FHEM => Anfängerfragen => Thema gestartet von: Hackstall am 18 Juli 2026, 23:42:41
Titel: HILFE: FHEM startet nicht mehr ndefined subroutine &MQTT::DEVICE::client_attr
Beitrag von: Hackstall am 18 Juli 2026, 23:42:41
Hi ich habe ein riesiges Problem:
nachdem ich meinen FHEM Container neu gestartet habe kommen folgende Fehler im LOG:
2026.07.18 23:39:50 1: PERL WARNING: Subroutine send_ping redefined at .//FHEM/00_MQTT.pm line 690, <$fh> line 45.
2026.07.18 23:39:50 1: PERL WARNING: Subroutine send_disconnect redefined at .//FHEM/00_MQTT.pm line 694, <$fh> line 45.
2026.07.18 23:39:50 1: PERL WARNING: Subroutine send_message redefined at .//FHEM/00_MQTT.pm line 701, <$fh> line 45.
2026.07.18 23:39:50 1: PERL WARNING: Subroutine topic_to_regexp redefined at .//FHEM/00_MQTT.pm line 716, <$fh> line 45.
2026.07.18 23:39:50 1: PERL WARNING: Subroutine client_subscribe_topic redefined at .//FHEM/00_MQTT.pm line 727, <$fh> line 45.
2026.07.18 23:39:50 1: PERL WARNING: Subroutine client_unsubscribe_topic redefined at .//FHEM/00_MQTT.pm line 746, <$fh> line 45.
2026.07.18 23:39:50 1: PERL WARNING: Subroutine Client_Define redefined at .//FHEM/00_MQTT.pm line 763, <$fh> line 45.
2026.07.18 23:39:50 1: PERL WARNING: Subroutine Client_Undefine redefined at .//FHEM/00_MQTT.pm line 779, <$fh> line 45.
2026.07.18 23:39:50 1: PERL WARNING: Subroutine client_attr redefined at .//FHEM/00_MQTT.pm line 784, <$fh> line 45.
2026.07.18 23:39:50 1: PERL WARNING: Subroutine notify_client_connected redefined at .//FHEM/00_MQTT.pm line 898, <$fh> line 45.
2026.07.18 23:39:50 1: PERL WARNING: Subroutine notify_client_disconnected redefined at .//FHEM/00_MQTT.pm line 903, <$fh> line 45.
2026.07.18 23:39:50 1: PERL WARNING: Subroutine notify_client_connection_timeout redefined at .//FHEM/00_MQTT.pm line 908, <$fh> line 45.
2026.07.18 23:39:50 1: PERL WARNING: Subroutine client_start redefined at .//FHEM/00_MQTT.pm line 913, <$fh> line 45.
2026.07.18 23:39:50 1: PERL WARNING: Subroutine client_stop redefined at .//FHEM/00_MQTT.pm line 945, <$fh> line 45.
Undefined subroutine &MQTT::DEVICE::client_attr called at .//FHEM/10_MQTT_DEVICE.pm line 233, <$fh> line 47.
Fhem startet nicht weiter.
Im Gegentel es rebootet:
ERROR: Fatal: No message from FHEM since 60 seconds that server has started.
INFO: Stopping container. Bye!
INFO: Preparing user environment
INFO: Creating group 'fhem' with GID 1000
INFO: Enforcing GID for group 'bluetooth' to 6001
INFO: Creating user 'fhem' with UID 1000
INFO: Creating log directory /opt/fhem/log
INFO: Creating PID directory /opt/fhem/log
INFO: Enforcing user and group ownership for /opt/fhem to fhem:fhem
INFO: Enforcing file and directory permissions for /opt/fhem
INFO: Correcting group ownership for /dev/tty*
INFO: Found GPIO: Correcting group permissions in /dev and /sys to 'gpio' with GID 6002
INFO: Found I2C: Correcting group permissions in /dev to 'i2c' with GID 6003
INFO: Updating /etc/sudoers.d/fhem-docker
INFO: Patching /etc/hosts file with DOCKER_HOST and DOCKER_GW'
INFO: Adding 172.18.0.1 host.docker.internal to /etc/hosts
INFO: Adding 172.18.0.1 gateway.docker.internal to /etc/hosts
INFO: Pre-authorizing SSH to Docker host for user 'fhem'
INFO: Updating SSH key pinning and SSH client permissions for user 'fhem'
INFO: Preparing user environment done
INFO: Starting FHEM
2026.07.18 23:41:00 1: PERL WARNING: given is deprecated at .//FHEM/99_myUtils.pm line 1283.
2026.07.18 23:41:00 1: PERL WARNING: when is deprecated at .//FHEM/99_myUtils.pm line 1285.
2026.07.18 23:41:00 1: PERL WARNING: when is deprecated at .//FHEM/99_myUtils.pm line 1293.
2026.07.18 23:41:00 1: PERL WARNING: when is deprecated at .//FHEM/99_myUtils.pm line 1300.
2026.07.18 23:41:00 1: PERL WARNING: when is deprecated at .//FHEM/99_myUtils.pm line 1307.
2026.07.18 23:41:00 1: Including fhem.cfg
2026.07.18 23:41:00 1: PERL WARNING: Constant subroutine MQTT::MQTT_CONNECT_REFUSED_UNACCEPTABLE_PROTOCOL_VERSION redefined at /usr/src/app/core/lib/perl5/Net/MQTT/Constants.pm line 44, <$fh> line 45.
2026.07.18 23:41:00 1: PERL WARNING: Constant subroutine MQTT::MQTT_PINGRESP redefined at /usr/src/app/core/lib/perl5/Net/MQTT/Constants.pm line 44, <$fh> line 45.
2026.07.18 23:41:00 1: PERL WARNING: Constant subroutine MQTT::MQTT_UNSUBACK redefined at /usr/src/app/core/lib/perl5/Net/MQTT/Constants.pm line 44, <$fh> line 45.
Zusätzlich kommt irgendwie:
Bitte bitte um Hilfe
Titel: Aw: HILFE: FHEM startet nicht mehr ndefined subroutine &MQTT::DEVICE::client_attr
Beitrag von: Hackstall am 19 Juli 2026, 01:05:17
OK die Empfehlung wird wohl sein auf MQTT2 umzustellen aber was ist denn der beste weg für die SubScribe und Publish Set.
Bisher sieht das bei mir so aus:
define GiEx_003 MQTT2_DEVICE zigbee2mqtt
setuuid GiEx_003 64efb41c-f33f-1829-0b37-a8bf5ae71a4215d1
attr GiEx_003 IODev mqttClient
attr GiEx_003 event-on-change-reading .*
attr GiEx_003 publishSet_INTERVAL zigbee2mqtt/0xa4c13850c1c8eacf/set/cycle_irrigation_interval
attr GiEx_003 publishSet_MODE duration,capacity zigbee2mqtt/0xa4c13850c1c8eacf/set/mode
attr GiEx_003 publishSet_NUMTIMES zigbee2mqtt/0xa4c13850c1c8eacf/set/cycle_irrigation_num_times
attr GiEx_003 publishSet_STATE ON,OFF zigbee2mqtt/0xa4c13850c1c8eacf/set
attr GiEx_003 publishSet_TARGET zigbee2mqtt/0xa4c13850c1c8eacf/set/irrigation_target
attr GiEx_003 room Haus.EG.Garten,Sys_MQTT
attr GiEx_003 subscribeReading_SENSOR zigbee2mqtt/0xa4c13850c1c8eacf-GiEx-03
attr GiEx_003 userReadings onState {ReadingsVal("GiEx_003","state","Idle")}
attr GiEx_003 webCmd STATE ON:STATE OFF
Der autocreate hat anscheinend alle attr Subscribe und publish entfernt
Wie würdet Ihr vorgehen
