ich betreibe eine Readingsgroup zum einfachen einstellen der Zeiten und Aktionen für verschiedene Rollo Devices.
Das ganze besteht aus 2x Velux Rollos und 3x Shelly. Bei den Shellys fügt die RG leerspalten ein, was sehr unübersichtlich ist.
Kann mir jemand auf die Sprünge helfen wo die Leerspalten herkommen? Anbei ein Bild zur Verdeutlichung und ein List der RG
DEF <Gerät>,<Position>,<Zeit_Auf_Früh>,<Zeit_Auf_Spät>,<Zeit_Auf_WE/Hol>,<Zeit_Zu_Früh>,<Zeit_Zu_Spät>,<Modus_Zu>,<Modus_Auf>
(MQTT2_shellyplus2pm_.*|Velux_.*|.*Rolladen|Jalousie_.*):pct,!?ASC_Time_Up_Early,!?ASC_Time_Up_Late,!?ASC_Time_Up_WE_Holiday,!?ASC_Time_Down_Early,!?ASC_Time_Down_Late,!?ASC_Mode_Down,!?ASC_Mode_Up
FUUID 697e9bbc-f33f-6b5c-0621-8d5456292659d9bf
NAME rg_ASC_Rolllaeden_Times
NR 498
NTFY_ORDER 50-rg_ASC_Rolllaeden_Times
STATE Initialized
TYPE readingsGroup
changed 0
mayBeVisible 1
CONTENT:
MQTT2_shellyplus2pm_2cbcbb2d7040 1
MQTT2_shellyplus2pm_2cbcbb7c2f4c 1
MQTT2_shellyplus2pm_30c9224ea21c 1
Velux_0 1
Velux_1 1
CONTENT2:
DEVICES:
ARRAY(0x5d116abc)
ARRAY(0x58c36568)
ARRAY(0x5d1e2af0)
ARRAY(0x5d308094)
ARRAY(0x5c82754c)
ARRAY(0x5d135380)
fhem:
lastDefChange 6
last_update 1775076577.36226
helper:
DEF
commands:
ASC_Mode_Down ASC_Mode_Down:always,absent,off
ASC_Mode_Up ASC_Mode_Up:always,absent,off
ASC_Time_Down_Early ASC_Time_Down_Early:15:00,15:15,15:30,15:45,16:00,16:15,16:30,16:45,17:00,17:15,17:30,17:45,18:00,18:15,18:30,18:45,19:00,19:15,19:30,19:45,20:00,20:15,20:30,20:45,21:00,21:15,21:30,21:45,22:00
ASC_Time_Down_Late ASC_Time_Down_Late:19:00,19:15,19:30,19:45,20:00,20:15,20:30,20:45,21:00,21:15,21:30,21:45,22:00,22:15,22:30,22:45,23:00,23:15,23:30
ASC_Time_Up_Early ASC_Time_Up_Early:05:00,05:05,05:30,05:55,06:00,06:15,06:30,06:45,07:00,07:15,07:30,07:45,08:00,08:15,08:30,08:45,09:00,09:15,09:30,09:45,10:00
ASC_Time_Up_Late ASC_Time_Up_Late:06:00,06:15,06:30,06:45,07:00,07:15,07:30,07:45,08:00,08:15,08:30,08:45,09:00,09:15,09:30,09:45,10:00
ASC_Time_Up_WE_Holiday ASC_Time_Up_WE_Holiday:06:00,06:15,06:30,06:45,07:00,07:15,07:30,07:45,08:00,08:15,08:30,08:45,09:00,09:15,09:30,09:45,10:00
pct pct:0,10,20,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100
positions:
MQTT2_shellyplus2pm_2cbcbb2d7040.ASC_Mode_Down 2:7
MQTT2_shellyplus2pm_2cbcbb2d7040.ASC_Mode_Up 2:8
MQTT2_shellyplus2pm_2cbcbb2d7040.ASC_Time_Down_Early 2:5
MQTT2_shellyplus2pm_2cbcbb2d7040.ASC_Time_Down_Late 2:6
MQTT2_shellyplus2pm_2cbcbb2d7040.ASC_Time_Up_Early 2:2
MQTT2_shellyplus2pm_2cbcbb2d7040.ASC_Time_Up_Late 2:3
MQTT2_shellyplus2pm_2cbcbb2d7040.ASC_Time_Up_WE_Holiday 2:4
MQTT2_shellyplus2pm_2cbcbb2d7040.pct 2:1
MQTT2_shellyplus2pm_2cbcbb7c2f4c.ASC_Mode_Down 3:7
MQTT2_shellyplus2pm_2cbcbb7c2f4c.ASC_Mode_Up 3:8
MQTT2_shellyplus2pm_2cbcbb7c2f4c.ASC_Time_Down_Early 3:5
MQTT2_shellyplus2pm_2cbcbb7c2f4c.ASC_Time_Down_Late 3:6
MQTT2_shellyplus2pm_2cbcbb7c2f4c.ASC_Time_Up_Early 3:2
MQTT2_shellyplus2pm_2cbcbb7c2f4c.ASC_Time_Up_Late 3:3
MQTT2_shellyplus2pm_2cbcbb7c2f4c.ASC_Time_Up_WE_Holiday 3:4
MQTT2_shellyplus2pm_2cbcbb7c2f4c.pct 3:1
MQTT2_shellyplus2pm_30c9224ea21c.ASC_Mode_Down 4:7
MQTT2_shellyplus2pm_30c9224ea21c.ASC_Mode_Up 4:8
MQTT2_shellyplus2pm_30c9224ea21c.ASC_Time_Down_Early 4:5
MQTT2_shellyplus2pm_30c9224ea21c.ASC_Time_Down_Late 4:6
MQTT2_shellyplus2pm_30c9224ea21c.ASC_Time_Up_Early 4:2
MQTT2_shellyplus2pm_30c9224ea21c.ASC_Time_Up_Late 4:3
MQTT2_shellyplus2pm_30c9224ea21c.ASC_Time_Up_WE_Holiday 4:4
MQTT2_shellyplus2pm_30c9224ea21c.pct 4:1
Velux_0.ASC_Mode_Down 5:7
Velux_0.ASC_Mode_Up 5:8
Velux_0.ASC_Time_Down_Early 5:5
Velux_0.ASC_Time_Down_Late 5:6
Velux_0.ASC_Time_Up_Early 5:2
Velux_0.ASC_Time_Up_Late 5:3
Velux_0.ASC_Time_Up_WE_Holiday 5:4
Velux_0.pct 5:1
Velux_1.ASC_Mode_Down 6:7
Velux_1.ASC_Mode_Up 6:8
Velux_1.ASC_Time_Down_Early 6:5
Velux_1.ASC_Time_Down_Late 6:6
Velux_1.ASC_Time_Up_Early 6:2
Velux_1.ASC_Time_Up_Late 6:3
Velux_1.ASC_Time_Up_WE_Holiday 6:4
Velux_1.pct 6:1
values:
formated:
undef
ARRAY(0x5d1bfd58)
ARRAY(0x5d0ec280)
ARRAY(0x5d1ce32c)
ARRAY(0x5c7f6940)
ARRAY(0x5d0ec5dc)
ARRAY(0x5d1ce2dc)
ARRAY(0x5c58c0a4)
ARRAY(0x5d1df444)
orig:
undef
ARRAY(0x5d1c8014)
ARRAY(0x5d1c52e8)
ARRAY(0x5c8242c0)
ARRAY(0x5d1df3e0)
ARRAY(0x5d1be534)
ARRAY(0x5d1df0ac)
ARRAY(0x5d1e6ce0)
ARRAY(0x5d0b1fc4)
prefixsuffix:
undef
ARRAY(0x5c8293c0)
ARRAY(0x5d1c0014)
ARRAY(0x5d0b5438)
ARRAY(0x5d3078c4)
ARRAY(0x5d0b1da8)
ARRAY(0x5cb11870)
ARRAY(0x5d0f0730)
ARRAY(0x5d1c9a0c)
commands {pct => 'pct:0,10,20,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100',
ASC_Time_Down_Early => 'ASC_Time_Down_Early:15:00,15:15,15:30,15:45,16:00,16:15,16:30,16:45,17:00,17:15,17:30,17:45,18:00,18:15,18:30,18:45,19:00,19:15,19:30,19:45,20:00,20:15,20:30,20:45,21:00,21:15,21:30,21:45,22:00',
ASC_Time_Down_Late => 'ASC_Time_Down_Late:19:00,19:15,19:30,19:45,20:00,20:15,20:30,20:45,21:00,21:15,21:30,21:45,22:00,22:15,22:30,22:45,23:00,23:15,23:30',
ASC_Time_Up_WE_Holiday => 'ASC_Time_Up_WE_Holiday:06:00,06:15,06:30,06:45,07:00,07:15,07:30,07:45,08:00,08:15,08:30,08:45,09:00,09:15,09:30,09:45,10:00',
ASC_Time_Up_Early => 'ASC_Time_Up_Early:05:00,05:05,05:30,05:55,06:00,06:15,06:30,06:45,07:00,07:15,07:30,07:45,08:00,08:15,08:30,08:45,09:00,09:15,09:30,09:45,10:00',
ASC_Time_Up_Late => 'ASC_Time_Up_Late:06:00,06:15,06:30,06:45,07:00,07:15,07:30,07:45,08:00,08:15,08:30,08:45,09:00,09:15,09:30,09:45,10:00',
ASC_Mode_Down => 'ASC_Mode_Down:always,absent,off',
ASC_Mode_Up => 'ASC_Mode_Up:always,absent,off' }
Vielen Dank
Matze
Hallo Matze,
hast du das Problem schon gelöst?
Falls nicht, warum verwendest du in der Definition immer "!?"
Das "!" verstehe ich aber das "?" verstehe ich nicht.
Laut Commandref:
Wenn Regex mit einem '?' beginnt, wird es mit den Attributen des Geräts verglichen und nicht mit den Werten (Readings) verglichen.
Wenn Regex mit einem '!' beginnt, wird die Anzeige des Wertes erzwungen, auch wenn kein Reading mit diesem Namen verfügbar ist.
Ich würde mal versuchen die "?" wegzulassen
(MQTT2_shellyplus2pm_.*|Velux_.*|.*Rolladen|Jalousie_.*):pct,!ASC_Time_Up_Early,!ASC_Time_Up_Late,!ASC_Time_Up_WE_Holiday,!ASC_Time_Down_Early,!ASC_Time_Down_Late,!ASC_Mode_Down,!ASC_Mode_Up
Gruß Robert
