FHEM - Hausautomations-Systeme => Homematic => Thema gestartet von: Stefan M. am 02 August 2013, 08:29:03
Titel: HM-CFG-Lan und HM-LC-SW4-WM
Beitrag von: Stefan M. am 02 August 2013, 08:29:03
ich habe ein kleines Problem.
Ich habe den HM-CFG-Lan und HMInfo ins FHEM eingebunden.
define HML HMLAN 192.168.0.25
attr HML hmId 123ABC
attr HML hmProtocolEvents 1
attr HML loglevel 1
attr HML room HMLan
attr HML userReadings 1
attr HML wdTimer 25
define HMI HMinfo
attr HMI room HMLan
attr HMI sumERROR battery:ok,sabotageError:off,powerError:ok,overload:off,overheat:off,reduced:off,motorError:no,error:none,uncertain:yes,smoke_detect:none,cover:closed
attr HMI sumStatus battery,sabotageError,powerError,motor
attr HMI webCmd protoEvents:rssi:peerXref:configCheck:models
der Adapter scheint auch zu funktionieren.
Nun versuche ich den HM-LC-SW4-WM zum laufen zu bekommen.
define CUL_HM_HM_LC_SW4_WM_20F44F CUL_HM 20F44F
attr CUL_HM_HM_LC_SW4_WM_20F44F .devInfo 040100
attr CUL_HM_HM_LC_SW4_WM_20F44F .stc 10
attr CUL_HM_HM_LC_SW4_WM_20F44F expert 2_full
attr CUL_HM_HM_LC_SW4_WM_20F44F firmware 1.12
attr CUL_HM_HM_LC_SW4_WM_20F44F model HM-LC-SW4-WM
attr CUL_HM_HM_LC_SW4_WM_20F44F peerIDs
attr CUL_HM_HM_LC_SW4_WM_20F44F room HMLan
attr CUL_HM_HM_LC_SW4_WM_20F44F serialNr KEQ0122434
attr CUL_HM_HM_LC_SW4_WM_20F44F subType switch
attr CUL_HM_HM_LC_SW4_WM_20F44F webCmd getConfig
define CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 CUL_HM 20F44F01
attr CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 autoReadReg 4_reqStatus
attr CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 expert 1_on
attr CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 model HM-LC-SW4-WM
attr CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 peerIDs
attr CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 room CUL_HM
attr CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 webCmd toggle:on:off:statusRequest
define CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02 CUL_HM 20F44F02
attr CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02 expert 1
attr CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02 model HM-LC-SW4-WM
attr CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02 peerIDs
attr CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02 room CUL_HM
attr CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02 webCmd toggle:on:off:statusRequest
define CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03 CUL_HM 20F44F03
attr CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03 expert 1
attr CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03 model HM-LC-SW4-WM
attr CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03 peerIDs
attr CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03 room CUL_HM
attr CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03 webCmd toggle:on:off:statusRequest
define CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04 CUL_HM 20F44F04
attr CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04 expert 1
attr CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04 model HM-LC-SW4-WM
attr CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04 peerIDs
attr CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04 room CUL_HM
attr CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04 webCmd toggle:on:off:statusRequest
Auszug aus dem Logfile
Zitat2013-08-01_18:37:48 CUL_HM_HM_LC_SW4_WM_20F44F RESPONSE TIMEOUT:RegisterRead
2013-08-01_18:38:14 CUL_HM_HM_LC_SW4_WM_20F44F RESPONSE TIMEOUT:PeerList
2013-08-01_18:38:40 CUL_HM_HM_LC_SW4_WM_20F44F RESPONSE TIMEOUT:PeerList
2013-08-01_18:39:05 CUL_HM_HM_LC_SW4_WM_20F44F RESPONSE TIMEOUT:PeerList
2013-08-01_18:39:30 CUL_HM_HM_LC_SW4_WM_20F44F RESPONSE TIMEOUT:PeerList
2013-08-01_18:39:39 CUL_HM_HM_LC_SW4_WM_20F44F MISSING ACK
2013-08-01_18:39:47 CUL_HM_HM_LC_SW4_WM_20F44F MISSING ACK
2013-08-01_18:39:54 CUL_HM_HM_LC_SW4_WM_20F44F MISSING ACK
2013-08-01_18:43:55 CUL_HM_HM_LC_SW4_WM_20F44F RESPONSE TIMEOUT:PeerList
2013-08-01_18:44:07 CUL_HM_HM_LC_SW4_WM_20F44F MISSING ACK
2013-08-01_18:44:34 CUL_HM_HM_LC_SW4_WM_20F44F RESPONSE TIMEOUT:RegisterRead
2013-08-01_18:44:57 CUL_HM_HM_LC_SW4_WM_20F44F RESPONSE TIMEOUT:PeerList
2013-08-01_18:45:23 CUL_HM_HM_LC_SW4_WM_20F44F RESPONSE TIMEOUT:PeerList
2013-08-01_18:45:48 CUL_HM_HM_LC_SW4_WM_20F44F RESPONSE TIMEOUT:PeerList
2013-08-01_18:46:13 CUL_HM_HM_LC_SW4_WM_20F44F RESPONSE TIMEOUT:PeerList
2013-08-02_08:10:08 CUL_HM_HM_LC_SW4_WM_20F44F MISSING ACK
2013-08-02_08:10:14 CUL_HM_HM_LC_SW4_WM_20F44F MISSING ACK
2013-08-02_08:12:01 CUL_HM_HM_LC_SW4_WM_20F44F powerOn: -
2013-08-02_08:12:01 CUL_HM_HM_LC_SW4_WM_20F44F level: 0 %
2013-08-02_08:12:01 CUL_HM_HM_LC_SW4_WM_20F44F off
2013-08-02_08:24:34 CUL_HM_HM_LC_SW4_WM_20F44F RESPONSE TIMEOUT:RegisterRead
2013-08-02_08:24:59 CUL_HM_HM_LC_SW4_WM_20F44F RESPONSE TIMEOUT:PeerList
Der ConfigCheck zeigt folgendes
ZitatconfigCheck done:
 incomplete register set
    CUL_HM_HM_LC_SW4_WM_20F44F:RegL_00:
 missing Peer Registerset
 incomplete list
 empty list
    empty: CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01
    empty: CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02
    empty: CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03
    empty: CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04
    empty: CUL_HM_HM_SEC_RHS_1F194F
    empty: CUL_HM_HM_Sen_Wa_Od_1F06B1
 peer not verified
was bedeutet CUL_HM_HM_LC_SW4_WM_20F44F:RegL_00 ?
Der Switch wurde über den Anlernmodus eingebracht. Wenn ich nun die Taste am Switch drücke ändert sich der Status. Wenn ich die Kontakte über FHEM schalten möchte funktioniert es nicht.
Hat jemand eine Idee an was das liegen kann ?
Über die Homematic Software funktioniert das schalten.
Die beiden anderen Komponenten scheinen erst mal zu funktionieren.
lg
Stefan
Titel: Aw: HM-CFG-Lan und HM-LC-SW4-WM
Beitrag von: martinp876 am 02 August 2013, 14:22:58
ich denke, du hast nicht korrekt gepairt. Offensichtlich geht quasi überhauptkeine kommunikation.
Welche HMId benutzt du  mit der HMSW? Nutze doch die gleiche in FHEM für HMLAN. Ansonsten musst du beim wechseln immer neu pairen
Beitrag von: Stefan M. am 04 August 2013, 12:37:30
Hallo Martin
Ich glaube schon dass der HMLan mit Fhem kommuniziert. In der HM Software habe ich keine HMID gefunden, hier gibt es nur die Seriennummer. Die Verschlüsselung ist ausgeschaltet. Für den CUL_HM_HM_SEC_RHS_1F194F und der
CUL_HM_HM_Sen_Wa_Od_1F06B1 sehe ich ja Informationen die empfangen werden. Das was nicht geht ist das Senden von Kommandos an das CUL_HM_HM_LC_SW4_WM. Die Statusänderung wenn ich manuell am Switch den Port schalte sehe ich in FHEM.
Irgendwie verstehe ich es noch nicht so recht.
Stefan
Beitrag von: Stefan M. am 04 August 2013, 13:40:35
Hallo zusammen
jetzt geht's, war doch an der HMID gelegen. Hab die richtige HMID im durch Zufall FHEM Logfile gefunden.
Stefan
Beitrag von: martinp876 am 04 August 2013, 13:56:25
Hallo Stefan,
dass Nachrichten Empfangen werden sagt nichts über das pairen aus. HMLAN schreibt alles mit, egal von oder für wen.
habe jetzt auch nicht gefunden, wo du die HMID in der HMSW aendern kannst.
kannst du einmal schauen, wohin deine Devices ihre statusmeldungen schicken? Ist es an deine FHEM-HMid?
Zeichne einmal ein paar Aktionen auf - mit
attr global verbose 1
attr global mseclog 1
attr <hmlan> loglevel 1
das Ergebniss ist im Logfile, einfach einmal schicken.
Gruss Martin
Beitrag von: Stefan M. am 04 August 2013, 14:32:50
Hallo Martin,
hier mal einige Logs.
der Switch funktioniert jetzt auch von FHEM aus.
lg
Stefan
2013.08.04 14:21:14.772 1: HMLAN_Send:  HML I:K
2013.08.04 14:21:14.781 1: HMLAN_Parse: HML V:03C1 sNo:JEQ0706016 d:1EA224 O:1EA224 t:0E842509 IDcnt:0001
2013.08.04 14:22:04.791 1: HMLAN_Send:  HML I:K
2013.08.04 14:22:04.798 1: HMLAN_Parse: HML V:03C1 sNo:JEQ0706016 d:1EA224 O:1EA224 t:0E84E870 IDcnt:0001
2013.08.04 14:22:07.741 4: Connection accepted from FHEMWEB:192.168.0.13:62487
2013.08.04 14:22:07.746 4: HTTP FHEMWEB:192.168.0.13:62487 GET /fhem?cmd.CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01=set%20CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01%20on&room=CUL_HM
2013.08.04 14:22:07.750 5: Cmd: >set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 on<
2013.08.04 14:22:07.757 5: Triggering CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 (1 changes)
2013.08.04 14:22:07.769 5: Notify loop for CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 set_on
2013.08.04 14:22:07.876 2: CUL_HM set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 on
2013.08.04 14:22:07.879 1: HMLAN_Send:  HML S:+20F44F,00,01,
2013.08.04 14:22:07.881 1: HMLAN_Send:  HML S:S49470E46 stat:  00 t:00000000 d:01 r:49470E46 m:5A B011 1EA224 20F44F 0201C80000
2013.08.04 14:22:07.887 1: SND L:0E N:5A F:B0 CMD:11 SRC:1EA224 DST:CUL_HM_HM_LC_SW4_WM_20F44F 0201C80000 (SET CHANNEL:0x01 VALUE:0xC8 RAMPTIME:0x0000) (,BURST,BIDI,RPTEN)
2013.08.04 14:22:07.897 4: Connection accepted from FHEMWEB:192.168.0.13:62490
2013.08.04 14:22:07.902 4: HTTP FHEMWEB:192.168.0.13:62487 GET /fhem?room=CUL_HM
2013.08.04 14:22:08.619 4: /fhem?room=CUL_HM / RL: 1781 / text/html; charset=UTF-8 / Content-Encoding: gzip
2013.08.04 14:22:08.623 4: Connection accepted from FHEMWEB:192.168.0.13:62492
2013.08.04 14:22:08.633 1: HMLAN_Parse: HML R:R49470E46 stat:0001 t:0E84F680 d:FF r:FFEC     m:5A 8002 20F44F 1EA224 0101C80018
2013.08.04 14:22:08.636 5: HML dispatch A0E5A800220F44F1EA2240101C80018::-20:HML
2013.08.04 14:22:08.642 1: RCV L:0E N:5A F:80 CMD:02 SRC:CUL_HM_HM_LC_SW4_WM_20F44F DST:1EA224 0101C80018 (ACK_STATUS CHANNEL:0x01 STATUS:0xC8 UP:0x00 DOWN:0x00 LOWBAT:0x00 RSSI:0x18) (,RPTEN)
2013.08.04 14:22:08.654 5: Triggering CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 (3 changes)
2013.08.04 14:22:08.667 5: Notify loop for CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 level: 100 %
2013.08.04 14:22:08.809 4: Connection accepted from FHEMWEB:192.168.0.13:62493
2013.08.04 14:22:08.814 4: HTTP FHEMWEB:192.168.0.13:62487 GET /fhem/images/default/set_on.png
2013.08.04 14:22:08.819 4: HTTP FHEMWEB:192.168.0.13:62493 GET /fhem/pgm2/fhemweb.js
2013.08.04 14:22:08.824 4: HTTP FHEMWEB:192.168.0.13:62492 GET /fhem/pgm2/svg.js
2013.08.04 14:22:08.831 4: Connection closed for FHEMWEB:192.168.0.13:62396
2013.08.04 14:22:08.835 4: Connection accepted from FHEMWEB:192.168.0.13:62494
2013.08.04 14:22:08.838 4: HTTP FHEMWEB:192.168.0.13:62490 GET /fhem/pgm2/style.css
2013.08.04 14:22:08.845 4: Connection closed for FHEMWEB:192.168.0.13:62487
2013.08.04 14:22:08.849 4: HTTP FHEMWEB:192.168.0.13:62493 GET /fhem/pgm2/fhemweb_time.js
2013.08.04 14:22:08.853 4: HTTP FHEMWEB:192.168.0.13:62492 GET /fhem/images/default/icoHaus.png
2013.08.04 14:22:08.858 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/pgm2/fhemweb_colorpicker.js
2013.08.04 14:22:08.864 4: Connection accepted from FHEMWEB:192.168.0.13:62496
2013.08.04 14:22:08.869 4: HTTP FHEMWEB:192.168.0.13:62493 GET /fhem/images/default/set_on.png
2013.08.04 14:22:08.874 4: HTTP FHEMWEB:192.168.0.13:62492 GET /fhem/images/default/off.png
2013.08.04 14:22:08.879 4: Connection accepted from FHEMWEB:192.168.0.13:62498
2013.08.04 14:22:08.882 4: HTTP FHEMWEB:192.168.0.13:62490 GET /fhem/images/default/icoEverything.png
2013.08.04 14:22:08.887 4: HTTP FHEMWEB:192.168.0.13:62496 GET /fhem/pgm2/fhemweb_slider.js
2013.08.04 14:22:08.895 4: HTTP FHEMWEB:192.168.0.13:62498 GET /fhem/pgm2/fhemweb_svg.js
2013.08.04 14:22:08.954 4: HTTP FHEMWEB:192.168.0.13:62498 GET /fhem/icons/fhemicon.png
2013.08.04 14:22:09.044 4: HTTP FHEMWEB:192.168.0.13:62498 GET /fhem?room=CUL_HM&XHR=1&inform=1&timestamp=1375618928127
2013.08.04 14:22:11.578 4: HTTP FHEMWEB:192.168.0.13:62496 GET /fhem?cmd.CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02=set%20CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02%20on&room=CUL_HM
2013.08.04 14:22:11.584 5: Cmd: >set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02 on<
2013.08.04 14:22:11.590 5: Triggering CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02 (1 changes)
2013.08.04 14:22:11.604 5: Notify loop for CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02 set_on
2013.08.04 14:22:11.715 2: CUL_HM set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02 on
2013.08.04 14:22:11.718 1: HMLAN_Send:  HML S:S49471D44 stat:  00 t:00000000 d:01 r:49471D44 m:5B B011 1EA224 20F44F 0202C80000
2013.08.04 14:22:11.724 1: SND L:0E N:5B F:B0 CMD:11 SRC:1EA224 DST:CUL_HM_HM_LC_SW4_WM_20F44F 0202C80000 (SET CHANNEL:0x02 VALUE:0xC8 RAMPTIME:0x0000) (,BURST,BIDI,RPTEN)
2013.08.04 14:22:11.735 4: HTTP FHEMWEB:192.168.0.13:62496 GET /fhem?room=CUL_HM
2013.08.04 14:22:12.405 4: /fhem?room=CUL_HM / RL: 1799 / text/html; charset=UTF-8 / Content-Encoding: gzip
2013.08.04 14:22:12.414 1: HMLAN_Parse: HML R:R49471D44 stat:0001 t:0E85057B d:FF r:FFEC     m:5B 8002 20F44F 1EA224 0102C80018
2013.08.04 14:22:12.417 5: HML dispatch A0E5B800220F44F1EA2240102C80018::-20:HML
2013.08.04 14:22:12.422 1: RCV L:0E N:5B F:80 CMD:02 SRC:CUL_HM_HM_LC_SW4_WM_20F44F DST:1EA224 0102C80018 (ACK_STATUS CHANNEL:0x02 STATUS:0xC8 UP:0x00 DOWN:0x00 LOWBAT:0x00 RSSI:0x18) (,RPTEN)
2013.08.04 14:22:12.439 5: Triggering CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02 (3 changes)
2013.08.04 14:22:12.451 5: Notify loop for CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02 level: 100 %
2013.08.04 14:22:12.591 4: HTTP FHEMWEB:192.168.0.13:62490 GET /fhem/images/default/on.png
2013.08.04 14:22:12.599 4: Connection closed for FHEMWEB:192.168.0.13:62498
2013.08.04 14:22:12.602 4: HTTP FHEMWEB:192.168.0.13:62493 GET /fhem/pgm2/svg.js
2013.08.04 14:22:12.606 4: HTTP FHEMWEB:192.168.0.13:62492 GET /fhem/images/default/set_on.png
2013.08.04 14:22:12.612 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/pgm2/fhemweb.js
2013.08.04 14:22:12.619 4: Connection accepted from FHEMWEB:192.168.0.13:62502
2013.08.04 14:22:12.623 4: Connection closed for FHEMWEB:192.168.0.13:62490
2013.08.04 14:22:12.626 4: HTTP FHEMWEB:192.168.0.13:62496 GET /fhem/pgm2/style.css
2013.08.04 14:22:12.633 4: HTTP FHEMWEB:192.168.0.13:62493 GET /fhem/pgm2/fhemweb_time.js
2013.08.04 14:22:12.638 4: Connection closed for FHEMWEB:192.168.0.13:62492
2013.08.04 14:22:12.642 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/images/default/icoHaus.png
2013.08.04 14:22:12.647 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem/pgm2/fhemweb_colorpicker.js
2013.08.04 14:22:12.654 4: Connection accepted from FHEMWEB:192.168.0.13:62503
2013.08.04 14:22:12.658 4: HTTP FHEMWEB:192.168.0.13:62493 GET /fhem/images/default/on.png
2013.08.04 14:22:12.663 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/images/default/set_on.png
2013.08.04 14:22:12.667 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem/images/default/off.png
2013.08.04 14:22:12.673 4: HTTP FHEMWEB:192.168.0.13:62503 GET /fhem/pgm2/fhemweb_slider.js
2013.08.04 14:22:12.678 4: Connection accepted from FHEMWEB:192.168.0.13:62505
2013.08.04 14:22:12.681 4: HTTP FHEMWEB:192.168.0.13:62496 GET /fhem/images/default/icoEverything.png
2013.08.04 14:22:12.688 4: HTTP FHEMWEB:192.168.0.13:62505 GET /fhem/pgm2/fhemweb_svg.js
2013.08.04 14:22:12.746 4: HTTP FHEMWEB:192.168.0.13:62505 GET /fhem/icons/fhemicon.png
2013.08.04 14:22:12.852 4: HTTP FHEMWEB:192.168.0.13:62505 GET /fhem?room=CUL_HM&XHR=1&inform=1&timestamp=1375618931937
2013.08.04 14:22:13.727 4: HTTP FHEMWEB:192.168.0.13:62496 GET /fhem?cmd.CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03=set%20CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03%20on&room=CUL_HM
2013.08.04 14:22:13.733 5: Cmd: >set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03 on<
2013.08.04 14:22:13.739 5: Triggering CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03 (1 changes)
2013.08.04 14:22:13.750 5: Notify loop for CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03 set_on
2013.08.04 14:22:13.863 2: CUL_HM set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03 on
2013.08.04 14:22:13.866 1: HMLAN_Send:  HML S:S494725A9 stat:  00 t:00000000 d:01 r:494725A9 m:5C B011 1EA224 20F44F 0203C80000
2013.08.04 14:22:13.873 1: SND L:0E N:5C F:B0 CMD:11 SRC:1EA224 DST:CUL_HM_HM_LC_SW4_WM_20F44F 0203C80000 (SET CHANNEL:0x03 VALUE:0xC8 RAMPTIME:0x0000) (,BURST,BIDI,RPTEN)
2013.08.04 14:22:13.884 4: HTTP FHEMWEB:192.168.0.13:62496 GET /fhem?room=CUL_HM
2013.08.04 14:22:14.578 4: /fhem?room=CUL_HM / RL: 1800 / text/html; charset=UTF-8 / Content-Encoding: gzip
2013.08.04 14:22:14.587 1: HMLAN_Parse: HML R:R494725A9 stat:0201 t:0E850DE0 d:FF r:FFEC     m:5C 8002 20F44F 1EA224 0103C80018
2013.08.04 14:22:14.589 1: HMLAN_Parse: HML new condition Warning-HighLoad
2013.08.04 14:22:14.591 5: Triggering HML (1 changes)
2013.08.04 14:22:14.604 5: Notify loop for HML cond: Warning-HighLoad
2013.08.04 14:22:14.711 5: Triggering HML (1 changes)
2013.08.04 14:22:14.723 5: Notify loop for HML Xmit-Events: Overload-released:1 ERROR-Overload:1 ok:5 Warning-HighLoad:2
2013.08.04 14:22:14.824 5: HML dispatch A0E5C800220F44F1EA2240103C80018::-20:HML
2013.08.04 14:22:14.830 1: RCV L:0E N:5C F:80 CMD:02 SRC:CUL_HM_HM_LC_SW4_WM_20F44F DST:1EA224 0103C80018 (ACK_STATUS CHANNEL:0x03 STATUS:0xC8 UP:0x00 DOWN:0x00 LOWBAT:0x00 RSSI:0x18) (,RPTEN)
2013.08.04 14:22:14.840 5: Triggering CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03 (3 changes)
2013.08.04 14:22:14.854 5: Notify loop for CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03 level: 100 %
2013.08.04 14:22:14.989 4: HTTP FHEMWEB:192.168.0.13:62493 GET /fhem/pgm2/fhemweb_slider.js
2013.08.04 14:22:14.998 4: Connection closed for FHEMWEB:192.168.0.13:62505
2013.08.04 14:22:15.002 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/pgm2/fhemweb_colorpicker.js
2013.08.04 14:22:15.007 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem/pgm2/fhemweb.js
2013.08.04 14:22:15.013 4: HTTP FHEMWEB:192.168.0.13:62503 GET /fhem/pgm2/svg.js
2013.08.04 14:22:15.019 4: Connection accepted from FHEMWEB:192.168.0.13:62507
2013.08.04 14:22:15.022 4: HTTP FHEMWEB:192.168.0.13:62496 GET /fhem/pgm2/style.css
2013.08.04 14:22:15.029 4: HTTP FHEMWEB:192.168.0.13:62493 GET /fhem/pgm2/fhemweb_time.js
2013.08.04 14:22:15.034 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/images/default/icoHaus.png
2013.08.04 14:22:15.039 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem/images/default/icoEverything.png
2013.08.04 14:22:15.045 4: HTTP FHEMWEB:192.168.0.13:62503 GET /fhem/images/default/on.png
2013.08.04 14:22:15.050 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem/pgm2/fhemweb_svg.js
2013.08.04 14:22:15.057 4: HTTP FHEMWEB:192.168.0.13:62493 GET /fhem/images/default/off.png
2013.08.04 14:22:15.062 4: HTTP FHEMWEB:192.168.0.13:62496 GET /fhem/images/default/set_on.png
2013.08.04 14:22:15.077 4: HTTP FHEMWEB:192.168.0.13:62496 GET /fhem/icons/fhemicon.png
2013.08.04 14:22:15.219 4: HTTP FHEMWEB:192.168.0.13:62496 GET /fhem?room=CUL_HM&XHR=1&inform=1&timestamp=1375618934305
2013.08.04 14:22:15.697 4: HTTP FHEMWEB:192.168.0.13:62493 GET /fhem?cmd.CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04=set%20CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04%20on&room=CUL_HM
2013.08.04 14:22:15.702 5: Cmd: >set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04 on<
2013.08.04 14:22:15.708 5: Triggering CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04 (1 changes)
2013.08.04 14:22:15.719 5: Notify loop for CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04 set_on
2013.08.04 14:22:15.831 2: CUL_HM set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04 on
2013.08.04 14:22:15.834 1: HMLAN_Send:  HML S:S49472D59 stat:  00 t:00000000 d:01 r:49472D59 m:5D B011 1EA224 20F44F 0204C80000
2013.08.04 14:22:15.840 1: SND L:0E N:5D F:B0 CMD:11 SRC:1EA224 DST:CUL_HM_HM_LC_SW4_WM_20F44F 0204C80000 (SET CHANNEL:0x04 VALUE:0xC8 RAMPTIME:0x0000) (,BURST,BIDI,RPTEN)
2013.08.04 14:22:15.853 4: HTTP FHEMWEB:192.168.0.13:62493 GET /fhem?room=CUL_HM
2013.08.04 14:22:16.588 4: /fhem?room=CUL_HM / RL: 1782 / text/html; charset=UTF-8 / Content-Encoding: gzip
2013.08.04 14:22:16.597 1: HMLAN_Parse: HML R:R49472D59 stat:0201 t:0E851590 d:FF r:FFEC     m:5D 8002 20F44F 1EA224 0104C80018
2013.08.04 14:22:16.600 5: HML dispatch A0E5D800220F44F1EA2240104C80018::-20:HML
2013.08.04 14:22:16.605 1: RCV L:0E N:5D F:80 CMD:02 SRC:CUL_HM_HM_LC_SW4_WM_20F44F DST:1EA224 0104C80018 (ACK_STATUS CHANNEL:0x04 STATUS:0xC8 UP:0x00 DOWN:0x00 LOWBAT:0x00 RSSI:0x18) (,RPTEN)
2013.08.04 14:22:16.618 5: Triggering CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04 (3 changes)
2013.08.04 14:22:16.630 5: Notify loop for CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04 level: 100 %
2013.08.04 14:22:16.765 4: HTTP FHEMWEB:192.168.0.13:62493 GET /fhem/pgm2/style.css
2013.08.04 14:22:16.770 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/pgm2/fhemweb_slider.js
2013.08.04 14:22:16.777 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem/pgm2/fhemweb_colorpicker.js
2013.08.04 14:22:16.783 4: HTTP FHEMWEB:192.168.0.13:62503 GET /fhem/pgm2/fhemweb.js
2013.08.04 14:22:16.790 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem/pgm2/svg.js
2013.08.04 14:22:16.795 4: Connection accepted from FHEMWEB:192.168.0.13:62509
2013.08.04 14:22:16.799 4: Connection closed for FHEMWEB:192.168.0.13:62496
2013.08.04 14:22:16.804 4: HTTP FHEMWEB:192.168.0.13:62493 GET /fhem/pgm2/fhemweb_time.js
2013.08.04 14:22:16.809 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/images/default/icoHaus.png
2013.08.04 14:22:16.814 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem/images/default/icoEverything.png
2013.08.04 14:22:16.818 4: HTTP FHEMWEB:192.168.0.13:62503 GET /fhem/images/default/on.png
2013.08.04 14:22:16.823 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem/images/default/set_on.png
2013.08.04 14:22:16.828 4: HTTP FHEMWEB:192.168.0.13:62509 GET /fhem/pgm2/fhemweb_svg.js
2013.08.04 14:22:16.891 4: HTTP FHEMWEB:192.168.0.13:62509 GET /fhem/icons/fhemicon.png
2013.08.04 14:22:16.990 4: HTTP FHEMWEB:192.168.0.13:62509 GET /fhem?room=CUL_HM&XHR=1&inform=1&timestamp=1375618936075
2013.08.04 14:22:17.000 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem?cmd.CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01=set%20CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01%20off&room=CUL_HM
2013.08.04 14:22:18.005 5: Cmd: >set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 off<
2013.08.04 14:22:18.012 5: Triggering CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 (1 changes)
2013.08.04 14:22:18.024 5: Notify loop for CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 set_off
2013.08.04 14:22:18.131 2: CUL_HM set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 off
2013.08.04 14:22:18.134 1: HMLAN_Send:  HML S:S49473655 stat:  00 t:00000000 d:01 r:49473655 m:5E B011 1EA224 20F44F 0201000000
2013.08.04 14:22:18.141 1: SND L:0E N:5E F:B0 CMD:11 SRC:1EA224 DST:CUL_HM_HM_LC_SW4_WM_20F44F 0201000000 (SET CHANNEL:0x01 VALUE:0x00 RAMPTIME:0x0000) (,BURST,BIDI,RPTEN)
2013.08.04 14:22:18.151 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem?room=CUL_HM
2013.08.04 14:22:18.874 4: /fhem?room=CUL_HM / RL: 1785 / text/html; charset=UTF-8 / Content-Encoding: gzip
2013.08.04 14:22:18.882 1: HMLAN_Parse: HML R:R49473655 stat:0201 t:0E851E8D d:FF r:FFEC     m:5E 8002 20F44F 1EA224 0101000018
2013.08.04 14:22:18.886 5: HML dispatch A0E5E800220F44F1EA2240101000018::-20:HML
2013.08.04 14:22:18.891 1: RCV L:0E N:5E F:80 CMD:02 SRC:CUL_HM_HM_LC_SW4_WM_20F44F DST:1EA224 0101000018 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0x00 DOWN:0x00 LOWBAT:0x00 RSSI:0x18) (,RPTEN)
2013.08.04 14:22:18.903 5: Triggering CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 (3 changes)
2013.08.04 14:22:18.915 5: Notify loop for CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 level: 0 %
2013.08.04 14:22:19.059 4: HTTP FHEMWEB:192.168.0.13:62493 GET /fhem/pgm2/fhemweb_slider.js
2013.08.04 14:22:19.065 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/pgm2/fhemweb_colorpicker.js
2013.08.04 14:22:19.070 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem/pgm2/fhemweb.js
2013.08.04 14:22:19.076 4: HTTP FHEMWEB:192.168.0.13:62503 GET /fhem/pgm2/svg.js
2013.08.04 14:22:19.082 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem/pgm2/style.css
2013.08.04 14:22:19.088 4: Connection accepted from FHEMWEB:192.168.0.13:62511
2013.08.04 14:22:19.091 4: Connection closed for FHEMWEB:192.168.0.13:62509
2013.08.04 14:22:19.097 4: HTTP FHEMWEB:192.168.0.13:62493 GET /fhem/pgm2/fhemweb_time.js
2013.08.04 14:22:19.102 4: HTTP FHEMWEB:192.168.0.13:62511 GET /fhem/pgm2/fhemweb_svg.js
2013.08.04 14:22:19.107 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/images/default/icoHaus.png
2013.08.04 14:22:19.113 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem/images/default/icoEverything.png
2013.08.04 14:22:19.118 4: HTTP FHEMWEB:192.168.0.13:62503 GET /fhem/images/default/set_off.png
2013.08.04 14:22:19.123 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem/images/default/on.png
2013.08.04 14:22:19.133 4: HTTP FHEMWEB:192.168.0.13:62503 GET /fhem/icons/fhemicon.png
2013.08.04 14:22:19.284 4: HTTP FHEMWEB:192.168.0.13:62503 GET /fhem?room=CUL_HM&XHR=1&inform=1&timestamp=1375618938370
2013.08.04 14:22:19.908 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem?cmd.CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02=set%20CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02%20off&room=CUL_HM
2013.08.04 14:22:19.913 5: Cmd: >set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02 off<
2013.08.04 14:22:19.919 5: Triggering CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02 (1 changes)
2013.08.04 14:22:19.931 5: Notify loop for CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02 set_off
2013.08.04 14:22:20.044 2: CUL_HM set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02 off
2013.08.04 14:22:20.047 1: HMLAN_Send:  HML S:S49473DCE stat:  00 t:00000000 d:01 r:49473DCE m:5F B011 1EA224 20F44F 0202000000
2013.08.04 14:22:20.054 1: SND L:0E N:5F F:B0 CMD:11 SRC:1EA224 DST:CUL_HM_HM_LC_SW4_WM_20F44F 0202000000 (SET CHANNEL:0x02 VALUE:0x00 RAMPTIME:0x0000) (,BURST,BIDI,RPTEN)
2013.08.04 14:22:20.065 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem?room=CUL_HM
2013.08.04 14:22:20.994 4: /fhem?room=CUL_HM / RL: 1795 / text/html; charset=UTF-8 / Content-Encoding: gzip
2013.08.04 14:22:21.003 1: HMLAN_Parse: HML R:R49473DCE stat:0201 t:0E852606 d:FF r:FFEC     m:5F 8002 20F44F 1EA224 0102000018
2013.08.04 14:22:21.006 5: HML dispatch A0E5F800220F44F1EA2240102000018::-20:HML
2013.08.04 14:22:21.014 1: RCV L:0E N:5F F:80 CMD:02 SRC:CUL_HM_HM_LC_SW4_WM_20F44F DST:1EA224 0102000018 (ACK_STATUS CHANNEL:0x02 STATUS:0x00 UP:0x00 DOWN:0x00 LOWBAT:0x00 RSSI:0x18) (,RPTEN)
2013.08.04 14:22:21.025 5: Triggering CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02 (3 changes)
2013.08.04 14:22:21.036 5: Notify loop for CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02 level: 0 %
2013.08.04 14:22:21.209 4: HTTP FHEMWEB:192.168.0.13:62493 GET /fhem/pgm2/fhemweb_slider.js
2013.08.04 14:22:21.221 4: HTTP FHEMWEB:192.168.0.13:62511 GET /fhem/pgm2/fhemweb_colorpicker.js
2013.08.04 14:22:21.226 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/pgm2/fhemweb.js
2013.08.04 14:22:21.231 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem/pgm2/svg.js
2013.08.04 14:22:21.239 4: Connection closed for FHEMWEB:192.168.0.13:62503
2013.08.04 14:22:21.242 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem/pgm2/style.css
2013.08.04 14:22:21.248 4: Connection accepted from FHEMWEB:192.168.0.13:62513
2013.08.04 14:22:21.253 4: HTTP FHEMWEB:192.168.0.13:62493 GET /fhem/pgm2/fhemweb_time.js
2013.08.04 14:22:21.258 4: HTTP FHEMWEB:192.168.0.13:62511 GET /fhem/images/default/icoHaus.png
2013.08.04 14:22:21.263 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/images/default/icoEverything.png
2013.08.04 14:22:21.269 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem/images/default/off.png
2013.08.04 14:22:21.274 4: HTTP FHEMWEB:192.168.0.13:62513 GET /fhem/pgm2/fhemweb_svg.js
2013.08.04 14:22:21.278 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem/images/default/set_off.png
2013.08.04 14:22:21.286 4: HTTP FHEMWEB:192.168.0.13:62493 GET /fhem/images/default/on.png
2013.08.04 14:22:21.302 4: HTTP FHEMWEB:192.168.0.13:62493 GET /fhem/icons/fhemicon.png
2013.08.04 14:22:21.450 4: HTTP FHEMWEB:192.168.0.13:62493 GET /fhem?room=CUL_HM&XHR=1&inform=1&timestamp=1375618940535
2013.08.04 14:22:22.098 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem?cmd.CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03=set%20CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03%20off&room=CUL_HM
2013.08.04 14:22:22.104 5: Cmd: >set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03 off<
2013.08.04 14:22:22.110 5: Triggering CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03 (1 changes)
2013.08.04 14:22:22.122 5: Notify loop for CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03 set_off
2013.08.04 14:22:22.231 2: CUL_HM set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03 off
2013.08.04 14:22:22.234 1: HMLAN_Send:  HML S:S49474659 stat:  00 t:00000000 d:01 r:49474659 m:60 B011 1EA224 20F44F 0203000000
2013.08.04 14:22:22.241 1: SND L:0E N:60 F:B0 CMD:11 SRC:1EA224 DST:CUL_HM_HM_LC_SW4_WM_20F44F 0203000000 (SET CHANNEL:0x03 VALUE:0x00 RAMPTIME:0x0000) (,BURST,BIDI,RPTEN)
2013.08.04 14:22:22.252 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem?room=CUL_HM
2013.08.04 14:22:22.949 4: /fhem?room=CUL_HM / RL: 1795 / text/html; charset=UTF-8 / Content-Encoding: gzip
2013.08.04 14:22:22.957 1: HMLAN_Parse: HML R:R49474659 stat:0201 t:0E852E92 d:FF r:FFEC     m:60 8002 20F44F 1EA224 0103000019
2013.08.04 14:22:22.960 5: HML dispatch A0E60800220F44F1EA2240103000019::-20:HML
2013.08.04 14:22:22.966 1: RCV L:0E N:60 F:80 CMD:02 SRC:CUL_HM_HM_LC_SW4_WM_20F44F DST:1EA224 0103000019 (ACK_STATUS CHANNEL:0x03 STATUS:0x00 UP:0x00 DOWN:0x00 LOWBAT:0x00 RSSI:0x19) (,RPTEN)
2013.08.04 14:22:22.983 5: Triggering CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03 (3 changes)
2013.08.04 14:22:22.995 5: Notify loop for CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03 level: 0 %
2013.08.04 14:22:23.133 4: Connection closed for FHEMWEB:192.168.0.13:62493
2013.08.04 14:22:23.137 4: HTTP FHEMWEB:192.168.0.13:62511 GET /fhem/pgm2/fhemweb_slider.js
2013.08.04 14:22:23.142 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/pgm2/fhemweb_colorpicker.js
2013.08.04 14:22:23.147 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem/pgm2/fhemweb.js
2013.08.04 14:22:23.153 4: HTTP FHEMWEB:192.168.0.13:62513 GET /fhem/pgm2/svg.js
2013.08.04 14:22:23.158 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem/pgm2/style.css
2013.08.04 14:22:23.164 4: Connection accepted from FHEMWEB:192.168.0.13:62515
2013.08.04 14:22:23.170 4: HTTP FHEMWEB:192.168.0.13:62511 GET /fhem/pgm2/fhemweb_time.js
2013.08.04 14:22:23.175 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/images/default/icoHaus.png
2013.08.04 14:22:23.180 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem/images/default/icoEverything.png
2013.08.04 14:22:23.185 4: HTTP FHEMWEB:192.168.0.13:62513 GET /fhem/images/default/off.png
2013.08.04 14:22:23.190 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem/images/default/set_off.png
2013.08.04 14:22:23.194 4: HTTP FHEMWEB:192.168.0.13:62515 GET /fhem/pgm2/fhemweb_svg.js
2013.08.04 14:22:23.201 4: HTTP FHEMWEB:192.168.0.13:62511 GET /fhem/images/default/on.png
2013.08.04 14:22:23.219 4: HTTP FHEMWEB:192.168.0.13:62511 GET /fhem/icons/fhemicon.png
2013.08.04 14:22:23.353 4: HTTP FHEMWEB:192.168.0.13:62511 GET /fhem?room=CUL_HM&XHR=1&inform=1&timestamp=1375618942440
2013.08.04 14:22:23.955 4: HTTP FHEMWEB:192.168.0.13:62515 GET /fhem?cmd.CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04=set%20CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04%20off&room=CUL_HM
2013.08.04 14:22:23.959 5: Cmd: >set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04 off<
2013.08.04 14:22:23.966 5: Triggering CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04 (1 changes)
2013.08.04 14:22:23.982 5: Notify loop for CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04 set_off
2013.08.04 14:22:24.094 2: CUL_HM set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04 off
2013.08.04 14:22:24.098 1: HMLAN_Send:  HML S:S49474DA1 stat:  00 t:00000000 d:01 r:49474DA1 m:61 B011 1EA224 20F44F 0204000000
2013.08.04 14:22:24.104 1: SND L:0E N:61 F:B0 CMD:11 SRC:1EA224 DST:CUL_HM_HM_LC_SW4_WM_20F44F 0204000000 (SET CHANNEL:0x04 VALUE:0x00 RAMPTIME:0x0000) (,BURST,BIDI,RPTEN)
2013.08.04 14:22:24.116 4: HTTP FHEMWEB:192.168.0.13:62515 GET /fhem?room=CUL_HM
2013.08.04 14:22:24.809 4: /fhem?room=CUL_HM / RL: 1778 / text/html; charset=UTF-8 / Content-Encoding: gzip
2013.08.04 14:22:24.817 1: HMLAN_Parse: HML R:R49474DA1 stat:0201 t:0E8535D9 d:FF r:FFEC     m:61 8002 20F44F 1EA224 0104000018
2013.08.04 14:22:24.820 5: HML dispatch A0E61800220F44F1EA2240104000018::-20:HML
2013.08.04 14:22:24.826 1: RCV L:0E N:61 F:80 CMD:02 SRC:CUL_HM_HM_LC_SW4_WM_20F44F DST:1EA224 0104000018 (ACK_STATUS CHANNEL:0x04 STATUS:0x00 UP:0x00 DOWN:0x00 LOWBAT:0x00 RSSI:0x18) (,RPTEN)
2013.08.04 14:22:24.838 5: Triggering CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04 (3 changes)
2013.08.04 14:22:24.850 5: Notify loop for CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04 level: 0 %
2013.08.04 14:22:24.987 4: Connection closed for FHEMWEB:192.168.0.13:62511
2013.08.04 14:22:24.991 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/pgm2/fhemweb_slider.js
2013.08.04 14:22:24.997 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem/pgm2/fhemweb_colorpicker.js
2013.08.04 14:22:25.002 4: HTTP FHEMWEB:192.168.0.13:62513 GET /fhem/pgm2/fhemweb.js
2013.08.04 14:22:25.007 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem/pgm2/svg.js
2013.08.04 14:22:25.014 4: Connection accepted from FHEMWEB:192.168.0.13:62517
2013.08.04 14:22:25.017 4: HTTP FHEMWEB:192.168.0.13:62515 GET /fhem/pgm2/style.css
2013.08.04 14:22:25.025 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/pgm2/fhemweb_time.js
2013.08.04 14:22:25.030 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem/images/default/icoHaus.png
2013.08.04 14:22:25.035 4: HTTP FHEMWEB:192.168.0.13:62513 GET /fhem/images/default/icoEverything.png
2013.08.04 14:22:25.041 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem/images/default/off.png
2013.08.04 14:22:25.046 4: HTTP FHEMWEB:192.168.0.13:62517 GET /fhem/pgm2/fhemweb_svg.js
2013.08.04 14:22:25.053 4: HTTP FHEMWEB:192.168.0.13:62515 GET /fhem/images/default/set_off.png
2013.08.04 14:22:25.071 4: HTTP FHEMWEB:192.168.0.13:62515 GET /fhem/icons/fhemicon.png
2013.08.04 14:22:25.211 4: HTTP FHEMWEB:192.168.0.13:62515 GET /fhem?room=CUL_HM&XHR=1&inform=1&timestamp=1375618944297
2013.08.04 14:22:25.994 4: HTTP FHEMWEB:192.168.0.13:62517 GET /fhem?cmd.CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01=set%20CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01%20statusRequest&room=CUL_HM
2013.08.04 14:22:25.999 5: Cmd: >set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 statusRequest<
2013.08.04 14:22:26.005 2: CUL_HM set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 statusRequest
2013.08.04 14:22:26.008 1: HMLAN_Send:  HML S:+20F44F,00,01,
2013.08.04 14:22:26.010 1: HMLAN_Send:  HML S:S49475516 stat:  00 t:00000000 d:01 r:49475516 m:62 B001 1EA224 20F44F 010E
2013.08.04 14:22:26.016 1: SND L:0B N:62 F:B0 CMD:01 SRC:1EA224 DST:CUL_HM_HM_LC_SW4_WM_20F44F 010E (CONFIG_STATUS_REQUEST CHANNEL:0x01) (,BURST,BIDI,RPTEN)
2013.08.04 14:22:26.027 4: HTTP FHEMWEB:192.168.0.13:62517 GET /fhem?room=CUL_HM
2013.08.04 14:22:26.758 4: /fhem?room=CUL_HM / RL: 1760 / text/html; charset=UTF-8 / Content-Encoding: gzip
2013.08.04 14:22:26.763 1: HMLAN_Parse: HML R:E20F44F   stat:0000 t:0E853D4D d:FF r:FFEC     m:62 A410 20F44F 1EA224 0601000018
2013.08.04 14:22:26.766 5: HML dispatch A0E62A41020F44F1EA2240601000018::-20:HML
2013.08.04 14:22:26.771 1: RCV L:0E N:62 F:A4 CMD:10 SRC:CUL_HM_HM_LC_SW4_WM_20F44F DST:1EA224 0601000018 (INFO_ACTUATOR_STATUS RSSI:0x18 CHANNEL:0x01 STATUS:0x00 UNKNOWN:0x00) (,CFG,BIDI,RPTEN)
2013.08.04 14:22:26.785 1: SND L:0A N:62 F:80 CMD:02 SRC:1EA224 DST:CUL_HM_HM_LC_SW4_WM_20F44F 00 (ACK) (,RPTEN)
2013.08.04 14:22:26.791 5: Triggering CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 (3 changes)
2013.08.04 14:22:26.802 5: Notify loop for CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 level: 0 %
2013.08.04 14:22:26.938 1: HMLAN_Parse: HML R:R49475516 stat:0201 t:0E853D52 d:FF r:FFEC     m:62 A410 20F44F 1EA224 0601000018
2013.08.04 14:22:26.941 5: HML dispatch A0E62A41020F44F1EA2240601000018::-20:HML
2013.08.04 14:22:26.945 4: CUL_HM CUL_HM_HM_LC_SW4_WM_20F44F dup: dont process
2013.08.04 14:22:26.950 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/pgm2/fhemweb_slider.js
2013.08.04 14:22:26.955 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem/pgm2/fhemweb_colorpicker.js
2013.08.04 14:22:26.961 4: HTTP FHEMWEB:192.168.0.13:62513 GET /fhem/pgm2/fhemweb.js
2013.08.04 14:22:26.966 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem/pgm2/svg.js
2013.08.04 14:22:26.972 4: Connection accepted from FHEMWEB:192.168.0.13:62519
2013.08.04 14:22:26.975 4: HTTP FHEMWEB:192.168.0.13:62517 GET /fhem/pgm2/style.css
2013.08.04 14:22:26.981 4: Connection closed for FHEMWEB:192.168.0.13:62515
2013.08.04 14:22:26.991 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/pgm2/fhemweb_time.js
2013.08.04 14:22:26.995 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem/images/default/icoHaus.png
2013.08.04 14:22:26.000 4: HTTP FHEMWEB:192.168.0.13:62513 GET /fhem/images/default/icoEverything.png
2013.08.04 14:22:27.005 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem/images/default/off.png
2013.08.04 14:22:27.011 4: HTTP FHEMWEB:192.168.0.13:62519 GET /fhem/pgm2/fhemweb_svg.js
2013.08.04 14:22:27.067 4: HTTP FHEMWEB:192.168.0.13:62519 GET /fhem/icons/fhemicon.png
2013.08.04 14:22:27.171 4: HTTP FHEMWEB:192.168.0.13:62519 GET /fhem?room=CUL_HM&XHR=1&inform=1&timestamp=1375618946255
2013.08.04 14:22:28.306 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem?cmd.CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02=set%20CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02%20statusRequest&room=CUL_HM
2013.08.04 14:22:28.311 5: Cmd: >set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02 statusRequest<
2013.08.04 14:22:28.316 2: CUL_HM set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02 statusRequest
2013.08.04 14:22:28.319 1: HMLAN_Send:  HML S:+20F44F,00,01,
2013.08.04 14:22:28.322 1: HMLAN_Send:  HML S:S49475E1E stat:  00 t:00000000 d:01 r:49475E1E m:63 B001 1EA224 20F44F 020E
2013.08.04 14:22:28.327 1: SND L:0B N:63 F:B0 CMD:01 SRC:1EA224 DST:CUL_HM_HM_LC_SW4_WM_20F44F 020E (CONFIG_STATUS_REQUEST CHANNEL:0x02) (,BURST,BIDI,RPTEN)
2013.08.04 14:22:28.344 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem?room=CUL_HM
2013.08.04 14:22:29.066 4: /fhem?room=CUL_HM / RL: 1760 / text/html; charset=UTF-8 / Content-Encoding: gzip
2013.08.04 14:22:29.072 1: HMLAN_Parse: HML R:E20F44F   stat:0000 t:0E854656 d:FF r:FFEC     m:63 A410 20F44F 1EA224 0602000018
2013.08.04 14:22:29.075 5: HML dispatch A0E63A41020F44F1EA2240602000018::-20:HML
2013.08.04 14:22:29.081 1: RCV L:0E N:63 F:A4 CMD:10 SRC:CUL_HM_HM_LC_SW4_WM_20F44F DST:1EA224 0602000018 (INFO_ACTUATOR_STATUS RSSI:0x18 CHANNEL:0x02 STATUS:0x00 UNKNOWN:0x00) (,CFG,BIDI,RPTEN)
2013.08.04 14:22:29.091 1: SND L:0A N:63 F:80 CMD:02 SRC:1EA224 DST:CUL_HM_HM_LC_SW4_WM_20F44F 00 (ACK) (,RPTEN)
2013.08.04 14:22:29.097 5: Triggering CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02 (3 changes)
2013.08.04 14:22:29.109 5: Notify loop for CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02 level: 0 %
2013.08.04 14:22:29.241 1: HMLAN_Parse: HML R:R49475E1E stat:0201 t:0E85465B d:FF r:FFEC     m:63 A410 20F44F 1EA224 0602000018
2013.08.04 14:22:29.243 5: HML dispatch A0E63A41020F44F1EA2240602000018::-20:HML
2013.08.04 14:22:29.249 4: CUL_HM CUL_HM_HM_LC_SW4_WM_20F44F dup: dont process
2013.08.04 14:22:29.256 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/pgm2/fhemweb_colorpicker.js
2013.08.04 14:22:29.262 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem/pgm2/fhemweb.js
2013.08.04 14:22:29.267 4: HTTP FHEMWEB:192.168.0.13:62513 GET /fhem/pgm2/svg.js
2013.08.04 14:22:29.273 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem/pgm2/style.css
2013.08.04 14:22:29.279 4: Connection accepted from FHEMWEB:192.168.0.13:62521
2013.08.04 14:22:29.282 4: HTTP FHEMWEB:192.168.0.13:62517 GET /fhem/pgm2/fhemweb_slider.js
2013.08.04 14:22:29.287 4: Connection closed for FHEMWEB:192.168.0.13:62519
2013.08.04 14:22:29.293 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/pgm2/fhemweb_time.js
2013.08.04 14:22:29.297 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem/images/default/icoHaus.png
2013.08.04 14:22:29.302 4: HTTP FHEMWEB:192.168.0.13:62513 GET /fhem/images/default/icoEverything.png
2013.08.04 14:22:29.307 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem/images/default/off.png
2013.08.04 14:22:29.312 4: HTTP FHEMWEB:192.168.0.13:62521 GET /fhem/pgm2/fhemweb_svg.js
2013.08.04 14:22:29.369 4: HTTP FHEMWEB:192.168.0.13:62521 GET /fhem/icons/fhemicon.png
2013.08.04 14:22:29.474 4: HTTP FHEMWEB:192.168.0.13:62521 GET /fhem?room=CUL_HM&XHR=1&inform=1&timestamp=1375618948557
2013.08.04 14:22:29.887 1: HMLAN_Send:  HML I:K
2013.08.04 14:22:29.894 1: HMLAN_Parse: HML V:03C1 sNo:JEQ0706016 d:1EA224 O:1EA224 t:0E854A7C IDcnt:0001
2013.08.04 14:22:30.266 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem?cmd.CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03=set%20CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03%20statusRequest&room=CUL_HM
2013.08.04 14:22:30.271 5: Cmd: >set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03 statusRequest<
2013.08.04 14:22:30.277 2: CUL_HM set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03 statusRequest
2013.08.04 14:22:30.280 1: HMLAN_Send:  HML S:+20F44F,00,01,
2013.08.04 14:22:30.282 1: HMLAN_Send:  HML S:S494765C6 stat:  00 t:00000000 d:01 r:494765C6 m:64 B001 1EA224 20F44F 030E
2013.08.04 14:22:30.288 1: SND L:0B N:64 F:B0 CMD:01 SRC:1EA224 DST:CUL_HM_HM_LC_SW4_WM_20F44F 030E (CONFIG_STATUS_REQUEST CHANNEL:0x03) (,BURST,BIDI,RPTEN)
2013.08.04 14:22:30.300 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem?room=CUL_HM
2013.08.04 14:22:30.995 4: /fhem?room=CUL_HM / RL: 1760 / text/html; charset=UTF-8 / Content-Encoding: gzip
2013.08.04 14:22:31.004 1: HMLAN_Parse: HML R:E20F44F   stat:0000 t:0E854DFE d:FF r:FFEC     m:64 A410 20F44F 1EA224 0603000018
2013.08.04 14:22:31.007 5: HML dispatch A0E64A41020F44F1EA2240603000018::-20:HML
2013.08.04 14:22:31.013 1: RCV L:0E N:64 F:A4 CMD:10 SRC:CUL_HM_HM_LC_SW4_WM_20F44F DST:1EA224 0603000018 (INFO_ACTUATOR_STATUS RSSI:0x18 CHANNEL:0x03 STATUS:0x00 UNKNOWN:0x00) (,CFG,BIDI,RPTEN)
2013.08.04 14:22:31.023 1: SND L:0A N:64 F:80 CMD:02 SRC:1EA224 DST:CUL_HM_HM_LC_SW4_WM_20F44F 00 (ACK) (,RPTEN)
2013.08.04 14:22:31.030 5: Triggering CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03 (3 changes)
2013.08.04 14:22:31.041 5: Notify loop for CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03 level: 0 %
2013.08.04 14:22:31.171 1: HMLAN_Parse: HML R:R494765C6 stat:0201 t:0E854E03 d:FF r:FFEC     m:64 A410 20F44F 1EA224 0603000018
2013.08.04 14:22:31.174 5: HML dispatch A0E64A41020F44F1EA2240603000018::-20:HML
2013.08.04 14:22:31.178 4: CUL_HM CUL_HM_HM_LC_SW4_WM_20F44F dup: dont process
2013.08.04 14:22:31.184 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/pgm2/fhemweb_colorpicker.js
2013.08.04 14:22:31.189 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem/pgm2/fhemweb.js
2013.08.04 14:22:31.194 4: HTTP FHEMWEB:192.168.0.13:62513 GET /fhem/pgm2/svg.js
2013.08.04 14:22:31.199 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem/pgm2/style.css
2013.08.04 14:22:31.206 4: Connection accepted from FHEMWEB:192.168.0.13:62523
2013.08.04 14:22:31.208 4: HTTP FHEMWEB:192.168.0.13:62517 GET /fhem/pgm2/fhemweb_slider.js
2013.08.04 14:22:31.214 4: Connection closed for FHEMWEB:192.168.0.13:62521
2013.08.04 14:22:31.219 4: HTTP FHEMWEB:192.168.0.13:62523 GET /fhem/pgm2/fhemweb_svg.js
2013.08.04 14:22:31.223 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/pgm2/fhemweb_time.js
2013.08.04 14:22:31.229 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem/images/default/icoHaus.png
2013.08.04 14:22:31.234 4: HTTP FHEMWEB:192.168.0.13:62513 GET /fhem/images/default/icoEverything.png
2013.08.04 14:22:31.238 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem/images/default/off.png
2013.08.04 14:22:31.250 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem/icons/fhemicon.png
2013.08.04 14:22:31.392 4: HTTP FHEMWEB:192.168.0.13:62507 GET /fhem?room=CUL_HM&XHR=1&inform=1&timestamp=1375618950477
2013.08.04 14:22:32.586 4: HTTP FHEMWEB:192.168.0.13:62513 GET /fhem?cmd.CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04=set%20CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04%20statusRequest&room=CUL_HM
2013.08.04 14:22:32.590 5: Cmd: >set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04 statusRequest<
2013.08.04 14:22:32.595 2: CUL_HM set CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04 statusRequest
2013.08.04 14:22:32.598 1: HMLAN_Send:  HML S:+20F44F,00,01,
2013.08.04 14:22:32.599 1: HMLAN_Send:  HML S:S49476ED4 stat:  00 t:00000000 d:01 r:49476ED4 m:65 B001 1EA224 20F44F 040E
2013.08.04 14:22:32.605 1: SND L:0B N:65 F:B0 CMD:01 SRC:1EA224 DST:CUL_HM_HM_LC_SW4_WM_20F44F 040E (CONFIG_STATUS_REQUEST CHANNEL:0x04) (,BURST,BIDI,RPTEN)
2013.08.04 14:22:32.621 4: HTTP FHEMWEB:192.168.0.13:62513 GET /fhem?room=CUL_HM
2013.08.04 14:22:33.241 4: /fhem?room=CUL_HM / RL: 1760 / text/html; charset=UTF-8 / Content-Encoding: gzip
2013.08.04 14:22:33.247 1: HMLAN_Parse: HML R:E20F44F   stat:0000 t:0E85570B d:FF r:FFEC     m:65 A410 20F44F 1EA224 0604000018
2013.08.04 14:22:33.250 5: HML dispatch A0E65A41020F44F1EA2240604000018::-20:HML
2013.08.04 14:22:33.256 1: RCV L:0E N:65 F:A4 CMD:10 SRC:CUL_HM_HM_LC_SW4_WM_20F44F DST:1EA224 0604000018 (INFO_ACTUATOR_STATUS RSSI:0x18 CHANNEL:0x04 STATUS:0x00 UNKNOWN:0x00) (,CFG,BIDI,RPTEN)
2013.08.04 14:22:33.267 1: SND L:0A N:65 F:80 CMD:02 SRC:1EA224 DST:CUL_HM_HM_LC_SW4_WM_20F44F 00 (ACK) (,RPTEN)
2013.08.04 14:22:33.273 5: Triggering CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04 (3 changes)
2013.08.04 14:22:33.285 5: Notify loop for CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04 level: 0 %
2013.08.04 14:22:33.421 1: HMLAN_Parse: HML R:R49476ED4 stat:0201 t:0E855710 d:FF r:FFEC     m:65 A410 20F44F 1EA224 0604000018
2013.08.04 14:22:33.423 5: HML dispatch A0E65A41020F44F1EA2240604000018::-20:HML
2013.08.04 14:22:33.428 4: CUL_HM CUL_HM_HM_LC_SW4_WM_20F44F dup: dont process
2013.08.04 14:22:33.434 4: HTTP FHEMWEB:192.168.0.13:62523 GET /fhem/pgm2/fhemweb_colorpicker.js
2013.08.04 14:22:33.439 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/pgm2/fhemweb.js
2013.08.04 14:22:33.445 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem/pgm2/svg.js
2013.08.04 14:22:33.451 4: HTTP FHEMWEB:192.168.0.13:62513 GET /fhem/pgm2/style.css
2013.08.04 14:22:33.458 4: Connection closed for FHEMWEB:192.168.0.13:62507
2013.08.04 14:22:33.461 4: Connection accepted from FHEMWEB:192.168.0.13:62525
2013.08.04 14:22:33.465 4: HTTP FHEMWEB:192.168.0.13:62517 GET /fhem/pgm2/fhemweb_slider.js
2013.08.04 14:22:33.472 4: HTTP FHEMWEB:192.168.0.13:62523 GET /fhem/pgm2/fhemweb_time.js
2013.08.04 14:22:33.477 4: HTTP FHEMWEB:192.168.0.13:62525 GET /fhem/pgm2/fhemweb_svg.js
2013.08.04 14:22:33.482 4: HTTP FHEMWEB:192.168.0.13:62494 GET /fhem/images/default/icoHaus.png
2013.08.04 14:22:33.487 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem/images/default/icoEverything.png
2013.08.04 14:22:33.501 4: HTTP FHEMWEB:192.168.0.13:62513 GET /fhem/images/default/off.png
2013.08.04 14:22:33.508 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem/icons/fhemicon.png
2013.08.04 14:22:33.643 4: HTTP FHEMWEB:192.168.0.13:62502 GET /fhem?room=CUL_HM&XHR=1&inform=1&timestamp=1375618952727
2013.08.04 14:22:54.897 1: HMLAN_Send:  HML I:K
2013.08.04 14:22:54.904 1: HMLAN_Parse: HML V:03C1 sNo:JEQ0706016 d:1EA224 O:1EA224 t:0E85AC32 IDcnt:0001
2013.08.04 14:23:20.029 1: HMLAN_Send:  HML I:K
2013.08.04 14:23:20.038 1: HMLAN_Parse: HML V:03C1 sNo:JEQ0706016 d:1EA224 O:1EA224 t:0E860E62 IDcnt:0001
2013.08.04 14:23:32.453 5: exec at command ipsw_1
IPSS1:  2<
2013.08.04 14:23:45.040 1: HMLAN_Send:  HML I:K
2013.08.04 14:23:45.053 1: HMLAN_Parse: HML V:03C1 sNo:JEQ0706016 d:1EA224 O:1EA224 t:0E86701B IDcnt:0001
2013.08.04 14:24:10.053 1: HMLAN_Send:  HML I:K
2013.08.04 14:24:10.074 1: HMLAN_Parse: HML V:03C1 sNo:JEQ0706016 d:1EA224 O:1EA224 t:0E86D1D0 IDcnt:0001
2013.08.04 14:24:14.093 5: CUL/RAW: /K718392580E
2013.08.04 14:24:35.061 1: HMLAN_Send:  HML I:K
2013.08.04 14:24:35.069 1: HMLAN_Parse: HML V:03C1 sNo:JEQ0706016 d:1EA224 O:1EA224 t:0E873383 IDcnt:0001
2013.08.04 14:25:00.071 1: HMLAN_Send:  HML I:K
2013.08.04 14:25:00.078 1: HMLAN_Parse: HML V:03C1 sNo:JEQ0706016 d:1EA224 O:1EA224 t:0E879539 IDcnt:0001
Beitrag von: martinp876 am 04 August 2013, 15:09:21
gut,dass es funktioniert.
Dein HMLAN sendet einen besonderen status. Diesen halte ich für HiLoad - jedenfalls verhält es sich so bei mir. Das ist die vorstufe, in der sich das HMLAN "abschaltet". Nach einigen Minuten wird es wieder operativ.
1) warum es bei dir zu diesem Zeitpunkt kommt, kann ich nicht sagen
2) es ist nur ein Merker - alles funktioniert noch einwandfrei.
3) es könnte sein, dass vorher auch die "abschaltstufe" erreicht wurde. Dann muss man warten. FHEM (HMLAN) empfängt noch aber sendet nicht mehr.
=> beobachte die Readings in HMLAN 'cond'
wenn es häufiger auftritt können wir versuchen die Bedingungen zu ergründen (wirklich Klar ist es nicht, wenn es auftritt)
gruss Martin
Beitrag von: Stefan M. am 10 August 2013, 14:46:31
Hallo zusammen
könnte mir bitte jemand erklären was das bedeutet und was ich dagegen tun kann ?
configCheck done:
    CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01:RegL_03:self01
    CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02:RegL_03:self02
    CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03:RegL_03:self03
    CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04:RegL_03:self04
    CUL_HM_HM_SEC_RHS_1F194F:RegL_00:
    CUL_HM_HM_LC_SW4_WM_20F44F_Sw_01 - found:20F44F01,20F44F01, expected:20F44F01,
    CUL_HM_HM_LC_SW4_WM_20F44F_Sw_02 - found:20F44F02,20F44F02, expected:20F44F02,
    CUL_HM_HM_LC_SW4_WM_20F44F_Sw_03 - found:20F44F03,20F44F03, expected:20F44F03,
    CUL_HM_HM_LC_SW4_WM_20F44F_Sw_04 - found:20F44F04,20F44F04, expected:20F44F04,
incomplete list
 empty list
 peer not verified
Beitrag von: martinp876 am 10 August 2013, 18:27:35
beim SW4 fehlt die Terminierung der RegL 3. Es sollte mit einem getConfig gehoben werden. Falls nicht, ein List schicken.
da ist ein Peer mehrfach enthalten. Hast du dies editiert? Ein getConfig sollte es lösen. Falls nicht, siehe oben - incl roh-messages vom getConfig
empty list:
hier wurden keine Register gelesen.
Eigentlich sollte nach erfolgreichem getConfig alles ohne fehler kommen.
Next support in 2 weeks :-(
Gruss Martin
Beitrag von: fiedel am 13 September 2013, 09:50:53
ich möchte mich gern mit 2 kleinen Fragen hier anhängen:
1.: Was bewirken die orangenen Attribute aus dem ersten Post? Ich habe keine Dokumentation dazu gefunden und würde es gern verstehen.
attr HML loglevel 1
attr HML room HMLan
attr HML wdTimer 25
define HMI HMinfo
attr HMI room HMLan
2.: Aktuell habe ich einen HM-CFG-USB Adapter über den ich einen KFM100S empfange und ein HM-LC-SW4-PCB steuere. Wenn ich jetzt den HM-LC-SW4-PCB stromlos mache, bekomme ich auch keine Daten mehr vom KFM100S. Schalte ich ihn wieder ein, kommen auch die KFM100S- Daten wieder. Muss ich den HM-LC-SW4-PCB immer unpairen, wenn ich ihn abschalten möchte? Das Gerät wird bei mir nur den Sommer über zur Bewässerung genutzt.
Vielen Dank sagt
Frank
Edit:
Und noch eine dritte Frage:
Der KFM100S bringt beim Config Check:
configCheck done:
    Sens_L_Zisterne:RegL_00:
    Sens_L_Zisterne:RegL_01:
 incomplete list
 empty list
    empty: Sens_L_Zisterne
 peer not verified
Das ist vermutlich normal, weil der KFM100S ja kein "richtiges" HM- Gerät ist?
Beitrag von: martinp876 am 15 September 2013, 14:01:05
hi,
1) ist beides im commandref beschrieben, leider nur in Enslisch
wdTimer
trigger zeit des HMLAN, nur für experten.
sumERROR
man kann bestimmte Readings und deren Werte als "error" definieren und ggf. Zählen lassed. HMInfo zaehlt die "Fehler" und generiert ein Reading. So erhält man eine Übersicht und kann auch einen "sammeltrigger" generieren. Das spart processing Zeit und könnte die Übersicht erhöhen - glaube ich. Beispiele siehe Commandref
2) den KFM100 kenne ich nicht. Kannst du einmal ein paar logs schicken, wenn beide mit einander reden? Roh-messages mit
auch einmal wenn der SW4 aus ist.
den SW4 musst du nicht unpairen, bestenfalls den KFM. Evtl. kann man an den logs sehen, was der KFM loswreden will.
kannst du auch ein getConfig beim KFM100 machen und loggen? Dann können wir darüber nachdenken
Gruss Martin
