ich verzweifele an folgendem Sachverhalt:
defmod d_Balkon DOIF ([Balkon:humidity-humidity] <40)(set Du_Balkon off) DOELSE (set Du_Balkon on)funktioniert ohne Probleme.
Der (mE) gleiche Code mit anderen Geräten führt zur o.g. Fehlermeldung:
defmod d_TuyaBalkon DOIF ([TuyaBalkon:humidity] <35)(set Du_TuyaBalkon off) DOELSE (set Du_TuyaBalkon on)
Sieht jemand meinen Fehler? Das Reading "humidity" ist korrekt.
Hier das Listing:
[code]define tuya_smartlife_bfc79f5fc0a9ce7e03rpka fhempy tuya_smartlife tuya_smartlife_integration bfc79f5fc0a9ce7e03rpka
attr tuya_smartlife_bfc79f5fc0a9ce7e03rpka alias TuyaBalkon
attr tuya_smartlife_bfc79f5fc0a9ce7e03rpka group tuya_smartlife
attr tuya_smartlife_bfc79f5fc0a9ce7e03rpka room fhempy
attr tuya_smartlife_bfc79f5fc0a9ce7e03rpka stateFormat humidity
# DEF tuya_smartlife tuya_smartlife_integration bfc79f5fc0a9ce7e03rpka
# DEVICEID bfc79f5fc0a9ce7e03rpka
# FHEMPYTYPE tuya_smartlife
# FUUID 674dd01e-f33f-a79d-6bee-b2104c6760205e50
# IODev fhempy_local
# NAME tuya_smartlife_bfc79f5fc0a9ce7e03rpka
# NR 842
# PYTHONTYPE tuya_smartlife
# STATE 0
# TYPE fhempy
# eventCount 4
# READINGS:
# 2025-01-03 17:58:11 battery_percentage 70
# 2025-01-03 17:58:11 battery_state high
# 2025-01-03 17:58:11 humidity 0
# 2025-01-03 17:57:57 state ready
# 2025-01-03 17:58:11 temp_current 7
# 2025-01-03 17:58:11 temp_unit_convert c
# args:
# tuya_smartlife_bfc79f5fc0a9ce7e03rpka
# fhempy
# tuya_smartlife
# tuya_smartlife_integration
# bfc79f5fc0a9ce7e03rpka
# argsh:
# hmccu:
setstate tuya_smartlife_bfc79f5fc0a9ce7e03rpka 0
setstate tuya_smartlife_bfc79f5fc0a9ce7e03rpka 2025-01-03 17:58:11 battery_percentage 70
setstate tuya_smartlife_bfc79f5fc0a9ce7e03rpka 2025-01-03 17:58:11 battery_state high
setstate tuya_smartlife_bfc79f5fc0a9ce7e03rpka 2025-01-03 17:58:11 humidity 0
setstate tuya_smartlife_bfc79f5fc0a9ce7e03rpka 2025-01-03 17:57:57 state ready
setstate tuya_smartlife_bfc79f5fc0a9ce7e03rpka 2025-01-03 17:58:11 temp_current 7
setstate tuya_smartlife_bfc79f5fc0a9ce7e03rpka 2025-01-03 17:58:11 temp_unit_convert c
[/code]
Vielen Dank,
Ingo
Hallo Ingo,
du darfst mW nicht den alias nehmen, sondern den richtigen Namen.
Was gibt denn dieser Ausdruck in der FHEM Kommandozeile zurück?
{ReadingsVal('TuyaBalkon','humidity','Fehler')}{ReadingsVal('tuya_smartlife_bfc79f5fc0a9ce7e03rpka','humidity','Fehler')}
Hallo Otto,
danke für Deine Mühe!
Der erste Code gibt "Fehler" zurück, der zweite "0". "0" ist tatsächlich der aktuelle Feuchtigkeitsgrad, der gesuchte Wert.
Du liegst also richtig; ich muss den Originalnamen nehmen.
Habs ausprobiert und es funktioniert.
Tausend Dank!
LG Ingo
