Revision 30388: 59_Weather: Improved the language initialization logic by replacing ...
59_Weather: Improved the language initialization logic by replacing the experimental given/when construct with a more standard if/elsif structure
Source: Revision 30388: 59_Weather: Improved the language initialization logic by replacing ... (http://svn.fhem.de/trac/changeset/30388/trunk)
