--2023.08.27--1: FHEMWEB SSL/HTTPS error: SSL accept attempt failed error:0A00009C:SSL routines::http request (peer: 192.168.YYY.XXX)
--2023.08.27--1: FHEMWEB SSL/HTTPS error: SSL accept attempt failed error:0A000412:SSL routines::sslv3 alert bad certificate (peer: 192.168.YYY.XXX)
--2023.08.27--1: FHEMWEB SSL/HTTPS error: Broken pipe SSL accept attempt failed (peer: 192.168.YYY.XXX)
--2023.08.27--1: FHEMWEB SSL/HTTPS error: SSL accept attempt failed error:0A000126:SSL routines::unexpected eof while reading (peer: 192.168.YYY.XXX)
--2023.08.27--1: FHEMWEB SSL/HTTPS error: Broken pipe SSL accept attempt failed error:0A000126:SSL routines::unexpected eof while reading (peer: 192.168.YYY.XXX)
--2023.08.27--1: FHEMWEB SSL/HTTPS error: SSL accept attempt failed error:0A000418:SSL routines::tlsv1 alert unknown ca (peer: 192.168.YYY.XXX)
--2023.08.27--3: FHEMWEB WEB CSRF error: csrf_492128915895744 ne csrf_324470343590636 for client WEB_192.168.YYY.XXX_38256 / command set myProPlanta update . For details see the csrfToken FHEMWEB attribute.
--2023.08.27--1: FHEMWEB SSL/HTTPS error: Connection reset by peer SSL accept attempt failed (peer: 192.168.YYY.XXX)
--2023.08.27--3: FHEMWEB WEB CSRF error: csrf_366473950784511 ne csrf_601076458141169 for client WEB_192.168.YYY.XXX_54744 / command "env". For details see the csrfToken FHEMWEB attribute.
--2023.08.27--1: UPD FHEM/01_FHEMWEB.pm
--2023.08.27--3: FHEMWEB WEB CSRF error: ne csrf_857037614955152 for client WEB_192.168.YYY.XXX_50570 / command help fheminfo ENX. For details see the csrfToken FHEMWEB attribute.
--2023.08.28--1: FHEMWEB SSL/HTTPS error: Broken pipe SSL accept attempt failed (peer: 192.168.YYY.XXX)
--2023.08.28--1: FHEMWEB SSL/HTTPS error: SSL accept attempt failed error:0A000126:SSL routines::unexpected eof while reading (peer: 192.168.YYY.XXX)
--2023.08.29--1: FHEMWEB SSL/HTTPS error: Broken pipe SSL accept attempt failed (peer: 192.168.YYY.XXX)
--2023.08.29--1: FHEMWEB SSL/HTTPS error: SSL accept attempt failed error:0A000126:SSL routines::unexpected eof while reading (peer: 192.168.YYY.XXX)
--2023.08.30--1: FHEMWEB SSL/HTTPS error: Broken pipe SSL accept attempt failed (peer: 192.168.YYY.XXX)
--2023.08.31--1: FHEMWEB SSL/HTTPS error: Broken pipe SSL accept attempt failed (peer: 192.168.YYY.XXX)
--2023.08.31--1: FHEMWEB SSL/HTTPS error: SSL accept attempt failed error:0A000126:SSL routines::unexpected eof while reading (peer: 192.168.YYY.XXX)
defmod WEB FHEMWEB 8084
attr WEB HTTPS 1
attr WEB JavaScripts codemirror/fhem_codemirror.js
attr WEB SVGcache 1
attr WEB alias Webserver
attr WEB confirmDelete 0
attr WEB confirmJSError 0
attr WEB fwcompress 0
attr WEB group Server
attr WEB icon rc_WEB
attr WEB longpoll websocket
attr WEB longpollSVG 1
attr WEB plotEmbed 2
attr WEB stylesheetPrefix dark
defmod allowedWEB allowed
attr allowedWEB alias Webserver Allowed
attr allowedWEB basicAuth SHA256:blablabla
attr allowedWEB basicAuthExpiry 7
attr allowedWEB basicAuthMsg FHEM Webserver
attr allowedWEB group Server
attr allowedWEB icon secur_locked
attr allowedWEB room Server
attr allowedWEB validFor WEB
SSL accept attempt failed error:0A000416:SSL routines::sslv3 alert certificate unknownreproduzieren (mit einem selbstsignierten Zertifikat), das aber zuverlaessig: es scheint was Neues zu sein.
