set HM_7B746E_Weather peerChan 0 HM_77BC01_Weather single set
set HM_7B746E_Climate peerChan 0 HM_77BC01_Climate single seterhalte ich jeweils die Fehlermeldung 'peerChan requires parameter: -btnNumber- -actChn- [({single})] [({set}|unset)] [(actor|remote|{both})]'. Ich kann keinen Syntaxfehler erkennen.| Internals: DEF 7B746E FUUID 68ff76b6-f33f-bfeb-ad25-c7cf75a7b36a9238 HMLAN1_MSGCNT 56 HMLAN1_RAWMSG E7B746E,0000,C90100EB,FF,FFB1,3D84707B746E00000000C43E HMLAN1_RSSI -79 HMLAN1_TIME 2025-10-28 14:44:10 IODev HMLAN1 LASTInputDev HMLAN1 MSGCNT 56 NAME HM_7B746E NOTIFYDEV global NR 3555 STATE CMDs_done TYPE CUL_HM channel_01 HM_7B746E_Weather channel_02 HM_7B746E_Climate channel_03 HM_7B746E_WindowRec channel_06 HM_7B746E_remote channel_07 HM_7B746E_SwitchTr eventCount 18 lastMsg No:3D - t:70 s:7B746E d:000000 00C43E protCondBurst off protLastRcv 2025-10-28 14:44:10 protRcv 56 last_at:2025-10-28 14:44:10 protSnd 7 last_at:2025-10-28 14:04:46 protSndB 1 last_at:2025-10-28 14:04:43 protState CMDs_done rssi_at_HMLAN1 cnt:56 min:-99 max:-74 avg:-81.89 lst:-79 READINGS: 2025-10-28 14:04:43 Activity alive 2025-10-28 14:04:44 CommandAccepted yes 2025-10-28 14:04:43 D-firmware 1.4 2025-10-28 14:04:43 D-serialNr TEQ2539535 2025-10-28 14:03:19 IODev HMLAN1 2025-10-28 14:00:50 PairedTo 0x2BA11A 2025-10-28 14:00:50 R-burstRx on 2025-10-28 14:00:50 R-cyclicInfoMsg on 2025-10-28 14:00:50 R-cyclicInfoMsgDis 0 2025-10-28 14:00:50 R-pairCentral 0x2BA11A 2025-10-28 14:00:50 RegL_00. 00:00 01:01 02:01 09:01 0A:2B 0B:A1 0C:1A 0F:00 11:00 12:16 16:00 18:00 19:00 1A:00 2025-10-28 14:03:11 RegL_07. 2025-10-28 14:44:00 battery ok 2025-10-28 14:44:00 batteryLevel 3 2025-10-28 14:44:00 desired-temp 17.0 2025-10-28 14:44:00 measured-temp 19.6 2025-10-28 14:04:46 state CMDs_done helper: HM_CMDNR 61 cSnd 012BA11A7B746E0703,012BA11A7B746E07040000000001 mId 00AD peerFriend peerOpt -:thermostat regLst 0 rxType 6 supp_Pair_Rep 0 expert: def 1 det 0 raw 1 tpl 0 io: newChn +7B746E,00,00,00 nextSend 1761659050.42373 prefIO rxt 0 vccu p: 7B746E 00 00 00 mRssi: mNo 3D io: HMLAN1: -77 -77 prt: awake 0 bErr 0 brstWu 0 sProc 0 q: qReqConf qReqStat role: dev 1 prs 1 rssi: at_HMLAN1: avg -81.8928571428571 cnt 56 lst -79 max -74 min -99 shRegW: 07 02 tmpl: Attributes: IODev HMLAN1 actCycle 000:10 actStatus alive autoReadReg 4_reqStatus expert 2_raw firmware 1.4 model HM-TC-IT-WM-W-EU msgRepeat 1 room CUL_HM serialNr TEQ2539535 subType thermostat verbose 5 webCmd getConfig:clear msgEvents |
| Internals: DEF 77BC01 FUUID 68ff78dc-f33f-bfeb-fc2a-3b45e691a7bf0408 HMLAN1_MSGCNT 51 HMLAN1_RAWMSG E77BC01,0000,C90156BC,FF,FFC1,40861077BC010000000A84AB100000 HMLAN1_RSSI -63 HMLAN1_TIME 2025-10-28 14:44:32 IODev HMLAN1 LASTInputDev HMLAN1 MSGCNT 51 NAME HM_77BC01 NOTIFYDEV global NR 3570 STATE CMDs_done TYPE CUL_HM channel_01 HM_77BC01_Weather channel_02 HM_77BC01_Climate channel_03 HM_77BC01_WindowRec channel_04 HM_77BC01_Clima channel_05 HM_77BC01_ClimaTeam channel_06 HM_77BC01_remote eventCount 34 lastMsg No:40 - t:10 s:77BC01 d:000000 0A84AB100000 protLastRcv 2025-10-28 14:44:32 protRcv 49 last_at:2025-10-28 14:44:32 protSnd 30 last_at:2025-10-28 14:07:15 protState CMDs_done rssi_at_HMLAN1 cnt:51 min:-67 max:-62 avg:-63.7 lst:-63 READINGS: 2025-10-28 14:07:22 Activity alive 2025-10-28 14:07:07 CommandAccepted yes 2025-10-28 14:07:22 D-firmware 1.5 2025-10-28 14:07:22 D-serialNr SEQ2547770 2025-10-28 14:03:19 IODev HMLAN1 2025-10-28 14:07:07 PairedTo 0x2BA11A 2025-10-28 14:07:07 R-backOnTime 10 s 2025-10-28 14:07:07 R-burstRx on 2025-10-28 14:07:07 R-cyclicInfoMsg on 2025-10-28 14:07:07 R-cyclicInfoMsgDis 0 2025-10-28 14:07:07 R-pairCentral 0x2BA11A 2025-10-28 14:07:07 RegL_00. 00:00 01:01 02:01 09:01 0A:2B 0B:A1 0C:1A 0E:0A 0F:00 11:00 12:15 16:00 18:00 19:00 1A:00 2025-10-28 14:44:32 actuator 0 2025-10-28 14:44:32 battery ok 2025-10-28 14:44:32 batteryLevel 3.1 2025-10-28 14:44:32 desired-temp 16.5 2025-10-28 14:44:32 measured-temp 17.1 2025-10-28 14:44:32 motorErr ok 2025-10-28 14:07:16 state CMDs_done RegL_07.: VAL helper: HM_CMDNR 64 cSnd 012BA11A77BC010603,012BA11A77BC0106040000000001 mId 0095 peerFriend peerOpt -:thermostat regLst 0 rxType 140 supp_Pair_Rep 0 expert: def 1 det 0 raw 1 tpl 0 io: newChn +77BC01,00,00,00 nextSend 1761659072.39007 prefIO rxt 2 vccu p: 77BC01 00 00 00 mRssi: mNo 40 io: HMLAN1: -59 -59 prt: bErr 0 sProc 0 q: qReqConf qReqStat regCollect: role: dev 1 prs 1 rssi: at_HMLAN1: avg -63.7058823529412 cnt 51 lst -63 max -62 min -67 shRegW: 07 04 shadowReg: tmpl: Attributes: IODev HMLAN1 actCycle 000:10 actStatus alive autoReadReg 4_reqStatus expert 2_raw firmware 1.5 model HM-CC-RT-DN room CUL_HM serialNr SEQ2547770 subType thermostat webCmd getConfig:clear msgEvents:burstXmit |
| Latest Revision: 27190 File Rev Last Change fhem.pl 27110 2023-01-23 15:15:30Z rudolfkoenig 90_at.pm 25248 2021-11-21 10:29:01Z rudolfkoenig 98_autocreate.pm 23727 2021-02-12 20:31:37Z rudolfkoenig 09_CUL_FHTTK.pm 18391 2019-01-23 19:05:58Z Matscher 10_CUL_HM.pm 20633 2019-12-01 13:24:15Z martinp876 14_CUL_WS.pm 26674 2022-11-08 17:23:41Z rudolfkoenig 98_dewpoint.pm 18846 2019-03-10 11:45:58Z hotbso 98_DOIF.pm 27190 2023-02-07 19:11:02Z Damian 98_dummy.pm 25606 2022-02-01 10:43:57Z rudolfkoenig 55_DWD_OpenData.pm 23797 2021-02-21 19:49:57Z jensb 98_fheminfo.pm 25077 2021-10-16 10:15:07Z betateilchen 01_FHEMWEB.pm 27173 2023-02-03 13:32:47Z rudolfkoenig 11_FHT.pm 26173 2022-06-26 09:03:47Z rudolfkoenig 92_FileLog.pm 26959 2023-01-04 12:56:01Z rudolfkoenig 72_FRITZBOX.pm 27108 2023-01-23 06:57:53Z jowiemann 10_FS20.pm 14888 2017-08-13 12:07:12Z rudolfkoenig 98_help.pm 25013 2021-09-23 21:07:00Z betateilchen 98_HMinfo.pm 26935 2022-12-31 16:25:33Z martinp876 00_HMLAN.pm 25204 2021-11-09 05:41:42Z martinp876 95_holiday.pm 25187 2021-11-06 09:54:35Z rudolfkoenig 98_HourCounter.pm 11307 2016-04-25 08:02:06Z rudolfkoenig 99_myUtils.pm 4 2018-01-24 23:00:00Z manfredalpers 91_notify.pm 25888 2022-03-27 10:22:58Z rudolfkoenig 73_PRESENCE.pm 20782 2019-12-19 10:51:06Z markusbloch 70_Pushover.pm 20897 2020-01-06 12:16:20Z loredo 98_RandomTimer.pm 25373 2021-12-24 11:57:02Z Beta-User 33_readingsGroup.pm 23844 2021-02-27 19:43:24Z justme1968 98_structure.pm 27133 2023-01-27 18:26:46Z rudolfkoenig 99_SUNRISE_EL.pm 24249 2021-04-14 05:45:49Z rudolfkoenig 98_SVG.pm 26539 2022-10-15 10:44:44Z rudolfkoenig 42_SYSMON.pm 26358 2022-08-29 21:11:26Z hexenmeister 32_SYSSTAT.pm 24779 2021-07-20 09:21:08Z justme1968 98_telnet.pm 25754 2022-02-27 16:49:52Z rudolfkoenig 59_Twilight.pm 25067 2021-10-13 04:26:30Z Beta-User 98_update.pm 26986 2023-01-06 17:15:47Z rudolfkoenig 99_Utils.pm 24128 2021-04-02 16:29:11Z rudolfkoenig # $Id: 99_UtilsHourCounter.pm 2014-12-16 20:15:33 john $ 98_version.pm 26611 2022-10-28 16:32:29Z betateilchen 91_watchdog.pm 26108 2022-06-01 08:25:03Z rudolfkoenig 98_weblink.pm 26988 2023-01-07 09:18:42Z rudolfkoenig AttrTemplate.pm 27145 2023-01-29 11:48:19Z rudolfkoenig Blocking.pm 23268 2020-12-01 11:48:48Z rudolfkoenig Color.pm 20813 2019-12-22 18:42:10Z justme1968 DevIo.pm 26055 2022-05-17 20:12:20Z rudolfkoenig FritzBoxUtils.pm 23727 2021-02-12 20:31:37Z rudolfkoenig GPUtils.pm 19666 2019-06-20 11:17:29Z CoolTux HMConfig.pm 25160 2021-10-30 17:38:52Z martinp876 HttpUtils.pm 27022 2023-01-11 07:51:42Z rudolfkoenig Meta.pm 26889 2022-12-23 15:04:11Z CoolTux RTypes.pm 10476 2016-01-12 21:03:33Z borisneubert SetExtensions.pm 25286 2021-12-03 10:16:56Z rudolfkoenig TcpServerUtils.pm 25866 2022-03-21 09:01:16Z rudolfkoenig doif.js 24438 2021-05-14 18:08:18Z Ellert fhemweb.js 27117 2023-01-25 09:13:32Z rudolfkoenig fhemweb_readingsGroup.js 15189 2017-10-03 17:53:27Z justme1968 svg.js 23428 2020-12-27 22:07:20Z rudolfkoenig |
