seit einige Zeit ist mir aufgefallen das sich der Status eines meiner HM-Sec-SC-2 Shutter Controls nicht mehr ändert.
Interessant ist jedoch, das der hmstate korrekt aktualisiert wird - siehe Listing unten:
Habt ihr eine Idee woran das liegen kann?
CFGFN
DEF LEQ1243628:1
FUUID 659680fd-f33f-3cef-0121-d6afaf68d3a69b7d
IODev piVCCU
NAME Kueche_Terrassentuer
NR 331
STATE closed
TYPE HMCCUCHN
ccuaddr LEQ1243628:1
ccudevstate active
ccuif BidCos-RF
ccuname Kueche_Terrassentuer:1
ccurolestate SHUTTER_CONTACT
ccusubtype HM-Sec-SC-2
ccutype HM-Sec-SC-2
eventCount 3
firmware 2.4
readonly no
Helper:
DBLOG:
ERROR:
logdb:
TIME 1704362237.65302
VALUE NO_ERROR
LOWBAT:
logdb:
TIME 1704362372.92248
VALUE ok
STATE:
logdb:
VALUE closed
activity:
logdb:
VALUE alive
battery:
logdb:
VALUE ok
devstate:
logdb:
VALUE ok
hmstate:
logdb:
VALUE closed
rssidevice:
logdb:
VALUE -255
rssipeer:
logdb:
VALUE -255
sign:
logdb:
VALUE on
state:
logdb:
VALUE closed
2024-01-04 10:57:17 ERROR NO_ERROR
2024-01-04 10:57:17 IODev piVCCU
2024-01-04 14:31:51 LOWBAT ok
2024-01-04 10:57:17 STATE closed
2024-01-04 10:57:17 activity alive
2024-01-04 10:57:17 battery ok
2024-01-04 14:31:51 devstate ok
2024-01-04 14:31:51 hmstate closed
2024-01-04 10:57:17 rssidevice -255
2024-01-04 10:57:17 rssipeer -255
2024-01-04 10:57:17 sign on
2024-01-04 10:57:17 state closed
hmccu:
channels 1
detect 1
devspec LEQ1243628:1
nodefaults 0
role 1:SHUTTER_CONTACT
setDefaults 0
cmdlist:
get
set
control:
dp:
0.AES_KEY:
VALUES:
NVAL 1
ONVAL 1
OSVAL on
OVAL 1
SVAL on
VAL 1
0.CONFIG_PENDING:
VALUES:
NVAL false
ONVAL false
OSVAL false
OVAL false
SVAL false
VAL false
0.LOWBAT:
VALUES:
NVAL false
ONVAL false
OSVAL ok
OVAL false
SVAL ok
VAL false
0.RSSI_DEVICE:
VALUES:
NVAL -255
ONVAL -255
OSVAL -255
OVAL 1
SVAL -255
VAL 1
0.RSSI_PEER:
VALUES:
NVAL -255
ONVAL -255
OSVAL -255
OVAL 1
SVAL -255
VAL 1
0.STICKY_UNREACH:
VALUES:
NVAL false
ONVAL false
OSVAL false
OVAL false
SVAL false
VAL false
0.UNREACH:
VALUES:
NVAL false
ONVAL false
OSVAL alive
OVAL false
SVAL alive
VAL false
1.ERROR:
VALUES:
NVAL 0
ONVAL 0
OSVAL NO_ERROR
OVAL 0
SVAL NO_ERROR
VAL 0
1.LOWBAT:
VALUES:
NVAL 0
ONVAL 0
OSVAL ok
OVAL 0
SVAL ok
VAL 0
1.STATE:
VALUES:
NVAL false
ONVAL false
OSVAL closed
OVAL false
SVAL closed
VAL false
roleCmds:
get:
set:
state:
chn 1
dpt STATE
devStateIcon close:fts_window_1w open:fts_window_1w_open
event-on-change-reading .*
room Homematic,Kueche
userattr Tuer Tuer_map structexclude
Danke und beste Grüße,
amibman
Also wenn du das Fenster jetzt öffnest, wechselt nur hmstate auf open und state bleibt auf close?
Hallo zap,
danke für die schnelle Rückmeldung.
Ich denke das Problem hat sich gelöst... ich hätte einfach vorher mal direkt in der CCU schauen sollen ::).
Es gab wohl generell ein Problem, das sich der Status des Sensors nicht geändert hat.
Hin und wieder hat dieser sehr alte SC-2 dieses Phänomen :-\ .
Nach einem Reset des Sensors und neuem Pairing mit der CCU hat dann FHEM-seitig auch alles wieder geklappt.
Danke nochmals und beste Grüße,
ambiman
