ich führe ein FHEM-Update innerhalb eines DOIF aus.
defmod Update_FHEM_DOIF DOIF ([Update_Status:FHEM_Update] eq "run")\
(IF ([Update:FHEM] gt "0")\
(set Update_Status run,\
setreading Update_Status ALL_Update run,\
update)\
ELSE\
(setreading Update_Status FHEM_Update idle,\
set Update_Status idle))
attr Update_FHEM_DOIF devStateStyle style="text-align:right"
attr Update_FHEM_DOIF do always
attr Update_FHEM_DOIF group Update
attr Update_FHEM_DOIF room SystemdatenDies hat aber jedesmal die nachfolgenden Meldungen im Log zur Folge. Wie kann ich dies vermeiden?
2023.10.31 15:29:38 0: Strange call for nonexistent <undefined>: ActivateInformFn
2023.10.31 15:29:38 1: eval: {if(ReadingValIf('Update','FHEM','') gt "0"){fhem('set Update_Status run');fhem(' setreading Update_Status ALL_Update run');fhem(' update')}else{fhem('setreading Update_Status FHEM_Update idle');fhem(' set Update_Status idle')}}
2023.10.31 15:29:38 1: stacktrace:
2023.10.31 15:29:38 1: main::CallFn called by ./FHEM/98_update.pm (84)
2023.10.31 15:29:38 1: main::CommandUpdate called by fhem.pl (1278)
2023.10.31 15:29:38 1: main::AnalyzeCommand called by fhem.pl (1129)
2023.10.31 15:29:38 1: main::AnalyzeCommandChain called by fhem.pl (4020)
2023.10.31 15:29:38 1: main::fhem called by (eval 18840) (1)
2023.10.31 15:29:38 1: (eval) called by fhem.pl (1173)
2023.10.31 15:29:38 1: main::AnalyzePerlCommand called by fhem.pl (1202)
2023.10.31 15:29:38 1: main::AnalyzeCommandChain called by ./FHEM/98_IF.pm (344)
2023.10.31 15:29:38 1: main::CommandIF called by fhem.pl (1278)
2023.10.31 15:29:38 1: main::AnalyzeCommandChain called by ./FHEM/98_DOIF.pm (2628)
2023.10.31 15:29:38 1: main::ParseCommandsDoIf called by ./FHEM/98_DOIF.pm (3051)
2023.10.31 15:29:38 1: main::DOIF_cmd called by ./FHEM/98_DOIF.pm (3307)
2023.10.31 15:29:38 1: main::DOIF_Trigger called by ./FHEM/98_DOIF.pm (3570)
2023.10.31 15:29:38 1: main::DOIF_Notify called by fhem.pl (3980)
2023.10.31 15:29:38 1: main::CallFn called by fhem.pl (3892)
2023.10.31 15:29:38 1: main::DoTrigger called by fhem.pl (5004)
2023.10.31 15:29:38 1: main::readingsEndUpdate called by fhem.pl (5187)
2023.10.31 15:29:38 1: main::readingsSingleUpdate called by fhem.pl (2563)
2023.10.31 15:29:38 1: main::CommandSetReading called by fhem.pl (1278)
2023.10.31 15:29:38 1: main::AnalyzeCommandChain called by ./FHEM/01_FHEMWEB.pm (2861)
2023.10.31 15:29:38 1: main::FW_fC called by ./FHEM/01_FHEMWEB.pm (981)
2023.10.31 15:29:38 1: main::FW_answerCall called by ./FHEM/01_FHEMWEB.pm (609)
2023.10.31 15:29:38 1: main::FW_Read called by fhem.pl (3980)
2023.10.31 15:29:38 1: main::CallFn called by fhem.pl (784)
2023.10.31 15:29:38 2: Update_FHEM_DOIF: IF ([Update:FHEM] gt "0") (set Update_Status run, setreading Update_Status ALL_Update run, update) ELSE (setreading Update_Status FHEM_Update idle, set Update_Status idle): Executing the update the background.
FHEM ist aktuell und läuft auf einem pi3B unter bookworm.
Jürgen
Zitatich führe ein FHEM-Update innerhalb eines DOIF aus.
Warum?
ZitatDies hat aber jedesmal die nachfolgenden Meldungen im Log zur Folge.
Habs gefixt.
ZitatWie kann ich dies vermeiden?
Hier melden :)
Zitat von: rudolfkoenig am 03 November 2023, 18:51:15Zitatich führe ein FHEM-Update innerhalb eines DOIF aus.
Warum?
Weil es möglich ist.
Zitat von: betateilchen am 03 November 2023, 19:10:23Zitat von: rudolfkoenig am 03 November 2023, 18:51:15Zitatich führe ein FHEM-Update innerhalb eines DOIF aus.
Warum?
Auch ;D
Ich lasse mir in FTUI3 anzeigen, ob es für FHEM bzw FTUI updates gibt. Bei Bedarf kann ich dann den jeweiligen "button" drücken und das Update wird mit Hilfe des DOIF durchgeführt und die Anzeigen werden aktuallisiert. Vorher wird natürlich auf dem Testsystem getestet.
Danke für die Korrektur.
Jürgen
Das erklärt aber noch nicht, warum man dafür ein DOIF braucht.
Aber wenn es Dich glücklich macht...
