Warum bekomme ich beim CALVIEW BW_Ferien_cw für heute "c-today 0" ?
get BW_Ferien events limit:when=today
30.03.2026 00:00 13d Osterferien
DEF BW_Ferien next
FUUID 6996d59e-f33f-4fdf-7fbc-6c07aadb2fdd0874
INTERVAL 43200
KALENDER BW_Ferien
NAME BW_Ferien_cw
NR 445
NTFY_ORDER 50-BW_Ferien_cw
STATE t: 5 td: 0 tm: 0
TYPE CALVIEW
eventCount 10
2026-03-31 11:03:27 c-term 5
2026-03-31 11:03:27 c-today 0
2026-03-31 11:03:27 c-tomorrow 0
2026-03-31 11:03:27 state t: 5 td: 0 tm: 0
2026-03-31 11:03:27 t_001_bdate 30.03.2026
2026-03-31 11:03:27 t_001_btime 00:00
2026-03-31 11:03:27 t_001_categories
2026-03-31 11:03:27 t_001_daysleft -1
2026-03-31 11:03:27 t_001_daysleftLong in -1 Tagen
2026-03-31 11:03:27 t_001_description Osterferien 2026 in Baden-Württemberg - Importiert von Ferienwiki
2026-03-31 11:03:27 t_001_duration 1123200
2026-03-31 11:03:27 t_001_edate 12.04.2026
2026-03-31 11:03:27 t_001_etime 00:00
2026-03-31 11:03:27 t_001_location
2026-03-31 11:03:27 t_001_mode next
2026-03-31 11:03:27 t_001_source BW_Ferien
2026-03-31 11:03:27 t_001_sourcecolor white
2026-03-31 11:03:27 t_001_summary Osterferien
2026-03-31 11:03:27 t_001_timeshort 00:00 - 00:00
2026-03-31 11:03:27 t_001_weekday 1
2026-03-31 11:03:27 t_001_weekdayname Montag
2026-03-31 11:03:27 t_002_bdate 26.05.2026
2026-03-31 11:03:27 t_002_btime 00:00
2026-03-31 11:03:27 t_002_categories
2026-03-31 11:03:27 t_002_daysleft 56
2026-03-31 11:03:27 t_002_daysleftLong in 56 Tagen
2026-03-31 11:03:27 t_002_description Pfingstferien 2026 in Baden-Württemberg - Importiert von Ferienwiki
2026-03-31 11:03:27 t_002_duration 950400
2026-03-31 11:03:27 t_002_edate 06.06.2026
2026-03-31 11:03:27 t_002_etime 00:00
2026-03-31 11:03:27 t_002_location
2026-03-31 11:03:27 t_002_mode next
2026-03-31 11:03:27 t_002_source BW_Ferien
2026-03-31 11:03:27 t_002_sourcecolor white
2026-03-31 11:03:27 t_002_summary Pfingstferien
2026-03-31 11:03:27 t_002_timeshort 00:00 - 00:00
2026-03-31 11:03:27 t_002_weekday 2
2026-03-31 11:03:27 t_002_weekdayname Dienstag
2026-03-31 11:03:27 t_003_bdate 30.07.2026
2026-03-31 11:03:27 t_003_btime 00:00
2026-03-31 11:03:27 t_003_categories
2026-03-31 11:03:27 t_003_daysleft 121
2026-03-31 11:03:27 t_003_daysleftLong in 121 Tagen
2026-03-31 11:03:27 t_003_description Sommerferien 2026 in Baden-Württemberg - Importiert von Ferienwiki
2026-03-31 11:03:27 t_003_duration 3888000
2026-03-31 11:03:27 t_003_edate 13.09.2026
2026-03-31 11:03:27 t_003_etime 00:00
2026-03-31 11:03:27 t_003_location
2026-03-31 11:03:27 t_003_mode next
2026-03-31 11:03:27 t_003_source BW_Ferien
2026-03-31 11:03:27 t_003_sourcecolor white
2026-03-31 11:03:27 t_003_summary Sommerferien
2026-03-31 11:03:27 t_003_timeshort 00:00 - 00:00
2026-03-31 11:03:27 t_003_weekday 4
2026-03-31 11:03:27 t_003_weekdayname Donnerstag
2026-03-31 11:03:27 t_004_bdate 26.10.2026
2026-03-31 11:03:27 t_004_btime 00:00
2026-03-31 11:03:27 t_004_categories
2026-03-31 11:03:27 t_004_daysleft 209
2026-03-31 11:03:27 t_004_daysleftLong in 209 Tagen
2026-03-31 11:03:27 t_004_description Herbstferien 2026 in Baden-Württemberg - Importiert von Ferienwiki
2026-03-31 11:03:27 t_004_duration 518400
2026-03-31 11:03:27 t_004_edate 01.11.2026
2026-03-31 11:03:27 t_004_etime 00:00
2026-03-31 11:03:27 t_004_location
2026-03-31 11:03:27 t_004_mode next
2026-03-31 11:03:27 t_004_source BW_Ferien
2026-03-31 11:03:27 t_004_sourcecolor white
2026-03-31 11:03:27 t_004_summary Herbstferien
2026-03-31 11:03:27 t_004_timeshort 00:00 - 00:00
2026-03-31 11:03:27 t_004_weekday 1
2026-03-31 11:03:27 t_004_weekdayname Montag
2026-03-31 11:03:27 t_005_bdate 23.12.2026
2026-03-31 11:03:27 t_005_btime 00:00
2026-03-31 11:03:27 t_005_categories
2026-03-31 11:03:27 t_005_daysleft 267
2026-03-31 11:03:27 t_005_daysleftLong in 267 Tagen
2026-03-31 11:03:27 t_005_description Weihnachtsferien 2026 in Baden-Württemberg - Importiert von Ferienwiki
2026-03-31 11:03:27 t_005_duration 1555200
2026-03-31 11:03:27 t_005_edate 10.01.2027
2026-03-31 11:03:27 t_005_etime 00:00
2026-03-31 11:03:27 t_005_location
2026-03-31 11:03:27 t_005_mode next
2026-03-31 11:03:27 t_005_source BW_Ferien
2026-03-31 11:03:27 t_005_sourcecolor white
2026-03-31 11:03:27 t_005_summary Weihnachtsferien
2026-03-31 11:03:27 t_005_timeshort 00:00 - 00:00
2026-03-31 11:03:27 t_005_weekday 3
2026-03-31 11:03:27 t_005_weekdayname Mittwoch
modes next
room Kalender
Die Readings sind in der Commandref nicht erklärt, aber steht das "c" nicht für "count", "c-today" also für die Anzahl der heutigen Termine? Und heute ist nichts.
Mir ist da eher die Rückgabe des get nicht ganz klar.
Wobei in der Commandref gibt es da einen leichten Unterschied zwischen "zeigt Termine für Tag x" and "zeigt anstehende Termin für heute".
Nachtrag:
Sorry, jetzt erst verstanden. Ferien haben gestern begonnen, sind also auch heute. Unabhängig von falschen Ergebnis: Ergibt limit:from=-1d etwas anderes (gestern ist der Beginn des Termins)?
Hilft nicht weiter, aber ich habe das mal bei mir nachgestellt und kann es bestätigen. Bisher nutze ich nur einen Abfallkalender, da gibt es keine Termine, die über mehrere Tage gehen. Wenn ich aber zum Test welche eintrage, dann ist c-today nur zu Beginn des Termins 1, nicht an den folgenden Tagen.
Ach so, und vergiss den Beitrag oben drüber ;-)
