Ich bekomme regelmäßig alle 5 min diese Meldung in den logfile:
Can't use string ("landevice0") as an ARRAY ref while "strict refs" in use at ./FHEM/72_FRITZBOX.pm line 4327.
2025.07.23 20:24:18 1: [fritzbox | 7390 | 84.06.88 | Readout_Aborted.7794] - ERROR:Error: Timeout when reading Fritz!Box data. 144 | BlockingStart
Ich kann damit nichts anfangen. Wer kann helfen?
Danke im Voraus!
Andi
Hallo Andi,
welches FritzOS hat Deine Box?
Grüße Jörg
FRITZ!OS: 06.88
Hier noch weitere Infos:
AGENTTMOUT 50
APICHECKED 1
APICHECK_RET_CODES Ok
DEBUGLOG OFF
DEF 192.168.178.1
FUUID 5c7fed65-f33f-4a30-be6c-1bd5a1277d0a693e
HOST 192.168.178.1
INTERVAL 300
IPv6 -1
LUADATA 1
LUAQUERY 1
MODEL FRITZ!Box Fon WLAN 7390
NAME fritzbox
NR 110
NTFY_ORDER 50-fritzbox
SECPORT 49443
SID_RENEW_CNT 23
SID_RENEW_ERR_CNT 0
STATE Error: Timeout when reading Fritz!Box data. 144 | BlockingStart
STATUS active
TIMEOUT 55
TR064 1
TYPE FRITZBOX
UPNP -1
VERSION 08.10.00
WAN_ACCESS_TYPE DSL
WEBCONNECT 1
eventCount 49
LuaQueryCmd:
GSM_AcT:
AttrVal 1
active 0
cmd gsm:settings/AcT
GSM_NetworkState:
AttrVal 1
active 1
cmd gsm:settings/NetworkState
GSM_RSSI:
AttrVal 1
active 1
cmd gsm:settings/RSSI
TodayBytesReceivedHigh:
AttrVal 1
active 1
cmd inetstat:status/Today/BytesReceivedHigh
TodayBytesReceivedLow:
AttrVal 1
active 1
cmd inetstat:status/Today/BytesReceivedLow
TodayBytesSentHigh:
AttrVal 1
active 1
cmd inetstat:status/Today/BytesSentHigh
TodayBytesSentLow:
AttrVal 1
active 1
cmd inetstat:status/Today/BytesSentLow
UMTS_enabled:
AttrVal 1
active 1
cmd umts:settings/enabled
alarmClock:
AttrVal 1
active 1
cmd telcfg:settings/AlarmClock/list(Name,Active,Time,Number,Weekdays)
box_DNS_over_TLS:
AttrVal 1
active 0
cmd dnscfg:settings/dns_over_tls_enabled
box_cpuTemp:
AttrVal 1
active 1
cmd power:status/act_temperature
box_dect:
AttrVal 1
active 1
cmd dect:settings/enabled
box_fwUpdate:
AttrVal 1
active 1
cmd updatecheck:status/update_available_hint
box_fwVersion:
AttrVal 1
active 0
cmd logic:status/nspver
box_fwVersion_neu:
AttrVal 1
active 1
cmd uimodlogic:status/nspver
box_guestWlan:
AttrVal 1
active 1
cmd wlan:settings/guest_ap_enabled
box_guestWlanRemain:
AttrVal 1
active 1
cmd wlan:settings/guest_time_remain
box_ipv4_DHCP_LAN_DNS:
AttrVal 1
active 1
cmd dnscfg:settings/ipv4_dhcpserver_lan_dns
box_ipv6_1st_DNS:
AttrVal 1
active 1
cmd ipv6:settings/first_dns
box_ipv6_2nd_DNS:
AttrVal 1
active 1
cmd ipv6:settings/second_dns
box_ipv6_Enabled:
AttrVal 1
active 1
cmd ipv6:settings/enabled
box_ipv6_Extern:
AttrVal 1
active 1
cmd ipv6:settings/ip
box_ipv6_Prefix:
AttrVal 1
active 0
cmd ipv6:settings/ip_prefix
box_ipv6_Uptime:
AttrVal 1
active 1
cmd ipv6:settings/uptime
box_ipv6_Valid:
AttrVal 1
active 1
cmd ipv6:settings/ip_valid
box_is_double_wlan:
AttrVal 1
active 1
cmd wlan:settings/feature_flags/DBDC
box_macFilter_active:
AttrVal 1
active 1
cmd wlan:settings/is_macfilter_active
box_moh:
AttrVal 1
active 1
cmd telcfg:settings/MOHType
box_stdDialPort:
AttrVal 1
active 1
cmd telcfg:settings/DialPort
box_tr064:
AttrVal 1
active 1
cmd tr064:settings/enabled
box_tr069:
AttrVal 1
active 1
cmd tr069:settings/enabled
box_upnp:
AttrVal 1
active 1
cmd box:settings/upnp_activated
box_upnpCtrl:
AttrVal 1
active 1
cmd box:settings/upnp_control_activated
box_uptimeHours:
AttrVal 1
active 1
cmd uimodlogic:status/uptime_hours
box_uptimeMinutes:
AttrVal 1
active 1
cmd uimodlogic:status/uptime_minutes
box_wlan_24GHz:
AttrVal 1
active 1
cmd wlan:settings/ap_enabled
box_wlan_5GHz:
AttrVal 1
active 1
cmd wlan:settings/ap_enabled_scnd
dectUser:
AttrVal 1
active 1
cmd telcfg:settings/Foncontrol/User/list(Id,Name,Intern,IntRingTone,AlarmRingTone0,RadioRingID,ImagePath,G722RingTone,G722RingToneName,NoRingTime,RingAllowed,NoRingTimeFlags,NoRingWithNightSetting)
diversity:
AttrVal 1
active 0
cmd telcfg:settings/Diversity/list(MSN,Active,Destination)
dslStatGlobalIn:
AttrVal 1
active 1
cmd dslstatglobal:status/in
dslStatGlobalOut:
AttrVal 1
active 1
cmd dslstatglobal:status/out
fonPort:
AttrVal 1
active 1
cmd telcfg:settings/MSN/Port/list(Name,MSN)
handset:
AttrVal 1
active 1
cmd dect:settings/Handset/list(User,Manufacturer,Model,FWVersion,Productname)
handsetCount:
AttrVal 1
active 1
cmd dect:settings/Handset/count
init:
AttrVal 1
active 0
lanDevice:
AttrVal 1
active 1
cmd landevice:settings/landevice/list(mac,ip,ethernet,ethernet_port,ethernetport,guest,name,active,online,wlan,speed,UID,static_dhcp)
lanDeviceNew:
AttrVal 1
active 1
cmd landevice:settings/landevice/list(mac,ip,ethernet,guest,name,friendly_name,active,online,wlan,speed,UID)
radio:
AttrVal 1
active 1
cmd configd:settings/WEBRADIO/list(Name)
ringGender:
AttrVal 1
active 0
cmd telcfg:settings/VoiceRingtoneGender
sip_info:
AttrVal 1
active 1
cmd sip:settings/sip/list(activated,displayname,connect)
tam:
AttrVal 1
active 1
cmd tam:settings/TAM/list(Name,Display,Active,NumNewMessages,NumOldMessages)
userProfil:
AttrVal 1
active 1
cmd user:settings/user/list(name,filter_profile_UID,this_month_time,today_time,type)
userProfilNew:
AttrVal 1
active 1
cmd user:settings/user/list(name,type)
userTicket:
AttrVal 1
active 1
cmd userticket:settings/ticket/list(id)
vpn_info:
AttrVal 1
active 1
cmd vpn:settings/connection/list(remote_ip,activated,name,state,access_type,connected_since)
wlanList:
AttrVal 1
active 1
cmd wlan:settings/wlanlist/list(mac,speed,speed_rx,rssi,is_guest,is_remote,is_repeater,is_ap)
wlanListNew:
AttrVal 1
active 1
cmd wlan:settings/wlanlist/list(mac,speed,rssi)
2025-07-23 20:02:25 box_fwVersion 84.06.88
2025-07-23 14:39:03 box_guestWlan on
2025-07-23 14:39:03 box_guestWlanRemain -1
2025-07-20 15:55:11 box_ipv6_Extern 2003:d1:97ff:38e4:c225:6ff:febb:d4d5
2025-07-20 15:55:11 box_ipv6_Prefix 2003:d1:9706:2000::
2025-07-23 14:39:03 box_macFilter_active off
2025-07-23 20:02:25 box_model FRITZ!Box Fon WLAN 7390 [avm]
2025-07-23 14:57:47 box_wan_AccessType 0
2025-07-23 14:39:03 box_wlan_2.4GHz on
2025-07-23 14:39:03 box_wlan_5GHz off
2025-07-23 14:39:03 retStat_SetGet_nonBlocking set guestWlan: off
2025-07-23 21:54:18 retStat_lastReadout Error: Timeout when reading Fritz!Box data. 144 | BlockingStart
2025-07-21 17:04:02 retStat_lastReadoutError cannot connect due to network error 500
2025-07-23 20:02:25 retStat_processReadout 0.00 s
2025-07-23 21:54:18 state Error: Timeout when reading Fritz!Box data. 144 | BlockingStart
fhem:
LOCAL 0
definedHost 192.168.178.1
fwVersion 688
fwVersionStr 06.88
is_double_wlan -1
sid 392df2b4f36ede65
sidErrCount 0
sidNewCount 1
sidTime 1753293740.12608
helper:
FhemLog3Std 0
TimerCmd fritzbox.Cmd
TimerReadout fritzbox.Readout
debugLog fritzbox_debugLog
logDebug
timerInActive 0
boxUser fhem@a9s.de
comment Wenn fritzbox offline, dann
das Attribut fritzboxIP setzen
trotz Fehlermeldung funktionierts dann
room 3.1_Kommunikation,9.1_System
Hallo Andi,
ich bin erst nächste Woche aus dem Urlaub zurück. Dann kann ich mir das ansehen.
Grüße Jörg
