Ich habe ein Missing Ack bei meinem Ventilator im Keller. Für mich aus heiterem Himmel. Hier ein list Vent_K
DEF 2B8AE2
FUUID 5c9fc509-f33f-914e-3146-f7c2e8a6b98bce35
IODev MAPLECUL868
NAME Vent_K
NR 79
NTFY_ORDER 48-Vent_K
STATE MISSING ACK
TYPE CUL_HM
chanNo 01
disableNotifyFn 1
eventCount 590
protCmdDel 96
protResnd 288 last_at:2024-06-30 19:11:14
protResndFail 96 last_at:2024-06-30 19:11:20
protSnd 96 last_at:2024-06-30 19:11:00
protState CMDs_done_Errors:1
2024-05-03 07:00:00 CommandAccepted yes
2022-05-11 23:51:44 D-firmware 1.12
2022-05-11 23:51:44 D-serialNr LEQ0545314
2024-06-30 19:11:00 IODev MAPLECUL868
2022-05-12 20:16:53 PairedTo 0x123456
2022-05-12 20:16:53 R-pairCentral 0x123456
2017-08-27 21:07:23 R-sign off
2022-05-12 20:16:53 RegL_00. 00:00 02:01 03:00 04:00 05:00 06:00 07:00 08:00 09:00 0A:12 0B:34 0C:56
2022-05-12 20:16:54 RegL_01. 00:00 08:00
2022-05-12 20:17:54 cfgState ok
2024-06-30 19:11:20 commState CMDs_done_Errors:1
2024-05-03 08:00:08 deviceMsg off (to broadcast)
2024-05-03 08:00:08 level 0
2024-05-03 08:00:08 pct 0
2022-05-11 08:40:30 powerOn 2022-05-11 08:40:30
2024-05-03 08:00:08 recentStateType info
2021-12-28 14:29:17 sabotageAttackId_ErrIoId_F10000 cnt:36
2021-12-28 14:29:17 sabotageAttack_ErrIoAttack_cnt 36
2024-06-30 19:11:20 state MISSING ACK
2024-05-03 08:00:08 timedOn off
2024-06-30 19:00:00 trigLast fhem:02
helper:
HM_CMDNR 56
cSnd 111234562B8AE20201C800008CA5,011234562B8AE2010E
mId 0002
peerFriend peerSens,peerVirt
peerIDsState complete
peerOpt 3:switch
regLst 0,1,3p
rxType 1
stateUpdatDly 3600
cmds:
TmplKey :no:1719605306.64549
TmplTs 1719605306.64549
cmdKey 1:1:0::Vent_K:0002:01:
cmdLst:
assignHmKey noArg
clear [({msgErrors}|msgEvents|rssi|attack|trigger|register|oldRegs|readings|all)]
deviceRename -newName-
fwUpdate -filename- [-bootTime-]
getConfig noArg
getDevInfo noArg
getRegRaw (List0|List1|List2|List3|List4|List5|List6|List7) [-peerChn-]
getVersion noArg
inhibit [(on|{off})]
off noArg
on noArg
on-for-timer -ontime-
on-till -time-
pair noArg
peerBulk -peer1,peer2,...- [({set}|unset)]
peerIODev [IO] -btn- [({set}|unset)] 'not for future use'
peerSmart -peerOpt-
press [(long|{short})] [(-peer-|{self01})] [(-repCount-|{0})] [(-repDelay-|{0.25})]
raw -data- [...]
regBulk -list-.-peerChn- -addr1:data1- [-addr2:data2-]...
regSet [(prep|{exec})] -regName- -value- [-peerChn-]
reset noArg
sign [(on|{off})]
statusRequest noArg
toggle noArg
tplDel -tplDel-
tplSet_0 -tplChan-
unpair noArg
lst:
condition slider,0,1,255
peer
peerOpt Auto_Btn_01,Auto_Btn_02,Auto_Btn_03,Auto_Btn_04,Hand_1_1,Hand_1_2,Hand_1_3,Hand_1_4,T_Nachttisch_li_Btn_01,T_Nachttisch_li_Btn_02,T_Nachttisch_re_Btn_01,T_Nachttisch_re_Btn_02,T_W_Deckenlampe_Btn_01,T_W_Deckenlampe_Btn_02,T_li_Deckenlampe_Btn_01,T_li_Deckenlampe_Btn_02,T_re_Deckenlampe_Btn_01,T_re_Deckenlampe_Btn_02,VCCU
tplChan
tplDel
tplPeer
rtrvLst:
cmdList [({short}|long)]
deviceInfo [({short}|long)]
list [({normal}|full)]
param -param-
reg -addr- -list- [-peerChn-]
regList noArg
regTable noArg
regVal -addr- -list- [-peerChn-]
saveConfig [-filename-]
tplInfo noArg
expert:
def 1
det 0
raw 1
tpl 0
io:
flgs 0
newChn +2B8AE2,00,00,00
nextSend 1719767474.75196
rxt 0
vccu VCCU
p:
2B8AE2
00
00
00
prefIO:
mRssi:
mNo
io:
MAPLECUL868:
MAPLECUL868_2:
myHmUART:
peerIDsH:
00000000 broadcast
prt:
bErr 0
sProc 0
q:
qReqConf
qReqStat
role:
chn 1
dev 1
prs 1
tmpl:
IOgrp VCCU
autoReadReg 4_reqStatus
expert defReg,rawReg
firmware 1.12
model HM-LC-SW1-FM
peerIDs 00000000
room CUL_HM,Keller
serialNr LEQ0545314
subType switch
webCmd statusRequest:toggle:on:offWie fange ich das Ding wieder ein. Shutdown restart hat nicht geholfen.
Der Switch hat an Broadcast gesendet, das lässt vermuten, dass er sich nicht mehr an sein Pairing erinnert. Ggf. ist das Device auch einfach den bekannten Kondensator-Tod gestorben.
Im config check habe ich das
Vent_K: RegL_00.,RegL_01.Kann ich versuchen mit
set <Name des IO-Device> hmPairSerial <serial>das alles wieder einzufangen?
Zitat von: stgeran am 30 Juni 2024, 20:14:28Im config check habe ich das
was soll das bringen?
seit 3.5 ist er still, hat 288 mal nicht geantwortet.
ich würde erst mal schauen, ob spannung anliegt.
dann spannung abschalten und wieder ein.
danach ein list zeigen.
Ich würde ihn erst einmal stromlos machen und schauen, ob er dann wieder normal reagiert.
