FHEM - Hausautomations-Systeme => Sonstige Systeme => Thema gestartet von: Nobbynews am 14 Februar 2026, 05:23:25
Titel: [gelöst] SIGNALduino - warnings im Log-File
Beitrag von: Nobbynews am 14 Februar 2026, 05:23:25
Guten Morgen,
jedesmal, wenn ich in FHEMWEB die SIGNALduinos aufrufe, kommen etliche warnings ins Log-File:
2026.02.14 05:02:52 1: PERL WARNING: Use of uninitialized value $lfn in concatenation (.) or string at ./FHEM/00_SIGNALduino.pm line 3118.
2026.02.14 05:02:52 1: stacktrace:
2026.02.14 05:02:52 1:     main::__ANON__                      called by ./FHEM/00_SIGNALduino.pm (3118)
2026.02.14 05:02:52 1:     main::SIGNALduino_FW_Detail         called by ./FHEM/01_FHEMWEB.pm (1594)
2026.02.14 05:02:52 1:     main::FW_doDetail                   called by ./FHEM/01_FHEMWEB.pm (1210)
2026.02.14 05:02:52 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (614)
2026.02.14 05:02:52 1:     main::FW_Read                       called by fhem.pl (4007)
2026.02.14 05:02:52 1:     main::CallFn                        called by fhem.pl (789)
2026.02.14 05:02:52 1: PERL WARNING: Use of uninitialized value $lfn in concatenation (.) or string at ./FHEM/00_SIGNALduino.pm line 3126.
2026.02.14 05:02:52 1:     main::__ANON__                      called by ./FHEM/00_SIGNALduino.pm (3126)
Version vom Modul ist:
00_SIGNALduino.pm     0 2026-01-16 10:03:31Z sidey79
List eines SIGNALduinos:
define SIGNALFSK SIGNALduino 192.168.2.96:23
attr SIGNALFSK hardware ESP8266cc1101
attr SIGNALFSK icon it_wifi
attr SIGNALFSK longids 1
attr SIGNALFSK rfmode Fine_Offset_WH51_434
attr SIGNALFSK room 10_I/O-Geräte
attr SIGNALFSK verbose 2
attr SIGNALFSK whitelist_IDs 107
#   Clients    SD_WS
#   ClientsKeepOrder 1
#   DEF        192.168.2.96:23
#   DMSG       W107#510DE0650E7F0EF87DFFFFFF01B1
#   DevState   initialized
#   DeviceName 192.168.2.96:23
#   FD         272
#   FUUID      64c001f2-f33f-8873-9cbc-e283199b9fc94f16
#   FVERSION   00_SIGNALduino.pm:v4.0.0-s0/2026-01-16
#   LASTDMSG   W107#510DE0650E7F0EF87DFFFFFF01B1
#   LASTDMSGID 107
#   MSGCNT     53692
#   NAME       SIGNALFSK
#   NR         865
#   PARTIAL
#   RAWMSG     MN;D=510DE0650E7F0EF87DFFFFFF01B1;R=20;
#   RSSI       -64
#   STATE      opened
#   TIME       1771042924
#   TYPE       SIGNALduino
#   cc1101_available 1
#   eventCount 1475
#   sendworking 0
#   unknownmessages
#   version    V 3.5.1-RC1 SIGNALESP cc1101 (chip CC1101) - compiled at Jun 18 2023 10:45:20
#   versionProtocols 1.59
#   versionmodul 4.0.0
#   DoubleMsgIDs:
#   MatchList:
#     10:SD_WS07 ^P7#[A-Fa-f0-9]{6}[AFaf][A-Fa-f0-9]{2,3}
#     11:SD_WS09 ^P9#F[A-Fa-f0-9]+
#     12:SD_WS   ^W\d+x{0,1}#.*
#     13:RFXX10REC ^(20|29)[A-Fa-f0-9]+
#     14:Dooya   ^P16#[A-Fa-f0-9]+
#     15:SOMFY   ^Ys[0-9A-F]+
#     16:SD_WS_Maverick ^P47#[A-Fa-f0-9]+
#     17:SD_UT   ^P(?:14|20|24|26|29|30|34|46|56|68|69|76|78|81|83|86|90|91|91.1|92|93|95|97|99|104|105|114|118|121|127|128)#.*
#     18:FLAMINGO ^P13\.?1?#[A-Fa-f0-9]+
#     19:CUL_WS  ^K[A-Fa-f0-9]{5,}
#     1:IT       ^i......
#     20:Revolt  ^r[A-Fa-f0-9]{22}
#     21:FS10    ^P61#[A-F0-9]+
#     22:Siro    ^P72#[A-Fa-f0-9]+
#     23:FHT     ^81..(04|09|0d)..(0909a001|83098301|c409c401)..
#     24:FS20    ^81..(04|0c)..0101a001
#     25:CUL_EM  ^E0.................
#     26:Fernotron ^P82#.*
#     27:SD_BELL ^P(?:15|32|41|42|57|79|96|98|112)#.*
#     28:SD_Keeloq ^P(?:87|88)#.*
#     29:SD_GT   ^P49#[A-Fa-f0-9]+
#     2:CUL_TCM97001 ^s[A-Fa-f0-9]+
#     30:LaCrosse ^(\S+\s+9 |OK\sWS\s)
#     31:KOPP_FC ^kr\w{18,}
#     32:PCA301  ^\S+\s+24
#     33:SD_Rojaflex ^P109#[A-Fa-f0-9]+
#     3:SD_RSL   ^P1#[A-Fa-f0-9]{8}
#     4:OREGON   ^(3[8-9A-F]|[4-6][0-9A-F]|7[0-8]).*
#     5:CUL_TX   ^TX..........
#     6:SD_AS    ^P2#[A-Fa-f0-9]{7,8}
#     7:Hideki   ^P12#75[A-F0-9]+
#     9:CUL_FHTTK ^T[A-F0-9]{8}
#     X:SIGNALduino_un ^[u]\d+#.*
#   OLDREADINGS:
#   QUEUE:
#   READINGS:
#     2026-02-14 05:00:52   cc1101_config   Freq: 433.920 MHz, Bandwidth: 135 kHz, rAmpl: 33 dB, sens: 8 dB, DataRate: 17.26 kBaud
#     2026-02-14 05:00:52   cc1101_config_ext Modulation: 2-FSK, Syncmod: 16/16 sync word bits detected, Deviation: 34.91 kHz
#     2026-02-14 04:55:44   cc1101_patable  C3E = 00 84 00 00 00 00 00 00 => 5_dBm
#     2023-07-26 06:42:38   cmds            V R t X S P C r W s x e
#     2026-02-14 05:00:52   config          MS=1;MU=1;MC=1;Mred=1
#     2023-07-29 07:03:10   freeram         41320
#     2026-02-14 04:53:58   ping            OK
#     2026-02-14 04:55:42   state           opened
#     2026-02-14 04:38:44   uptime          0 00:04:22
#   additionalSets:
#   helper:
#   keepalive:
#     ok         1
#     retry      0
#   mcIdList:
#   mnIdList:
#     107
#   msIdList:
#   muIdList:
setstate SIGNALFSK opened
setstate SIGNALFSK 2026-02-14 05:00:52 cc1101_config Freq: 433.920 MHz, Bandwidth: 135 kHz, rAmpl: 33 dB, sens: 8 dB, DataRate: 17.26 kBaud
setstate SIGNALFSK 2026-02-14 05:00:52 cc1101_config_ext Modulation: 2-FSK, Syncmod: 16/16 sync word bits detected, Deviation: 34.91 kHz
setstate SIGNALFSK 2026-02-14 04:55:44 cc1101_patable C3E = 00 84 00 00 00 00 00 00 => 5_dBm
setstate SIGNALFSK 2023-07-26 06:42:38 cmds V R t X S P C r W s x e
setstate SIGNALFSK 2026-02-14 05:00:52 config MS=1;;MU=1;;MC=1;;Mred=1
setstate SIGNALFSK 2023-07-29 07:03:10 freeram 41320
setstate SIGNALFSK 2026-02-14 04:53:58 ping OK
setstate SIGNALFSK 2026-02-14 04:55:42 state opened
setstate SIGNALFSK 2026-02-14 04:38:44 uptime 0 00:04:22
Könnte sich das jemand mal bitte ansehen?
Titel: Aw: SIGNALduino - warnings im Log-File
Beitrag von: Sidey am 14 Februar 2026, 08:48:49
Schau ich mir an. Kannst Du mir noch ein update list geben?
Grüße Sidey
Beitrag von: Nobbynews am 14 Februar 2026, 08:57:49
Zitat von: Sidey am 14 Februar 2026, 08:48:49Schau ich mir an. Kannst Du mir noch ein
update list
http://fhem.de/fhemupdate/controls_fhem.txt
https://raw.githubusercontent.com/RFD-FHEM/RFFHEM/master/controls_signalduino.txt
Beitrag von: Sidey am 14 Februar 2026, 12:25:46
Hi Nobbynews,
Ich habe da eine Vermutung.
Ich habe etwas angepasst:
update all https://raw.githubusercontent.com/RFD-
FHEM/RFFHEM/refs/heads/fix/FileLogWarning/controls_signalduino.txt
Ich erwarte:
1. Die Warnungen erscheinen nicht mehr
2. Im Information Menü Abschnitt erscheint "No device of TYPE=FileLog found"
Grüße Sidey
Beitrag von: Nobbynews am 14 Februar 2026, 12:35:30
Hallo Sidey,
Uodate habe ich durchgeführt.
Es bleibt aber leider bei den warnings:
2026.02.14 12:33:08 1: PERL WARNING: Use of uninitialized value $lfn in concatenation (.) or string at ./FHEM/00_SIGNALduino.pm line 3118.
2026.02.14 12:33:08 1: stacktrace:
2026.02.14 12:33:08 1:     main::__ANON__                      called by ./FHEM/00_SIGNALduino.pm (3118)
2026.02.14 12:33:08 1:     main::SIGNALduino_FW_Detail         called by ./FHEM/01_FHEMWEB.pm (1597)
2026.02.14 12:33:08 1:     main::FW_doDetail                   called by ./FHEM/01_FHEMWEB.pm (1213)
2026.02.14 12:33:08 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (614)
2026.02.14 12:33:08 1:     main::FW_Read                       called by fhem.pl (4007)
2026.02.14 12:33:08 1:     main::CallFn                        called by fhem.pl (789)
2026.02.14 12:33:08 1: PERL WARNING: Use of uninitialized value $lfn in concatenation (.) or string at ./FHEM/00_SIGNALduino.pm line 3126.
2026.02.14 12:33:08 1:     main::__ANON__                      called by ./FHEM/00_SIGNALduino.pm (3126)
Norbert
Beitrag von: Sidey am 14 Februar 2026, 12:40:16
Seltsam. Du hast FHEM auch neu gestartet nach dem Update?
Wurden durch das Update Dateien getauscht? Im Log sollte sich dazu was finden.
Grüße Sidey
Beitrag von: Nobbynews am 14 Februar 2026, 13:37:37
Shutdown restart habe ich ausgeführt.
Hier mal der Auszug aus dem Log:
2026.02.14 12:30:51 1: backup tar: Removing leading `/' from member names tar: Removing leading `/' from hard link targets tar: /Festplatte/FHEM/log/MQTT_Netzfrequenz1-2026-02-14.log: file changed as we read it
2026.02.14 12:30:51 1: backup done: FHEM-20260214_123027.tar.gz (77642469 Bytes)
2026.02.14 12:30:51 1: fhem
2026.02.14 12:30:51 1: UPD FHEM/00_SIGNALduino.pm
2026.02.14 12:30:51 1: UPD FHEM/10_FS10.pm
2026.02.14 12:30:51 1: UPD FHEM/10_SD_GT.pm
2026.02.14 12:30:51 1: UPD FHEM/14_FLAMINGO.pm
2026.02.14 12:30:51 1: UPD FHEM/14_Hideki.pm
2026.02.14 12:30:51 1: UPD FHEM/14_SD_BELL.pm
2026.02.14 12:30:51 1: UPD FHEM/14_SD_UT.pm
2026.02.14 12:30:52 1: UPD FHEM/14_SD_WS.pm
2026.02.14 12:30:52 1: UPD FHEM/14_SD_WS07.pm
2026.02.14 12:30:52 1: UPD FHEM/14_SD_WS09.pm
2026.02.14 12:30:52 1: UPD FHEM/14_SD_WS_Maverick.pm
2026.02.14 12:30:52 1: UPD FHEM/41_OREGON.pm
2026.02.14 12:30:52 1: UPD FHEM/lib/SD_ProtocolData.pm
2026.02.14 12:30:52 1: UPD FHEM/lib/SD_Protocols.pm
2026.02.14 12:30:52 1: saving fhem.cfg
2026.02.14 12:30:52 1: Downloading https://raw.githubusercontent.com/RFD-FHEM/RFFHEM/master/controls_signalduino.txt
2026.02.14 12:30:52 1: signalduino
2026.02.14 12:30:52 1: UPD FHEM/00_SIGNALduino.pm
2026.02.14 12:30:52 1: UPD FHEM/10_FS10.pm
2026.02.14 12:30:52 1: UPD FHEM/10_SD_GT.pm
2026.02.14 12:30:52 1: UPD FHEM/14_FLAMINGO.pm
2026.02.14 12:30:53 1: UPD FHEM/14_Hideki.pm
2026.02.14 12:30:53 1: UPD FHEM/14_SD_BELL.pm
2026.02.14 12:30:53 1: UPD FHEM/14_SD_UT.pm
2026.02.14 12:30:53 1: UPD FHEM/14_SD_WS.pm
2026.02.14 12:30:53 1: UPD FHEM/14_SD_WS07.pm
2026.02.14 12:30:53 1: UPD FHEM/14_SD_WS09.pm
2026.02.14 12:30:54 1: UPD FHEM/14_SD_WS_Maverick.pm
2026.02.14 12:30:54 1: UPD FHEM/41_OREGON.pm
2026.02.14 12:30:54 1: UPD FHEM/lib/SD_ProtocolData.pm
2026.02.14 12:30:54 1: UPD FHEM/lib/SD_Protocols.pm
2026.02.14 12:30:54 1: saving fhem.cfg
2026.02.14 12:30:54 1: New entries in the CHANGED file:
2026.02.14 12:30:54 1: 2026-02-13 - Bugfix FS10 SetExtensions (#1350)
2026.02.14 12:30:54 1: Calling /usr/bin/perl ./contrib/commandref_modular.pl, this may take a while
2026.02.14 12:30:54 2: cm, set fakeWT HK_Henrike 18 18.1
2026.02.14 12:30:54 1: update finished, "shutdown restart" is needed to activate the changes.
2026.02.14 12:30:55 1:
2026.02.14 12:30:56 1: fheminfo Statistics data sent to server. See Logfile (level 4) for details.
2026.02.14 12:30:58 0: Server shutdown
2026.02.14 12:31:42 1: Including fhem.cfg
Beitrag von: Sidey am 14 Februar 2026, 18:08:17
Zitat von: Nobbynews am 14 Februar 2026, 13:37:37Shutdown restart habe ich ausgeführt.
Es wurde nicht die von mir bereitgestellte Steuerdatei geladen.
Hast Du den update all Befehl exakt wie oben angegeben verwendet?
Grüße Sidey
Beitrag von: Nobbynews am 14 Februar 2026, 18:45:12
Zitat von: Sidey am 14 Februar 2026, 18:08:17Es wurde nicht die von mir bereitgestellte Steuerdatei geladen.
Habe ich Doof natürlich nicht gemacht.
Nur ein einfaches Update.
Mit dem richtigen update aus #3 sind die warnings jetzt weg.
Danke.
Norbert
Beitrag von: Sidey am 14 Februar 2026, 19:17:32
Zitat von: Nobbynews am 14 Februar 2026, 18:45:12Nur ein einfaches Update.
Sehr gut. Steht jetzt im Infomenü auch folgender Text: "No device of TYPE=FileLog found" ?
Grüße Sidey
Beitrag von: Nobbynews am 14 Februar 2026, 19:19:58
Zitat von: Sidey am 14 Februar 2026, 19:17:32Sehr gut. Steht jetzt im Infomenü auch folgender Text: "No device of TYPE=FileLog found" ?
Ja.
Beitrag von: Nobbynews am 16 Februar 2026, 12:39:54
Hallo Sidey,
wird der Fix in den Master-Branch übernommen?
Norbert
Beitrag von: Sidey am 16 Februar 2026, 14:12:32
Ja, ich möchte aber vorher noch etwas anpassen.
Grüße Sidey
Beitrag von: Sidey am 17 Februar 2026, 17:28:38
Zitat von: Nobbynews am 16 Februar 2026, 12:39:54wird der Fix in den Master-Branch übernommen?
Ich habe die verschiedenen Situationen jetzt unterschiedlich behandelt (Kein Filelog, kein logfile):
Würdest Du bitte noch mal aktualisieren. Möchte sichergehen, dass auch dein Fall korrekt behandelt ist.
Grüße Sidey
Beitrag von: Nobbynews am 17 Februar 2026, 19:16:54
Hallo Sidey,
das update habe ich durchgeführt.
Konnte erst einmal nix ungewöhnliches feststellen.
Keine warnings etc. im Log-File.
Norbert
Titel: Aw: [gelöst] SIGNALduino - warnings im Log-File
Beitrag von: Nobbynews am 21 Februar 2026, 04:47:46
Master-Branch ist ja jetzt auch aktualisiert.
Vielen Dank.
Norbert
