cmd: 011506210402c60040 / 0a46410428ffff00000fb0
2023-05-26 08:09:48.482 [update notice] received unknown MS cmd: 011506210402c80040 / 0a4841042a9f050000f501
2023-05-26 08:09:49.592 [update notice] received unknown MS cmd: 011506210400800040 / 0a00800d02f4010cfe8f00
2023-05-26 08:09:49.972 [update notice] received unknown MM cmd: 100305010a00002f0e000000000000
2023-05-26 08:09:50.582 [update notice] received unknown MM cmd: 101305010a00000a0e000000000100
2023-05-26 08:09:50.792 [update notice] received unknown MS cmd: 011506210400840040 / 0a04800d02e8030000c101
2023-05-26 08:09:51.254 [update notice] received update-read broadcast datetime QQ=10: 14.301;08:21:39;26.05.2023
IP-RPI:8889/data gibt leider keine Daten der Ochsner Wärmepumpe aus.
Hat evtl. jemand eine ähnliche Wärmepumpe und kann mir hierbei helfen?
Vielen Dank im Voraus und beste Grüße
Foradh
