FHEM => English Corner => Thema gestartet von: nustoooo am 14 Juni 2024, 11:17:13
Titel: Dooya - Bi-directional protocol
Beitrag von: nustoooo am 14 Juni 2024, 11:17:13
I've tried browsing through the forum, but most discussions were in german and not sure if I understood them well, so my question is:
Is there support for the Dooya bi-directional protocol using SIGNALDuino & FHEM?
Titel: Aw: Dooya - Bi-directional protocol
Beitrag von: Prof. Dr. Peter Henning am 20 Juni 2024, 04:31:50
Yes.
https://fhem.de/commandref.html#Dooya
When such questions arise, you should always look up the english version of the FHEM CommandRef.
Regards
pah
Beitrag von: nustoooo am 20 Juni 2024, 05:50:12
Thank you for the answer, I did actually look at the commandref, but it doesn't clearly state if it supports the bi-directional protocol (which uses FSK modulation) or just the standard dooya protocol (with OOK modulation).
I will give it a try and see for myself if it works, thank you again!
Beitrag von: Prof. Dr. Peter Henning am 21 Juni 2024, 01:37:15
Lookup the name of the module maintainer and send him a private message.
In the commandref it says "sending" and "receiving".
Regards
pah
