Seit dem neuen Template wird bei mir das STATE nicht mehr korrekt angezeigt.
Statt "Online" und "Offline" wird nun neu {"state":"online"} und {"state":"offline"} angezeigt.
Das macht nun Probleme bei der weiteren Verarbeitung.
Kann das ein Modul Verantwortlicher einmal prüfen?
Version Z2M ist die 1.38
Habe nun soeben auf 1.39 geupdatet = gleiches verhalten
Danke euch.
Gruss, Fabian
Und hier noch das List vom Device.
(Ein "Copy for" kann ich leider nicht einfügen. Bekomme dann beim Absenden hier im Forum immer ein Datenbankfehler des Forums)
CID zigbee_pi
DEF zigbee_pi
FUUID 6500adc0-f33f-c1dd-1b0e-de8e7b96f0000ac0
IODev myBroker
LASTInputDev myBroker
MSGCNT 9
NAME MQTT2_zigbee_pi
NR 74
STATE {"state":"online"}
TYPE MQTT2_DEVICE
eventCount 8
myBroker_CONN myBroker_127.0.0.1_57008
myBroker_MSGCNT 9
myBroker_TIME 2024-07-06 14:23:33
2024-07-06 14:22:22 IODev myBroker
2024-07-06 14:02:04 attrTemplateVersion 20240627
2024-07-06 14:23:32 devices [{"definition":null,"disabled":false,"endpoints":{"1":{"bindings":[],"clusters":{"input":[],"output":[]},"configured_reportings":[],"scenes":[]},"10":{"bindings":[],"clusters":{"input":[],"output":[]},"configured_reportings":[],"scenes":[]},"11":{"bindings":[],"clusters":{"input":["ssIasAce","genTime"],"output":["ssIasZone","ssIasWd"]},"configured_reportings":[],"scenes":[]},"110":{"bindings":[],"clusters":{"input":[],"output":[]},"configured_reportings":[],"scenes":[]},"12":{"bindings":[],"clusters":{"input":[],"output":[]},"configured_reportings":[],"scenes":[]},"13":{"bindings":[],"clusters":{"input":["genOta"],"output":[]},"configured_reportings":[],"scenes":[]},"2":{"bindings":[],"clusters":{"input":[],"output":[]},"configured_reportings":[],"scenes":[]},"242":{"bindings":[],"clusters":{"input":[],"output":[]},"configured_reportings":[],"scenes":[]},"3":{"bindings":[],"clusters":{"input":[],"output":[]},"configured_reportings":[],"scenes":[]},"4":{"bindings":[],"clusters":{"input":[],"output":[]},"configured_reportings":[],"scenes":[]},"47":{"bindings":[],"clusters":{"input":[],"output":[]},"configured_reportings":[],"scenes":[]},"5":{"bindings":[],"clusters":{"input":[],"output":[]},"configured_reportings":[],"scenes":[]},"6":{"bindings":[],"clusters":{"input":[],"output":[]},"configured_reportings":[],"scenes":[]},"8":{"bindings":[],"clusters":{"input":[],"output":[]},"configured_reportings":[],"scenes":[]}},"friendly_name":"Coordinator","ieee_address":"0x00124b002a2eafb4","interview_completed":true,"interviewing":false,"network_address":0,"supported":true,"type":"Coordinator"},{"date_code":"20240523","definition":{"description":"SMART+ lamp E27 RGBW","exposes":[{"features":[{"access":7,"description":"On/off state of this light","label":"State","name":"state","property":"state","type":"binary","value_off":"OFF","value_on":"ON","value_toggle":"TOGGLE"},{"access":7,"description":"Brightness of this light","label":"Brightness","name":"brightness","property":"brightness","type":"numeric","value_max":254,"value_min":0},{"access":7,"description":"Color temperature of this light","label":"Color temp","name":"color_temp","presets":[{"description":"Coolest temperature supported","name":"coolest","value":153},{"description":"Cool temperature (250 mireds / 4000 Kelvin)","name":"cool","value":250},{"description":"Neutral temperature (370 mireds / 2700 Kelvin)","name":"neutral","value":370},{"description":"Warmest temperature supported","name":"warmest","value":370}],"property":"color_temp","type":"numeric","unit":"mired","value_max":370,"value_min":153},{"access":7,"description":"Color of this light in the CIE 1931 color space (x/y)","features":[{"access":7,"label":"X","name":"x","property":"x","type":"numeric"},{"access":7,"label":"Y","name":"y","property":"y","type":"numeric"}],"label":"Color (X/Y)","name":"color_xy","property":"color","type":"composite"},{"access":7,"description":"Color of this light expressed as hue/saturation","features":[{"access":7,"label":"Hue","name":"hue","property":"hue","type":"numeric"},{"access":7,"label":"Saturation","name":"saturation","property":"saturation","type":"numeric"}],"label":"Color (HS)","name":"color_hs","property":"color","type":"composite"}],"type":"light"},{"access":2,"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)","label":"Effect","name":"effect","property":"effect","type":"enum","values":["blink","breathe","okay","channel_change","finish_effect","stop_effect","colorloop","stop_colorloop"]},{"access":1,"category":"diagnostic","description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"4058075208391","options":[{"access":2,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","label":"Transition","name":"transition","property":"transition","type":"numeric","value_min":0},{"access":2,"description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true).","label":"Color sync","name":"color_sync","property":"color_sync","type":"binary","value_off":false,"value_on":true},{"access":2,"description":"State actions will also be published as 'action' when true (default false).","label":"State action","name":"state_action","property":"state_action","type":"binary","value_off":false,"value_on":true}],"supports_ota":true,"vendor":"LEDVANCE"},"disabled":false,"endpoints":{"1":{"bindings":[],"clusters":{"input":["genBasic","genIdentify","genGroups","genScenes","genOnOff","genLevelCtrl","lightingColorCtrl","haDiagnostic","touchlink"],"output":["genOta"]},"configured_reportings":[],"scenes":[]},"242":{"bindings":[],"clusters":{"input":[],"output":["greenPower"]},"configured_reportings":[],"scenes":[]}},"friendly_name":"FL_Kugel","ieee_address":"0xf0d1b800001ffc9d","interview_completed":true,"interviewing":false,"manufacturer":"LEDVANCE","model_id":"A60S RGBW","network_address":3348,"power_source":"Mains (single phase)","software_build_id":"03197310","supported":true,"type":"Router"}]
2024-07-06 14:23:33 extensions []
2024-07-06 14:23:32 groups []
2024-07-06 14:23:32 info {"commit":"03269267","config":{"advanced":{"adapter_concurrent":null,"adapter_delay":null,"availability_blacklist":[],"availability_blocklist":[],"availability_passlist":[],"availability_whitelist":[],"cache_state":true,"cache_state_persistent":true,"cache_state_send_on_startup":true,"channel":11,"elapsed":false,"ext_pan_id":[221,221,221,221,221,221,221,221],"homeassistant_legacy_entity_attributes":false,"ikea_ota_use_test_url":true,"last_seen":"disable","legacy_api":false,"legacy_availability_payload":false,"log_debug_namespace_ignore":"","log_debug_to_mqtt_frontend":false,"log_directory":"/opt/zigbee2mqtt/data/log/%TIMESTAMP%","log_file":"log.log","log_level":"info","log_namespaced_levels":{},"log_output":["console","file"],"log_rotation":true,"log_symlink_current":false,"log_syslog":{},"output":"json","pan_id":6754,"report":false,"soft_reset_timeout":0,"timestamp_format":"YYYY-MM-DD HH:mm:ss"},"blocklist":[],"device_options":{"legacy":false},"devices":{"0xf0d1b800001ffc9d":{"friendly_name":"FL_Kugel"}},"external_converters":[],"frontend":{"port":8080},"groups":{},"homeassistant":false,"map_options":{"graphviz":{"colors":{"fill":{"coordinator":"#e04e5d","enddevice":"#fff8ce","router":"#4ea3e0"},"font":{"coordinator":"#ffffff","enddevice":"#000000","router":"#ffffff"},"line":{"active":"#009900","inactive":"#994444"}}}},"mqtt":{"base_topic":"zigbee2mqtt","client_id":"zigbee_pi","force_disable_retain":false,"include_device_information":false,"keepalive":60,"reject_unauthorized":true,"server":"mqtt://localhost","user":"pi","version":4},"ota":{"disable_automatic_update_check":false,"ikea_ota_use_test_url":true,"update_check_interval":1440},"passlist":[],"permit_join":false,"serial":{"disable_led":false,"port":"/dev/ttyUSB0"}},"config_schema":{"definitions":{"device":{"properties":{"debounce":{"description":"Debounces messages of this device","title":"Debounce","type":"number"},"debounce_ignore":{"description":"Protects unique payload values of specified payload properties from overriding within debounce time","examples":["action"],"items":{"type":"string"},"title":"Ignore debounce","type":"array"},"disabled":{"description":"Disables the device (excludes device from network scans, availability and group state updates)","requiresRestart":true,"title":"Disabled","type":"boolean"},"filtered_attributes":{"description":"Filter attributes with regex from published payload.","examples":["^temperature$","^battery$","^action$"],"items":{"type":"string"},"title":"Filtered publish attributes","type":"array"},"filtered_cache":{"description":"Filter attributes with regex from being added to the cache, this prevents the attribute from being in the published payload when the value didn't change.","examples":["^input_actions$"],"items":{"type":"string"},"title":"Filtered attributes from cache","type":"array"},"filtered_optimistic":{"description":"Filter attributes with regex from optimistic publish payload when calling /set. (This has no effect if optimistic is set to false).","examples":["^color_(mode|temp)$","color"],"items":{"type":"string"},"title":"Filtered optimistic attributes","type":"array"},"friendly_name":{"description":"Used in the MQTT topic of a device. By default this is the device ID","readOnly":true,"title":"Friendly name","type":"string"},"homeassistant":{"properties":{"name":{"description":"Name of the device in Home Assistant","title":"Home Assistant name","type":"string"}},"title":"Home Assistant","type":["object","null"]},"icon":{"description":"The user-defined device icon for the frontend. It can be a full URL link to an image (e.g. https://SOME.SITE/MODEL123.jpg) (you cannot use a path to a local file) or base64 encoded data URL (e.g. image/svg+xml;base64,PHN2ZyB3aW....R0aD)","title":"Icon","type":"string"},"optimistic":{"default":true,"description":"Publish optimistic state after set","title":"Optimistic","type":"boolean"},"qos":{"description":"QoS level for MQTT messages of this device","title":"QoS","type":"number"},"retain":{"description":"Retain MQTT messages of this device","title":"Retain","type":"boolean"},"retention":{"description":"Sets the MQTT Message Expiry in seconds, Make sure to set mqtt.version to 5","title":"Retention","type":"number"}},"required":["friendly_name"],"type":"object"},"group":{"properties":{"devices":{"items":{"type":"string"},"type":"array"},"filtered_attributes":{"items":{"type":"string"},"type":"array"},"friendly_name":{"type":"string"},"off_state":{"default":"auto","description":"Control when to publish state OFF for a group. 'all_members_off': only publish state OFF when all group members are in state OFF, 'last_member_state': publish state OFF whenever one of its members changes to OFF","enum":["all_members_off","last_member_state"],"requiresRestart":true,"title":"Group off state","type":["string"]},"optimistic":{"type":"boolean"},"qos":{"type":"number"},"retain":{"type":"boolean"}},"required":["friendly_name"],"type":"object"}},"properties":{"advanced":{"properties":{"adapter_concurrent":{"description":"Adapter concurrency (e.g. 2 for CC2531 or 16 for CC26X2R1) (default: null, uses recommended value)","requiresRestart":true,"title":"Adapter concurrency","type":["number","null"]},"adapter_delay":{"description":"Adapter delay","requiresRestart":true,"title":"Adapter delay","type":["number","null"]},"cache_state":{"default":true,"description":"MQTT message payload will contain all attributes, not only changed ones. Has to be true when integrating via Home Assistant","title":"Cache state","type":"boolean"},"cache_state_persistent":{"default":true,"description":"Persist cached state, only used when cache_state: true","title":"Persist cache state","type":"boolean"},"cache_state_send_on_startup":{"default":true,"description":"Send cached state on startup, only used when cache_state: true","title":"Send cached state on startup","type":"boolean"},"channel":{"default":11,"description":"Zigbee channel, changing requires repairing all devices! (Note: use a ZLL channel: 11, 15, 20, or 25 to avoid Problems)","examples":[15,20,25],"maximum":26,"minimum":11,"requiresRestart":true,"title":"ZigBee channel","type":"number"},"elapsed":{"default":false,"description":"Add an elapsed attribute to MQTT messages, contains milliseconds since the previous msg","title":"Elapsed","type":"boolean"},"ext_pan_id":{"description":"Zigbee extended pan ID, changing requires repairing all devices!","oneOf":[{"title":"Extended pan ID (string)","type":"string"},{"items":{"type":"number"},"title":"Extended pan ID (array)","type":"array"}],"requiresRestart":true,"title":"Ext Pan ID"},"last_seen":{"default":"disable","description":"Add a last_seen attribute to MQTT messages, contains date/time of last Zigbee message","enum":["disable","ISO_8601","ISO_8601_local","epoch"],"title":"Last seen","type":"string"},"legacy_api":{"default":true,"description":"Disables the legacy api (false = disable)","requiresRestart":true,"title":"Legacy API","type":"boolean"},"legacy_availability_payload":{"default":true,"description":"Payload to be used for device availability and bridge/state topics. true = text, false = JSON","requiresRestart":true,"title":"Legacy availability payload","type":"boolean"},"log_debug_namespace_ignore":{"default":"","description":"Do not log these namespaces (regex-based) for debug level","examples":["^zhc:legacy:fz:(tuya|moes)","^zhc:legacy:fz:(tuya|moes)|^zh:ember:uart:|^zh:controller"],"title":"Log debug namespace ignore","type":"string"},"log_debug_to_mqtt_frontend":{"default":false,"description":"Log debug level to MQTT and frontend (may decrease overall performance)","requiresRestart":true,"title":"Log debug to MQTT and frontend","type":"boolean"},"log_directory":{"description":"Location of log directory","examples":["data/log/%TIMESTAMP%"],"requiresRestart":true,"title":"Log directory","type":"string"},"log_file":{"default":"log.txt","description":"Log file name, can also contain timestamp","examples":["zigbee2mqtt_%TIMESTAMP%.log"],"requiresRestart":true,"title":"Log file","type":"string"},"log_level":{"default":"info","description":"Logging level","enum":["error","warning","info","debug","warn"],"title":"Log level","type":"string"},"log_namespaced_levels":{"additionalProperties":{"enum":["error","warning","info","debug"],"type":"string"},"default":{},"description":"Set individual log levels for certain namespaces","examples":[{"z2m:mqtt":"warning"},{"zh:ember:uart:ash":"info"}],"propertyNames":{"pattern":"^(z2m|zhc|zh)(:[a-z0-9]{1,})*$"},"title":"Log Namespaced Levels","type":"object"},"log_output":{"description":"Output location of the log, leave empty to suppress logging","items":{"enum":["console","file","syslog"],"type":"string"},"requiresRestart":true,"title":"Log output","type":"array"},"log_rotation":{"default":true,"description":"Log rotation","requiresRestart":true,"title":"Log rotation","type":"boolean"},"log_symlink_current":{"default":false,"description":"Create symlink to current logs in the log directory","requiresRestart":true,"title":"Log symlink current","type":"boolean"},"log_syslog":{"oneOf":[{"title":"syslog (disabled)","type":"null"},{"properties":{"app_name":{"default":"Zigbee2MQTT","description":"The name of the application (Default: Zigbee2MQTT).","title":"Localhost","type":"string"},"eol":{"default":"/n","description":"The end of line character to be added to the end of the message (Default: Message without modifications).","title":"eol","type":"string"},"host":{"default":"localhost","description":"The host running syslogd, defaults to localhost.","title":"Host","type":"string"},"localhost":{"default":"localhost","description":"Host to indicate that log messages are coming from (Default: localhost).","title":"Localhost","type":"string"},"path":{"default":"/dev/log","description":"The path to the syslog dgram socket (i.e. /dev/log or /var/run/syslog for OS X).","examples":["/var/run/syslog"],"title":"Path","type":"string"},"pid":{"default":"process.pid","description":"PID of the process that log messages are coming from (Default process.pid).","title":"PID","type":"string"},"port":{"default":514,"description":"The port on the host that syslog is running on, defaults to syslogd's default port.","title":"Port","type":"number"},"protocol":{"default":"udp4","description":"The network protocol to log over (e.g. tcp4, udp4, tls4, unix, unix-connect, etc).","examples":["udp4","tls4","unix","unix-connect"],"title":"Protocol","type":"string"},"type":{"default":"5424","description":"The type of the syslog protocol to use (Default: BSD, also valid: 5424).","title":"Type","type":"string"}},"title":"syslog (enabled)","type":"object"}],"requiresRestart":true},"network_key":{"description":"Network encryption key, changing requires repairing all devices!","oneOf":[{"title":"Network key(string)","type":"string"},{"items":{"type":"number"},"title":"Network key(array)","type":"array"}],"requiresRestart":true,"title":"Network key"},"output":{"description":"Examples when 'state' of a device is published json: topic: 'zigbee2mqtt/my_bulb' payload '{\"state\": \"ON\"}' attribute: topic 'zigbee2mqtt/my_bulb/state' payload 'ON' attribute_and_json: both json and attribute (see above)","enum":["attribute_and_json","attribute","json"],"title":"MQTT output type","type":"string"},"pan_id":{"description":"ZigBee pan ID, changing requires repairing all devices!","oneOf":[{"title":"Pan ID (string)","type":"string"},{"title":"Pan ID (number)","type":"number"}],"requiresRestart":true,"title":"Pan ID"},"timestamp_format":{"description":"Log timestamp format","examples":["YYYY-MM-DD HH:mm:ss"],"requiresRestart":true,"title":"Timestamp format","type":"string"},"transmit_power":{"description":"Transmit power of adapter, only available for Z-Stack (CC253*/CC2652/CC1352) adapters, CC2652 = 5dbm, CC1352 max is = 20dbm (5dbm default)","requiresRestart":true,"title":"Transmit power","type":["number","null"]}},"title":"Advanced","type":"object"},"availability":{"description":"Checks whether devices are online/offline","oneOf":[{"title":"Availability (simple)","type":"boolean"},{"properties":{"active":{"description":"Options for active devices (routers/mains powered)","properties":{"timeout":{"default":10,"description":"Time after which an active device will be marked as offline in minutes","requiresRestart":true,"title":"Timeout","type":"number"}},"requiresRestart":true,"title":"Active","type":"object"},"passive":{"description":"Options for passive devices (mostly battery powered)","properties":{"timeout":{"default":1500,"description":"Time after which an passive device will be marked as offline in minutes","requiresRestart":true,"title":"Timeout","type":"number"}},"requiresRestart":true,"title":"Passive","type":"object"}},"title":"Availability (advanced)","type":"object"}],"requiresRestart":true,"title":"Availability"},"ban":{"items":{"type":"string"},"readOnly":true,"requiresRestart":true,"title":"Ban (deprecated, use blocklist)","type":"array"},"blocklist":{"description":"Block devices from the network (by ieeeAddr)","items":{"type":"string"},"requiresRestart":true,"title":"Blocklist","type":"array"},"device_options":{"title":"Options that are applied to all devices","type":"object"},"devices":{"patternProperties":{"^.*$":{"$ref":"#/definitions/device"}},"propertyNames":{"pattern":"^0x[\\d\\w]{16}$"},"type":"object"},"external_converters":{"description":"You can define external converters to e.g. add support for a DiY device","examples":["DIYRuZ_FreePad.js"],"items":{"type":"string"},"requiresRestart":true,"title":"External converters","type":"array"},"frontend":{"oneOf":[{"title":"Frontend (simple)","type":"boolean"},{"properties":{"auth_token":{"description":"Enables authentication, disabled by default","requiresRestart":true,"title":"Auth token","type":["string","null"]},"host":{"description":"Frontend binding host. Binds to a unix socket when an absolute path is given instead.","examples":["127.0.0.1","::1","/run/zigbee2mqtt/zigbee2mqtt.sock"],"requiresRestart":true,"title":"Bind host","type":["string","null"]},"port":{"default":8080,"description":"Frontend binding port. Ignored when using a unix domain socket","requiresRestart":true,"title":"Port","type":"number"},"ssl_cert":{"description":"SSL Certificate file path for exposing HTTPS. The sibling property 'ssl_key' must be set for HTTPS to be activated.","requiresRestart":true,"title":"Certificate file path","type":["string","null"]},"ssl_key":{"description":"SSL key file path for exposing HTTPS. The sibling property 'ssl_cert' must be set for HTTPS to be activated.","requiresRestart":true,"title":"key file path","type":["string","null"]},"url":{"description":"URL on which the frontend can be reached, currently only used for the Home Assistant device configuration page","requiresRestart":true,"title":"URL","type":["string","null"]}},"title":"Frontend (advanced)","type":"object"}],"requiresRestart":true,"title":"Frontend"},"groups":{"patternProperties":{"^.*$":{"$ref":"#/definitions/group"}},"propertyNames":{"pattern":"^[\\w].*$"},"type":"object"},"homeassistant":{"default":false,"description":"Home Assistant integration (MQTT discovery)","oneOf":[{"title":"Home Assistant (simple)","type":"boolean"},{"properties":{"discovery_topic":{"description":"Home Assistant discovery topic","examples":["homeassistant"],"requiresRestart":true,"title":"Homeassistant discovery topic","type":"string"},"legacy_entity_attributes":{"default":true,"description":"Home Assistant legacy entity attributes, when enabled Zigbee2MQTT will add state attributes to each entity, additional to the separate entities and devices it already creates","title":"Home Assistant legacy entity attributes","type":"boolean"},"legacy_triggers":{"default":true,"description":"Home Assistant legacy triggers, when enabled Zigbee2mqt will send an empty 'action' or 'click' after one has been send. A 'sensor_action' and 'sensor_click' will be discoverd","title":"Home Assistant legacy triggers","type":"boolean"},"status_topic":{"description":"Home Assistant status topic","examples":["homeassistant/status"],"requiresRestart":true,"title":"Home Assistant status topic","type":"string"}},"title":"Home Assistant (advanced)","type":"object"}],"requiresRestart":true,"title":"Home Assistant integration"},"map_options":{"properties":{"graphviz":{"properties":{"colors":{"properties":{"fill":{"properties":{"coordinator":{"type":"string"},"enddevice":{"type":"string"},"router":{"type":"string"}},"type":"object"},"font":{"properties":{"coordinator":{"type":"string"},"enddevice":{"type":"string"},"router":{"type":"string"}},"type":"object"},"line":{"properties":{"active":{"type":"string"},"inactive":{"type":"string"}},"type":"object"}},"type":"object"}},"type":"object"}},"title":"Networkmap","type":"object"},"mqtt":{"properties":{"base_topic":{"default":"zigbee2mqtt","description":"MQTT base topic for Zigbee2MQTT MQTT messages","examples":["zigbee2mqtt"],"requiresRestart":true,"title":"Base topic","type":"string"},"ca":{"description":"Absolute path to SSL/TLS certificate of CA used to sign server and client certificates","examples":["/etc/ssl/mqtt-ca.crt"],"requiresRestart":true,"title":"Certificate authority","type":"string"},"cert":{"description":"Absolute path to SSL/TLS certificate for client-authentication","examples":["/etc/ssl/mqtt-client.crt"],"requiresRestart":true,"title":"SSL/TLS certificate","type":"string"},"client_id":{"description":"MQTT client ID","examples":["MY_CLIENT_ID"],"requiresRestart":true,"title":"Client ID","type":"string"},"force_disable_retain":{"default":false,"description":"Disable retain for all send messages. ONLY enable if you MQTT broker doesn't support retained message (e.g. AWS IoT core, Azure IoT Hub, Google Cloud IoT core, IBM Watson IoT Platform). Enabling will break the Home Assistant integration","requiresRestart":true,"title":"Force disable retain","type":"boolean"},"include_device_information":{"default":false,"description":"Include device information to mqtt messages","title":"Include device information","type":"boolean"},"keepalive":{"default":60,"description":"MQTT keepalive in second","requiresRestart":true,"title":"Keepalive","type":"number"},"key":{"description":"Absolute path to SSL/TLS key for client-authentication","examples":["/etc/ssl/mqtt-client.key"],"requiresRestart":true,"title":"SSL/TLS key","type":"string"},"password":{"description":"MQTT server authentication password","examples":["ILOVEPELMENI"],"requiresRestart":true,"title":"Password","type":"string"},"reject_unauthorized":{"default":true,"description":"Disable self-signed SSL certificate","requiresRestart":true,"title":"Reject unauthorized","type":"boolean"},"server":{"description":"MQTT server URL (use mqtts:// for SSL/TLS connection)","examples":["mqtt://localhost:1883"],"requiresRestart":true,"title":"MQTT server","type":"string"},"user":{"description":"MQTT server authentication user","examples":["johnnysilverhand"],"requiresRestart":true,"title":"User","type":"string"},"version":{"default":4,"description":"MQTT protocol version","examples":[5],"requiresRestart":true,"title":"Version","type":["number","null"]}},"required":["server"],"title":"MQTT","type":"object"},"ota":{"properties":{"disable_automatic_update_check":{"default":false,"description":"Zigbee devices may request a firmware update, and do so frequently, causing Zigbee2MQTT to reach out to third party servers. If you disable these device initiated checks, you can still initiate a firmware update check manually.","title":"Disable automatic update check","type":"boolean"},"ikea_ota_use_test_url":{"default":false,"description":"Use IKEA TRADFRI OTA test server, see OTA updates documentation","requiresRestart":true,"title":"IKEA TRADFRI OTA use test url","type":"boolean"},"update_check_interval":{"default":1440,"description":"Your device may request a check for a new firmware update. This value determines how frequently third party servers may actually be contacted to look for firmware updates. The value is set in minutes, and the default is 1 day.","title":"Update check interval","type":"number"},"zigbee_ota_override_index_location":{"description":"Location of override OTA index file","examples":["index.json"],"requiresRestart":true,"title":"OTA index override file name","type":["string","null"]}},"title":"OTA updates","type":"object"},"passlist":{"description":"Allow only certain devices to join the network (by ieeeAddr). Note that all devices not on the passlist will be removed from the network!","items":{"type":"string"},"requiresRestart":true,"title":"Passlist","type":"array"},"permit_join":{"default":false,"description":"Allow new devices to join (re-applied at restart)","title":"Permit join","type":"boolean"},"serial":{"properties":{"adapter":{"default":"auto","description":"Adapter type, not needed unless you are experiencing problems","enum":["deconz","zstack","zigate","ezsp","auto","ember"],"requiresRestart":true,"title":"Adapter","type":["string"]},"baudrate":{"description":"Baud rate speed for serial port, this can be anything firmware support but default is 115200 for Z-Stack and EZSP, 38400 for Deconz, however note that some EZSP firmware need 57600","examples":[38400,57600,115200],"requiresRestart":true,"title":"Baudrate","type":"number"},"disable_led":{"default":false,"description":"Disable LED of the adapter if supported","requiresRestart":true,"title":"Disable led","type":"boolean"},"port":{"description":"Location of the adapter. To autodetect the port, set null","examples":["/dev/ttyACM0"],"requiresRestart":true,"title":"Port","type":["string","null"]},"rtscts":{"description":"RTS / CTS Hardware Flow Control for serial port","requiresRestart":true,"title":"RTS / CTS","type":"boolean"}},"title":"Serial","type":"object"},"whitelist":{"items":{"type":"string"},"readOnly":true,"requiresRestart":true,"title":"Whitelist (deprecated, use passlist)","type":"array"}},"required":["mqtt"],"type":"object"},"coordinator":{"ieee_address":"0x00124b002a2eafb4","meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20210708,"transportrev":2},"type":"zStack3x0"},"log_level":"info","network":{"channel":11,"extended_pan_id":"0x00124b002a2eafb4","pan_id":6754},"permit_join":false,"restart_required":false,"version":"1.39.0","zigbee_herdsman":{"version":"0.50.1"},"zigbee_herdsman_converters":{"version":"19.62.0"}}
2024-07-06 14:23:33 log_level info
2024-07-06 14:23:33 log_message z2m: Zigbee2MQTT started!
2024-07-06 14:07:48 log_namespace z2m:mqtt
2024-07-06 14:23:31 state {"state":"online"}
2024-07-06 14:05:15 subscriptions zigbee2mqtt/#
alias MQTT2 Bridge
bridgeRegexp zigbee2mqtt/([A-Za-z0-9._]+)[/]?.*:.* "zigbee_$1"
comment To check for new updates of the deamon software, you might want to use a separate HTTPMOD device. See HTTPMOD template zigbee2mqtt_daemon_updates for further details.
devStateIcon online:mqtt@green
offline:mqtt@red
devicetopic zigbee2mqtt
getList networkmap_raw:noArg raw $DEVICETOPIC/bridge/request/networkmap raw
networkmap_graphviz:noArg graphviz $DEVICETOPIC/bridge/request/networkmap graphviz
group Funkmodule
model zigbee2mqtt_bridge
readingList $DEVICETOPIC/bridge/state:.* state
$DEVICETOPIC/bridge/config/devices:.* {}
$DEVICETOPIC/bridge/config/log_level:.* log_level
$DEVICETOPIC/bridge/config/permit_join:.* permit_join
$DEVICETOPIC/bridge/config/rename:.* { json2nameValue($EVENT, 'rename_') }
$DEVICETOPIC/bridge/config:.* { json2nameValue($EVENT) }
$DEVICETOPIC/bridge/log:.*\"type\".\"devices\".\"message\".* devices
$DEVICETOPIC/bridge/log:.* log
$DEVICETOPIC/bridge/logging:.* { json2nameValue($EVENT,'log_') }
$DEVICETOPIC/bridge/response/networkmap:.* { my $type = $EVENT =~ m/.*,"type":"(raw|graphviz)",.*/ ? $1 : 'networkmap'; $EVENT =~ m/{"data":\{.*"value":"?(.*[^"])"?\},"status":"ok"\}/ ? { $type=>$1 } : {} }
$DEVICETOPIC/bridge/devices:.* devices
$DEVICETOPIC/bridge/info:.* info
$DEVICETOPIC/bridge/groups:.* groups
$DEVICETOPIC/bridge/event:.* { json2nameValue($EVENT) }
$DEVICETOPIC/bridge/extensions:.* extensions
$DEVICETOPIC/bridge/response/permit_join:.* { json2nameValue($EVENT) }
$DEVICETOPIC/bridge/definitions:.* {}
room System
setList log_level:debug,info,warn,error $DEVICETOPIC/bridge/config/log_level $EVTPART1
permit_join:true,false $DEVICETOPIC/bridge/request/permit_join $EVTPART1
remove:textField $DEVICETOPIC/bridge/config/remove $EVTPART1
ota_update:textField $DEVICETOPIC/bridge/ota_update/update $EVTPART1
ota_update_check:textField $DEVICETOPIC/bridge/ota_update/check $EVTPART1
y_device_setting:textField $DEVICETOPIC/$EVTPART1/set {"$EVTPART2": "$EVTPART3"}
x_bind:textField $DEVICETOPIC/bridge/bind/$EVTPART1 $EVTPART2
x_bind_unbind:textField $DEVICETOPIC/bridge/unbind/$EVTPART1 $EVTPART2
x_device_options:textField $DEVICETOPIC/bridge/config/device_options {"friendly_name":"$EVTPART1","options": {"$EVTPART2": "$EVTPART3"}}
x_group_add_to:textField $DEVICETOPIC/bridge/group/$EVTPART1/add $EVTPART2
x_group_rm_from:textField $DEVICETOPIC/bridge/group/$EVTPART1/remove $EVTPART2
x_group_rm_from_all:textField $DEVICETOPIC/bridge/group/$EVTPART1/remove_all $EVTPART2
x_group_add_group:textField $DEVICETOPIC/bridge/config/add_group $EVTPART1
x_group_rm_group:textField $DEVICETOPIC/bridge/config/remove_group $EVTPART1
z_elapsed:textField $DEVICETOPIC/bridge/config/elapsed $EVTPART1
z_last_seen:disable,ISO_8601,epoch,ISO_8601_local $DEVICETOPIC/bridge/config/last_seen $EVTPART1
z_ban:textField $DEVICETOPIC/bridge/config/ban $EVTPART1
z_rename:textField $DEVICETOPIC/bridge/config/rename {"old":"$EVTPART1","new":"$EVTPART2"}
z_reset_CC:noArg $DEVICETOPIC/bridge/config/reset
setStateList on off
sortby 03
Kannst Du mal im Trafficmonitor von myBroker (oder im Ui unter Logs) schauen und zeigen was da unter dem zigbee2mqtt/bridge/state Topic bei Dir gesendet wird bei einem start/stop von z2m.
Kannst du mir sagen wo ich eines von beidem finde?
Den Trafficmonitor kenne ich nicht und eine Logdatei in FHEM kann ich ebenfalls nicht finden
Wenn ich auf MQTT Server klicke dann zeigt es mir 2 Server an, die ich dann im Detail anschauen kann.
Fotos davon im Anhang
Zitat von: TomLee am 06 Juli 2024, 14:50:26Kannst Du mal im Trafficmonitor von myBroker (oder im Ui unter Logs) schauen und zeigen was da unter dem
Trafficmonitor:
Oben in myBroker auf Show MQTT traffic klicken.
Hast Du das Frontend von z2m aktiviert ? Dort könntest auch nachschauen, unter Logs.
Da wird bei beiden nichts angezeugt.
Aber ist es korrekt das ich 2 MQTT Server habe?
In dem zweiten Server "myBroker_127.0.0.1_58452" wird ja der falsche State angezeigt.
Dieser Server ist ja auch in dem MQTT Device drin.
Eventuell einen löschen oder anders verknüpfen?
Auch im Frontend von Z2M ist das Log komplett leer.
Das schalten der verknüpften Lampe funktioniert jedoch gut
Die Devices mit der IP hinten dran ignorierst Du einfach, schau einfach nur in dem myBroker-Device. Das andere sind "Verbindungen".
Der Trafficmonitor hängt ab und an, versuchs nochmal (Seite aktualisieren), irgendwann wirst den MQTT-Verkehr sehen.
Jetzt zeigt er auch was an wenn ich etwas im System tue.
Einen Hinweis auf den STATE finde ich nicht - siehe Foto
Warum wird bei Dir der log_level Topic so oft übertragen ? Das ist bei mir nicht so.
Gib mal oben bei Filter zigbee2mqtt/bridge/state ein und starte z2m neu.
Dann kommt diese Meldung:
15:54:49.459 zigbee_pi zigbee2mqtt/bridge/state {"state":"offline"}
15:55:15.243 zigbee_pi zigbee2mqtt/bridge/state {"state":"online"}
OK, Tatsache, das ist bei mir nicht so. Das soll mal einer verstehen.
Für dich als Lösung würd ich vorschlagen den readingList-Eintrag so anzupassen:
$DEVICETOPIC/bridge/state:.* { json2nameValue($EVENT) }
Das Template anpassen ? Mal abwarten, glaub eher nicht ...
An dem Topic gab es wirklich Änderungen vor ein paar Wochen:
Evtl. gibts hier ja jemand, der sich aus dem bisher geschilderten jetzt einen Reim machen kann:
https://github.com/Koenkk/zigbee2mqtt/pull/23072/commits/93bcdbae18ac60f11127a1344bcd000dce26ac97
Hallo TomLee,
hab das ReadingList entsprechend angepasst und nach einem Neustart nun wieder i.O.
Danke für deine Hilfe 👍
Es war bei mir auch so, das der Status nicht richtig angezeigt wurde.
Das hat auch bei mir geholfen, danke.
Zitat von: TomLee am 06 Juli 2024, 16:04:25OK, Tatsache, das ist bei mir nicht so. Das soll mal einer verstehen.
Laut Doku:
https://www.zigbee2mqtt.io/guide/usage/mqtt_topics_and_messages.html#zigbee2mqtt-bridge-state
https://www.zigbee2mqtt.io/guide/configuration/device-availability.html#availability-payload
steht advanced.legacy_availability_payload per default auf true
Weder in der mit installierten configuration.yaml oder der configuration.example.yaml ist ein legacy_availability_payload: false vorgegeben.
Ihr müsst doch beide selbst diese Einstellung vorgenommen haben ?
edit:
Im Frontend unter Einstellungen->Erweitert kann man diese Einstellung vornehmen.
Ja, du hattest recht.
Bei mir war "legacy_availability_payload: false"
Muss ich wohl irgendwann mal fälschlich verstellt haben.
Gruß Björn
edit:
Habe gerade das selbe Problem. Den Lösungsansatz mit
$DEVICETOPIC/bridge/state:.* { json2nameValue($EVENT) }habe ich gesehen (aber nicht probiert), mich würde interessieren, woran es liegt.
Neuinstallation und
gibt es im FrontEnd unter
bei mir nicht. Auch nicht im configuration.yaml
Ich könnte es jetzt reinschreiben, aber Nachfolgende mit neuer Installation sollten dann das selbe Problem haben?
Edit:
Habe eben mal
availability:
# Enable the feature (default: false)
enabled: trueins configuration.yaml gepackt. Das wird auch im Frontend (glaube ich, dass es das ist) unter Einstellungen -> Verfügbarkeit angezeigt.
An der Anzeige in fhem ändert das aber bis jetzt nichts.
Edit2:
und wenn ich das richtig verstehe, ist das "Feature" für alle Devices?
Was müsste man in die jeweiligen Devices aufnehmen, damit diese auch offline/online gezeigt werden?
EDIT: zur Erklärung https://forum.fhem.de/index.php?topic=140990.0
