Hallo.
Ich habe mir mal den Fenster-/Türkontakt von AVM FRITZ!DECT 350 zugelegt.
Er lies sich ohne Probleme mit der Fritzbox koppeln.
Auch in fhem konnte er wie andere FRITZ!DECT-Geräte gekoppelt werden.
ABER
Es werden automatisch in fhem 2 Geräte angelegt mit unterschiedlichen Inhalten:
.FhemMetaInternals 1
DEF fb1:15282_0250173_1 HANFUNUnit,alarmSensor
FUUID 65c32a11-f33f-c7ad-832c-cb2be5886e7a2f9f
FVERSION 10_FBDECT.pm:0.282120/2023-11-26
IODev fb1
LASTInputDev fb1
MSGCNT 45
NAME FBDECT_fb1_15282_0250173_1
NR 1303
STATE off
TYPE FBDECT
eventCount 45
fb1_MSGCNT 45
fb1_TIME 2024-02-07 12:31:08
id 15282_0250173_1
props HANFUNUnit,alarmSensor
.attraggr:
.attreocr:
.attreour:
present
state
.attrminint:
power:120
Helper:
DBLOG:
lastalertchgtimestamp:
dblog:
TIME 1707293468.96531
VALUE 2024-02-07 09:10:29
present:
dblog:
TIME 1707305468.96883
VALUE yes
state:
dblog:
VALUE off
2024-02-07 12:31:08 AIN 15282 0250173-1
2024-02-07 12:31:08 FBNAME FRITZ!DECT #5
2024-02-07 12:31:08 FBPROP HANFUNUnit,alarmSensor
2024-02-07 12:31:08 FBTYPE FRITZ!DECT 350
2024-02-07 12:31:08 ID 2006
2024-02-07 08:50:44 IODev fb1
2024-02-07 12:31:08 etsideviceid 20
2024-02-07 12:31:08 fwversion 0.0
2024-02-07 12:31:08 lastalertchgtimestamp 2024-02-07 09:10:29
2024-02-07 12:31:08 present yes
2024-02-07 12:31:08 state off
2024-02-07 12:31:08 unittype WINDOW_OPEN_CLOSE_DETECTOR
alias FritzEingangstuer
event-min-interval power:120
event-on-change-reading .*
event-on-update-reading present,state
room FBDECT
und
DEF fb1:15282_0250173 HANFUN
FUUID 65c32d95-f33f-c7ad-f41c-40ed0dd73eef1231
IODev fb1
LASTInputDev fb1
MSGCNT 46
NR 1305
STATE ???
TYPE FBDECT
eventCount 46
fb1_MSGCNT 46
fb1_TIME 2024-02-07 12:36:08
id 15282_0250173
props HANFUN
.attraggr:
.attreocr:
.attreour:
battery
batteryPercent
batterystate
present
state
.attrminint:
power:120
Helper:
DBLOG:
battery:
dblog:
TIME 1707305768.97889
VALUE 100
batteryPercent:
dblog:
VALUE 100
present:
dblog:
VALUE yes
2024-02-07 12:36:08 AIN 15282 0250173
2024-02-07 12:36:08 FBNAME FritzTuerkontakt 1
2024-02-07 12:36:08 FBPROP HANFUN
2024-02-07 12:36:08 FBTYPE FRITZ!DECT 350
2024-02-07 12:36:08 ID 20
2024-02-07 12:36:08 battery 100 %
2024-02-07 12:36:08 batteryPercent 100
2024-02-07 12:36:08 batteryState ok
2024-02-07 12:36:08 batterylow 0
2024-02-07 12:36:08 fwversion 03.55
2024-02-07 12:36:08 present yes
alias FritzEingangstuer_1
event-on-update-reading battery,batteryPercent,batterystate,present,state
room FBDECT
Kann jemand mir sagen, wie ich aus den beiden Geräten ein funktionierendes Gerät in fhem bekomme?
LG tabbi
Hallo!
Ich werde aus dem vorigen Post nicht ganz schlau: funktioniert der FRITZ!DECT 350 mit FHEM oder nicht?
Genauer gesagt: Tür auf mit FRITZ!DECT 350 erkennen, dann Licht mit HomeMatic Aktor einschalten, geht das?
Danke im Voraus!
