Ich möchte gerne einen HM-CC-SCD in der Home App anzeigen lassen.
Ich sehe das Gerät auch schon allerdings wird als Wert unknown angezeigt.
Normal gibt es folgende drei state: normal, added, addedStrong
Hier mein List:
DEF 12E95E
FUUID 68fc3307-f33f-2b59-2ab0-dc82da5738f04de5
IODev SCC1
LASTInputDev SCC1
MSGCNT 12
NAME CO2
NR 955
NTFY_ORDER 48-CO2
SCC1_MSGCNT 12
SCC1_RAWMSG A0C0DA04112E95E41150A010E00::-63:SCC1
SCC1_RSSI -63
SCC1_TIME 2025-10-25 07:20:08
STATE normal
TYPE CUL_HM
chanNo 01
disableNotifyFn 1
eventCount 2
lastMsg No:0D - t:41 s:12E95E d:41150A 010E00
protLastRcv 2025-10-25 07:19:59
protRcv 2 last_at:2025-10-25 07:19:59
rssi_at_SCC1 cnt:12 min:-65 max:-61.5 avg:-63.58 lst:-63
CL:
Authenticated 0
BUF
FD 89
FW_ID 1761368944.69193
LASTACCESS 1761369959.66493
NAME WEB_192.168.2.149_49775
NR 10000023
PEER 192.168.2.149
PORT 49775
SNAME WEB
SSL
STATE Connected
TEMPORARY 1
TYPE FHEMWEB
canAsyncOutput 1
encoding UTF-8
2025-10-25 07:25:59 state Connected
2025-10-25 04:16:43 D-firmware 1.0
2025-10-25 04:16:43 D-serialNr GEQ0207616
2025-10-25 07:00:08 IODev SCC1
2025-10-25 07:19:59 battery ok
2025-10-25 04:31:31 cfgState updating
2025-10-25 04:31:31 commState CMDs_pending
2025-10-25 07:19:59 state normal
2025-10-25 07:19:59 trigger_cnt 14
helper:
HM_CMDNR 13
lastMsgTm 1761369599.61672
mId 0056
peerFriend peerAct,peerVirt
peerOpt 4:smokeDetector
regLst 0,1,4p
rxType 12
supp_Pair_Rep 0
cmds:
TmplKey :no:1761368420.60959
TmplTs 1761368420.60959
cmdKey 1:1:0::CO2:0056:01:
cmdLst:
assignHmKey noArg
clear [({msgErrors}|msgEvents|rssi|attack|trigger|register|oldRegs|readings|all)]
deviceRename -newName-
fwUpdate -filename- [-bootTime-]
getConfig noArg
getDevInfo noArg
getRegRaw (List0|List1|List2|List3|List4|List5|List6|List7) [-peerChn-]
peerBulk -peer1,peer2,...- [({set}|unset)]
peerChan -btnNumber- -actChn- [({single})] [({set}|unset)] [({actor})]
peerSmart -peerOpt-
raw -data- [...]
regBulk -list-.-peerChn- -addr1:data1- [-addr2:data2-]...
regSet [(prep|{exec})] -regName- -value- [-peerChn-]
reset noArg
sign [(on|{off})]
tplDel -tplDel-
tplSet_0 -tplChan-
trgEventL -peer- -condition-
trgEventS -peer- -condition-
trgPressL [(-peer-|{all})]
trgPressS [(-peer-|{all})]
unpair noArg
lst:
condition Smoke Alarm,added,addedStrong,no alarm,normal,tone off
peer
peerOpt Aquarium_Sw,Arbeitszimmer_Fenster,BWlinks_Sw_01,BWlinks_Sw_02,BWlinks_Sw_03,BWlinks_Sw_04,BWrechts_Sw_01,BWrechts_Sw_02,BWrechts_Sw_03,BWrechts_Sw_04,Bad_Fenster_rechts,BitcoinMiner_Sw
tplChan
tplDel
tplPeer
rtrvLst:
cmdList [({short}|long)]
deviceInfo [({short}|long)]
list [({normal}|full)]
param -param-
reg -addr- -list- [-peerChn-]
regList noArg
regTable noArg
regVal -addr- -list- [-peerChn-]
saveConfig [-filename-]
tplInfo noArg
expert:
def 0
det 0
raw 1
tpl 0
io:
flgs 2
newChn +12E95E,02,00,00
nextSend 1761369608.71857
rxt 2
sendWu 1
vccu
p:
12E95E
00
00
00
prefIO:
mRssi:
mNo 0D
io:
SCC1:
-59
-59
peerIDsH:
prt:
bErr 0
sProc 0
q:
qReqConf 00
qReqStat
role:
chn 1
dev 1
rssi:
at_SCC1:
avg -63.5833333333333
cnt 12
lst -63
max -61.5
min -65
tmpl:
IODev SCC1
autoReadReg 4_reqStatus
expert rawReg
firmware 1.0
genericDeviceType AirQualitySensor
model HM-CC-SCD
room Alexa,CUL_HM,Homekit,Küche
serialNr GEQ0207616
subType smokeDetector
webCmd statusRequest
