To reset my sensor, I currently unplug the USB for a few seconds.
I see in the Engineering Specifications on page 2 that it knows a Command Class 'Device Reset Locally'. In Attr classes, DEVICE_RESET_LOCALLY is included.
Would it be possible to send the sensor a reset command?
Regards,
Paul
ZitatWould it be possible to send the sensor a reset command?
As far as I see, this cannot be done.
I found no hint of this class in the "Application-Command-Class-Specification".
zwave.js seems to lack a command, it just parses the message (which FHEM also does).
According to the zave.me documentation (https://z-wave.me/manual/z-way/Command_Class_Reference.html#SECTION0016610000000000000000) :
ZitatReports to the controller that device was resetted locally (using local button operation).
[...]This means the device is certainly not in our network anymore
IMHO this would be too much of a reset for your purpose.
ZitatTo reset my sensor, I currently unplug the USB for a few seconds.
To what purpose?
FHEM has a meterReset command...
Because humidity, temperature and others stop updating. A reset gets him running again.
I don't know what meterReset does. The issue is in the Multisensor, not in Fhem.
I'm in parallel working with Aeotec support. If anything relevant comes up, I will share it.
ZitatI don't know what meterReset does.
Its a ZWave command.
https://fhem.de/commandref_modular.html#ZWave-set-meterReset
ZitatReset all accumulated meter values.
Note: see meterSupported command and its output to detect if resetting the value is supported by the device.
The command will reset ALL accumulated values, it is not possible to choose a single value.
Fine, but it isn't "meterRestart". My issue was that these readings (pl) were not updated. They aren't accumulations, just reporting current measurements.
Please forgive my ignorance.
I would test it anyway (if its supported), as it may affect the reporting.
