FHEM => English Corner => Thema gestartet von: andyBex0791 am 28 November 2024, 21:02:54
Titel: Raspberry PI server shutdown every minute approximately
Beitrag von: andyBex0791 am 28 November 2024, 21:02:54
Hi I am not sure If I have done something wrong. I have a max system with a flashed cube. I created a notify that runs perfectly 'NO' cron anywhere.
I developed & tested it for a few days running on a windows laptop with no issues. maybe here is where I have gone wrong maybe someone can confirm.
I loaded raspbian bookworm onto a PI 3+ followed the fhem install instrutions. copied the config accross to the PI from the windows install. modified the setting for the CUL as its port details are obviously different. i thought it was running perfectly and maybe it was but a few days on I have checked the lots and it shuting down every minute or so.
ZitatProtect this FHEM installation by defining an allowed device with define allowed allowed
You can disable this message with attr global motd none
2024.11.28 19:47:09 0: Featurelevel: 6.3
2024.11.28 19:47:09 0: Server started with 32 defined entities (fhem.pl:29222/2024-10-11 perl:5.036000 os:linux user:fhem pid:30676)
2024.11.28 19:48:38 0: Server shutdown
2024.11.28 19:48:39 1: Including fhem.cfg
2024.11.28 19:48:39 3: WEB: port 8083 opened
2024.11.28 19:48:39 2: eventTypes: loaded 248 lines from ./log/eventTypes.txt
2024.11.28 19:48:40 3: Opening CUL_0 device /dev/ttyACM0
2024.11.28 19:48:40 3: Setting CUL_0 serial parameters to 9600,8,N,1
2024.11.28 19:48:40 3: CUL_0: Possible commands: BbCFiAZNEkGMKLUYRTVWXOefhltxz
2024.11.28 19:48:40 3: CUL_0 device opened
2024.11.28 19:48:40 2: Switched CUL_0 rfmode to MAX
2024.11.28 19:48:40 1: Including ./log/fhem.save
2024.11.28 19:48:40 1: Messages collected while initializing FHEM:SecurityCheck:
  WEB is not password protected
2024.11.28 19:48:40 0: Featurelevel: 6.3
2024.11.28 19:48:40 0: Server started with 32 defined entities (fhem.pl:29222/2024-10-11 perl:5.036000 os:linux user:fhem pid:32379)
2024.11.28 19:50:09 0: Server shutdown
2024.11.28 19:50:09 1: Including fhem.cfg
2024.11.28 19:50:10 3: WEB: port 8083 opened
2024.11.28 19:50:10 2: eventTypes: loaded 248 lines from ./log/eventTypes.txt
2024.11.28 19:50:10 3: Opening CUL_0 device /dev/ttyACM0
2024.11.28 19:50:10 3: Setting CUL_0 serial parameters to 9600,8,N,1
2024.11.28 19:50:10 3: CUL_0: Possible commands: BbCFiAZNEkGMKLUYRTVWXOefhltxz
2024.11.28 19:50:10 3: CUL_0 device opened
2024.11.28 19:50:10 2: Switched CUL_0 rfmode to MAX
2024.11.28 19:50:10 1: Including ./log/fhem.save
2024.11.28 19:50:10 1: Messages collected while initializing FHEM:SecurityCheck:
I have searched and forgive me if I have missed the obvious but I am stuck.
Titel: Aw: Raspberry PI server shutdown every minute approximately
Beitrag von: Otto123 am 28 November 2024, 23:21:38
please disconnect all usb Sticks from raspberry and if FHEM is started than put this in the FHEM commandline
attr initialUsbCheck disable 1and press save. Than you could reconnect the usb Devices.
kind regards
Otto
