Hallo alle,
Ich habe ein Qubino (Goap) ZMNKIDx OnOff Thermostat 2 über ein Aeotec Z-Stick Gen5+, und vielmals diese Fehlermeldung.
Ich kenne https://forum.fhem.de/index.php?topic=79659.0, und verstehe aber nicht wie ich es reparieren kann.
Es handelt sich um
define BadkIRPanelen ZWave dfbd3e8e 25
attr BadkIRPanelen DbLogInclude temperature,power,desired-temp,setpointTemp
attr BadkIRPanelen classes ZWAVEPLUS_INFO ASSOCIATION ASSOCIATION_GRP_INFO TRANSPORT_SERVICE VERSION MANUFACTURER_SPECIFIC DEVICE_RESET_LOCALLY THERMOSTAT_MODE THERMOSTAT_SETPOINT THERMOSTAT_OPERATING_STATE SENSOR_MULTILEVEL METER ALARM POWERLEVEL CONFIGURATION SECURITY_S2 SUPERVISION
attr BadkIRPanelen event-on-change-reading state,temperature,desired-temp,setpointTemp
attr BadkIRPanelen group BadkWarmte
attr BadkIRPanelen noWakeupForApplicationUpdate 1
attr BadkIRPanelen room 03 Klimaat,20 Badkamer,Zwave
attr BadkIRPanelen stateFormat state<BR>temperature | thermostatOperatingState | transmit
attr BadkIRPanelen vclasses ALARM:8 ASSOCIATION:2 ASSOCIATION_GRP_INFO:3 CONFIGURATION:1 DEVICE_RESET_LOCALLY:1 MANUFACTURER_SPECIFIC:2 METER:4 POWERLEVEL:1 SECURITY_S2:1 SENSOR_MULTILEVEL:7 SUPERVISION:1 THERMOSTAT_MODE:3 THERMOSTAT_OPERATING_STATE:1 THERMOSTAT_SETPOINT:3 TRANSPORT_SERVICE:2 VERSION:2 ZWAVEPLUS_INFO:2
attr BadkIRPanelen verbose 4
# DEF dfbd3e8e 25
# FUUID 647c9485-f33f-0a13-5f37-6e8010cb67a2a411
# IODev ZWaveDongle
# LASTInputDev ZWaveDongle
# MSGCNT 6
# NAME BadkIRPanelen
# NR 241
# STATE desired-temp 10<BR>22.6 C | idle | OK
# TYPE ZWave
# ZWaveDongle_MSGCNT 6
# ZWaveDongle_RAWMSG 00040019063105012200e2
# ZWaveDongle_TIME 2025-07-27 13:40:48
# ZWaveSubDevice no
# cmdsPending 0
# eventCount 7
# homeId dfbd3e8e
# isWakeUp
# lastMsgSent 1753615648.28763
# nodeIdHex 19
# webCmd desired-temp
# .attraggr:
# .attreocr:
# state
# temperature
# desired-temp
# setpointTemp
# .attrminint:
# .vclasses:
# ALARM 8
# ASSOCIATION 2
# ASSOCIATION_GRP_INFO 3
# CONFIGURATION 1
# DEVICE_RESET_LOCALLY 1
# MANUFACTURER_SPECIFIC 2
# METER 4
# POWERLEVEL 1
# SECURITY_S2 1
# SENSOR_MULTILEVEL 7
# SUPERVISION 1
# THERMOSTAT_MODE 3
# THERMOSTAT_OPERATING_STATE 1
# THERMOSTAT_SETPOINT 3
# TRANSPORT_SERVICE 2
# VERSION 2
# ZWAVEPLUS_INFO 2
# Helper:
# DBLOG:
# temperature:
# LogDB:
# TIME 1753616448.20704
# VALUE 22.6
# READINGS:
# 2025-07-27 01:10:17 IODev ZWaveDongle
# 2025-07-26 23:17:22 SEND_DATA failed:00
# 2025-06-11 14:25:11 energy 1249.1 kWh
# 2025-07-08 10:33:12 model Qubino (Goap) ZMNKIDx OnOff Thermostat 2
# 2025-07-08 10:33:12 modelConfig qubino/ZMNKIDx.xml
# 2025-07-08 10:33:12 modelId 0159-0005-0054
# 2025-06-26 20:32:20 power 0 W
# 2025-07-08 10:32:51 powerlvl current 0 remain 0
# 2025-07-27 13:27:28 state desired-temp 10
# 2025-07-27 13:40:48 temperature 22.6 C
# 2025-06-11 14:32:05 thermostatOperatingState idle
# 2025-07-27 13:27:28 timeToAck 0.613
# 2025-07-27 13:27:28 transmit OK
# 2025-07-27 12:38:42 version Lib 3 Prot 6.09 App 21.0 HW 1 FWCounter 1 FW 21.0
# 2025-07-22 21:28:53 zwavePlusInfo version:01 role:AlwaysOnSlave node:Z-Wave+Node installerIcon:1200 userIcon:1200
setstate BadkIRPanelen desired-temp 10<BR>22.6 C | idle | OK
setstate BadkIRPanelen 2025-07-27 01:10:17 IODev ZWaveDongle
setstate BadkIRPanelen 2025-07-26 23:17:22 SEND_DATA failed:00
setstate BadkIRPanelen 2025-06-11 14:25:11 energy 1249.1 kWh
setstate BadkIRPanelen 2025-07-08 10:33:12 model Qubino (Goap) ZMNKIDx OnOff Thermostat 2
setstate BadkIRPanelen 2025-07-08 10:33:12 modelConfig qubino/ZMNKIDx.xml
setstate BadkIRPanelen 2025-07-08 10:33:12 modelId 0159-0005-0054
setstate BadkIRPanelen 2025-06-26 20:32:20 power 0 W
setstate BadkIRPanelen 2025-07-08 10:32:51 powerlvl current 0 remain 0
setstate BadkIRPanelen 2025-07-27 13:27:28 state desired-temp 10
setstate BadkIRPanelen 2025-07-27 13:40:48 temperature 22.6 C
setstate BadkIRPanelen 2025-06-11 14:32:05 thermostatOperatingState idle
setstate BadkIRPanelen 2025-07-27 13:27:28 timeToAck 0.613
setstate BadkIRPanelen 2025-07-27 13:27:28 transmit OK
setstate BadkIRPanelen 2025-07-27 12:38:42 version Lib 3 Prot 6.09 App 21.0 HW 1 FWCounter 1 FW 21.0
setstate BadkIRPanelen 2025-07-22 21:28:53 zwavePlusInfo version:01 role:AlwaysOnSlave node:Z-Wave+Node installerIcon:1200 userIcon:1200
und
define ZWaveDongle ZWDongle /dev/ttyACM1@115200
attr ZWaveDongle homeId dfbd3e8e
attr ZWaveDongle model ZWDongle
attr ZWaveDongle room Test,Zwave
attr ZWaveDongle verbose 0
# CallbackNr 0
# Clients :ZWave:
# DEF /dev/ttyACM1@115200
# DeviceName /dev/ttyACM1@115200
# FD 35
# FUUID 67e40548-f33f-b2bd-1762-912dffb4950dba30
# MaxSendRetries 3
# NAME ZWaveDongle
# NR 834
# PARTIAL
# RAWMSG 00040018063105012200eb
# ReadTime 1753619591.61276
# STATE Initialized
# SendRetries 0
# SendTime 1753618914.46594
# TYPE ZWDongle
# WaitForAck 0
# ZWaveDongle_MSGCNT 12261
# ZWaveDongle_TIME 2025-07-27 14:33:11
# devioNoSTATE 1
# eventCount 1
# homeId dfbd3e8e
# nodeIdHex 01
# nrNAck 0
# .attraggr:
# .attrminint:
# .clientArray:
# ZWave
# MatchList:
# 1:ZWave .*
# READINGS:
# 2025-07-27 01:10:17 caps Vers:1 Rev:1 ManufID:0086 ProductType:0001 ProductID:005a SERIAL_API_GET_INIT_DATA SERIAL_API_APPL_NODE_INFORMATION APPLICATION_COMMAND_HANDLER ZW_GET_CONTROLLER_CAPABILITIES SERIAL_API_SET_TIMEOUTS SERIAL_API_GET_CAPABILITIES SERIAL_API_SOFT_RESET UNKNOWN_09 ZW_SET_R_F_RECEIVE_MODE ZW_SET_SLEEP_MODE ZW_SEND_NODE_INFORMATION ZW_SEND_DATA ZW_SEND_DATA_MULTI ZW_GET_VERSION ZW_SEND_DATA_ABORT ZW_R_F_POWER_LEVEL_SET ZW_SEND_DATA_META ZW_GET_RANDOM MEMORY_GET_ID MEMORY_GET_BYTE MEMORY_PUT_BYTE MEMORY_GET_BUFFER MEMORY_PUT_BUFFER FLASH_AUTO_PROG_SET NVM_GET_ID NVM_EXT_READ_LONG_BUFFER NVM_EXT_WRITE_LONG_BUFFER NVM_EXT_READ_LONG_BYTE NVM_EXT_WRITE_LONG_BYTE ZW_GET_NODE_PROTOCOL_INFO ZW_SET_DEFAULT ZW_REPLICATION_COMMAND_COMPLETE ZW_REPLICATION_SEND_DATA ZW_ASSIGN_RETURN_ROUTE ZW_DELETE_RETURN_ROUTE ZW_REQUEST_NODE_NEIGHBOR_UPDATE ZW_APPLICATION_UPDATE ZW_ADD_NODE_TO_NETWORK ZW_REMOVE_NODE_FROM_NETWORK ZW_CREATE_NEW_PRIMARY ZW_CONTROLLER_CHANGE ZW_SET_LEARN_MODE ZW_ASSIGN_SUC_RETURN_ROUTE ZW_REQUEST_NETWORK_UPDATE ZW_SET_SUC_NODE_ID ZW_DELETE_SUC_RETURN_ROUTE ZW_GET_SUC_NODE_ID ZW_SEND_SUC_ID ZW_EXPLORE_REQUEST_INCLUSION ZW_REQUEST_NODE_INFO ZW_REMOVE_FAILED_NODE_ID ZW_IS_FAILED_NODE ZW_REPLACE_FAILED_NODE UNKNOWN_66 UNKNOWN_67 GET_ROUTING_TABLE_LINE LOCK_ROUTE_RESPONSE ZW_GET_PRIORITY_ROUTE ZW_SET_PRIORITY_ROUTE UNKNOWN_98 ZW_SET_WUT_TIMEOUT ZW_WATCHDOG_ENABLE ZW_WATCHDOG_DISABLE ZW_WATCHDOG_CHECK ZW_SET_EXT_INT_LEVEL ZW_RF_POWERLEVEL_GET ZW_TYPE_LIBRARY ZW_SEND_TEST_FRAME ZW_GET_PROTOCOL_STATUS WATCHDOG_START WATCHDOG_STOP ZW_SET_ROUTING_MAX UNKNOWN_ee UNKNOWN_ef
# 2025-07-27 01:10:17 ctrlCaps MEMBER PRIMARY SUC
# 2025-07-27 01:10:17 homeId HomeId:dfbd3e8e CtrlNodeIdHex:01
# 2025-07-25 10:29:36 nodeList ZWaveDongle UNKNOWN_7 UNKNOWN_8 UNKNOWN_9 UNKNOWN_16 BadkDeur Multisensor BadkSensor BadkKast FibaroStrip BadkSpots BadkVentilator BadkVloer BadkIRPanelen UNKNOWN_27 UNKNOWN_28 UNKNOWN_29 BadkSpiegels BadkSpiegellampjes VoordeurMelderTech UNKNOWN_33
# 2025-07-27 01:10:17 random 6ac4e0d65eee4aad32328c910bc700acc37c6e69f70a355f47d5de66984a78b3
# 2025-07-27 01:10:17 state Initialized
# 2025-07-27 01:10:17 sucNodeId 1
# 2025-04-09 08:46:47 version Z-Wave 4.54
Das Problem werde ich untersuchen, aber dafuer brauche ich die problematischen Roh-Nachrichten.
Diese sieht man mit "attr ZWDongle verbose 4".
Heute Morgen habe ich diesen Abschnitt aus meinem Logfile kopiert. Reicht das aus?
2025.07.28 10:06:58 3: ZWave set BadkIRPanelen desired-temp 10
2025.07.28 10:06:58 4: ZWDongle_Read ZWaveDongle: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2025.07.28 10:06:58 4: ZWDongle_Read ZWaveDongle: rcvd 001321000005 (request ZW_SEND_DATA), sending ACK
2025.07.28 10:06:58 4: CMD:ZW_SEND_DATA ID:00 ARG:0005 CB:21
2025.07.28 10:06:58 4: ZWaveDongle transmit OK for CB 21, target BadkVloer
2025.07.28 10:06:58 4: ZWDongle_Read ZWaveDongle: rcvd 001322000003 (request ZW_SEND_DATA), sending ACK
2025.07.28 10:06:58 4: CMD:ZW_SEND_DATA ID:00 ARG:0003 CB:22
2025.07.28 10:06:58 4: ZWaveDongle transmit OK for CB 22, target BadkIRPanelen
2025.07.28 10:06:58 4: ZWDongle_Read ZWaveDongle: rcvd 000400190743030122006400 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:06:58 4: CMD:APPLICATION_COMMAND_HANDLER ID:19 ARG:0743030122006400 CB:00
2025.07.28 10:06:58 1: BadkIRPanelen: THERMOSTAT_SETPOINT_REPORT wrong number of bytes received
2025.07.28 10:06:58 4: ZWDongle_Read ZWaveDongle: rcvd 001323000006 (request ZW_SEND_DATA), sending ACK
2025.07.28 10:06:58 4: CMD:ZW_SEND_DATA ID:00 ARG:0006 CB:23
2025.07.28 10:06:58 4: ZWaveDongle transmit OK for CB 23, target BadkVloer
2025.07.28 10:06:58 4: ZWDongle_Read ZWaveDongle: rcvd 001324000002 (request ZW_SEND_DATA), sending ACK
2025.07.28 10:06:58 4: CMD:ZW_SEND_DATA ID:00 ARG:0002 CB:24
2025.07.28 10:06:58 4: ZWaveDongle transmit OK for CB 24, target BadkIRPanelen
2025.07.28 10:06:58 4: ZWDongle_Read ZWaveDongle: rcvd 0004001806430301220064 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:06:58 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:06430301220064 CB:00
2025.07.28 10:06:58 4: ZWDongle_Read ZWaveDongle: rcvd 000400180440030122 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:06:58 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:0440030122 CB:00
2025.07.28 10:06:58 4: ZWDongle_Read ZWaveDongle: rcvd 0004001803420300 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:06:58 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:03420300 CB:00
2025.07.28 10:06:58 4: ZWDongle_Read ZWaveDongle: rcvd 0004001303800364 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:06:58 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:03800364 CB:00
2025.07.28 10:06:59 4: ZWDongle_Read ZWaveDongle: rcvd 000400130831050124000000f8 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:06:59 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0831050124000000f8 CB:00
2025.07.28 10:06:59 4: ZWDongle_Read ZWaveDongle: rcvd 00040013053105050145 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:06:59 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:053105050145 CB:00
2025.07.28 10:07:00 4: ZWDongle_Read ZWaveDongle: rcvd 00040013083105030c00000003 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:07:00 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:083105030c00000003 CB:00
2025.07.28 10:07:01 4: ZWDongle_Read ZWaveDongle: rcvd 000400130531051b0100 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:07:01 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0531051b0100 CB:00
2025.07.28 10:07:02 4: ZWDongle_Read ZWaveDongle: rcvd 000400200a600d02003105030a05e3 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:07:02 4: CMD:APPLICATION_COMMAND_HANDLER ID:20 ARG:0a600d02003105030a05e3 CB:00
2025.07.28 10:07:03 4: ZWDongle_Read ZWaveDongle: rcvd 00040012032001ff (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:07:03 4: CMD:APPLICATION_COMMAND_HANDLER ID:12 ARG:032001ff CB:00
2025.07.28 10:07:03 4: ZWDongle_Read ZWaveDongle: rcvd 00040012097105000000ff070800 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:07:03 4: CMD:APPLICATION_COMMAND_HANDLER ID:12 ARG:097105000000ff070800 CB:00
2025.07.28 10:07:23 4: ZWDongle_Read ZWaveDongle: rcvd 00040018063105012200c0 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:07:23 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:063105012200c0 CB:00
2025.07.28 10:07:30 4: ZWDongle_Read ZWaveDongle: rcvd 0004001303800364 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:07:30 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:03800364 CB:00
2025.07.28 10:07:30 4: ZWDongle_Read ZWaveDongle: rcvd 000400130831050124000000f8 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:07:30 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0831050124000000f8 CB:00
2025.07.28 10:07:30 4: ZWDongle_Read ZWaveDongle: rcvd 00040013053105050145 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:07:30 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:053105050145 CB:00
2025.07.28 10:07:31 4: ZWDongle_Read ZWaveDongle: rcvd 00040013083105030c00000005 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:07:31 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:083105030c00000005 CB:00
2025.07.28 10:07:32 4: ZWDongle_Read ZWaveDongle: rcvd 000400130531051b0100 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:07:32 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0531051b0100 CB:00
2025.07.28 10:07:53 4: ZWDongle_Read ZWaveDongle: rcvd 000400180e3202212400000182000000000000 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:07:53 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:0e3202212400000182000000000000 CB:00
2025.07.28 10:07:53 4: ZWDongle_Read ZWaveDongle: rcvd 000400180e320221540000000d000000000000 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:07:53 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:0e320221540000000d000000000000 CB:00
2025.07.28 10:07:53 4: ZWDongle_Read ZWaveDongle: rcvd 000400180a3202a122093c00000000 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:07:53 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:0a3202a122093c00000000 CB:00
2025.07.28 10:08:01 4: ZWDongle_Read ZWaveDongle: rcvd 0004001303800364 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:08:01 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:03800364 CB:00
2025.07.28 10:08:01 4: ZWDongle_Read ZWaveDongle: rcvd 000400130831050124000000f8 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:08:01 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0831050124000000f8 CB:00
2025.07.28 10:08:01 4: ZWDongle_Read ZWaveDongle: rcvd 00040013053105050145 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:08:01 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:053105050145 CB:00
2025.07.28 10:08:02 4: ZWDongle_Read ZWaveDongle: rcvd 000400200a600d02003105030a0616 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:08:02 4: CMD:APPLICATION_COMMAND_HANDLER ID:20 ARG:0a600d02003105030a0616 CB:00
2025.07.28 10:08:02 4: ZWDongle_Read ZWaveDongle: rcvd 00040013083105030c00000005 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:08:02 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:083105030c00000005 CB:00
2025.07.28 10:08:03 4: ZWDongle_Read ZWaveDongle: rcvd 000400130531051b0100 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:08:03 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0531051b0100 CB:00
2025.07.28 10:08:23 4: ZWDongle_Read ZWaveDongle: rcvd 00040018063105012200c1 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:08:23 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:063105012200c1 CB:00
2025.07.28 10:08:32 4: ZWDongle_Read ZWaveDongle: rcvd 0004001303800364 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:08:32 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:03800364 CB:00
2025.07.28 10:08:33 4: ZWDongle_Read ZWaveDongle: rcvd 000400130831050124000000f8 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:08:33 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0831050124000000f8 CB:00
2025.07.28 10:08:33 4: ZWDongle_Read ZWaveDongle: rcvd 00040013053105050145 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:08:33 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:053105050145 CB:00
2025.07.28 10:08:34 4: ZWDongle_Read ZWaveDongle: rcvd 00040013083105030c00000005 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:08:34 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:083105030c00000005 CB:00
2025.07.28 10:08:34 4: ZWDongle_Read ZWaveDongle: rcvd 000400130531051b0100 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:08:34 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0531051b0100 CB:00
2025.07.28 10:09:02 4: ZWDongle_Read ZWaveDongle: rcvd 000400200a600d02003105030a0771 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:09:02 4: CMD:APPLICATION_COMMAND_HANDLER ID:20 ARG:0a600d02003105030a0771 CB:00
2025.07.28 10:09:04 4: ZWDongle_Read ZWaveDongle: rcvd 0004001303800364 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:09:04 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:03800364 CB:00
2025.07.28 10:09:04 4: ZWDongle_Read ZWaveDongle: rcvd 000400130831050124000000f8 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:09:04 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0831050124000000f8 CB:00
2025.07.28 10:09:04 4: ZWDongle_Read ZWaveDongle: rcvd 00040013053105050145 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:09:04 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:053105050145 CB:00
2025.07.28 10:09:05 4: ZWDongle_Read ZWaveDongle: rcvd 00040013083105030c00000006 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:09:05 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:083105030c00000006 CB:00
2025.07.28 10:09:06 4: ZWDongle_Read ZWaveDongle: rcvd 000400130531051b0100 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:09:06 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0531051b0100 CB:00
2025.07.28 10:09:23 4: ZWDongle_Read ZWaveDongle: rcvd 000400180e3202212400000182000000000000 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:09:23 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:0e3202212400000182000000000000 CB:00
2025.07.28 10:09:23 4: ZWDongle_Read ZWaveDongle: rcvd 000400180e3202215400000016000000000000 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:09:23 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:0e3202215400000016000000000000 CB:00
2025.07.28 10:09:23 4: ZWDongle_Read ZWaveDongle: rcvd 000400180a3202a122094e00000000 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:09:23 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:0a3202a122094e00000000 CB:00
2025.07.28 10:09:23 4: ZWDongle_Read ZWaveDongle: rcvd 00040018063105012200c2 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:09:23 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:063105012200c2 CB:00
2025.07.28 10:09:35 4: ZWDongle_Read ZWaveDongle: rcvd 0004001303800364 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:09:35 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:03800364 CB:00
2025.07.28 10:09:35 4: ZWDongle_Read ZWaveDongle: rcvd 000400130831050124000000f8 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:09:35 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0831050124000000f8 CB:00
2025.07.28 10:09:35 4: ZWDongle_Read ZWaveDongle: rcvd 00040013053105050145 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:09:35 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:053105050145 CB:00
2025.07.28 10:09:36 4: ZWDongle_Read ZWaveDongle: rcvd 00040013083105030c00000008 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:09:36 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:083105030c00000008 CB:00
2025.07.28 10:09:37 4: ZWDongle_Read ZWaveDongle: rcvd 000400130531051b0100 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:09:37 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0531051b0100 CB:00
2025.07.28 10:10:02 4: ZWDongle_Read ZWaveDongle: rcvd 000400200a600d02003105030a07d0 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:10:02 4: CMD:APPLICATION_COMMAND_HANDLER ID:20 ARG:0a600d02003105030a07d0 CB:00
2025.07.28 10:10:06 4: ZWDongle_Read ZWaveDongle: rcvd 0004001303800364 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:10:06 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:03800364 CB:00
2025.07.28 10:10:06 4: ZWDongle_Read ZWaveDongle: rcvd 000400130831050124000000f8 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:10:06 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0831050124000000f8 CB:00
2025.07.28 10:10:07 4: ZWDongle_Read ZWaveDongle: rcvd 00040013053105050145 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:10:07 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:053105050145 CB:00
2025.07.28 10:10:07 4: ZWDongle_Read ZWaveDongle: rcvd 00040013083105030c00000007 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:10:07 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:083105030c00000007 CB:00
2025.07.28 10:10:08 4: ZWDongle_Read ZWaveDongle: rcvd 000400130531051b0100 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:10:08 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0531051b0100 CB:00
2025.07.28 10:10:23 4: ZWDongle_Read ZWaveDongle: rcvd 00040018063105012200c2 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:10:23 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:063105012200c2 CB:00
2025.07.28 10:10:38 4: ZWDongle_Read ZWaveDongle: rcvd 0004001303800364 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:10:38 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:03800364 CB:00
2025.07.28 10:10:38 4: ZWDongle_Read ZWaveDongle: rcvd 000400130831050124000000f8 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:10:38 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0831050124000000f8 CB:00
2025.07.28 10:10:38 4: ZWDongle_Read ZWaveDongle: rcvd 00040013053105050145 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:10:38 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:053105050145 CB:00
2025.07.28 10:10:39 4: ZWDongle_Read ZWaveDongle: rcvd 00040013083105030c00000006 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:10:39 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:083105030c00000006 CB:00
2025.07.28 10:10:40 4: ZWDongle_Read ZWaveDongle: rcvd 000400130531051b0100 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:10:40 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0531051b0100 CB:00
2025.07.28 10:10:53 4: ZWDongle_Read ZWaveDongle: rcvd 000400180e3202212400000182000000000000 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:10:53 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:0e3202212400000182000000000000 CB:00
2025.07.28 10:10:53 4: ZWDongle_Read ZWaveDongle: rcvd 000400180e3202215400000007000000000000 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:10:53 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:0e3202215400000007000000000000 CB:00
2025.07.28 10:10:53 4: ZWDongle_Read ZWaveDongle: rcvd 000400180a3202a122094e00000000 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:10:53 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:0a3202a122094e00000000 CB:00
2025.07.28 10:11:09 4: ZWDongle_Read ZWaveDongle: rcvd 0004001303800364 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:11:09 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:03800364 CB:00
2025.07.28 10:11:09 4: ZWDongle_Read ZWaveDongle: rcvd 000400130831050124000000f8 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:11:09 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0831050124000000f8 CB:00
2025.07.28 10:11:09 4: ZWDongle_Read ZWaveDongle: rcvd 00040013053105050145 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:11:09 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:053105050145 CB:00
2025.07.28 10:11:10 4: ZWDongle_Read ZWaveDongle: rcvd 00040013083105030c00000007 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:11:10 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:083105030c00000007 CB:00
2025.07.28 10:11:11 4: ZWDongle_Read ZWaveDongle: rcvd 000400130531051b0100 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:11:11 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0531051b0100 CB:00
2025.07.28 10:11:23 4: ZWDongle_Read ZWaveDongle: rcvd 00040018063105012200c5 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:11:23 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:063105012200c5 CB:00
2025.07.28 10:11:40 4: ZWDongle_Read ZWaveDongle: rcvd 0004001303800364 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:11:40 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:03800364 CB:00
2025.07.28 10:11:40 4: ZWDongle_Read ZWaveDongle: rcvd 000400130831050124000000f8 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:11:40 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0831050124000000f8 CB:00
2025.07.28 10:11:40 4: ZWDongle_Read ZWaveDongle: rcvd 00040013053105050145 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:11:40 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:053105050145 CB:00
2025.07.28 10:11:41 4: ZWDongle_Read ZWaveDongle: rcvd 00040013083105030c00000007 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:11:41 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:083105030c00000007 CB:00
2025.07.28 10:11:42 4: ZWDongle_Read ZWaveDongle: rcvd 000400130531051b0100 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:11:42 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0531051b0100 CB:00
2025.07.28 10:12:11 4: ZWDongle_Read ZWaveDongle: rcvd 0004001303800364 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:12:11 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:03800364 CB:00
2025.07.28 10:12:12 4: ZWDongle_Read ZWaveDongle: rcvd 000400130831050124000000f8 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:12:12 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0831050124000000f8 CB:00
2025.07.28 10:12:12 4: ZWDongle_Read ZWaveDongle: rcvd 00040013053105050145 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:12:12 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:053105050145 CB:00
2025.07.28 10:12:13 4: ZWDongle_Read ZWaveDongle: rcvd 00040013083105030c00000007 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:12:13 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:083105030c00000007 CB:00
2025.07.28 10:12:13 4: ZWDongle_Read ZWaveDongle: rcvd 000400130531051b0100 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:12:13 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0531051b0100 CB:00
2025.07.28 10:12:22 4: ZWDongle_Read ZWaveDongle: rcvd 000400200a600d02003105030a0792 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:12:22 4: CMD:APPLICATION_COMMAND_HANDLER ID:20 ARG:0a600d02003105030a0792 CB:00
2025.07.28 10:12:23 4: ZWDongle_Read ZWaveDongle: rcvd 000400180e3202212400000182000000000000 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:12:23 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:0e3202212400000182000000000000 CB:00
2025.07.28 10:12:23 4: ZWDongle_Read ZWaveDongle: rcvd 000400180e3202215400000014000000000000 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:12:23 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:0e3202215400000014000000000000 CB:00
2025.07.28 10:12:23 4: ZWDongle_Read ZWaveDongle: rcvd 000400180a3202a122095200000000 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:12:23 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:0a3202a122095200000000 CB:00
2025.07.28 10:12:23 4: ZWDongle_Read ZWaveDongle: rcvd 00040018063105012200c6 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:12:23 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:063105012200c6 CB:00
2025.07.28 10:12:43 4: ZWDongle_Read ZWaveDongle: rcvd 0004001303800364 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:12:43 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:03800364 CB:00
2025.07.28 10:12:43 4: ZWDongle_Read ZWaveDongle: rcvd 000400130831050124000000f8 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:12:43 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0831050124000000f8 CB:00
2025.07.28 10:12:43 4: ZWDongle_Read ZWaveDongle: rcvd 00040013053105050145 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:12:43 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:053105050145 CB:00
2025.07.28 10:12:44 4: ZWDongle_Read ZWaveDongle: rcvd 00040013083105030c00000006 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:12:44 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:083105030c00000006 CB:00
2025.07.28 10:12:45 4: ZWDongle_Read ZWaveDongle: rcvd 000400130531051b0100 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:12:45 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0531051b0100 CB:00
2025.07.28 10:13:14 4: ZWDongle_Read ZWaveDongle: rcvd 0004001303800364 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:13:14 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:03800364 CB:00
2025.07.28 10:13:14 4: ZWDongle_Read ZWaveDongle: rcvd 000400130831050124000000f8 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:13:14 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0831050124000000f8 CB:00
2025.07.28 10:13:14 4: ZWDongle_Read ZWaveDongle: rcvd 00040013053105050145 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:13:14 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:053105050145 CB:00
2025.07.28 10:13:15 4: ZWDongle_Read ZWaveDongle: rcvd 00040013083105030c00000005 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:13:15 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:083105030c00000005 CB:00
2025.07.28 10:13:16 4: ZWDongle_Read ZWaveDongle: rcvd 000400130531051b0100 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:13:16 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0531051b0100 CB:00
2025.07.28 10:13:22 4: ZWDongle_Read ZWaveDongle: rcvd 000400200a600d02003105030a06ae (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:13:22 4: CMD:APPLICATION_COMMAND_HANDLER ID:20 ARG:0a600d02003105030a06ae CB:00
2025.07.28 10:13:23 4: ZWDongle_Read ZWaveDongle: rcvd 00040018063105012200c6 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:13:23 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:063105012200c6 CB:00
2025.07.28 10:13:34 4: ZWDongle_Read ZWaveDongle: rcvd 00040013028407 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:13:34 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:028407 CB:00
2025.07.28 10:13:36 4: ZWDongle_Read ZWaveDongle: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2025.07.28 10:13:36 4: ZWDongle_Read ZWaveDongle: rcvd 00132500000f (request ZW_SEND_DATA), sending ACK
2025.07.28 10:13:36 4: CMD:ZW_SEND_DATA ID:00 ARG:000f CB:25
2025.07.28 10:13:36 4: ZWaveDongle transmit OK for CB 25, target BadkSensor
2025.07.28 10:13:45 4: ZWDongle_Read ZWaveDongle: rcvd 0004001303800364 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:13:45 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:03800364 CB:00
2025.07.28 10:13:45 4: ZWDongle_Read ZWaveDongle: rcvd 000400130831050124000000f8 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:13:45 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0831050124000000f8 CB:00
2025.07.28 10:13:46 4: ZWDongle_Read ZWaveDongle: rcvd 00040013053105050145 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:13:46 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:053105050145 CB:00
2025.07.28 10:13:46 4: ZWDongle_Read ZWaveDongle: rcvd 00040013083105030c00000004 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:13:46 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:083105030c00000004 CB:00
2025.07.28 10:13:47 4: ZWDongle_Read ZWaveDongle: rcvd 000400130531051b0100 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:13:47 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0531051b0100 CB:00
2025.07.28 10:13:53 4: ZWDongle_Read ZWaveDongle: rcvd 000400180e3202212400000182000000000000 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:13:53 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:0e3202212400000182000000000000 CB:00
2025.07.28 10:13:53 4: ZWDongle_Read ZWaveDongle: rcvd 000400180e320221540000001a000000000000 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:13:53 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:0e320221540000001a000000000000 CB:00
2025.07.28 10:13:53 4: ZWDongle_Read ZWaveDongle: rcvd 000400180a3202a122094300000000 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:13:53 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:0a3202a122094300000000 CB:00
2025.07.28 10:14:17 4: ZWDongle_Read ZWaveDongle: rcvd 0004001303800364 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:14:17 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:03800364 CB:00
2025.07.28 10:14:17 4: ZWDongle_Read ZWaveDongle: rcvd 000400130831050124000000f8 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:14:17 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0831050124000000f8 CB:00
2025.07.28 10:14:17 4: ZWDongle_Read ZWaveDongle: rcvd 00040013053105050145 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:14:17 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:053105050145 CB:00
2025.07.28 10:14:18 4: ZWDongle_Read ZWaveDongle: rcvd 00040013083105030c00000003 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:14:18 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:083105030c00000003 CB:00
2025.07.28 10:14:19 4: ZWDongle_Read ZWaveDongle: rcvd 000400130531051b0100 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:14:19 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0531051b0100 CB:00
2025.07.28 10:14:22 4: ZWDongle_Read ZWaveDongle: rcvd 000400200a600d02003105030a05f8 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:14:22 4: CMD:APPLICATION_COMMAND_HANDLER ID:20 ARG:0a600d02003105030a05f8 CB:00
2025.07.28 10:14:23 4: ZWDongle_Read ZWaveDongle: rcvd 00040018063105012200c4 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:14:23 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:063105012200c4 CB:00
2025.07.28 10:14:48 4: ZWDongle_Read ZWaveDongle: rcvd 0004001303800364 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:14:48 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:03800364 CB:00
2025.07.28 10:14:48 4: ZWDongle_Read ZWaveDongle: rcvd 000400130831050124000000f8 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:14:48 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0831050124000000f8 CB:00
2025.07.28 10:14:48 4: ZWDongle_Read ZWaveDongle: rcvd 00040013053105050145 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:14:48 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:053105050145 CB:00
2025.07.28 10:14:49 4: ZWDongle_Read ZWaveDongle: rcvd 00040013083105030c00000003 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:14:49 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:083105030c00000003 CB:00
2025.07.28 10:14:50 4: ZWDongle_Read ZWaveDongle: rcvd 000400130531051b0100 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:14:50 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0531051b0100 CB:00
2025.07.28 10:15:19 4: ZWDongle_Read ZWaveDongle: rcvd 0004001303800364 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:15:19 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:03800364 CB:00
2025.07.28 10:15:19 4: ZWDongle_Read ZWaveDongle: rcvd 000400130831050124000000f8 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:15:19 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0831050124000000f8 CB:00
2025.07.28 10:15:19 4: ZWDongle_Read ZWaveDongle: rcvd 00040013053105050145 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:15:19 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:053105050145 CB:00
2025.07.28 10:15:20 3: ZWave got config for aeotec/zw100.xml from ./FHEM/lib/openzwave_deviceconfig.xml.gz, found 44 commands
2025.07.28 10:15:20 4: ZWDongle_Read ZWaveDongle: rcvd 00040013083105030c00000003 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:15:20 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:083105030c00000003 CB:00
2025.07.28 10:15:21 4: ZWDongle_Read ZWaveDongle: rcvd 000400130531051b0100 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:15:21 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0531051b0100 CB:00
2025.07.28 10:15:22 4: ZWDongle_Read ZWaveDongle: rcvd 000400200a600d02003105030a064c (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:15:22 4: CMD:APPLICATION_COMMAND_HANDLER ID:20 ARG:0a600d02003105030a064c CB:00
2025.07.28 10:15:23 4: ZWDongle_Read ZWaveDongle: rcvd 000400180e3202212400000182000000000000 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:15:23 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:0e3202212400000182000000000000 CB:00
2025.07.28 10:15:23 4: ZWDongle_Read ZWaveDongle: rcvd 000400180e3202215400000007000000000000 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:15:23 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:0e3202215400000007000000000000 CB:00
2025.07.28 10:15:23 4: ZWDongle_Read ZWaveDongle: rcvd 000400180a3202a122094400000000 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:15:23 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:0a3202a122094400000000 CB:00
2025.07.28 10:15:23 4: ZWDongle_Read ZWaveDongle: rcvd 00040018063105012200c0 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:15:23 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:063105012200c0 CB:00
2025.07.28 10:15:50 4: ZWDongle_Read ZWaveDongle: rcvd 0004001303800364 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:15:50 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:03800364 CB:00
2025.07.28 10:15:51 4: ZWDongle_Read ZWaveDongle: rcvd 000400130831050124000000f8 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:15:51 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0831050124000000f8 CB:00
2025.07.28 10:15:51 4: ZWDongle_Read ZWaveDongle: rcvd 00040013053105050145 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:15:51 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:053105050145 CB:00
2025.07.28 10:15:52 4: ZWDongle_Read ZWaveDongle: rcvd 00040013083105030c00000003 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:15:52 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:083105030c00000003 CB:00
2025.07.28 10:15:52 4: ZWDongle_Read ZWaveDongle: rcvd 000400130531051b0100 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:15:52 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0531051b0100 CB:00
2025.07.28 10:16:22 4: ZWDongle_Read ZWaveDongle: rcvd 0004001303800364 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:16:22 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:03800364 CB:00
2025.07.28 10:16:22 4: ZWDongle_Read ZWaveDongle: rcvd 000400130831050124000000f8 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:16:22 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0831050124000000f8 CB:00
2025.07.28 10:16:22 4: ZWDongle_Read ZWaveDongle: rcvd 00040013053105050145 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:16:22 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:053105050145 CB:00
2025.07.28 10:16:23 4: ZWDongle_Read ZWaveDongle: rcvd 00040018063105012200c0 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:16:23 4: CMD:APPLICATION_COMMAND_HANDLER ID:18 ARG:063105012200c0 CB:00
2025.07.28 10:16:23 4: ZWDongle_Read ZWaveDongle: rcvd 00040013083105030c00000003 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:16:23 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:083105030c00000003 CB:00
2025.07.28 10:16:24 4: ZWDongle_Read ZWaveDongle: rcvd 000400130531051b0100 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:16:24 4: CMD:APPLICATION_COMMAND_HANDLER ID:13 ARG:0531051b0100 CB:00
2025.07.28 10:16:28 4: ZWDongle_Read ZWaveDongle: rcvd 000400160a32022174000000000000 (request APPLICATION_COMMAND_HANDLER), sending ACK
2025.07.28 10:16:28 4: CMD:APPLICATION_COMMAND_HANDLER ID:16 ARG:0a32022174000000000000 CB:00
Laut SDS13781.pdf, Kapitel 4.114.5 (Thermostat Setpoint v3, Report Command) ist die Dekodierung im Modul richtig.
0743030122006400:
07: Laenge der ZWave Nachricht
43: Klasse Thermostat_Setpoint
03: Report Command
01: Type Heating
22: (001 00 010) Nachkommastellen:1, Skala:0 aka Celsius, Size:2
006400 => Das sind aber 3 Bytes, und nicht 2 wie laut Size es sein sollte, deswegen die Meldung.
Im verlinkten Thema war das Problem was Anderes: da hat jemand zwei Bytes an die Nachricht angehaengt, die Laenge war damit falsch.
Hier ist die Laenge (07) korrekt, nur passt das nicht zu Size.
Ich vermute ein Firmware Problem.
Da sowas nicht so einfach nachzuweisen und zu fixen ist, habe ich jetzt einen Patch eingebaut, damit die extra Laenge ignoriert wird.
