FHEM - Entwicklung => FHEM Code changes => Thema gestartet von: System am 19 Mai 2024, 23:21:09
Titel: Revision 28889: 49_SSCAM: NOTE! set enable/disable renamed to enableCam/disableCam, ...
Beitrag von: System am 19 Mai 2024, 23:21:09
49_SSCAM: NOTE! set enable/disable renamed to enableCam/disableCam, switch commandref to ID tags
Source: Revision 28889: 49_SSCAM: NOTE! set enable/disable renamed to enableCam/disableCam, ... (http://svn.fhem.de/trac/changeset/28889/trunk)
