Hi
I used to make calls to **9 from my fritzbox 7490 in some events.
Unfortunately after a fresh install this call doesn´t work anymore.
To be clear, the command is "set FritzBox ring 9"
During the start of FHEM I get:
PERL WARNING: Use of uninitialized value $val[0] in string eq at ./FHEM/72_FRITZBOX.pm line 1825.
but that doesn´t seem a big deal to me.
The logging doesn´t give me any information even with verbose = 5
I can see the debug info, but that is to complex for me.
In fhem.cfg I have
attr FritzBox INTERVAL 300
attr FritzBox boxUser fritz8145
What can be wrong?
Thanks
I changed this post because it works again. I updated again and did a reboot. Something has fixed the issue.
