defmod SMASI ModbusAttr 3 10 <IP>:502 TCP
attr SMASI busDelay 5
attr SMASI closeAfterResponse 0
attr SMASI dev-h-defLen 2
attr SMASI dev-h-defPoll 0
attr SMASI dev-h-defRevRegs 1
attr SMASI dev-i-defLen 2
attr SMASI dev-i-defPoll 1
attr SMASI dev-i-defRevRegs 1
attr SMASI dev-type-ENUM_JN-hint ja,nein
attr SMASI dev-type-ENUM_JN-len 2
attr SMASI dev-type-ENUM_JN-map 1129:ja, 1130:nein
attr SMASI enableControlSet 1
attr SMASI icon batterie
attr SMASI obj-h40075-name Eigenverbraucherhoehung eingeschaltet
attr SMASI obj-h40075-polldelay 310
attr SMASI obj-h40075-reading EigenverbraucherhoehungAktiv
attr SMASI obj-h40075-set 1
attr SMASI obj-h40075-showGet 1
attr SMASI obj-h40075-unpack n
attr SMASI obj-h40075-type ENUM_JN
attr SMASI obj-i30775-expr $val*-1
attr SMASI obj-i30775-ignoreExpr $val < -8000
attr SMASI obj-i30775-max 5000
attr SMASI obj-i30775-min -5000
attr SMASI obj-i30775-reading BatteryPower
attr SMASI obj-i30775-revRegs 1
attr SMASI obj-i30845-reading StateOfCharge
attr SMASI obj-i30847-polldelay 1800
attr SMASI obj-i30847-reading StateOfHealth
attr SMASI obj-i30849-expr $val/10
attr SMASI obj-i30849-format %.1f
attr SMASI obj-i30849-polldelay 600
attr SMASI obj-i30849-reading BatteryTemp
attr SMASI obj-i30849-revRegs 1
attr SMASI obj-i30851-expr $val/100
attr SMASI obj-i30851-format %.2f
attr SMASI obj-i30851-polldelay 180
attr SMASI obj-i30851-reading BatteryVoltage
attr SMASI obj-i30993-expr $val/1000
attr SMASI obj-i30993-format %.3f
attr SMASI obj-i30993-name Ladefaktor: Verhältnis Batterieladung/-endladung
attr SMASI obj-i30993-reading Ladefaktor
attr SMASI obj-i31009-reading DischargeBoundary
attr SMASI obj-i31009-showGet 0
attr SMASI obj-i31057-name Status Batterienutzungsbereich
attr SMASI obj-i31057-reading BatteryUsageType
attr SMASI room Energie
attr SMASI silentReconnect 1
attr SMASI stateFormat <div>BatteryPower W / StateOfCharge %</div>
attr SMASI verbose 5
2023.12.24 12:13:15.153 4: SMASI: set called with EigenverbraucherhoehungAktiv (h40075) setVal = 1130
2023.12.24 12:13:15.154 5: SMASI: GetSetChecks with force
2023.12.24 12:13:15.154 5: SMASI: GetSetChecks returns success
2023.12.24 12:13:15.154 5: SMASI: set packed hex 31313330 with n to hex 046a
2023.12.24 12:13:15.155 4: SMASI: DoRequest called from SetLDFn created new request, read buffer empty, id 3, fCode 3, tid 56,
request: id 3, write fc 16 h40075, len 2, value 046a, tid 228, master device SMASI, reading EigenverbraucherhoehungAktiv (set EigenverbraucherhoehungAktiv),
response: no id, no fcode
2023.12.24 12:13:15.155 5: SMASI: QueueRequest called from DoRequest with h40075, qlen 0 from master SMASI through io device SMASI
2023.12.24 12:13:15.155 5: SMASI: ProcessRequestQueue called from QueueRequest as direct:SMASI, qlen 1, force, request: request: id 3, write fc 16 h40075, len 2, value 046a, tid 228, master device SMASI, reading EigenverbraucherhoehungAktiv (set EigenverbraucherhoehungAktiv), queued 0.00 secs ago
2023.12.24 12:13:15.155 5: SMASI: checkDelays sendDelay, last send to same device was 53.591 secs ago, required delay is 0.1
2023.12.24 12:13:15.156 5: SMASI: checkDelays commDelay, last communication with same device was 53.578 secs ago, required delay is 0.1
2023.12.24 12:13:15.156 5: SMASI: checkDelays busDelayRead, last activity on bus was 53.578 secs ago, required delay is 5
2023.12.24 12:13:15.156 5: SMASI: checkDelays clientSwitchDelay is not relevant
2023.12.24 12:13:15.156 4: SMASI: ProcessRequestQueue (V4.5.6 - 7.11.2023) qlen 1, sending 00e40000000903109c8b000204046a via 192.168.1.34:502, read buffer empty, id 3, fCode 3, tid 56,
request: id 3, write fc 16 h40075, len 2, value 046a, tid 228, master device SMASI, reading EigenverbraucherhoehungAktiv (set EigenverbraucherhoehungAktiv), queued 0.00 secs ago,
2023.12.24 12:13:15.157 5: SMASI: Send called from ProcessRequestQueue
2023.12.24 12:13:15.157 5: DevIo_SimpleWrite SMASI: 00e40000000903109c8b000204046a
2023.12.24 12:13:15.158 5: SMASI: ReadAnswer called from SetLDFn
2023.12.24 12:13:15.159 5: SMASI: ReadAnswer remaining timeout is 1.99646210670471
2023.12.24 12:13:15.174 5: SMASI: ReadAnswer got: 00e400000003039003
2023.12.24 12:13:15.174 5: SMASI: ParseFrameStart called from ReadAnswer protocol TCP expecting id 3
2023.12.24 12:13:15.174 4: SMASI: ParseFrameStart (TCP, master) extracted id 3, fCode 144, tid 228, dlen 3 and potential data 03
2023.12.24 12:13:15.175 5: SMASI: HandleResponse called from ReadAnswer
2023.12.24 12:13:15.175 5: SMASI: HandleResponse is now creating response hash, masterHash is HASH(0x55f377d1a198)
2023.12.24 12:13:15.175 5: SMASI: HandleResponse is now calling ParseResponse, masterHash is HASH(0x55f377d1a198)
2023.12.24 12:13:15.175 5: SMASI: ParseResponse called from HandleResponse, fc 144
2023.12.24 12:13:15.176 4: SMASI: HandleResponse got response with error code 90 / 03, illegal data value
2023.12.24 12:13:15.176 4: SMASI: HandleResponse done, current frame / read buffer: 00e400000003039003, id 3, fCode 144, tid 228,
request: id 3, write fc 16 h40075, len 2, value 046a, tid 228, master device SMASI, reading EigenverbraucherhoehungAktiv (set EigenverbraucherhoehungAktiv), queued 0.02 secs ago, sent 0.02 secs ago,
response: id 3, fc 144, error code 03, h40075, len 2
2023.12.24 12:13:15.176 5: SMASI: ResetExpect for HandleResponse from response to idle
2023.12.24 12:13:15.176 5: SMASI: DropFrame called from ReadAnswer - drop 00e400000003039003
2023.12.24 12:13:15.177 5: SMASI: set is sending read after write
2023.12.24 12:13:15.177 4: SMASI: DoRequest called from SetLDFn created new request, read buffer empty,
request: id 3, read fc 3 h40075, len 2, tid 48, master device SMASI, reading EigenverbraucherhoehungAktiv (set EigenverbraucherhoehungAktiv Rd),
2023.12.24 12:13:15.177 5: SMASI: QueueRequest called from DoRequest with h40075, qlen 0 from master SMASI through io device SMASI
2023.12.24 12:13:15.177 5: SMASI: ProcessRequestQueue called from QueueRequest as direct:SMASI, qlen 1, force, request: request: id 3, read fc 3 h40075, len 2, tid 48, master device SMASI, reading EigenverbraucherhoehungAktiv (set EigenverbraucherhoehungAktiv Rd), queued 0.00 secs ago
2023.12.24 12:13:15.178 5: SMASI: checkDelays commDelay, last communication with same device was 0.003 secs ago, required delay is 0.1
2023.12.24 12:13:15.178 5: SMASI: checkDelays sendDelay, last send to same device was 0.019 secs ago, required delay is 0.1
2023.12.24 12:13:15.178 5: SMASI: checkDelays busDelayRead, last activity on bus was 0.003 secs ago, required delay is 5
2023.12.24 12:13:15.178 5: SMASI: checkDelays clientSwitchDelay is not relevant
2023.12.24 12:13:15.179 4: SMASI: checkDelays found busDelayRead not over, sleep for 4.997 forced
2023.12.24 12:13:20.176 4: SMASI: checkDelays sleep done, go on with sending
2023.12.24 12:13:20.177 4: SMASI: ProcessRequestQueue (V4.5.6 - 7.11.2023) qlen 1, sending 00300000000603039c8b0002 via 192.168.1.34:502, read buffer empty,
request: id 3, read fc 3 h40075, len 2, tid 48, master device SMASI, reading EigenverbraucherhoehungAktiv (set EigenverbraucherhoehungAktiv Rd), queued 5.00 secs ago,
modpoll -m tcp -p 502 -a 3 -t4 -r 40075 -c 2 -10 192.168.1.34 0 1130| Typ | Beschreibung | NaN-Wert |
| S16 | Vorzeichenbehaftetes Wort (16 Bit). | 0x8000 |
| S32 | Vorzeichenbehaftetes Doppelwort (32 Bit). | 0x8000 0000 |
| STR32 | 32-Byte-Datenfeld, im Format UTF8. | NULL |
| U16 | Ein Wort (16 Bit). | 0xFFFF |
| U32 | Ein Doppelwort (32 Bit). | 0xFFFF FFFF |
| U32 | Für Statuswerte werden nur die unteren 24 Bit eines Doppelworts (32 Bit) verwendet. | 0xFFFF FD |
| U64 | Ein Vierfachwort (64 Bit). | 0xFFFF FFFF FFFF FFFF |
unpak zu tun haben muss. Zumal hier Werte zulässig sind, die nicht in der fhem Doku gelistet sind (C,a,usw.)Zitat von: Aurel_B am 29 Dezember 2023, 10:52:24Mir fällt auf, dass Modbusattr "046a" sendet was nur 16bit sind (=also 1 Modbusregister)
0000 1130
