FHEM => Sonstiges => Thema gestartet von: pcbastler am 09 August 2023, 21:54:05
Titel: DebianMail unter Debian 12: TLS setup failed: hostname verification failed
Beitrag von: pcbastler am 09 August 2023, 21:54:05
seit dem Update meiner Smarthome-VM auf Debian 12.1 funktioniert der Mailversand nicht mehr. Selbst per Kommandozeile
sendEmail -f 'xxx@mydomain.net' -t 'fh_68@web.de' -u 'Test' -m 'Das ist ein Test' -s 'smtp.1blu.de' -xu 'LOGIN' -xp 'PASSWORT' -o tls=auto -o message-charset=utf-8
gibts den Fehler:TLS setup failed: hostname verification failed
Der SMTP-Server unterstützt (mit Thunderbird getestet) SSL/TLS auf Port 465 und StartTLS auf Port 587.
Log (sendEmail -vv):
Aug 09 21:28:23 smarthome sendEmail[969056]: DEBUG => Connecting to smtp.1blu.de:25
Aug 09 21:28:24 smarthome sendEmail[969056]: DEBUG => My IP address is: 192.168.35.7
Aug 09 21:28:24 smarthome sendEmail[969056]: DEBUG => evalSMTPresponse() - Found SMTP success code: 220
Aug 09 21:28:24 smarthome sendEmail[969056]: SUCCESS => Received:       220 ms-10.1blu.de ESMTP Exim 4.90_1 Ubuntu Wed, 09 Aug 2023 21:28:24 +0200
Aug 09 21:28:24 smarthome sendEmail[969056]: INFO => Sending:   EHLO smarthome.mydomain.home
Aug 09 21:28:24 smarthome sendEmail[969056]: DEBUG => evalSMTPresponse() - Found SMTP success code: 250
Aug 09 21:28:24 smarthome sendEmail[969056]: SUCCESS => Received:       250-ms-10.1blu.de Hello smarthome.mydomain.home [84.169.163.169], 250-SIZE 157286400, 250-8BITMIME, 250-PIPELINING, 250-AUTH LOGIN PLAIN, 250-CHUNKING, 250-STARTTLS, 250 HELP
Aug 09 21:28:24 smarthome sendEmail[969056]: DEBUG => The remote SMTP server supports TLS :)
Aug 09 21:28:24 smarthome sendEmail[969056]: DEBUG => Starting TLS
Aug 09 21:28:24 smarthome sendEmail[969056]: INFO => Sending:   STARTTLS
Aug 09 21:28:24 smarthome sendEmail[969056]: SUCCESS => Received:       220 TLS go ahead
Aug 09 21:28:24 smarthome sendEmail[969056]: ERROR => TLS setup failed: hostname verification failed
die Perl-Bibliotheken habe ich mittels CPAN -> upgrade schon auf den letzten Stand gebracht (damit ist
Use of uninitialized value $2 in concatenation (.) or string at /usr/share/perl5/IO/Socket/SSL.pm line 792. aus dem FHEM-Log beseitigt),
Auf Port 465 bekomme ich mit sendEmail keine Verbindung
sendEmail -f 'fhem@mydomain.net' -t 'fh_68@web.de' -u 'Test' -m 'Das ist ein Test' -s 'smtp.1blu.de:465' ....
Aug 09 21:30:47 smarthome sendEmail[969851]: DEBUG => Connecting to smtp.1blu.de:465
Aug 09 21:30:47 smarthome sendEmail[969851]: DEBUG => My IP address is: 192.168.35.7
Aug 09 21:31:47 smarthome sendEmail[969851]: ERROR => Timeout while reading from smtp.1blu.de:465 There was no response after 60 seconds.
Ganz alleine bin ich mit dem Problem wohl nicht, aber eine Lösung hab ich nirgendwo gefunden. Als Workaround hätte ich noch einen lokalen SMTP-Server, aber das sollte nicht die Lösung sein.
Wer kann hier weiterhelfen?
Titel: Aw: DebianMail unter Debian 12: TLS setup failed: hostname verification failed
Beitrag von: Otto123 am 09 August 2023, 22:50:48
was genau bedeutet update?
Edit: Ok auf einem neu installiertem debian 12 habe ich auch dieses Problem.
Beitrag von: pcbastler am 10 August 2023, 18:44:58
update war Debian 11 -> 12. Der Fehler ist unabhängig vom SMTP-Server, ich kann den auch mit smtp.web.de nachstellen
Beitrag von: Wernieman am 10 August 2023, 18:57:55
Habe jetzt kein passendes System vor Ort zum Testen .. könntest Du die "Hostnameverifikation" testweise mal im sendemail abschalten?
Beitrag von: pcbastler am 10 August 2023, 19:05:37
habe zwischendurch mit meinem lokalen Server (ohne SSL) getestet, da klappts noch. Liegt also erstmal bei SSL.
Ist auch offiziell als Bug erkannt: https://groups.google.com/g/linux.debian.bugs.dist/c/VuPw373HByE.
@wernieman: da fehlt leider das Hintergrundwissen, wenn ich den Hostnamen in der Kommandozeile durch die IP ersetze wirds nicht besser
Beitrag von: Wernieman am 10 August 2023, 19:08:03
Bei einiger Software gibt es die Möglichkeit, diesen Test per "Schalter" abzuschalten.
Hintergrund:
Im Zertifikat ist ein Hostname und der passt reverse nicht zum Aufruf (bzw. die Software denkt, das er nicht passt ...)
Beitrag von: pcbastler am 30 August 2023, 17:19:41
Mit dem Paket aus dem aktuellen testing-Zweig läuft es wieder.
Beitrag von: StephanSelve am 02 September 2023, 17:53:58
Zitat von: pcbastler am 30 August 2023, 17:19:41Mit dem Paket aus dem aktuellen testing-Zweig läuft es wieder.
Welches Paket? .... Bitte
Beitrag von: pcbastler am 04 September 2023, 21:16:28
sendemail_1.56-5.2_all.deb
Beitrag von: StephanSelve am 10 September 2023, 15:58:34
Zitat von: pcbastler am 04 September 2023, 21:16:28sendemail_1.56-5.2_all.deb
Vielen Dank!
Beitrag von: Funsailor am 06 Oktober 2023, 12:20:01
ich habe das gleiche Problem, sendemail funktioniert nicht mehr (scheinbar seit ich auf bookworm upgedatet habe) und ich bekomme die selbe Fehlermeldung:
"Oct 06 12:11:06 minipc sendemail[733]: ERROR => TLS setup failed: hostname verification failed"
Der Versuch mit der alten Version "sendemail_1.56-5.2_all.deb" funzt auch nicht.
Wie habt Ihr das mit der 1.56-5.2 Version zum laufen gebracht?
Beitrag von: Funsailor am 23 Oktober 2023, 13:57:49
Da ich auch mit der sendemail_1.56-5.2 Version nicht weitergekommen bin, habe ich mir den Patch von hier:
https://www.mail-archive.com/debian-bugs-dist@lists.debian.org/msg1915977.html
in die \usr\bin\senEmail eingebaut:
        ## Start TLS if possible
##        if ($conf{'tls_server'} == 1 and $conf{'tls_client'} == 1 and $opt{'tls'} =~ /^(yes|auto)$/) {
##            printmsg("DEBUG => Starting TLS", 2);
##            if (SMTPchat('STARTTLS')) { quit($conf{'error'}, 1); }
##            if (! IO::Socket::SSL->start_SSL($SERVER, SSL_version => 'SSLv23:!SSLv2')) {
##                quit("ERROR => TLS setup failed: " . IO::Socket::SSL::errstr(), 1);
##            printmsg("DEBUG => TLS: Using cipher: ". $SERVER->get_cipher(), 3);
               SSL_version => 'TLSv12:!SSLv2',
               SSL_verifycn_scheme => 'smtp',
               SSL_verifycn_name => $conf{'server'})) {quit("ERROR => TLS setup failed: " . IO::Socket::SSL::errstr(), 1);
Jetzt funktioniert das senden von Emails wieder Problemlos  ;D  8)
Mal sehen wie lange  ::)
Vorher hatte ich meine Probleme mit fhem
Zitathttps://forum.fhem.de/index.php?msg=1288545
gelöst.
Beitrag von: Wernieman am 23 Oktober 2023, 15:54:36
Genau eine dieser Eistellungen dürfte der Problemlöser gewesen sein. Könnte man sich rantasten ... würde pauschal an SSL_version Tippen ...
Beitrag von: juemuc am 23 Oktober 2023, 16:00:31
die Version sendemail_1.56-5.2 kann man wie folgt installieren:
1. Repository ergänzen mit
sudo nano /etc/apt/sources.list2. folgende Zeile ergänzen:
deb http://deb.debian.org/debian bookworm-backports main3. sudo apt update4. sudo apt install sendemail/bookworm-backports
Danach funktioniert sendemail wieder.
Jürgen
Beitrag von: Rewe2000 am 01 Dezember 2023, 17:26:31
Hallo Jürgen,
auch ich war nach der Installation auf Bookworm von dem Mailproblem betroffen, die von dir beschriebene Vorgehensweise hat das Problem auch bei mir beseitigt, Danke dafür.
Eine Frage als Gelegenheits Linux-User habe ich noch dazu.
Muss ich zu einen späteren Zeitpunkt den Eintrag wieder aus dem Repository entfernen oder kann der zukünftig so bleiben?
Irgendwann wird ja wahrscheinlich sendemail_1.56-5.2 als Standard beim Update mitkommen.
Gruß Reinhard
Beitrag von: Holger am 19 Dezember 2023, 12:10:12
Vielen Dank für die Lösung. Sie hat auch bei mir funktioniert.
Beitrag von: ph0x am 10 Januar 2024, 20:05:35
Zitat von: Rewe2000 am 01 Dezember 2023, 17:26:31Muss ich zu einen späteren Zeitpunkt den Eintrag wieder aus dem Repository entfernen oder kann der zukünftig so bleiben?
Gruß Reinhard
Die Backports als Quelle zu behalten, ist schon sinnvoll, da während der Lebensdauer einer Debian-Version im Main-Repo keine größeren Versionssprünge gemacht werden.
Daher sind manche Änderungen nur über Backports zu bekommen. Je älter die Debian-Version, desto mehr. Daher würde ich es nicht entfernen.
Beitrag von: heikoh81 am 25 Juli 2024, 22:49:14
Zitat von: Funsailor am 23 Oktober 2023, 13:57:49## Start TLS if possible
Danke, hat auch bei mir sendEmail wieder zum Laufen gebracht.
Ich verwende die Funktion an zu vielen Stellen, eine Umstellung z.B. auf die curl-Lösung wäre sehr sehr aufwändig.
Beitrag von: Flachzange am 03 Oktober 2024, 13:48:47
Mies! Diesen Thread hätte ich mal früher finden sollen, dann hätte ich mir die Analyse des Problems ersparen können (aber man lernt ja immer etwas dabei). Google hat mich immer irgendwo hingeschickt, aber dass die Antwort so nah hier im Forum ist, hätte ich auch nicht erwartet.
Mein Problem ist etwas anders gelagert: Das neueste Testing-Docker-Image (https://forum.fhem.de/index.php?topic=89745.0) läuft zwar weiterhin auf Bullseye, aber die Perl-Umgebung ist neuer und genau das löst auch hier das Problem aus. Erst hatte ich den Verdacht, dass diese Perl-Umgebung die CA-Zertifikate nicht kennt, aber nach Analyse der Perl-Doku war dann klar, dass neuerding der Hostname für die Überprüfung angebeben werden muss (https://github.com/zehm/sendEmail/issues/14) bzw. wie in der "offiziellen Lösung" des Maintainers die verifycn-Config definiert werden muss.
Zitat von: heikoh81 am 25 Juli 2024, 22:49:14Ich verwende die Funktion an zu vielen Stellen, eine Umstellung z.B. auf die curl-Lösung wäre sehr sehr aufwändig.
Aus diesem Grund nutze ich das msg-Modul. Da definiert man einmal an zentraler Stelle, wie E-Mails, Push, etc. verschickt werden und wenn sich dann mal die Methode ändert, muss nur genau eine Stelle anfassen.
Beitrag von: high8 am 09 November 2024, 14:35:17
sudo apt update4.
Jürgen
Hallo - bei mir meckert sudo apt update darüber, dass die Source keinen Public Key hat. Wüsste aber auch nicht, wie dieser dem key-ring zuzufügen sein soll. Hab dazu nichts gefunden ...
Auch die Option allow-insecure=yes in der sources.list hat nichts gebracht. Was übersehe ich?
pi@raspberrypi:~ $ sudo apt update
OK:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
Holen:2 http://deb.debian.org/debian bookworm-backports InRelease [59,0 kB]
OK:3 http://archive.raspberrypi.com/debian bookworm InRelease
Fehl:2 http://deb.debian.org/debian bookworm-backports InRelease
  Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
Paketlisten werden gelesen... Fertig
W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details.
W: GPG-Fehler: http://deb.debian.org/debian bookworm-backports InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
E: Das Depot »http://deb.debian.org/debian bookworm-backports InRelease« ist nicht signiert.
N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
Beitrag von: passibe am 09 November 2024, 14:52:18
Googeln. z.B. hier: https://forums.raspberrypi.com/viewtopic.php?t=365928
War früher mal apt-key, jetzt einfach nur gpg (https://keyring.debian.org).
Heißt:
gpg --keyserver keyring.debian.org --recv-keys <KEY ID>
<KEY ID> siehst du oben (0E98... und 6ED0...)
Edit: ggfs. sudo verwenden, bin mir gerade nicht sicher, ob man das braucht.
Beitrag von: high8 am 09 November 2024, 15:40:57
VIELEN DANK.
Also mit dem verlinkten Topic hat's direkt geklappt
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 0E98404D386FA1D9
Mit gpg hab ich komischerweise Fehler
pi@raspberrypi:~ $ sudo gpg --keyserver keyring.debian.org --recv-keys 0E98404D386FA1D9
gpg: Keine gültigen OpenPGP-Daten gefunden.
gpg: Anzahl insgesamt bearbeiteter Schlüssel: 0
pi@raspberrypi:~ $ sudo gpg --keyserver keyring.debian.org --recv-keys 6ED0E7B82643E131
Aber hauptsache es geht jetzt. Danke noch mal!!!
Beitrag von: KNUT345 am 05 Januar 2025, 08:56:02
sudo apt update4.
Jürgen
Hat auch bei mir bei Bookworm Version 12 super funktioniert, Danke.
Knut
Beitrag von: RalfRog am 08 April 2025, 15:20:48
Auch wenn ich hier mitgelesen hatte bin ich doch wieder über sendEmail in meiner neuen VM mit Bookworm & FHEM gestolpert.
Eine Ergänzung noch, da die im vorherigen Beitrag erwähnte Vorgehensweise hilft.
Ich habe mal geschaut wo die Unterschiede im Backport liegen (sendemail   1.56-5.2~bpo12+1).
Es ist genau das, was im Beitrag #11 genannt ist.
Zitat von: Funsailor am 23 Oktober 2023, 13:57:49....in die \usr\bin\senEmail eingebaut:
Jetzt funktioniert das senden....
Gruß Ralf
Beitrag von: Otto123 am 08 April 2025, 15:58:11
Falls es bei der nächsten debian Version dann wieder neue patches erfordert: Der User Torxgewinde hat im Wiki  (https://wiki.fhem.de/wiki/E-Mail_senden)eine Lösung mit curl hinterlassen, die ist vielleicht zukunftssicherer und, wenn ich es richtig verstehe, nicht blockierend!
Beitrag von: Torxgewinde am 12 April 2025, 09:11:11
Moin! Genau, die curl Lösung ist non-blocking und es ist alles als ein Device schnell installiert und ausprobiert.
Beitrag von: RalfRog am 12 April 2025, 13:43:19
Jep
Hab mir dein Wiki schon durchgelesen und bei curl mal in die Doku geschaut.
Ist ja mächtig mächtig.
Ich werd wohl umsteigen. Da ich zum Teil das msg-Modul nutze ist der Aufwand überschaubar.
Das Mail-Modul scheint aber auch handhabbar.
Gruß Ralf und danke für das Wiki
Beitrag von: Sidey am 17 April 2025, 18:38:29
Die Variante im Wiki hat sicher Vorteile.
Wer einen einfachen Ersatz für die bekannte Funktion debianMail sucht, dem könnte ich als Ersatz CurlMail anbieten:
######## CurlMail -  Mail aus einem Container mittels curl  über ein SSL Verbindung versenden ############
sub CurlMail
 my $rcpt = shift;
 my $subject = shift;
 my $text = shift;
 my $sender = shift;
 my $konto = shift;
 my $passwrd = shift;
 my $provider = shift;
 Log 1, qq[CurlMail: RCP: $rcpt];
 Log 1, qq[CurlMail: Subject: $subject];
 Log 1, qq[CurlMail: Text: $text];
 my @ret;
 my $curl_command = qq[curl --no-progress-meter --tlsv1.3 --ssl-reqd $provider --login-options AUTH=PLAIN --user "$konto:$passwrd" --mail-from "$sender" --mail-rcpt "$rcpt" --mail-rcpt-allowfails -H "Subject: $subject" -H "From: <$sender>" -F '=(;type=multipart/alternative' -F "=$text" -F "= <body>$text</body>;type=text/html" -F '=)'];
 open CURL, "$curl_command 2>&1 |" or die "Can't open curl $!\n";
 chomp(@ret = <CURL>);
 close CURL;
 Log 1, qq[CurlMail: curl returned: @ret] if (@ret);
Beitrag von: Torxgewinde am 18 April 2025, 08:55:12
Jo, geht natürlich auch, es gibt ja viele Wege zum Ziel. Ich hatte es auf Wunsch von Usern auf BlockingCall() (https://wiki.fhem.de/wiki/Blocking_Call)umgebaut, falls der E-Mail Versand mal -warum auch immer- lange dauert und FHEM dann stocken würde.
Mit die() muss man ein wenig vorsichtig sein, dass es einem nicht zuviel beendet (also, FHEM selbst zum Beispiel). Innerhalb eines eval() wäre es nutzbar.
Beitrag von: cotecmania am 22 Dezember 2025, 21:38:50
sudo apt update4.
Jürgen
Hat auch bei Trixie Debian 13 in Proxmox VM funktioniert !
Die Curl-Mail-Funktion habe ich auch mal getestet, funktioniert, aber da kann ich keine Anhaenge (Bilder von Cam) mitsenden.
Hat das vielleicht schonmal jemand umgesetzt ? Bräuchte nur den eigentlichen Aufruf.
So war mein alter (einfacher) Aufruf :
$ret .= qx(sendemail -f '$sender' -t '$rcpt' -u '$subject' -m '$text' -s '$provider' -xu '$konto' -xp '$passwrd' -o tls=yes  -a '$attach1' '$attach2' '$attach3' '$attach4' '$attach5' '$attach6' '$attach7' '$attach8' '$attach9' '$attach10');
Bei Curl ist das undurchsichtiger und ich bin Windows-Nerd  O:-) ...
Joe
Beitrag von: moskito am 22 Dezember 2025, 23:37:53
Das war aber dann nicht diese Curl Variante, oder?
https://wiki.fhem.de/wiki/E-Mail_senden#cURL_(Linux,_Windows) (https://wiki.fhem.de/wiki/E-Mail_senden#cURL_(Linux,_Windows))
Hier können Anhänge (relativ einfach) mitgesendet werden:
ZitatZwei Dateien mit anhängen: set sendMail message Subject="Dies ist ein Test" Anhang="./www/images/fhemSVG/bag.svg" Anhang="www/images/fhemSVG/batterie.svg" Mein Text, für die anzuhängenden Dateien können relative und absolute Pfade verwendet werden. Beim Vorbereiten der E-Mail wird geprüft ob die Dateien existieren, da dies sonst eine typische Fehlerquelle ist. Es wird nichts versendet wenn eine Datei nicht gefunden werden kann.
Danny
Beitrag von: cotecmania am 23 Dezember 2025, 10:58:40
Zitat von: moskito am 22 Dezember 2025, 23:37:53Das war aber dann nicht diese Curl Variante, oder?
Danny
Danke für den Hinweis.
Ich hatte die Funktion auf Seite 2 getestet, die dort gepostet war.
Werds mal bei Gelegenheit nach Wiki testen ...
Joe
